当前页面: 首页 >供求信息 >特价供应倍加福(P+F)传感器现货NBN40-L2-E2-V1;NBB2-12GM50-E0;NBN8-18GM50-E2-V1;NBN40-L2-A2-V1
供稿:hht8816 2009/2/23 11:27:13
人气:319
  • 有效期:2046/2/28 0:00:00
我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
基本品种:NBB,NBN,NEB,NCB,NJ,SJ,FJ,RJ,NMB
常用型号如下:NBN40-L2-E2-V1  NBN40-L2-A2-V1 NBN8-18GM50-E2-V1 连接插头V1-G
NBB2-12GM50-E0       NBN4-12GM50-E2-V1          NJ4-12GM40-E2              NBB2-12GM50-E2         NJ5-18GM-N
NBB2-12GM50-E0-V1    NBN5-F7-E2                 NBN5-F7-E0                 NJ4-12GM40-E2-V1       NJ40+U1+W
NBB2-12GM50-E2-V1    NBN8-18GM50-E0             NJ8-18GM-N                 NBB4-12GM50-E0-V1
NBN8-18GM50-E2       NJ15+U1+E2                 NBB4-12GM50-E2-V1          NBN8-18GM50-E0-V1
NJ15+U1+W            NBB5-18GM50-E0             NBN8-18GM50-E2-V1          NJ20+U1+E2
NBB5-18GM50-E2       NBN8-18GM40-Z0             NJ20+U1+W                  NBB10-30GM50-E0
NBN8-18GM60-WS       NJ30+U1+W                  NBB10-30GM50-E2            NBN8-18GM60-WO
NJ30+U1+E2           NBB15-30GM50-WS            NBN15-30GM50-E2            NJ1.5-8GM-N
NBB15-30GM50-WO      NBN15-30GM50-E0            NJ2-12GM-N                 NBB20-L2-E2-V1
NBN15-30GM40-Z0      NJ4-12GM-N                 NBN4-12GM50-E0-V1          NBN4-12GM50-E2
LVL-T1-G3S-E5PG-NA   LVL-T1-G3S-E5PG-NA         NBN4-12GM50-E0             NCN25-F35-A2-250-V1
光电传感器
基本品种:0J,0B,0CD,0CE,0BE,BCT\0BT,0CS,0BS系列
常用型号如下:ML5-54/32/115  光电开关反射板OMH-ML5 反光板ORR50订货货080873
OBT200-18GM70-E4       OBS2000-18GK70-E4          RLK39-8-2000-Z/31/40a/116
OBT200-18GM60-E5       OBS2000-18GK70-E5          RLK39-8-800-Z/31/40a/116
OBT200-18GM60-E4       OCS5000-F28-E5             RL39-8-800/32-40A/82A/116
OBT200-18GM-70-E5      OCS5000-F28-E4             RL39-8-800-30-40A/116/126A
OBT400-F28-E4           OCS5000-F8-UK             RL39-54-Z/31/40a/116
OBT400-F28-E5           LA39/LK39/31/40a/116       RL39-55/30/35/40a/116/126a
OCT800-F8-E4            LA39/LK39-Z/31/40a/116     RL39-55/32/35/40a82a/116
OCT800-F8-E5           RL39-8-2000/30/40a/116/126a
OBE5000-18GM70-SE4     LD39/LV39/30/40a/116/126a   RL39-8-2000/32/40a/82a/116
OBE5000-18GM70-SE7     LD39/LV39/32/40a/82a/116    RL39-8-2000/32/40a/82a/73c
OBE5000-18GM60-SE4     ML5-8-400/32/115            RL39-8-800/30/40a/116/126a
OBE5000-18GM70-SE5     ML5-8-400/30/115            RL39-8-800/32/40a/82a/116
OBE5000-18GM70-SE7     M5/MV5/32/115              RL39-8-800/32/40a/82a/73c
OBE5000-18GM60-SE5     RLK39-55/31/40a/116         RL39-54/30/40a/116/126a
OBE5000-F28-SE1         RLK39-8-2000/31/40a/116     RL39-54/30/40a/73c/126a
OBE5000-F28-SE5         RLK39-8-2000-Z/31/40a/116   RL39-54/32/40a/73c/82a
OBE5000-F8-SUK          RLK39-54/31/40a/116         RL39-54/32/40a/82a/116
OBE-5000-F8-SUKT        RLK39-55-Z/31/35/40a/116    RLK39-54-Z/31/40a/116
OBE10M-18GM60-SE5       OBE10M-18GM60-SE4           RLK39-55/31/35/40a/116
旋转编码器
基本品种:增量型TRD-GK系列,最大5000P\rev,10系列、58系列
增量型常用型号如下:DVM58N-011YYROBN-1213
10-11331_R-1024            14-14361-1024             30-3641_R-1024
10-15636_R-1024           14-14361-5000             30-4241_A-1000
10-11336_R-3600           14-1436X-1024             30-4201_A-1024
10-11631_R-1024           RHI58N-0BAK1R66N-01024  RVI78N-10CK2A31N-01000
10-11631_A-1024           RVI58N-011K1R66N-01024   RVI78N-10CK2A31N-02000
10-11651_R-1024           RVI58N-011K1R61N-01024   RVI78N-10CK2A31N-01024
