- 有效期:2055/12/31 0:00:00
郑州高恩供应三菱A系列可编程控制器(PLC)
128KWROM 128K 内存用于 AD51H, AD57G 1,600.00
16KHROM 16K 步 EP-ROM 内存用于 AD57(S1/S2), AD58 2,030.00
16KQROM EP-ROM MEMORY+B213 2,030.00
16KRAM 16K STEP RAM 2,180.00
16KROM 16K STEP EP-ROM 2,030.00
256KWROM 256K 内存用于 AD51H, AD57G 2,010.00
4KEROM EP-ROM MEMORY 1,350.00
4KRAM 4K STEP MEMORY (A1N, A3NMCA-0) 1,080.00
4KROM 4K STEP EP-ROM (A1N, A3NMCA-0) 810.00
64KWROM 56K BYTE MEMORY FOR AD51H, AD57G 1,210.00
8KROM 8K STEP EP-ROM 1,350.00
A0J2HCPU 8K STEPS, 480 I/O, 1.25uS/STEP 5,100.00
A11VC VOICE OUTPUT MODULE 14,160.00
A1NCPU 6KSTEPS, 256 I/O 11,330.00
A1NCPUP21 A1NCPU WITH MELSECNET II OPTICAL DATA LINK 22,250.00
A1NCPUR21 A1NCPU WITH MELSECNET II COAXIAL DATA LINK 22,250.00
A1S32B BASE UNIT: CPU, 2 I/O & POWER SUPPLY SLOTS 1,000.00
A1S33B BASE UNIT: CPU, 3 I/O & POWER SUPPLY SLOTS 1,080.00
A1S35B BASE UNIT: CPU, 5 I/O & POWER SUPPLY SLOTS 1,100.00
A1S38B BASE UNIT: CPU, 8 I/O & POWER SUPPLY SLOTS 1,660.00
A1S38HB QnAS BASE UNIT, 8 I/O, HIGH SPEED ACCESS TIME 2,510.00
A1S42X 64 PT. DYNAMIC INPUT 3,050.00
A1S52B-S1 EXTENSION UNIT : 2 I/O SLOTS 950.00
A1S55B-S1 EXTENSION UNIT : 5 I/O SLOTS 1,060.00
A1S58B-S1 EXTENSION UNIT : 8 I/O SLOTS 1,560.00
A1S61PN INPUT : AC 100 - 240VAC OUTPUT : DC 5V 8A 1,560.00
A1S62DA D/A CONVERTER : 2 CH., 4-20mA,-10V-+10V 4,990.00
A1S62PN INPUT : AC 100 - 220VAC OUTPUT : DC 5V 5A, DC 24V 0.8A 1,790.00
A1S62RD3N TEMPERATURE SENSOR : PT-100, 3 WIRES 5,940.00
A1S62RD4N TEMPERATURE SENSOR : PT-100, 4 WIRES 5,940.00
A1S63ADA A/D, D/A CONVERTER : 2 INPUT/1 OUTPUT, 4-20mA,-10V-+10V 4,690.00
A1S63P INPUT : DC 24V OUTPUT : DC 5V 8A 2,710.00
A1S64AD A/D CONVERTER : 4 CH., 4-20mA,-10V-+10V 4,240.00
A1S64TCRTBW-S1 3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS 10,430.00
A1S64TCRT-S1 THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL 8,020.00
A1S64TCTTBW-S1 3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS 10,430.00
A1S64TCTT-S1 THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL 8,020.00
A1S65B-S1 EXTENSION UNIT : 5 I/O, POWER SUPPLY SLOTS 1,170.00
A1S66ADA A/D, D/A CONVERTER : 4 INPUT/2 OUTPUT, 4-20mA,-10V-+10V 8,160.00
A1S68AD A/D CONVERTER : 8 CH., 0-20mA,-10V-+10V 6,480.00
A1S68B-S1 EXTENSION UNIT : 8 I/O, POWER SUPPLY SLOTS 1,720.00
A1S68DAI D/A CONVERTER UNIT : 8 CH., 4-20mA 8,430.00
A1S68DAV D/A CONVERTER UNIT : 8 CH., -10V-+10V 8,430.00
A1S68TD THERMOCOUPLE INPUT : 8 CH., B, R, S, E, J, K TYPE 12,110.00
A1SC01B 55 mm EXTENSION CABLE 360.00
A1SC03B 300 mm EXTENSION CABLE 420.00
A1SC05NB 450 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT 660.00
A1SC07B 0.7M BUS CONNECTION (AnS/QnAS CPU) 590.00
A1SC07NB 700 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT 780.00
A1SC12B 1.2M BUS CONNECTION (AnS/QnAS CPU ) 850.00
A1SC30B 3M BUS CONNECTION (AnS/QnAS CPU) 1,350.00
A1SC30NB 3 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT 1,980.00
A1SC50B 5M BUS CONNECTION (AnS/QnAS CPU) 1,990.00
A1SC50NB 5 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT 2,650.00
A1SC60B 6 M EXTENSION CABLE 2,140.00
A1SCPUC24-R2 CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, RS232 PORT 7,730.00
A1SD51S RS232C 2 CH., RS422/484 1 CH. 9,190.00
A1SD61 HIGH SPEED COUNTER, 1 CH., 50KPPS 6,210.00
A1SD62 HIGH SPEED COUNTER, 2 CH., 100KPPS, SINK 6,380.00
A1SD62D HIGH SPEED COUNTER, 2 CH., 200KPPS, SINK 6,830.00
A1SD62E HIGH SPEED COUNTER, 2 CH., 100KPPS, SOURCE 6,380.00
A1SD70 1 AXES, VOLTAGE OUTPUT 7,820.00
A1SD71-S2 2 AXIS, PULSE TRAIN, OUTPUT, SPEED CONTROL FUNCTION 13,980.00
A1SD71-S6 2 AXIS, PULSE TRAIN OUTPUT 14,530.00
A1SD71-S7 2 AXIS, PULSE TRAIN OUTPUT, MANUAL PULSAR INPUT 13,980.00
A1SD75-C01H CONNECTION CABLE BETWEEN A1SD75 & AD75TU 880.00
A1SD75M1 SSC NET, 1ASIS 6,830.00
