- 型号:6FX5002-5CA51-1BA06FX5002-5CA11-1CA0/6FX5002-5CA11-1CA0
- 数量:大量
- 制造商:德国
- 有效期:2026/1/31 0:00:00
天津大成恒业机电设备有限公司 010-88603269/65431486/65434982
6FC、6FX大量现货
6FX2001-3EB02 sin/cos 1 Vpp incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Radial flange outlet, 1024 S/R
6FX2001-3EC50
6FX2001-5FE13 EnDat absolute encoder, Synchronous flange and 5 V DC supply voltage Connection: • Radial flange outlet, Resolution: Single-turn 8192 steps/revolution(13-bit)
6FX2001-7KF10 spring disk coupling
6FX2001-7KP01 clamp
6FX2001-7KS06 spring disk coupling
6FX2002-1AA01-1AD0 V24-RS232 CABLE 9Pins[SOCKET]-9Pins[SOCKET]
6FX2002-1DC00-1AF0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(5M)
6FX2002-1DC00-1BA0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(10M)
6FX2002-1DC00-1BF0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(15M)
6FX2002-2CE02-1BA0 Signal cable built-in ROD320 L=10M
6FX2002-3AB01-1AF0
6FX2002-3AD01-1AH0 Cable 802C BL - 611U(7M)
6FX2002-3AD01-1BA0 Cable 802C BL - SIMODIRVE L=10M
6FX2002-4EA01-1AF0 MPI bus cable with three connectors CNC-MMC-MSTT(l2=5m;l1=1m)
6FX2002-4EA04-1AF0 MPI bus cable with three connectors CNC-MMC-MSTT(l2=1m;l1=5m)
6FX2002-4EA80-1BA0 Pre-assembled MPI bus cable
6FX2002-5AA12-1BF0 POWER CABLE 1FT5, CONNECTOR SIZE 2, 4X4 SQMM, L=15M
6FX2003-0AA02 Profibus connector
6FX2003-0CA10 power cable connector
6FX2003-0CB10 power cable connector
6FX2003-0CB20 power cable connector
6FX2003-0CE12 connector type 12-way
6FX2003-0DA00 Terminator for drive bus
6FX2003-0DS00 RS232 ISOLATOR
6FX2003-0LU00 POWER CONNECTOR SIZE 16-WAY SOCKET, UNION NUT1 6-POLE INSULATOR 8 SOCKET CONTACTS (1-2.5 MM2)2 CABLE
6FX2003-0LU10 POWER CONNECTOR 6-POL SIZE 1.5SOCKET, UNION NUT1 6-POLE INSULATOR 5 SOCKET CONTACTS (1.5-4MM2)5 SOCK
6FX2003-0SU01 SIGNAL CONNECTOR, 9-PINUNION NUT1 INSULATOR WITH SOCKET CONT.1 INSULATOR WITH PIN CONT.SOLDER VERSIO
6FX2003-0SU12
6FX2003-7DX00 Mounting flange for signal conn.(can be used for conn. With union cap and for conn. With external thread also)
6FX2003-7FX00 HF clamp for signal connector and power connector and power connector size1
6FX2006-1BA02 Cable distributor
6FX2006-1BC01 DISTRIBUTOR for hand-held unit with iicl. Shorting plug 3-wire connection
6FX2006-1BG00 Connecting kit
6FX2006-1HA0 Holder made of polystyrence
6FX2007-1AC03 "B-MPI handheld unit 3-step enabling button
including connecting cable with connector
3-wire enabling
- coiled connecting cable length: 3.5 m (11 ft 6 in)"
6FX2007-1AC04 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - coiled connecting cable length: 3.5 m (11 ft 6 in)"
6FX2007-1AC13 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - straight connecting cable length: 10 m (32 ft 10 in)"
6FX2007-1AC14 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - straight connecting cable length: 10 m (32 ft 10 in)"
6FX2007-1AD01 "Mini handheld unit 3-step enabling button incl. 2 magnets for attachment and connecting cable with connector • Coiled connecting cable Length: 1.5 m (4 ft 11 in), stretches to 3.5 m (11 ft 6 in)"
6FX2007-1AD11 "Mini handheld unit 3-step enabling button incl. 2 magnets for attachment and connecting cable with connector • Straight connecting cable Length: 5 m (16 ft 5 in)"
6FX2007-1AE04 "B-MPI handheld unit 3-step enabling button
4-wire enabling
6FX2007-1AE14 "B-MPI handheld unit 3-step enabling button
4-wire enabling
6FX4002-2CA51-1BF0 SIGNAL CABLE 611A---1PH6 ENCODER/SIMAG H, 3X2X0.14+4X0.14+2X0.5C L=15M
6FX4002-2CB31-1BA0 SIGNAL CABLE, 611A TO 1FT5 TG/SHAFT POSITION ENCODER, 12X0.23C, L=10M
6FX4002-2CB42-1BA0 SIGNAL CABLE, 810/820 TO BUILT-IN ENCODER ROD320, 4X2X0.38+4X0.5C, L=10M