RVI50N-09BK0A3TN-02000  RHI58N-0BAK1R61N-01000  RHI90N-0LAK1R61N-01000
RVI50N-09BK0A3TN-01000  RVI58N-011K1R66N-02048   RHI90N-0HAAAR61N-01024
RVI50N-09BK0A3TN-00600  RVI58N-011K1A61N-01024    RHI90N-0HAK1R61N-02048
RVI50N-09BK0A3TN-01024  RHI58N-0BAK1R61N-01024  RHI90N-0HAK1R61N-01024
RVI50N-09BK0A3TN-00500  RHI58N-0BAK1R6XN-01024  RHI90N-0HAK1R66N-01024
RVI58N-011AAR61N-02048  RHI58N-0BAK1R61N-00500   RHI90N-0LAK1R66N-01024
RVI58N-011K1A61N-02500   RVI58N-011K1A61N-02048   RHI90N-0NAK1R66N-01024
RVI58N-011K1R6XN-01024  RVI58N-011K1R61N-05000    RHI90N-0NAK1R61N-01024
RVI58N-011K1A61N-01000   RVI58N-011K1R61N-01000   RHI58N-0BAK1R31N-01024
RVI78N-10CALA31N-01000
绝对型常用型号如下:
ASS58N-F1AK1RHGN-0012  DVM58N-011AGR0BN-1212    PSS58N-F3AAGR0BN-0013
AVS58N-011K1R0BN-0016  DVM58N-011AGR0BN-1213    PVS58I-011AGR0BN-0013
AVM58N-011K1R0GN-1213  FVS58N-032K2R3GN-0013     PVM58N-011AGR0BN-1213
AVM58N-032K1RPGN-1212  FVS58N-011K2R3BN-0013     PSM58N-F2AAGR0BN-1213
AVM58N-011K1R0BN-1213  FVM58N-01LAEAABN-0812    PVM58I-032AGR0BN-1213
ASM58N-F2AK1R0GN-1213  FVM58N-011K2A3GN-1213    PVM58N-032AGR0BN-1213
安全栅
产品类型:远程I/O型隔离栅、本安型远程I/O系统、FieldConnex现场总线、各种网桥、现场总线配电器、中继器、现场总线I/O模盒、接线盒、现场总线安全栅、快速接插线
常用型号如下:
KC系列隔离式安全栅(超薄型)
模拟量输入
KCD2-STC-EX1(单通道,2/4线制智能变送器,有源/无源4-20mA输出)
模拟量输出
KCD2-SCD-EX1(单通道,电流驱动,智能型)
开关量输入
KCD2-SR-EX1.LB(单通道,2路继电器输出)
KCD2-SR-EX2(双通道,2路继电器输出)
开关量输出
CKD0-SD-EX1.1245(单通道,回路供电式)
KF系列隔离式安全栅(标准型)
模拟量输入
KDF-STC4-EX1
KFD2-STC4-EX1.2O
KFD2-STC4-EX1-Y122583
KFD2-STC4-EX1.2O-Y122582
模拟量输出
KFD2-CD-EX1.32(单通道,电流驱动)
KFD2-CD2-EX2(双通道,电流驱动)
KFD2-SCD-EX1.LK(单通道,电流驱动,智能型)
KFD2-SCD2-EX1.LK(单通道,电流驱动,智能型)
KFD2-SCD2-EX2.LK(双通道,电流驱动,智能型)
通用温度变送
KFD2-UT-2-EX1(单通道,4-20mA输出)
KFD2-UT2-EX2(双通道或一进二出,4-20mA输出)
开关量输入
KFD2-SH-EX1(单通道,故障安全型,继电器输出)
KFD2-SH-EX1.T.OP(单通道,故障安全型,晶体管输出)
KFD2-SR2-EX1.W(单通道,继电器输出)
KFD2-SR2-EX1.W.LB(单通道,2路继电器输出)
KFD2-SR2-EX2.W(双通道,2路继电器输出)
KFD2-SR2-EX2.2S(双通道,2路继电器输出)
KFD2-SR-EX1.4S.LK(单通道,4路继电器输出)
KFD2-SRA-EX4(四通道,4路继电器输出)
KFD2-ST2-EX1.LB(单通道,2路有源晶体管输出)
KFD2-ST2-EX2(双通道,有源晶体管输出)
KFD2-SOT2-EX2(双通道,无源晶体管输出)
天关量输出
KFD0-SD2-EX1.1045(单通道,回路供电)
KFD0-SD2-EX2.1045(双通道,回路供电)
KFD2-SL2-EX1(单通道,逻辑输入,带线路故障监测)
KFD2-SL2-EX1.B(单通道,逻辑输入)
KFD2-SL2-EX2.B(双通道,逻辑输入)
报警设定器
KFA6-DWB-EX1.D(单通道,输速报警,带显示,220VAC,带安全栅功能)
KFD2-CRG-1.D(单通道,变送器,带显示)
KFD2-CRG-EX1.D(单通道,变送器,带显示,带安全栅功能)
KFD2-DWB-1.D(单通道,转速报警,带显示)
KFD2-GUT-1.D(单通道,温度变送,带显示)
KFD2-GUT-EX1.D(单通道,温度变送,带显示,带安全栅功能)
KFD2-UFC-1.D(单通道,通用频率变送,带显示)
KFD2-UFC-EX1.D(单通道,通用频率变送,带显示,带安全栅功能)
KFU8-CRG-1.D(单通道,变送器,带显示,220VAC/24VDC)
KFU8-CRG-EX1.D(单通道,变送器,带显示,带安全栅功能,220VAC/24VDC)
KFU8-GUT-1.D(单通道,温度变送,带显示,220VAC/24VDC)
KFU8-GUT-EX1.D(单通道,温度变送,带显示,带安全栅功能,220VAC/24VDC)
KFU8-UFC-1.D(单通道,通用频率变送,带显示,220VAC/24VDC)
KFU8-UFC-EX1.D(单通道,通用频率变送,带显示,带安全栅功能,220VAC/24VDC)
回路供电隔离栅
KFD0-CC-EX1(单通道,电流/电压转换)
KFD0-CS-EX1.51P(单通道,电流驱动/传递)
KFD0-CS-EX2.51P(双通道,电流驱动/传递)
KFD0-SCS-EX1.55(单通道,智能现场设备)
KFD0-TR-EX1(单通道,RTD转换)
安装附件
KFD2-EB2.R4A.B(冗余型电源模块,24VDC/4A)
UPR-03(电源导轨,2m)
超声波传感器
常用型号如下:
UB500-18GM75-E4-V15   UB1000-18GM75-U-V15        UC2000-30GM-IUR2-T-V15
UB500-18GM75-E5-V15   UB2000-30GM-E4-V15        UC2000-30GM-IUR2-V15
UB500-18GM75-E6-V15   UB2000-30GM-E5-V15        UC4000-30GM-E6R2-V15
UB500-18GM75-E7-V15   UB2000-30GM-H3           UC4000-30GM-E7R2-V15
UB500-G18GM75-I-V15   UB2000-30GM-H3-V1        UC4000-30GM-IUR2-V15
UB500-18GM75-U-V15      UB4000-30GM-E4-V15        UC6000-30GM-E6R2-15
UB500-30GM-E4-V15       UB4000-30GM-E5-V15        UC6000-30GM-E7R2-V15