A1SD75M2 SSC NET, 2ASIS 10,430.00
A1SD75M3 SSC NET, 3ASIS 14,450.00
A1SD75P1-S3 1 AXES, PULSE TRAIN OUTPUT 7,270.00
A1SD75P2-S3 2 AXIS, PULSE TRAIN OUTPUT 11,000.00
A1SD75P3-S3 3 AXIS, PULSE TRAIN OUTPUT 15,420.00
A1SG60 BLANK COVER 160.00
A1SG62 DUMMY I/O MODULE, 16/32/64 SELECTABLE 1,140.00
A1SH42 DC 12/24V : 32 PT. SINK INPUT ; 32 PT. SINK TRANSISTOR OUTPUT 4,120.00
A1SHCPU CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256 4,010.00
A1SI61 16 PT. INTERRUPT MODULE 3,100.00
A1SJ51T64 MELSECNET I/O LINK MASTER, 64 REMOTE I/O CONTROL 1,940.00
A1SJ61BT11 CC-LINKmasterSTATION MODULE 2,790.00
A1SJ61QBT11 CC-LINKmasterMODULE 2,870.00
A1SJ71AP21 MELSECNET/II, MASTER/LOCAL, FIBER OPTIC SI-200/250 11,710.00
A1SJ71AR21 MELSECNET/II, MASTER/LOCAL, COAXIAL CABLE 11,710.00
A1SJ71AT21B MELSECNET/B, MASTER/LOCAL 7,770.00
A1SJ71BR11 MELSECNET/10, COAXIAL CABLE 13,910.00
A1SJ71E71N-B2 ETHERNET INTERFACE UNIT, 10BASE2 15,460.00
A1SJ71E71N-B5T ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5 15,460.00
A1SJ71LP21 MELSECNET/10, OPTICAL FIBER SI-200/250 13,910.00
A1SJ71LP21GE MELSECNET/10, OPTICAL FIBER GI-62.5/125 22,470.00
A1SJ71LR21 MELSECNET/10, 同轴电缆 13,910.00
A1SJ71PB92D PROFIBUS-DP INTERFACE MODULE 20,660.00
A1SJ71PB96F PROFIBUS-FMS INTERFACE MODULE 20,660.00
A1SJ71PT32-S3 MELSECNET/MINI-S3 MASTER, OPTICAL/TWISTED PAIR 5,100.00
A1SJ71QBR11 MELSECNET/10 , COAXIAL, COMPACT TYPE 14,740.00
A1SJ71QC24 RS232C &RS422 I/F, COMPACT TYPE 7,370.00
A1SJ71QC24N RS232C &RS422 I/F, COMPACT TYPE(NEW) 7,050.00
A1SJ71QC24-R2 RS232 I/F, 2 CH, COMPACT TYPE 7,370.00
A1SJ71QE71N-B2 ETHERNET INTERFACE UNIT, 10BASE2 16,050.00
A1SJ71QE71N-B5T ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5 16,050.00
A1SJ71QLP21 MELSECNET/10 , SI-200/250 FIBRE OPTIC, COMPACT TYPE 15,110.00
A1SJ71T32-S3 MELSECNET/MINI-S3 MASTER, TWISTED PAIR 4,620.00
A1SJ71UC24-PRF RS232C INTERFACE & PRINTER FUNCTION 6,160.00
A1SJ71UC24-R2 RS232C INTERFACE 4,800.00
A1SJ71UC24-R2-S2 MODUS, RS232C INTERFACE 5,720.00
A1SJ71UC24-R4 RS422/485 INTERFACE 4,800.00
A1SJ71UC24-R4-S2 MODUS, RS422/485 INTERFACE 3,960.00
A1SJ72QBR15 MELSECNET/10 REMOTE I/O MODULE, COAXIAL 14,740.00
A1SJ72QLP25 MELSECNET/10 REMOTE I/O MODULE, OPTICAL 14,740.00
A1SJ72T25B MELSECNET/B, REMOTE STATION 13,010.00
A1SJHCPU CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, 5 I/O SLOTS 3,940.00
A1SJHCPU-S8 CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, 8 I/O SLOTS 4,460.00
A1SNMCA-2KE MEMORY CASSETTE : 2K STEP EEPROM 1,020.00
A1SNMCA-8KE MEMORY CASSETTE : 8K STEP EEPROM 2,030.00
A1SNMCA-8KP MEMORY CASSETTE : 8K STEP EPROM 860.00
A1SP60 PULSE CATCH MODULE 2,330.00
A1ST60 8 ANALOG TIMERS 2,180.00
A1STA32 32 PTS, AWG 20 (0.5mm2), FOR A1SX41/42-S2/71, A1SY41/71 560.00
A1STA32-3 32 PTS, AWG 22 (0.3mm2), FOR A1SX41/42-S2/71, A1SY41/71 560.00
A1STA32-7 32 PTS, AWG 18 (0.7mm2), FOR A1SX41/42-S2/71, A1SY41/71 560.00
A1SX10 16 PT. AC 100V 1,560.00
A1SX10EU 16 PTS. AC 100V, EN/IEC STANDARD 1,750.00
A1SX20 16 PT. AC 200V 2,100.00
A1SX20EU 16 PTS. AC 200V, EN/IEC STANDARD 2,210.00
A1SX30 16 PT. AC 24VDC 24V 1,520.00
A1SX40 16 PT. DC 12/24V, SINK INPUT 1,480.00
A1SX40-S1 16 PT. DC 24V, SINK INPUT, FAST RESPONSE 1,560.00
A1SX40-S2 16 PT. DC 24V, SINK INPUT 1,480.00
A1SX41 32 PT. DC 12/24V, SINK INPUT 2,560.00
A1SX41-S1 32 PT. DC 24V, SINK INPUT, FAST RESPONSE 2,870.00
A1SX41-S2 32 PT. DC 24V, SINK INPUT 2,560.00
A1SX42 64 PT. DC 12/24V, SINK INPUT 4,120.00
A1SX42-S1 64 PT. DC 24V, SINK INPUT, FAST RESPONSE 4,620.00
A1SX42-S2 64 PT. DC 24V, SINK INPUT 4,120.00
A1SX48Y18 8 PT. DC 12/24V SINK INPUT ; 8 PT. RELAY OUTPUT 1,960.00
A1SX48Y58 8 PT. DC 12/24V SINK INPUT ; 8 PT. SINK TRANSISTOR OUTPUT 1,320.00
A1SX71 32 PT. DC 5/12V, SINK/SOURCE INPUT 2,790.00