6FX4002-2CB42-1BF0 SIGNAL CABLE, 810/820 TO BUILT-IN ENCODER ROD320, 4X2X0.38+4X0.5C, L=15M
6FX4002-5CA12-1BJ0 POWER CABLE, PREASSEMBLED, EXT., 4X4 C, CONNECTOR SIZE 2 [1FT/1FK TO 611/810D/SIMODRIVE] L=18M
6FX4002-5DA01-1BA0 POWER CABLE, 4X1.5C,CONN. SIZE 1, L=10M
6FX4002-5DA02-1BF0 POWER CABLE L=15M
6FX5002-2AD00-1BA0 SIGNAL CABLE, (611D/MCU TO ENDAT ENCODER) 3X2X0.14+4X2X0.5C L=10M
6FX5002-2CA11-1AF0 encoder cable,5M
6FX5002-2CA11-1AG0 encoder cable,6M
6FX5002-2CA11-1BA0 encoder cable,10M
6FX5002-2CA11-1BF0 encoder cable,15M
6FX5002-2CA11-1CA0 encoder cable,20M
6FX5002-2CA11-1CF0 encoder cable,25M
6FX5002-2CA31-1AF0 Signal cable,5M
6FX5002-2CB51-1BF0 SIGNAL CABLE (BUILT-ON ENCODER 5V 6FX2001-2) 4X2X0.34+4X0.5C L=15M
6FX5002-2CD01-1AF0 Signal cable, SMC30 --- external encoder(TTL), 5M
6FX5002-2CD01-1BA0 Signal cable, SMC30 --- external encoder(TTL), 10M
6FX5002-2CD01-1BF0 Signal cable, SMC30 --- external encoder(TTL), 15M
6FX5002-2CD01-1CA0 Signal cable, SMC30 --- external encoder(TTL), 20M
6FX5002-2CD01-1CF0 Signal cable, SMC30 --- external encoder(TTL), 25M
6FX5002-2CG00-1AF0 Incremental(sin/cos 1Vpp) encoder cable,5M, IP20/IP67
6FX5002-2CG00-1BA0 Incremental(sin/cos 1Vpp) encoder cable,10M, IP20/IP67
6FX5002-2CG00-1BF0 Incremental(sin/cos 1Vpp) encoder cable,15M, IP20/IP67
6FX5002-2CG00-1CA0 Incremental (sin/cos 1Vpp)encoder cable,20M, IP20/IP67
6FX5002-2CG00-1CF0 Incremental(sin/cos 1Vpp) encoder cable,25M, IP20/IP67
6FX5002-2CJ00-1AH0 Signal cable,SIMODRIVE Baseline-802C BL(7M)
6FX5002-2DC10-1AF0 DRIVE CLiQ Signal cable for Motor encoder --- Motor module,5M, IP20/IP67, with 24VDC
6FX5002-2DC10-1BA0 DRIVE CLiQSignal cable for Motor encoder --- Motor module,10M,IP20/IP67, with 24VDC
6FX5002-2DC10-1BF0 DRIVE CLiQSignal cable for Motor encoder --- Motor module,15M,IP20/IP67, with 24VDC
6FX5002-2EQ10-1BA0 SIGNAL CABLE, (ABSOLUTE ENCODER IN MOTOR) 3X2X0.14+4X0.14+2X0.5+4X0.22C L=10M
6FX5002-2EQ10-1BJ0 signal cable, (ABSOLUTE ENCODER IN MOTOR) 3X2X0.14+4X0.14+2X0.5+4X0.22 C, L=18M
6FX5002-5CA01-1AF0 power cable for 3,2-16 Nm motor,5M
6FX5002-5CA01-1BJ0 power cable for 3,2-16 Nm motor,18M
6FX5002-5CA11-1AF0 power cable for 18 Nm motor,5M
6FX5002-5CA11-1BA0 power cable for 18 Nm motor,10M
6FX5002-5CA11-1BF0 power cable for 18 Nm motor,15M
6FX5002-5CA11-1CA0 power cable for 18 Nm motor,20M
6FX5002-5CA21-1BA0 POWER CABLE 4X1.5C, CONN. SIZE 1.5 L=10M
6FX5002-5CA31-1AF0 power cable for 27 Nm motor,5M
6FX5002-5CA31-1BA0 power cable for 27 Nm motor,10M
6FX5002-5CA31-1BF0 power cable for 27 Nm motor,15M
6FX5002-5CA41-1AF0 power cable for 27 Nm motor,5M
6FX5002-5CA41-1BA0 power cable for 27 Nm motor,10M
6FX5002-5CA41-1BC0 power cable for 27 Nm motor,12M
6FX5002-5CA41-1BF0 power cable for 27 Nm motor,15M
6FX5002-5CA41-1CA0 power cable for 27 Nm motor,20M
6FX5002-5CA51-1AF0 power cable for 36 Nm motor,5M
6FX5002-5CA51-1BA0 power cable for 36 Nm motor,10M
6FX5002-5CA51-1BF0 power cable for 36 Nm motor,15M
6FX5002-5CS01-1AF0 Power cable below 18NM,5M
6FX5002-5CS01-1BA0 Power cable below 18NM,10M
6FX5002-5CS01-1BF0 Power cable below 18NM,15M
6FX5002-5CS02-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x1.5 sqr.mm, used for 1PH7101
6FX5002-5CS02-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x1.5 sqr.mm,used for 1PH7101
6FX5002-5CS02-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x1.5 sqr.mm,used for 1PH7101
6FX5002-5CS12-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x2.5 sqr.mm, used for 1PH7103
- 电话:010-88603269/65431486/654334982
- 传真:010-65431486-8005
- email:dachenghengye@yahoo.con