UB500-30GM-E5-V15       UB4000-30GM-H3-V1        UC6000-30GM-IUR2-V15
UB800-18GM40A-E5-V1     UB6000-30GM-E4-V15        UB500-F54-I-V15
UB800-18GM40A-I-V1       UB6000-30GM-E5-V15        UB500-F54-U-V15
UB800-18GM40A-U-V1   UC1000-30GM-E6R2-K-V15     UB2000-F54-E4-V15
UB1000-18GM75-E4-V15   UC1000-30GM-UYR2-K-V15    UB2000-F54-E5-V15
UB1000-18GM75-E5-V15   UC2000-30GM-E6R2-T-V15     UB2000-F54-H3-V1
UB1000-18GM75-E6-V15   UC2000-30GM-E6R2-V15       UB2000-F54-I-V15
UB1000-18/GM75-E7-V15   UC2000-30GM-E7R2-T-V15     UB2000-F54-U-V15
UB1000-18GM75-I-V15   UC2000-30GM-E7R2-V15
液位传感器
极限位置检测:
LFL系列浮子式开关           LML-P系列
     LFL1-N系列           LML-S系列
     LFL1-Z0/Z1系列           LML-Ex系列
     LFL1-WS/WO系列
     LFL2-U系列       连续量检测物位开关
     LFL3-U系列            LMC系列磁性浸入式开关
     LFLC系列                LMC-P系列
                            LMC-S系列
LVL系列音叉式关开            LMC-Ex系列
     LVL-A1系列
     LVL-T1系列        LTC系列微波导向式开关
     LVL-S1系列
     LVL-M系列             LUC系列超声波开关
     LVL-M NAMUR系列             LUC4系列
     LVL-MH系列                 LUC-T系列
     LVL-M2C系列
静压式天关
     LKL-P系列导电式开关         LHC系列
     LHC-M系列
     LCL系列电容式开关             PPC系列
     PPC-M系列
     LML系列磁性浸入式开关         LGC系列
NBB1,5-8GM40-A2-V1     NBB1,5-8GM40-E0-V1     NBB1,5-8GM40-E2-V1     NBB1,5-8GM40-Z0     NBB1,5-8GM40-Z1     NBB1,5-8GM50-A0-V1     NBB1,5-8GM50-A2-V1     NBB1,5-8GM50-E0     NBB1,5-8GM50-E0-V3     NBB1,5-8GM50-E2     NBB1,5-8GM50-E2-V3     NBB1,5-8GM50-Z0-V3     NBB1,5-8GM50-Z1-V3     NBB1,5-8GM60-A0     NBB1,5-8GM60-A2     NBB1,5-F41A-E2     NBB1,5-F41A-E2-V3     NBB1,5-F41-E2     NBB1,5-F41-E2-V3     NBB1.5-8GM70-B3/-V1
NBB10-30GK50-E0     NBB10-30GK50-E2     NBB10-30GKK-W?     NBB10-30GKK-WS     NBB10-30GM40-Z0     NBB10-30GM40-Z0-V1     NBB10-30GM40-Z1     NBB10-30GM40-Z1-V1     NBB10-30GM50-E0     NBB10-30GM50-E0-V1     NBB10-30GM50-E2     NBB10-30GM50-E2-C     NBB10-30GM50-E2-C-V1     NBB10-30GM50-E2-V1     NBB10-30GM50-Z0     NBB10-30GM50-Z0-V1     NBB10-30GM60-A0     NBB10-30GM60-A0-V1     NBB10-30GM60-A2     NBB10-30GM60-A2-V1     NBB10-30GM60-W?     NBB10-30GM60-WS
NBB15-30GM30-E2     NBB15-30GM30-E2-V1     NBB15-30GM50-E0     NBB15-30GM50-E0-V1     NBB15-30GM50-E2     NBB15-30GM50-E2-V1     NBB15-L2-A2-C-V1     NBB20+U1A+B3     NBB20+U1A+B3-V1     NBB20+U5A+B3     NBB20+U9A+B3     NBB20-L2-A0-Q2     NBB20-L2-A0-V1     NBB20-L2-A2-C-V1     NBB20-L2-A2-Q2     NBB20-L2-A2-V1     NBB20-L2-B3-V1     NBB20-L2-E0-Q2     NBB20-L2-E0-V1     NBB20-L2-E2-Q2     NBB20-L2-E2-V1
NBB2-12GK50-E0     NBB2-12GK50-E2     NBB2-12GM40-E0     NBB2-12GM40-E2     NBB2-12GM40-Z0  NBB2-12GM40-Z0-V1     NBB2-12GM40-Z1     NBB2-12GM40-Z1-V1     NBB2-12GM50-E0     NBB2-12GM50-E0-V1     NBB2-12GM50-E2     NBB2-12GM50-E2-C     NBB2-12GM50-E2-C-V1     NBB2-12GM50-E2-V1     NBB2-12GM60-A0     NBB2-12GM60-A0-V1     NBB2-12GM60-A2     NBB2-12GM60-A2-V1     NBB2-8GM40-E0-V1     NBB2-8GM40-E2-V1     NBB2-8GM50-E0     NBB2-8GM50-E2     NBB2-V3-E0     NBB2-V3-E0-V5     NBB2-V3-E2     NBB2-V3-E2-V5     NBB2-V3-E3-V5   NBB30+U1A+B3     NBB30+U9A+B3     NBB3-V3-Z4     NBB3-V3-Z4-V5     NBB3-V3-Z5     NBB3-V3-Z5-V5     NBB4-12GM30-E2     NBB4-12GM30-E2-V1     NBB4-12GM50-E0     NBB4-12GM50-E0-V1     NBB4-12GM50-E2     NBB4-12GM50-E2-V1     NBB5-18GK50-E0     NBB5-18GK50-E2     NBB5-18GM40-E2     NBB5-18GM40-Z0     NBB5-18GM40-Z0-V1     NBB5-18GM40-Z1     NBB5-18GM40-Z1-V1     NBB5-18GM50-E0     NBB5-18GM50-E0-V1     NBB5-18GM50-E2     NBB5-18GM50-E2-C     NBB5-18GM50-E2-C-V1     NBB5-18GM50-E2-V1     NBB5-18GM50-Z0     NBB5-18GM50-Z0-V1     NBB5-18GM60-A0     NBB5-18GM60-A0-V1     NBB5-18GM60-A2     NBB5-18GM60-A2-V1     NBB5-18GM60-W?     