A1SX80 16 PT. DC 12/24V, SINK/SOURCE INPUT 1,880.00
A1SX80-S1 16 PT. DC 24V, SINK/SOURCE IN (HIGH SPEED) 1,880.00
A1SX80-S2 16 PT. DC 24V, SINK/SOURCE INPUT 1,880.00
A1SX81 32 PT. DC 12/24V, SINK/SOURCE INPUT 3,190.00
A1SX81-S2 32 PT. DC 24V, SINK/SOURCE INPUT 3,190.00
A1SY10 16 PT. AC 240V/DC 24V, 2A, RELAY 2,030.00
A1SY10EU 16 PT. AC 240V/DC 24V 2A, RELAY, EN/IEC STANDARD 2,210.00
A1SY14EU 12 PT. AC 240V/DC 24V 2A, RELAY, EN/IEC STANDARD 2,210.00
A1SY18A 8 PT. AC 240V/DC 24V 2A, RELAY, INDEPENDENT COMMON 1,880.00
A1SY18AEU 8 PT. AC 240VDC 24V 2A, RELAY, EN/IEC STANDARD 1,980.00
A1SY22 16 PT. AC 240V 0.6A, TRIAC/SSR 2,490.00
A1SY28A 8 PT. AC 24V 1A, TRIAC/SSR, INDEPENDENT COMMON 2,180.00
A1SY28EU 8 PT. AC 240V 1A, TRIAC/SSR, EN/IEC STANDARD 2,420.00
A1SY40 16 PT. DC 12/24V 0.1A, TRANSISTOR SINK 1,480.00
A1SY41 32 PT. DC 12/24V 0.1A, TRANSISTOR SINK 2,560.00
A1SY42 64 PT. DC 12/24V 0.1A, TRANSISTOR SINK 4,120.00
A1SY50 16 PT. DC 12/24V 0.5A, TRANSISTOR SINK 1,560.00
A1SY60 16 PT. DC 24V 2A, TRANSISTOR SINK 3,100.00
A1SY68A 8 PT. DC 5/12/24/48V 2A, TRANSISTOR SINK/SOURCE 2,180.00
A1SY71 32 PT. DC 5/12V 16mA, TRANSISTOR SINK 2,560.00
A1SY80 16 PT. DC 12/24V 16mA, TRANSISTOR SOURCE 2,030.00
A1SY81 32 PT. DC 12/24V 0.1A, TRANSISTOR SOURCE 3,510.00
A2ACPU 14KSTEPS, 512 I/O, HIGH FUNCTION 13,450.00
A2ACPUP21 A2ACPU WITH MELSECNET II OPTICAL DATA LINK 20,640.00
A2ACPUP21-S1 A2ACPU-S1 WITH MELSECNET II OPTICAL DATA LINK 20,640.00
A2ACPUR21 A2ACPU WITH MELSECNET II COAXIAL DATA LINK 20,640.00
A2ACPUR21-S1 A2ACPU-S1 WITH MELSECNET II COAXIAL DATA LINK 20,640.00
A2ACPU-S1 14KSTEPS, 1024 I/O, HIGH FUNCTION 13,450.00
A2ASCPU CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 512, 0.2us/STEP 7,820.00
A2ASCPU-S1 CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 1024, 0.2us/STEP 9,390.00
A2ASCPU-S60 CPU, BUILT IN 30KSTEPS RAM, MAX. I/O 1024, 0.15us/STEP 20,140.00
A2NCPU 14KSTEPS, 512 I/O 12,140.00
A2NCPUP21 A2NCPU WITH MELSECNET II OPTICAL DATA LINK 21,850.00
A2NCPUP21-S1 A2NCPU-S1 WITH MELSECNET II OPTICAL DATA LINK 21,850.00
A2NCPUR21 A2NCPU WITH MELSECNET II COAXIAL DATA LINK 21,850.00
A2NCPUR21-S1 A2NCPU-S1 WITH MELSECNET II COAXIAL DATA LINK 21,850.00
A2NCPU-S1 14KSTEPS, 1024 I/O 13,760.00
A2SHCPU CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 512 5,840.00
A2SHCPU-S1 CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 1024 6,420.00
A2SMCA-14KP MEMORY CASSETTE : 14K STEP EPROM 1,170.00
A2SMCA-30KP MEMORY CASSETTE : 30K STEP EPROM 1,540.00
A2SMCA-60KE MEMORY CASSETTE : 60K STEP EEPROM 3,080.00
A2SNMCA-30KE MEMORY CASSETTE : 30K STEP EERPOM 2,180.00
A2SWA-28P READ/WRITE ADAPTER FOR A2SMCA-14KP 620.00
A2USHCPU-S1 CPU, BUILT IN 30KSTEPS RAM, MAX. I/O 1024, 0.09us/STEP 9,390.00
A32B BASE UNIT WITH : CPU, 2 I/O & POWER SUPPLY SLOTS 1,660.00
A32RB Q4AR DUAL SYS. BASE, 2 I/O SLOTS 5,600.00
A33RB Q4AR DUAL SYS. BASE, 3 I/O SLOTS 6,390.00
A35B BASE UNIT WITH : CPU, 5 I/O & POWER SUPPLY SLOTS 2,230.00
A37RHB Q4AR/QnA BASE, 7 I/O, , 2 POWER, 1 CPU SLOTS 4,470.00
A38B BASE UNIT WITH : CPU, 8 I/O & POWER SUPPLY SLOTS 3,730.00
A38HB QnA BASE UNIT, 8 I/O, HIGH SPEED ACCESS TIME 3,480.00
A3ACPU (30K+30K)STEPS, 2048 I/O, HIGH FUNCTION (0.15 uS/STEP) 31,660.00
A3ACPUP21 A3ACPU WITH MELSECNET II OPTICAL DATA LINK 38,850.00
A3ACPUR21 A3ACPU WITH MELSECNET II COAXIAL DATA LINK 38,850.00
A3NCPU (30K+30K)STEPS, 2048 I/O 32,370.00
A3NCPUP21 A3NCPU WITH MELSECNET II OPTICAL DATA LINK 40,470.00
A3NCPUR21 A3NCPU WITH MELSECNET II COAXIAL DATA LINK 40,470.00
A3NMCA-0 MEMORY CASSETTE : NO MEMORY, USE 4K RAM IC 3,080.00
A3NMCA-16 MEMORY CASSETTE : 128K BYTE MEMORY RAM 9,710.00
A3NMCA-2 MEMORY CASSETTE : 16K BYTE MEMORY RAM 3,230.00
A3NMCA-24 MEMORY CASSETTE : 192K BYTE MEMORY RAM 12,140.00