NBB5-18GM60-WS     NBB5-F33-A2     NBB5-F33-E0     NBB5-F33-E2     NBB5-F33M-A0     NBB5-F33M-A2     NBB5-F33M-E0     NBB5-F33M-E2     NBB5-F9-E0     NBB5-F9-E0-V3     NBB5-F9-E2     NBB5-F9-E2-V3     NBB6-F-B3     NBB8-18GM30-E2-V1     NBB8-18GM50-E0     NBB8-18GM50-E0-V1     NBB8-18GM50-E2     NBB8-18GM50-E2-V1     NBB8-18GM60-A0     NBB8-18GM60-A0-V1     NBB8-18GM60-A2     NBB8-18GM60-A2-V1
NBN10-F10-E0     NBN10-F10-E0-V1     NBN10-F10-E2     NBN10-F10-E2-V1     NBN12-18GM50-E0     NBN12-18GM50-E0-V1     NBN12-18GM50-E2     NBN12-18GM50-E2-V1     NBN15-30GK50-E0     NBN15-30GK50-E2     NBN15-30GKK-W?     NBN15-30GKK-WS     NBN15-30GM40-Z0     NBN15-30GM40-Z0-V1     NBN15-30GM40-Z1     NBN15-30GM40-Z1-V1     NBN15-30GM50-E0     NBN15-30GM50-E0-V1     NBN15-30GM50-E2     NBN15-30GM50-E2-C     NBN15-30GM50-E2-C-V1     NBN15-30GM50-E2-V1     NBN15-30GM50-Z0     NBN15-30GM50-Z0-V1     NBN15-30GM60-A0     NBN15-30GM60-A0-V1     NBN15-30GM60-A2     NBN15-30GM60-A2-V1     NBN15-30GM60-W?     NBN15-30GM60-WS     NBN15-F11-E0     NBN15-F11-E0-V1     NBN15-F11-E2     NBN15-F11-E2-V1     NBN15-M1K-W?     NBN15-M1K-WS     NBN25-30GM50-E0     NBN25-30GM50-E0-V1     NBN25-30GM50-E2     NBN25-30GM50-E2-V1     NBN2-8GM40-E0-V1     NBN2-8GM40-E2-V1     NBN2-8GM40-Z0     NBN2-8GM40-Z1     NBN2-8GM50-A2-V1     NBN2-8GM50-E0     NBN2-8GM50-E0-V3     NBN2-8GM50-E2     NBN2-8GM50-E2-V3     NBN2-8GM50-Z0-V3     NBN2-8GM50-Z1-V3     NBN2-8GM60-A2     NBN30+U5A+B3     NBN30-L2-A0-Q2     NBN30-L2-A0-V1     NBN30-L2-A2-C-V1     NBN30-L2-A2-Q2     NBN30-L2-A2-V1     NBN30-L2-B3-V1     NBN30-L2-E0-Q2     NBN30-L2-E0-V1     NBN30-L2-E2-Q2     NBN3-F25-E8     NBN3-F25-E8-0,14     NBN3-F25-E8-K     NBN3-F25-E8-K1V1     NBN3-F25-E8-V1     NBN3-F25F-E8-V1     NBN3-F25F-Z8-V1     NBN3-F25L-E2     NBN3-F25L-E2-V1     NBN3-F25R-E2     NBN3-F25R-E2-V1     NBN3-F25-Z8     NBN3-F25-Z8-0.14     NBN3-F25-Z8-K1V1     NBN3-F25-Z8-V1     NBN3-F31-E8-K     NBN3-F31-E8-K-K     NBN3-F31-E8-V1     NBN3-F31-E8-V18     NBN3-F31K-E8     NBN3-F31K-E8-K     NBN3-F31K-E8-V1-V1     NBN3-F31K-Z8     NBN3-F31K-Z8-K     NBN3-F31K-Z8-V1-V1     NBN3-F31-Z8-K     NBN3-F31-Z8-K-K     NBN3-F31-Z8-V1     NBN3-F31-Z8-V18     NBN40+U1A+B3     NBN40+U1A+B3-V1     NBN40+U5A+B3     NBN40+U9A+B3     NBN40-L2-A0-Q2     NBN40-L2-A0-V1     NBN40-L2-A2-Q2     NBN40-L2-A2-V1     NBN40-L2-B3-V1     NBN40-L2-B3-V1-     NBN40-L2-E0-V1     NBN40-L2-E2-Q2     NBN40-L2-E2-V1     NBN4-12GK50-E0     NBN4-12GK50-E2     NBN4-12GM40-E0     NBN4-12GM40-Z0     NBN4-12GM40-Z0-V1     NBN4-12GM40-Z1     NBN4-12GM40-Z1-V1     NBN4-12GM50-E0     NBN4-12GM50-E0-V1     NBN4-12GM50-E2     NBN4-12GM50-E2-C     NBN4-12GM50-E2-C-V1     NBN4-12GM50-E2-V1     NBN4-12GM60-A0     NBN4-12GM60-A0-V1     NBN4-12GM60-A2     NBN4-12GM60-A2-V1     NBN4-F29A-E2-C     NBN4-F29-E0     NBN4-F29-E2     NBN8-18GK50-E0     NBN8-18GK50-E2     NBN8-18GM40-Z0     NBN8-18GM40-Z0-V1     NBN8-18GM40-Z1     NBN8-18GM40-Z1-V1     NBN8-18GM50-E0     NBN8-18GM50-E0-V1     NBN8-18GM50-E2     NBN8-18GM50-E2-C     NBN8-18GM50-E2-C-V1     NBN8-18GM50-E2-V1     NBN8-18GM50-Z0     NBN8-18GM50-Z0-V1     NBN8-18GM60-A0     NBN8-18GM60-A0-V1     NBN8-18GM60-A2     NBN8-18GM60-A2-V1     NBN8-18GM60-W?     NBN8-18GM60-WS
NBB1.5-F41-E2-V3    NBB10-30GM50-E2    NBB10-F11-E0-Y88858    NBB2-12GM60-A2    NBB4-12GM50-E0    NBB5-F33-E0    NBN15-30GM40-Z0    NBN40-L2-E2-V1    NBN4-12GM40-Z0    NBN4-12GM50-E0    NBN8-18GM40-Z0    NCB10-30GM40-NO    NCN15-30GM40-NO    NCN15-M1K-E4    NCN30+U1+Z2
NCB1,5-8GM25-N0-     NCB1,5-8GM25-N0 10M     NCB1,5-8GM25-N0 5M     NCB10-30GM40-N0 10M     NCB10-30GM40-N0 15M     NCB10-30GM40-N0 5M     NCB10-30GM40-N0-V1     NCB10-30GM40-N0-V1-     NCB10-30GM60-Z0  NCB10-30GM60-Z1     NCB10-30GM60-Z1-V1     NCB10-30GM70-B3     NCB10-30GM70-B3-     NCB10-30GM70-B3-V1     NCB10-30GM70-B3-V1-     NCB10-F17-E2     NCB15+U1+N0     NCB15+U1+U     NCB15+U1+Z2     NCB2-12GM35-N0     NCB2-12GM35-N0-     NCB2-12GM35-N0 10M     NCB2-12GM35-N0 21M     NCB2-12GM35-N0 5M     NCB2-12GM35-N0-V1     NCB2-12GM40-Z0     NCB2-12GM40-Z0-V1     NCB2-12GM40-Z1     NCB2-12GM40-Z1-V1     NCB2-12GM60-B3     NCB2-12GM60-B3_V1     NCB2-F1-N0     NCB40-FP-N0-P1     NCB5-18GM40-N0     NCB5-18GM40-N0-     NCB5-18GM40-N0 10M     NCB5-18GM40-N0 5M     NCB5-18GM40-N0-V1     NCB5-18GM40-N0-V1-     NCB5-18GM60- B3     NCB5-18GM60- B3-V1     NCB5-18GM60-Z0     NCB5-18GM60-Z0-V1     NCB5-18GM60-Z1     NCB5-18GM60-Z1-V1     NCN100-F23-E2-V1     NCN15-30GM40-N0     NCN15-30GM40-N0-     NCN15-30GM40-N0 10M     NCN15-30GM40-N0-V1     NCN15-30GM60-Z0     NCN15-30GM60-Z0-Z1     NCN15-30GM60-Z1     NCN15-30GM60-Z1-V1     NCN15-30GM70-B3     NCN15-30GM70-B3-     NCN15-30GM70-B3-V1     NCN15-30GM70-B3-V1-     NCN15-M1A-B3     NCN15-M1K-E4     NCN15-M1K-E5     NCN15-M1K-N0     NCN15-M1K-Z2     NCN20+U1+N0     NCN20+U1+U     NCN20+U1+Z2     NCN30+U1+N0     NCN30+U1+U     NCN30+U1+Z2     NCN3-F25F-N4-V1     NCN3-F25-N4     NCN3-F25-N4-0,14     NCN3-F25-N4-K     NCN3-F25-N4-V1     NCN3-F31K-B3-V1-K     NCN3-F31K-N4     NCN3-F31K-N4-K     NCN3-F31K-N4-V1-V1     NCN3-F31-N4-K     NCN3-F31-N4-K-K     NCN3-F31-N4-V16-V16     NCN3-F31-N4-V18     NCN3-F31-V16-K     NCN40+U1+A0     NCN40+U1+A2     NCN40+U1+E0     NCN40+U1+E2     NCN40+U1+N0     NCN40+U1+U     NCN40+U1+Z2     NCN40+U1M+A2     NCN4-12GM35-N0     NCN4-12GM35-N0 10M     NCN4-12GM35-N0 5M     NCN4-12GM35-N0-V1     NCN4-12GM35-N0-V1-     NCN4-12GM40-Z0     NCN4-12GM40-Z0-V1     NCN4-12GM40-Z1     NCN4-12GM40-Z1-V1     NCN4-12GM60-B3     NCN4-12GM60-B3-V1     NCN50-FP-N0-P1     NCN8-18GM40-N0     NCN8-18GM40-N0-     NCN8-18GM40-N0 5M     NCN8-18GM40-N0-V1     NCN8-18GM40-N0-V1-     NCN8-18GM60-B3     NCN8-18GM60-B3-V1     NCN8-18GM60-Z0     NCN8-18GM60-Z0-V1     NCN8-18GM60-Z1     NCN8-18GM60-Z1-V1     NEB12-18GM50-E2     NEB12-18GM50-E2-V1     NEB12-18GM50-E-V1     NEB3-8GM45-E     NEB3-8GM45-E2     NEB3-8GM50-E2-V3     NEB3-8GM50-E-V3     NEB6-12GM50-E2     NEB6-12GM50-E2-V1     NEN10-12GM50-E2-V1     NEN20-18GM50-E2-V1     NEN40-30GM50-E2-V1     NEN6-8GM45-E2-V1
 NCB10-30GM60-Z0-V1