A3NMCA-4 MEMORY CASSETTE : 32K BYTE MEMORY RAM 4,040.00
A3NMCA-40 MEMORY CASSETTE : 320K BYTE MEMORY RAM 16,180.00
A3NMCA-56 MEMORY CASSETTE : 448K BYTE MEMORY RAM 20,230.00
A3NMCA-8 MEMORY CASSETTE : 64K BYTE MEMOR RAM 7,290.00
A42XY 64 PT. INPUT, 64 PT. SINK OUTPUT, DC 12/24V, 55/180mA 6,880.00
A52B EXTENSION UNIT WITH : 2 I/O SLOTS 1,870.00
A55B EXTENSION UNIT WITH : 5 I/O SLOTS 2,750.00
A58B EXTENSION UNIT WITH : 8 I/O SLOTS 2,780.00
A60MX MULTIPLEXER UNIT : 16 CHANNELS, NON-ISOLATED 13,760.00
A60MXR MULTIPLEXER UNIT : 16 CHANNELS, ISOLATED MERCURY RELAY 16,180.00
A60MXT THERMOCOUPLER MULTIPLEXER UNIT : 16 CHNNELS 22,660.00
A616AD A/D CONVERTER : 16 CH., 4-20mA,-10V-+10V 20,230.00
A616DAI D/A CONVERTER UNIT : 16 CHANNELS, CURRENT OUTPUT 28,780.00
A616DAV D/A CONVERTER UNIT : 16 CHANNELS, VOLTAGE OUTPUT 28,780.00
A616TD THERMOCOUPLER CONVERTER UNIT : 16 CHANNELS 20,230.00
A61P INPUT : AC 110/240V OUTPUT : DC 5V 8A 3,080.00
A61RP AC100-120/200-240V INPUT, DC 5V 8A OUTPUT 6,940.00
A62B EXTENSION UNIT WITH : 2 I/O, POWER SUPPLY SLOTS 2,030.00
A62DA CONVERTER UNIT : 2 CH., 4-20mA-10V-+10V 10,070.00
A62DA-S1 D/A CONVERTER UNIT : 2 CH., 4-20mA, 0-20mA-10V-+10V 10,070.00
A62P INPUT : AC 110/240V OUTPUT : DC 5V 5A, DC 24V 0.8A 4,450.00
A63P INPUT : DC 24V OUTPUT : DC 5V 8A 7,690.00
A65B EXTENSION UNIT WITH : 5 I/O, POWER SUPPLY SLOTS 3,080.00
A65P INPUT : AC 110/240V OUTPUT : DC 5V 2A, DC 24V 1.5A 5,260.00
A66P INPUT : AC 110/240V OUTPUT : DC 24V 1.2A 4,040.00
A68AD CONVERTER : 8 CH., 4-20mA,-10V-+10V 11,330.00
A68ADN A/D CONVERTER : 8 CH., 0-20mA-10V-+10V (HIGH RESOLUTION) 11,330.00
A68B EXTENSION UNIT WITH : 8 I/O, POWER SUPPLY SLOTS 4,450.00
A68DAI-S1 D/A CONVERTER UNIT : 8 CHANNELS 17,990.00
A68DAV D/A CONVERTER UNIT : 8 CHANNELS, VOLTAGE OUTPUT 17,990.00
A68P INPUT : AC 110/240V OUTPUT : DC 1.5V 4,860.00
A68RB Q4AR/QnA EBASE, 7 I/O, , 2 POWER, 2 CPU SLOTS 5,210.00
A68RD3N THERMOCOUPLE INPUT UNIT : PT100, 3 WIRES 11,330.00
A68RD4N THERMOCOUPLE INPUT UNIT : PT100, 4 WIRES 11,330.00
A6BAT BATTERY FOR MEMORY BACKUP 340.00
A6BR10 MELSECNET/10 COAXIAL CABLE REPEATER 14,400.00
A6BR10-DC MELSECNET/10 COAXIAL CABLE REPEATER, DC24V P/S 14,400.00
A6BSW-P-S3 BYPASS SWITCH 29,030.00
A6BSW-P-S4 BYPASS SWITCH 29,030.00
A6BSW-P-S5 BYPASS SWITCH 29,030.00
A6CAP-DC1 DUST PROOF CAP 200.00
A6CON1 SOLDERING 32-pt CONNECTOR 180.00
A6CON1E SOLDERING 32-pt CONNECTOR 180.00
A6CON2 CRIMP-CONTACT CONNECTION 32-pt CONNECTOR 200.00
A6CON2E CRIMP-CONTACT CONNECTION 32-pt CONNECTOR 210.00
A6CON3 FLAT CABLE PRESSURE-DISPLACEMENT 32-pt CONNECTOR 140.00
A6CON3E FLAT CABLE PRESSURE-DISPLACEMENT 32-pt CONNECTOR 140.00
A6CON-LJ5P ONLINE CONNECTOR FOR COMMUNICATION 750.00
A6CON-P214 TRANSPARENT PLUGS FOR ONE TOUCH CONNECTOR, 380.00
A6CON-P220 YELLOW PLUGS FOR ONE TOUCH CONNECTOR, 380.00
A6CON-P514 RED PLUGS FOR ONE TOUCH CONNECTOR, 380.00
A6CON-P520 BLUE PLUGS FOR ONE TOUCH CONNECTOR, 380.00
A6CON-PWJ5P ONLINE CONNECTOR FOR POWER SUPPLY 750.00
A6CPA-WP1 WATER PROOF CAP,(IP67) 650.00
A6CVR-16 16 PTS. MODULE PROTECT COVER, (10 PCS) 500.00
A6CVR-32 32 PTS. MODULE PROTECT COVER, (10 PCS) 440.00
A6CVR-8 8 PTS. MODULE PROTECT COVER, (10 PCS) 420.00
A6FD ASCII CHARACTER DISPLAY UNIT 7,940.00
A6RAF BUS SWITCH MODULE 4,680.00
A6SW16 SIMULATION SWTICH : 16 INPUT POINT 770.00
A6SW32 SIMULATION SWITCH : 32 INPUT POINT 1,160.00
A6TBX36-E 36 PTS, SOURCE INPUT, APPLICABLE TO A1SX81 580.00
A6TBX54-E 54 PTS, SOURCE INPUT, APPLICABLE TO A1SX81 750.00
A6TBX70 70 PTS, SINK INPUT, APPLICABLE TO A1SX41/42 890.00
A6TBX70-E 70 PTS, SOURCE INPUT, APPLICABLE TO A1SX81 890.00
A6TBXY36 36 PTS, SINK, APPLICABLE TO A1SX41/42 & A1SY41/42 580.00
A6TBXY54 54 PTS, SINK, APPLICABLE TO A1SX41/42 & A1SY41/42 750.00
A6TBY36-E 36 PTS, SOURCE OUTPUT, APPLICABLE TO A1SY81 580.00