NJ0,2-10GM-N     NJ0,6-3-22-E     NJ0,6-3-22-E2     NJ0,6-4GM22-E     NJ0,6-4GM22-E2     NJ0,8-4,5-N     NJ0,8-4,5-N-     NJ0,8-4,5-N-Y28554     NJ0,8-4-25-E     NJ0,8-5GM25-E     NJ0,8-5GM-N     NJ0,8-5GM-N-     NJ0,8-5GM-N 10M     NJ0,8-5GM-N-Y18620     NJ1,5-18GM-E2-D     NJ1,5-18GM-N-D     NJ1,5-18GM-N-D-V1     NJ1,5-6,5-40-E2     NJ1,5-6,5-40-E2-V3     NJ1,5-6,5-50-E     NJ1,5-6,5-N     NJ1,5-6,5-N 15M     NJ1,5-6,5-N 5M     NJ1,5-6,5-N-Y10324     NJ1,5-8GM40-E2     NJ1,5-8GM40-E2-V1     NJ1,5-8GM40-E2-V3     NJ1,5-8GM40-E-V1     NJ1,5-8GM40-W?     NJ1,5-8GM40-WS     NJ1,5-8GM50-E     NJ1,5-8GM-N     NJ1,5-8GM-N 10M     NJ1,5-8GM-N 5M     NJ1,5-8GM-N-V1     NJ1,5-F2-E2     NJ1,5-F2-E2-V1     NJ1,5-F-N     NJ10-22-N     NJ10-22-N-G     NJ10-30GK50-E     NJ10-30GK50-E2     NJ10-30GKK-A     NJ10-30GKK-A2     NJ10-30GKK-N     NJ10-30GK-N     NJ10-30GK-SN     NJ10-30GM50-A2     NJ10-30GM50-A2-V1     NJ10-30GM50-E     NJ10-30GM50-E2     NJ10-30GM50-E2-V1     NJ10-30GM-N     NJ10-30GM-N-     NJ10-30GM-N 10M     NJ10-30GM-N 5M     NJ10-30GM-N-V1     NJ10-30GM-N-V1-     NJ10-36-E2-G/EX     NJ10-36-E-G/EX     NJ10-36-W? G/EX     NJ10-36-WS-G/EX     NJ15/2+U1+E8-V1     NJ15+U1+2E2-NE/FE     NJ15+U1+A     NJ15+U1+A2     NJ15+U1+DW1-1     NJ15+U1+DW1-10     NJ15+U1+DW1-100     NJ15+U1+DW2-1     NJ15+U1+DW2-10     NJ15+U1+DW2-100     NJ15+U1+E     NJ15+U1+E1     NJ15+U1+E2     NJ15+U1+E3     NJ15+U1+N     NJ15+U1+N-Z10     NJ15+U1+W     NJ15+U10+A2     NJ15+U10+E2     NJ15+U1M+A2     NJ15+U1M+E2     NJ15-30GK50-E     NJ15-30GK50-E2     NJ15-30GKK-A     NJ15-30GKK-A2     NJ15-30GKK-N     NJ15-30GK-N     NJ15-30GK-N-150     NJ15-30GK-SN     NJ15-30GM50-A2     NJ15-30GM50-A2 5m     NJ15-30GM50-A2-V1     NJ15-30GM50-E     NJ15-30GM50-E2     NJ15-30GM50-E2-V1     NJ15-30GM-N     NJ15-30GM-N-     NJ15-30GM-N 10M     NJ15S+U1+N     NJ20+U1+A     NJ20+U1+A2     NJ20+U1+E     NJ20+U1+E1     NJ20+U1+E2     NJ20+U1+E2-C     NJ20+U1+E3     NJ20+U1+N     NJ20+U1+W     NJ20+U10+A2     NJ20+U10+E2     NJ20+U1M+A2     NJ20+U1M+E2     NJ20-40-A     NJ20-40-A2     NJ20-40-N     NJ20-40-W     NJ20P+U1+A2     NJ20S+U1+N     NJ2-11-N     NJ2-11-N-G     NJ2-11-SN     NJ2-11-SN-G     NJ2-12GK40-E     NJ2-12GK40-E2     NJ2-12GK-N     NJ2-12GK-SN  NJ2-12GM40-E     NJ2-12GM40-E2     NJ2-12GM40-E2-V1     NJ2-12GM40-E-V1     NJ2-12GM50-W V13     NJ2-12GM50-W?     NJ2-12GM50-WS     NJ2-12GM50-WS-V13     NJ2-12GM-N     NJ2-12GM-N-     NJ2-12GM-N 10M     NJ2-12GM-N 21M     NJ2-12GM-N 5M     NJ2-12GM-N-V1     NJ2-12GM-N-V1-     NJ25-50-E2     NJ25-50-N     NJ25-50-W?     NJ25-50-WS     NJ2-6,5-40-E2     NJ2-6,5-40-E2-V3     NJ2-6,5-50-E     NJ2-6,5-50-E-V3     NJ2-8GM40-E2     NJ2-8GM40-E2-V1     NJ2-8GM50-E     NJ2-8GM50-E-V3     NJ2-F1-E     NJ2-F1-E2     NJ2-F1-E2-V3     NJ2-F1-U?     NJ2-F1-US     NJ2-V3-N     NJ2-V3-N-V5     NJ30+U1+A     NJ30+U1+A2     NJ30+U1+E     NJ30+U1+E1     NJ30+U1+E2     NJ30+U1+E3     NJ30+U1+N     NJ30+U1+W     NJ30+U10+E2     NJ30+U1M+A2     NJ30+U1M+E2     NJ30P+U1+A2     NJ3-18GK-S1N     NJ40+U1+A     NJ40+U1+A2     NJ40+U1+E     NJ40+U1+E2     NJ40+U1+E2-C     NJ40+U1+N     NJ40+U1+W     NJ40+U10+E2     NJ40-FP-A2-B1-P1     NJ40-FP-SN-P1     NJ40-FP-W-B1-P1     NJ40P-FP-A2-P1     NJ4-12GK40-E     NJ4-12GK40-E2     NJ4-12GK-N     NJ4-12GK-SN     NJ4-12GM40-E     NJ4-12GM40-E2     NJ4-12GM40-E2-V1     NJ4-12GM40-E-V1     NJ4-12GM50-W V13     NJ4-12GM50-W?     