A6TBY54-E 54 PTS, SOURCE OUTPUT, APPLICABLE TO A1SY81 750.00
A6TE2-16SRN 16 PTS, RELAY OUTPUT UNIT, APPLICABLE TO A1SY41/42 1,620.00
A6WA-28P READ/WRITE ADAPTER FOR A1SMCA-8KP 420.00
AC05TB 0.5 M CABLE, SINK TYPE, APPLICABLE TO A6TB( ) 500.00
AC06B 0.6M BUS CONNECTION (A/QnA CPU & A7GT-CNB) 790.00
AC06TE 0.6 M CABLE FOR A6TE2-16SR 460.00
AC100R4-25P 10M RS422 CABLE FOR CPU CONNECTION (AnS/A/QnA/QnAS/FX2) 2,760.00
AC100TE 10 M CABLE FOR A6TE2-16SR 1,100.00
AC10TB 1 M CABLE, SINK TYPE, APPLICABLE TO A6TB( ) 530.00
AC10TE 1 M CABLE FOR A6TE2-16SR 440.00
AC12B 1.2M BUS CONNECTION (A/QnA CPU & A7GT-CNB) 1,200.00
AC12B-R 1.2M RIGHT-ANGELD BUS CONNECTION (A/QnA CPU & A7GT-CNB) 1,380.00
AC12MX CONNECTION CABLE FOR MULTIPLEXER UNIT (1.2m LONG) 970.00
AC20R4-A8PU CONNECTION CABLE BETWEEN A8PUCPU, 2m LONG 1,340.00
AC20TB 2 M CABLE, SINK TYPE, APPLICABLE TO A6TB( ) 580.00
AC300PIO-20P 30M PRINTER CONNECTION 3,310.00
AC300R4 RS422 CABLE BETWEEN THE GPPCPU, 30m LONG 4,080.00
AC300R4-25P 30M RS422 CABLE FOR CPU CONNECTION (AnS/A/QnA/QnAS/FX2) 4,610.00
AC30B 3M BUS CONNECTION (A/QnA CPU & A7GT-CNB) 1,600.00
AC30B-R 3M RIGHT-ANGELD BUS CONNECTION (A/QnA CPU & A7GT-CNB) 1,860.00
AC30PIO-20P 3M PRINTER CONNECTION 1,380.00
AC30R2 RS232 CABLE BETWEEN GPPAND SERIAL PRINTER, 3m LONG 2,120.00
AC30R2-9P 3M DATA TRANSFER CABLE (D-SUB 9 PIN/25 PIN) 1,620.00
AC30R2-9SS 3M DATA TRANSFER CABLE (D-SUB 9 PIN/9 PIN) 1,620.00
AC30R4 RS422 CABLE BETWEEN THE GPPCPU, 3m LONG 1,420.00
AC30R4-25P 3M RS422 CABLE FOR CPU CONNECTION (AnS/A/QnA/QnAS/FX2) 1,860.00
AC30R4-PUS A7PU CABLE, 3 M LONG 1,660.00
AC30TB 3 M CABLE, SINK TYPE, APPLICABLE TO A6TB( ) 640.00
AC30TE 3 M CABLE FOR A6TE2-16SR 660.00
AC50B 5M BUS CONNECTION (A/QnA CPU & A7GT-CNB) 1,990.00
AC50B-R 5M RIGHT-ANGELD BUS CONNECTION (A/QnA CPU & A7GT-CNB) 2,310.00
AC50TB 5 M CABLE, SINK TYPE, APPLICABLE TO A6TB( ) 750.00
AC50TE 5 M CABLE FOR A6TE2-16SR 660.00
AD51H-S3 AD51H-BASIC, 2 X RS422, 1 X RS232, 1 X PARALLEL 28,330.00
AD61 HIGH SPEED COUNTER : 2 CH., 50KPPS(1/2 PHASE) 7,200.00
AD61S1 HIGH SPEED COUNTER : 2 CH. , 10KPPS/1 PHASE, 7KPPS/2 PHASES 7,200.00
AD71-S2 POSITIONING CONTROL : 2 AXES, PULSE TRAIN OUTPUT 15,370.00
AD71TU TEACHING UNIT FOR AD71/72 8,100.00
AD72 POSITIONING CONTROL : 2 AXES, ANALOG OUTPUT 20,230.00
AD75P1-S3 PULSE TRAIN O/P, 1 AXIS 7,600.00
AD75P2-S3 PULSE TRAIN O/P, 2 AXES 11,990.00
AD75P3-S3 PULSE TRAIN O/P, 3 AXES 16,000.00
AD75TU AD75 TEACHING PANEL 7,550.00
AG60 BLANK UNIT 160.00
AG62 DUMMY UNIT : 16/32/48/64 POINT SELECTABLE 1,130.00
AH42 32 PT. INPUT, 32 PT. SINK OUTPUT, DC 12/24V 5,340.00
AI61 16 PT. INTERRUPT MODULE 4,610.00
AJ55TB2-16R REMOTE OUTPUT, 16 PTS, RELAY, AC240V 2A/PT. 3,530.00
AJ55TB2-16T REMOTE OUTPUT, 16 PTS, TRANSISTOR(SINK), DC24V 0.5A/PT. 2,870.00
AJ55TB2-4R REMOTE OUTPUT, 4 PTS, RELAY, AC240V 2A/PT. 1,850.00
AJ55TB2-4T REMOTE OUTPUT, 4 PTS, TRANSISTOR(SINK), DC24V 0.5A/PT. 1,790.00
AJ55TB2-8R REMOTE OUTPUT, 8 PTS, RELAY, AC240V 2A/PT. 2,160.00
AJ55TB2-8T REMOTE OUTPUT, 8 PTS, TRANSISTOR(SINK), DC24V 0.5A/PT. 2,010.00
AJ55TB3-16D REMOTE INPUT, 16 PTS, DC24V 2,870.00
AJ55TB32-16DR INPUT 8 PTS, DC24V / OUTPUT 8 PTS, RELAY AC240V 2A/PT. 3,080.00
AJ55TB32-16DT INPUT 8 PTS, DC24V / OUTPUT 8 PTS, TRAN.(SINK) DC24V 0.5A/PT. 2,870.00
AJ55TB32-4DR INPUT 2 PTS, DC24V / OUTPUT 2 PTS, RELAY AC240V 2A/PT. 1,790.00
AJ55TB32-4DT INPUT 2 PTS, DC24V / OUTPUT 2 PTS, TRAN.(SINK) DC24V 0.5A/PT. 1,850.00
AJ55TB32-8DR INPUT 4 PTS, DC24V / OUTPUT 4 PTS, RELAY AC240V 2A/PT. 2,010.00
AJ55TB32-8DT INPUT 4 PTS, DC24V / OUTPUT 4 PTS, TRAN.(SINK) DC24V 0.5A/PT. 1,940.00
AJ55TB3-4D REMOTE INPUT, 4 PTS, DC24V 1,700.00
AJ55TB3-8D REMOTE INPUT, 8 PTS, DC24V 1,940.00
AJ61BT11 MASTER/LOCAL MODULE FOR ACPU 5,880.00