NJ4-12GM50-WS     NJ4-12GM50-WS-20M     NJ4-12GM50-WS-V13     NJ4-12GM-N     NJ4-12GM-N 10M     NJ4-12GM-N 20M     NJ4-12GM-N 5M     NJ4-12GM-N-V1     NJ4-12GM-N-V1-     NJ4-30GM-N-200     NJ4-F1-E2-V3     NJ4-F1-U+A697     NJ4-F1-US     NJ50-FP-A2-P1     NJ50-FP-A-P1     NJ50-FP-N-P1     NJ50-FP-W-P1     NJ5-11-N     NJ5-11-N-G     NJ5-18GK50-E     NJ5-18GK50-E2     NJ5-18GK50-N     NJ5-18GK50-N-150     NJ5-18GK50-SN     NJ5-18GM50-A2     NJ5-18GM50-A2-V1     NJ5-18GM50-E     NJ5-18GM50-E2     NJ5-18GM50-E2-V1     NJ5-18GM50-E-V1     NJ5-18GM-N     NJ5-18GM-N-V1     NJ5-18GM-N-Z10     NJ5-30GK-S1N     NJ6-22-N     NJ6-22-N-G     NJ6-22-SN     NJ6-22-SN-G     NJ6-25-E2-G/EX     NJ6-25-E-G/EX     NJ6-25-W?-G/EX     NJ6-25-WS-G/EX     NJ6-F-A     NJ6-F-A2     NJ6-F-E     NJ6-F-E2     NJ6-F-N     NJ6S1+U1+N1     NJ8-18GK50-E     NJ8-18GK50-E2     NJ8-18GK-N     NJ8-18GK-N-150     NJ8-18GK-SN     NJ8-18GM50-A2     NJ8-18GM50-A2-V1     NJ8-18GM50-E     NJ8-18GM50-E2     NJ8-18GM50-E2-V1     NJ8-18GM50-E-V1     NJ8-18GM-N     NJ8-18GM-N-     NJ8-18GM-N-V1
UB1000+FP1+E6     UB2000-30GM-E4-V15     UB2000-30GM-E5-V15     UB2000-30GM-H1     UB2000-30GM-H2     UB2000-30GM-H3     UB2000-F42-E4-V15     UB2000-F42-E5-V15     UB2000-F42-E6-V15     UB2000-F42-E7-V15     UB2000-F42-I-V15     UB2000-F42S-E4-V15     UB2000-F42S-E5-V15     UB2000-F42S-E6-V15     UB2000-F42S-E7-V15     UB2000-F42S-I-V15     UB2000-F42S-U-V15     UB2000-F42-U-V15     UB2000-F54-E4-V15     UB2000-F54-E5-V15     UB2000-F54-I-V15     UB2000-F54-U-V15     UB3000+U9+H3     UB4000-30GM-E4-V15     UB4000-30GM-E5-V15     UB4000-30GM-H3     UB4000-F42-E4-V15     UB4000-F42-E5-V15     UB4000-F42-E6-V15     UB4000-F42-E7-V15     UB4000-F42-I-V15     UB4000-F42-U-V15     UB500+U9+H3     UB500-18GM75-E01-V15     UB500-18GM75-E23-V15     UB500-18GM75-E4-V15     UB500-18GM75-E5-V15     UB500-18GM75-E6-V15     UB500-18GM75-E7-V15     UB500-18GM75-I-V15     UB500-18GM75-U-V15     UB500-30GM75-E4-V15     UB500-30GM75-E5-V15     UB500-30GM-E4-V15     UB500-30GM-E5-V15     UB500-30GM-H3     UB500-F42-E4-V15     UB500-F42-E5-V15     UB500-F42-E6-V15     UB500-F42-E7-V15  UB500-F42-I-V15     UB500-F42S-E4-V15     UB500-F42S-E5-V15     UB500-F42S-E6-V15     UB500-F42S-E7-V15     UB500-F42S-I-V15     UB500-F42S-U-V15     UB500-F42-U-V15     UB500-F54-E4-V15     UB500-F54-E5-V15     UB500-F54-H3-V1     UB500-F54-I-V15     UB500-F54-U-V15     UB6000-30GM-E4-V15     UB6000-30GM-E5-V15     UB6000-30GM-H3     UB6000-FP-H3     UBE1500-F64-SE0     UBE1500-F64-SE0-V3     UBE1500-F64-SE2     UBE1500-F64-SE2-V3     UBE4000-30GM-SA2-V1     UBE500-18GK-SE0-V1     UBE500-18GK-SE2-V1     UBE500-18GK-V1     UBE500-F64-SE0     UBE500-F64-SE0-V3     UBE500-F64-SE2     UBE500-F64-SE2-V3     UC1000-30GM-E6-K-V1     UC1000-30GM-E6R2-K-V15     UC1000-30GM-IUR2-K-V15     UC1000-30GM-IU-V1-Y104638     UC2000-30GM-E6R2-V15     UC2000-30GM-E7R2-V15     UC2000-30GM-IUR2-V15     UC2000-F43-2KIR2-V17     UC3000+U9+E6+R2     UC3000+U9+E7+R2     UC3000+U9+IUE0+R2     UC3000+U9+IUE2+R2     UC300-30GM-E6R2-K-V15     UC300-30GM-IUR2-K-V15     UC300-30GM-IU-V1     UC300-F43-2KIR2-V17     UC4000-30GM-E6R2-V15     UC4000-30GM-E7R2-V15     UC4000-30GM-IUR2-V15     UC500+U9+E6+R2     UC500+U9+IUE2+R2     UC500-30GM-E6R2-V15     UC500-30GM-E7R2-V15     UC500-30GM-IUR2-V15     UC500-D1-3K-V7     UC6000-30GM-E6R2-V15     UC6000-30GM-E7R2-V15     UC6000-30GM-IUR2-V15     UC6000-FP-E6-R2-P5     UC6000-FP-E7-R2-P5     UC6000-FP-IUE0+R2-P5     UC6000-FP-IUE2+R2-P5     UCC1000-30GM-E6-V1     UCC1000-30GM-IU-V1     UDB-18GM35-2E2     UDB-18GM35-3E2     UDB-18GM35-4E2     UDBK-18GM35-3E2     UDBL-18GM35-3E2     UJ3000+U1+8B+RS     UJ4000-FP-8B     UJ4000-FP-E2-P1     UJ6000-FP-8B+RS