AJ61QBT11 CC-LINKmaster5,880.00
AJ65BT-64AD 4CH. A/D CONVERSION MODULE 7,550.00
AJ65BT-64DAI 4 CH. D/A CONVERSION MODULE, CURRENT OUTPUT 10,080.00
AJ65BT-64DAV 4 CH. D/A CONVERSION MODULE 10,080.00
AJ65BT-64RD3 4 CH. PT100(3-WIRE TYPE) TEMPERATURE INPUT MODULE 11,750.00
AJ65BT-64RD4 4 CH. PT100(4-WIRE TYPE) TEMPERATURE INPUT MODULE 11,750.00
AJ65BT-68TD 8 CH. THERMOCOUPLE TEMPERATURE INPUT MODULE 16,790.00
AJ65BTB1-16D 16PTS. IN, 24VDC(5MA) 3,280.00
AJ65BTB1-16DT 8PTS. INPUT, 24VDC(7MA); 8PTS. TRAN. OUTPUT, 24VDC(0.5A) 3,530.00
AJ65BTB1-16T 16PTS. TRANSISTOR OUTPUT, 24VDC(0.5A), 3,360.00
AJ65BTB2-16D 16PTS. IN, 24VDC(7MA) 3,530.00
AJ65BTB2-16DR 8PTS. INPUT, 8PTS. RELAY OUTPUT, 24VDC/240VAC(2A) 4,020.00
AJ65BTB2-16DT 8PTS. INPUT, 8PTS. TRAN. OUTPUT, 24VDC(0.5A) 3,700.00
AJ65BTB2-16R 16PTS. RELAY OUTPUT, 24VDC/240VAC(2A), 4,270.00
AJ65BTB2-16T 16PTS. TRANSISTOR OUTPUT, 24VDC(0.5A), 3,530.00
AJ65BTC1-32D 32PTS. IN, 24VDC(7MA) 4,120.00
AJ65BTC1-32T 32PTS. TRANSISTOR OUTPUT, 24VDC(0.1A), 4,370.00
AJ65BT-D62 HIGH SPEED COUNTER, DC INPUT, PRESET DC INPUT 7,480.00
AJ65BT-D62D HIGH SPEED COUNTER, DIFF. INPUT, PRESET DC INPUT 7,480.00
AJ65BT-D62D-S1 HIGH SPEED COUNTER, DIFF. INPUT, PRESET DIFF. INPUT 7,480.00
AJ65BT-D75P2-S3 2 AXES POSITIONING MODULE 10,110.00
AJ65BT-G4-S3 GPP FUNCTION PERIPHERAL CONNECTION UNIT 7,550.00
AJ65BT-R2 RS-232C INTERFACE MODULE 7,550.00
AJ65BT-RPI-10A CC-LINK SPATIAL OPTIC REPEATER 8,380.00
AJ65BT-RPI-10B CC-LINK SPATIAL OPTICA REPEATER 8,380.00
AJ65FBTA2-16T 16PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), TWO WIRE TYPE 5,130.00
AJ65FBTA2-16TE 16PTS. 1A TRANSISTOR OUTPUT (SOURCE TYPE), TWO WIRE TYPE 5,610.00
AJ65FBTA4-16D 16PTS. DC SINK INPUT, SINK TYPE, FOUR WIRE TYPE 5,130.00
AJ65FBTA4-16DE 16PTS. DC SINK INPUT, SOURCE TYPE, FOUR WIRE TYPE 5,130.00
AJ65FBTA42-16DT 8PTS. DC SINK INPUT, TRANSISTOR OUTPUT (SINK TYPE) 5,130.00
AJ65FBTA42-16DTE 8PTS. DC SINK INPUT, TRANSISTOR OUTPUT (SOURCE TYPE) 5,610.00
AJ65MBTL1N-16D 16PTS. DC+COM INPUT, EMBEDDED TYPE 44 PINS (2 ROWS) 2,050.00
AJ65MBTL1N-16D T 8PTS. INPUT,TRAN. OUTPUT, EMBEDDED TYPE 44 PINS (2 ROWS) 2,050.00
AJ65MBTL1N-16T 16PTS. 0.1A TRAN. OUTPUT, EMBEDDED TYPE 44 PINS (2 ROWS) 2,050.00
AJ65MBTL1N-32D 32PTS. DC+COM INPUT, EMBEDDED TYPE 62 PINS (2 ROWS) 3,400.00
AJ65MBTL1N-32T 32PTS. 0.1A TRAN. OUTPUT, EMBEDDED TYPE 62 PINS (2 ROWS) 3,500.00
AJ65SBT-62DA 2CH. D/A CONVERSION MODULE 5,350.00
AJ65SBT-64AD 4CH. A/D CONVERSION MODULE 4,990.00
AJ65SBTB1-16D 16PTS. INPUT, 24VDC(7MA) 2,160.00
AJ65SBTB1-16D1 16PTS. INPUT, 24VDC(5MA), 0.2MS RESPONSE 2,310.00
AJ65SBTB1-16DT 8PTS. INPUT/TRANS. OUTPUT (SINK TYPE) 2,400.00
AJ65SBTB1-16DT1 8PTS. INPUT/TRANS. OUTPUT (SINK TYPE), HIGH SPEED RESPOND 2,570.00
AJ65SBTB1-16DT2 8PTS. INPUT/TRANS. OUTPUT (SINK TYPE), LOW LEAKAGE 2,520.00
AJ65SBTB1-16DT3 8PTS. INPUT/TRANS. OUTPUT (SINK TYPE), HIGH SPEED/LOW LEAK. 2,560.00
AJ65SBTB1-16T 16PTS. TRANSISTOR OUTPUT, 24VDC(0.5A) 2,160.00
AJ65SBTB1-16T1 16PTS. TRANSISTOR OUTPUT, 24VDC(0.1A) 2,160.00
AJ65SBTB1-16TE 16PTS. TRANSISTOR OUTPUT, (SOURCE TYPE), ONE WIRE TYPE 2,520.00
AJ65SBTB1-32D 32PTS. INPUT, 24VDC(7MA) 3,630.00
AJ65SBTB1-32D1 32PTS. INPUT, 24VDC(5MA), RESPONSE TIME 0.2MS 3,860.00
AJ65SBTB1-32DT 16PTS. IN,24VDC(0.5MA), TRANSISTOR OUT (SINK TYPE) 3,380.00
AJ65SBTB1-32DT1 16PTS. INPUT, TRANS. OUTPUT (SINK TYPE), HIGH SPEED RESPOND 4,150.00
AJ65SBTB1-32DT2 16PTS. INPUT, TRANS. OUTPUT (SINK TYPE), HIGH SPEED/LOW LEAK. 4,150.00
AJ65SBTB1-32DT3 16PTS. INPUT, TRANS. OUTPUT (SINK TYPE), LOW LEAKAGE 4,150.00
AJ65SBTB1-32T 32PTS. TRAN. OUT, 24VDC(0.5A) 3,630.00
AJ65SBTB1-32T1 32PTS. TRAN. OUT, 24VDC(0.1A) 3,640.00
AJ65SBTB1-8D 8PTS. INPUT, 24VDC(7MA) 1,840.00
AJ65SBTB1-8T 8PTS. TRANSISTOR OUTPUT, 12/24VDC(0.5A) 1,840.00
AJ65SBTB1-8T1 8PTS. TRANSISTOR OUTPUT, 12/24VDC(0.5A), LOW LEAKAGE 2,060.00
AJ65SBTB2-16T 16PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), TWO WIRE TYPE 2,800.00
AJ65SBTB2-16T1 16PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), LOW LEAKAGE 2,790.00
AJ65SBTB2-8T 8PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), TWO WIRE TYPE 2,330.00
AJ65SBTB2-8T1 8PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), LOW LEAKAGE 1,400.00
AJ65SBTB2N-16A 16PTS., AC INPUT, TWO WIRE TYPE 2,710.00
AJ65SBTB2N-16R 16PTS. 24 VDC/240 VAC 2A, RELAY OUTPUT, TWO WIRE TYPE 3,300.00
AJ65SBTB2N-16S 16PTS. 0.6A TRIAC OUTPUT, TWO WIRE TYPE 4,960.00
AJ65SBTB2N-8A 8PTS., AC INPUT, TWO WIRE TYPE 2,240.00
AJ65SBTB2N-8R 8PTS. 24 VDC/240 VAC 2A, RELAY OUTPUT, TWO WIRE TYPE 2,520.00
AJ65SBTB2N-8S 8PTS. 0.6A TRIAC OUTPUT, TWO WIRE TYPE 3,280.00
AJ65SBTB3-16D 16PTS., DC SINK/SOURCE COMMON INPUT, THREE WIRE TYPE 2,800.00
AJ65SBTB32-16DT 8PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, 2 WIRE TYPE 2,800.00
AJ65SBTB32-16DT2 8PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, LOW LEAKAGE 1,680.00
AJ65SBTB32-8DT 4PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, 2 WIRE TYPE 2,330.00
AJ65SBTB32-8DT2 4PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, LOW LEAKAGE 2,330.00
AJ65SBTB3-8D 8PTS., DC SINK/SOURCE COMMON INPUT, THREE WIRE TYPE 2,330.00
AJ65SBTC1-32D 32PTS. INPUT, 24VDC(7MA) 3,560.00
AJ65SBTC1-32D1 32PTS. INPUT, 24VDC(7MA), 0.2MS RESPONSE 3,780.00
AJ65SBTC1-32DT 16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, 24VDC 3,560.00
AJ65SBTC1-32DT1 16PTS. IN,24VDC(0.5MA),16PTS. TRAN. OUT, 24VDC(0.1A) 3,780.00
AJ65SBTC1-32DT2 16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, 24VDC, LOW LEAKAGE 4,150.00
AJ65SBTC1-32DT3 16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, HIGH SPEED/LOW LEAK. 4,190.00
AJ65SBTC1-32T 32PTS. TRAN. OUT, 24VDC(0.1A) 3,560.00
AJ65SBTC1-32T1 32PTS. TRAN. OUT, 24VDC(0.1A), LOW LEAKAGE 4,150.00
AJ65SBTC4-16D 16PTS. INPUT, 24VDC(5MA) 2,180.00
AJ65SBTC4-16DT 8PTS., DC SINK/IN, 2, 3, 4 WIRE TYPE, 0.5A TRAN., OUT, 4 WIRE TYPE 2,180.00
AJ65SBTC4-16DT2 8PTS., DC SINK/IN, 2, 3, 4 WIRE TYPE, 0.5A TRAN., OUT, LOW LEAK. 2,560.00
AJ65SBTCF1-32D 32PTS. INPUT, 24VDC(7MA) 3,030.00
AJ65SBTCF1-32DT 16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, 24VDC 3,030.00
AJ65SBTCF1-32T 32PTS. TRAN. OUT, 24VDC(0.5A), 3,030.00
AJ65SBT-RPS CC-LINK OPTICAL REPEATER 3,410.00
AJ65SBT-RPT CC-LINK REPEATER (T-BRANCH) 2,080.00
AJ65SBTW4-16D 16PTS. INPUT, 24VDC(5MA), WATER PROOF 5,040.00
AJ65SBTW4-16DT 8PTS. IN,24VDC/0.5MA, 8PTS. TRAN. OUT, 24VDC/0.5A, WATER PROOF 5,040.00
AJ65VBTCU68ADI 8 CH. A/D CURRENT INPUT CONVERSION MODULE 8,380.00
AJ65VBTCU68ADV 8 CH. A/D VOLTAGE INPUT CONVERSION MODULE 8,380.00
AJ65VBTCU68DAVN 8 CH. D/A CONVERSION MODULE 11,170.00
AJ71AP21 MELSECNET MASTER/LOCAL, OPTICAL LINK 12,140.00
AJ71AR21 MELSECNET MASTER/LOCAL, COAXIAL LINK 12,140.00
AJ71AT21B MELSECNET/B MASTER/LOCAL 9,710.00
AJ71BR11 MELSECNET/10 MASTER/LOCAL, COAXIAL 14,490.00
AJ71C22-S1 MULTILINK UNIT 8,630.00
AJ71E71N-B2 ETHERNET INTERFACE UNIT, 10BASE2 20,000.00
AJ71E71N-B5T ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5 20,000.00
AJ71LP21 MELSECNET/10 MASTER/LOCAL, SI-200/250 OPTICAL LINK 14,490.00
AJ71LP21G MELSECNET/10 MASTER/LOCAL, GI-50/125 TYPE OPTICAL LINK 22,400.00
AJ71LP21GE MELSECNET/10 MASTER/LOCAL, GI-62.5/125 TYPE OPTICAL LINK 14,400.00
AJ71PT32-S3 MELSECNET/MINImasterUNIT 9,980.00
AJ71QBR11 MELSECNET/10 , COAXIAL 13,610.00
AJ71QC24 RS232C &RS422 I/F 8,060.00
AJ71QC24N RS232C &RS422 I/F(NEW TYPE) 8,620.00
AJ71QC24N-R2 RS232 I/F, 2 CH(NEW TYPE) 8,620.00
AJ71QC24N-R4 RS422 & RS422/485 I/F(NEW TYPE) 8,620.00
AJ71QC24-R2 RS232 I/F, 2 CH 8,060.00
AJ71QC24-R4 RS422 & RS422/485 I/F 8,060.00
AJ71QE71N-B2 ETHERNET INTERFACE UNIT, 10BASE2 18,890.00
AJ71QE71N-B5T ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5 15,110.00
AJ71QLP21 MELSECNET/10 , SI-200/250 FIBRE OPTIC 13,610.00
AJ71QLP21G MELSECNET/10 , GI-50/125 TYPE FIBRE OPTIC 21,160.00
AJ71QLP21S MELSECNET/10 , SI-200/250 FIBRE OPTIC, EXT POWER 18,120.00
AJ71UC24 COMPUTER LINK UNIT 13,670.00
AJ71UC24-S2 RS232/RS422/485 MODBUS PROTOCOL MODULE 13,500.00
AJ72P25 MELSECNET REMOTE I/O CONTROLLER, OPTICAL LINK 14,560.00
AJ72QBR15 MELSECNET/10 REMOTE I/O CONTROLLER, COAXIAL 13,610.00
AJ72QLP25 MELSECNET/10 REMOTE I/O CONTROLLER, SI FIBRE OPOTIC 21,160.00
AJ72QLP25G MELSECNET/10 REMOTE I/O CONTROLLER, GI FIBRE OPOTIC 21,160.00
AJ72R25 MELSECNET REMOTE I/O CONTROLLER, COAXIAL LINK 14,560.00
AJ72T25B MELSECNET/B REMOTE STATION 9,710.00
AS91 SYSTEM FAULT DETECTION MODULE 2,730.00
AS91 SYSTEM MONITOR MODULE 2,800.00
AS92R SYSTEM FAULT DETECTION MODULE 3,910.00
AX10 16 PTS. AC 100V, 10mA 2,840.00
AX11 32 PTS. AC 100V, 10mA 4,940.00
AX20 16 PT. AC 200V, 10mA 3,400.00
AX21 32 PT. AC 200V, 10mA 5,670.00
AX40 16 PT. DC 12/24V, SINK INPUT (4/10mA) 2,670.00
AX41 32 PT. DC 12/24V, SINK INPUT (4/10mA) 4,210.00
AX41-S1 32 PT. DC 12/24V, SINK INPUT (4/10mA), FAST RESPONSE 4,370.00
AX42 64 PT. DC 12/24V, SINK INPUT (3/7mA) 5,260.00
AX42-S1 64 PT. DC 12/24V, SINK INPUT (3/7mA), FAST RESPONSE 5,500.00
AX50-S1 16 PT. DC 48V, SINK/SOURCE (4mA) 2,890.00
AX60-S1 16 PT. DC 100/110/125V, SINK/SOURCE (2mA) 3,540.00
AX70 16 PT. DC 5/12/24V, SINK/SOURCE INPUT (2mA) 2,750.00
AX71 32 PT. DC 5/12/24V, SINK/SOURCE INPUT (3.5/2/4.5mA) 4,040.00
AX80 16 PT. DC 12/24V, SOURCE INPUT (4/10mA) 3,230.00
AX80E 16 PT. DC 12/24V, SOURCE INPUT (4/10mA), FAST RESPONSE 3,400.00
AX81 32 PT. DC 12/24V, SOURCE INPUT (4/10mA) 4,040.00
AX82 64 PT. DC 12/24V, SOURCE INPUT (8/7mA) 5,670.00
AY10 16 PT. RELAY OUTPUT, 2A 2,990.00
AY10A 16 PT. RELAY OUTPUT, 2A (INDEPENDENT COMMONS) 3,230.00
AY11 16 PT. RELAY OUTPUT, 2A 3,480.00
AY11A 16 PT. RELAY OUTPUT2A (INDEPENDENT COMMONS) 3,800.00
AY11E 16 PT. RELAY OUTPUT 2A (FUSED COMMON) 3,640.00
AY13 32 PT. RELAY OUTPUT 2A 5,500.00
AY13E 32 PT. RELAY OUTPUT 2A (FUSED COMMON) 6,550.00
AY22 16 PT. TRIAC OUTPUT 2A 4, 130.00
AY23 32 PT. TRIAC OUTPUT 0.6A 6,880.00
AY40 16 PT. DC 12/24V TRANSISTOR SINK OUTPUT 0.1A 3,080.00
AY40A 16 PT. DC 12/24V TRANSISTOR SINK OUTPUT 0.3A ( INDEPENDENT) 3,560.00
AY40P 16 PT. DC 12/24V TRANSISTOR SINK 0.1A (SHORT CCT. PROTECTION) 3,080.00
AY41 32 PT. DC 12/24V TRANSISTOR SINK 0.1A 3,890.00
AY41P 16 PT. DC 12/24V TRANSISTOR SINK 0.1A (SHORT CCT. PROTECTION) 3,890.00
AY42 64 PT. DC 12/24V TRANSISTOR SINK 0.1A 5,430.00
AY42-S1 64 PT. DC 12/24V TRANSISTOR SINK 0.1A (HIGH SPEED) 5,670.00
AY42-S3 64 PT. DC 12/24V TRANSISTOR SINK 0.1A (FUSED) 5,670.00
AY50 16 PT. DC 12/24V TRANSISTOR SINK 0.5A 3,400.00
AY51 32 PT. DC 12/24V TRANSISTOR SINK 0.5A 4,450.00
AY51-S1 32 PT., DC 12/24V TRANSISTOR SINK 0.3A 4,860.00
AY60 16 PT. DC 12/24/48V TRANSISTOR SOURCE 2A 3,890.00
AY60E 16 PT. DC 12/24/48V TRANSISTOR SOURCE 0.5A 4,450.00
AY60S 16 PT. DC 24/48V TRANSISTOR SINK FOR TTL & CMOS, 2A 5,370.00
AY70 16 PT. DC5/12V TRANSISTOR SINK FOR TTL & CMOS 16mA 2,840.00
AY71 32 PT. DC5/12V TRANSISTOR SINK FOR TTL & CMOS 16mA 3,730.00
AY72 64 PT. DC 5/12V TRANSISTOR SINK FOR TTL & CMOS, 16mA 5,500.00
AY80 16 PT. DC 12/24V TRANSISTOR SOURCE OUTPUT, 0.5A 3,890.00
AY81 32 PT. DC 12/24V TRANSISTOR SOURCE, 0.5A 5,260.00
AY81EP 32 PT. DC 12/24V TRANSISTOR SOURCE, 0.8A WITH SHORT CIRCUIT PROTECTION 7,310.00
AY82EP 64 PT. DC 12/24V TRANSISTOR SOURCE, 0.1A, WITH SHORT CIRCUIT PROTECTION 7,200.00
- 电话:0371-63897587
- 传真:0371-63897587
- email:kfs13@126.com
上一篇:郑州高恩供应三菱A900系列F900系列触摸屏(GOT)
下一篇:西门子传感器特价