RL23-8-H-1000-IR/100a/125     RL23-8-H-1000-IR/104/116/125     RL23-8-H-1000-IR/116/125     RL23-8-H-1000-IR/47/74a     RL23-8-H-1000-IR/47/74a/104     RL23-8-H-1000-IR/47/92     RL23-8-H-1000-IR/47/92/104     RL23-8-H-1000-IR/49/74a     RL23-8-H-1000-IR/49/74a/104     RL23-8-H-1000-IR/49/92     RL23-8-H-1000-IR/49/92/104     RL23-8-H-1000-IR-AS-1/116     RL23-8-H-2000-IR/100a/104/125     RL23-8-H-2000-IR/100a/125     RL23-8-H-2000-IR/104/116/125     RL23-8-H-2000-IR/116/125     RL23-8-H-2000-IR/47/74a     RL23-8-H-2000-IR/47/74a/104     RL23-8-H-2000-IR/47/92     RL23-8-H-2000-IR/47/92/104     RL23-8-H-2000-IR/49/74a     RL23-8-H-2000-IR/49/74a/104     RL23-8-H-2000-IR/49/92     RL23-8-H-2000-IR/49/92/104     RL23-8-H-2000-IR-AS-1/116     RL23-8-H-500-RT/100a/104/125     RL23-8-H-500-RT/100a/125     RL23-8-H-500-RT/104/116/125     RL23-8-H-500-RT/116/125     RL23-8-H-500-RT/47/74a     RL23-8-H-500-RT/47/74a/104     RL23-8-H-500-RT/47/92     RL23-8-H-500-RT/47/92/104     RL23-8-H-500-RT/49/74a     RL23-8-H-500-RT/49/74a/104     RL23-8-H-500-RT/49/92     RL23-8-H-500-RT/49/92/104     RL25/35/47/116     RL25/35/47/74a     RL25/35/47/92     RL25/35/49/116     RL25/35/49/74a     RL25/35/49/92     RL25/47/116     RL25/47/74a     RL25/47/92     RL25/49/116     RL25/49/74a     RL25/49/92     RL25-8-2000/47/116     RL25-8-2000/47/74a     RL25-8-2000/47/92     RL25-8-2000/49/116     RL25-8-2000/49/74a     RL25-8-2000/49/92     RL25-8-2000/AS-I     RL25-8-800/47/116     RL25-8-800/47/74a     RL25-8-800/47/92     RL25-8-800/49/116     RL25-8-800/49/74a     RL25-8-800/49/92     RL25-8-800/ASI     RL25-8-H-300/47/116  RL25-8-H-300/47/74     RL25-8-H-300/47/92     RL25-8-H-300/48/116     RL25-8-H-300/48/74     RL25-8-H-300/48/92     RL25-8-H-300/49/116     RL25-8-H-300/49/74     RL25-8-H-300/49/92     RL25-AS-I     RL25-AS-I/35     RL28-55/30/47/76a     RL28-55/32/47/76a     RL28-55/47/74     RL28-55/47/76a/105     RL28-55/47/76a/115     RL28-55/47/82b/105     RL28-55/47/82b/115     RL28-55/48/74     RL28-55/48/76a/105     RL28-55/48/76a/115     RL28-55/48/82b/105     RL28-55/48/82b/115     RL28-55/49/74     RL28-55/49/76a/105     RL28-55/49/76a/115     RL28-55/49/82b/105     RL28-55/49/82b/115     RL28-55/74/76a/110     RL28-55/74/82b/110     RL28-55/76a/82b/105/110     RL28-55/76a/82b/110/115     RL28-55/82b/110/115     RL28-55-V/30/74/76a     RL28-55-V/32/74/76a     RL28-55-V/32/76a/105     RL28-55-V/47/74     RL28-55-V/47/76a/105     RL28-55-V/47/76a/115     RL28-55-V/47/82b/105     RL28-55-V/47/82b/115     RL28-55-V/48/74     RL28-55-V/48/76a/105     RL28-55-V/48/76a/115     RL28-55-V/48/82b/105     RL28-55-V/48/82b/115     RL28-55-V/49/74     RL28-55-V/49/76a/105     RL28-55-V/49/76a/115     RL28-55-V/49/82b/105     RL28-55-V/49/82b/115     RL28-55-V/74/76a/110     RL28-55-V/74/82b/110     RL28-55-V/76a/82b/105/110     RL28-55-V/76a/82b/110/115     RL28-55-V/82b/105/110     RL28-55-V/82b/110/115     RL28-8-H-2000-IR/105/110     RL28-8-H-2000-IR/110/115     RL28-8-H-2000-IR/47/105     RL28-8-H-2000-IR/47/115     RL28-8-H-2000-IR/47/74     RL28-8-H-2000-IR/48/105     RL28-8-H-2000-IR/48/115     RL28-8-H-2000-IR/48/74     RL28-8-H-2000-IR/49/105     RL28-8-H-2000-IR/49/115     RL28-8-H-2000-IR/49/74     RL28-8-H-2000-IR/74/110     RL28-8-H-400-IR/105/110     RL28-8-H-400-IR/110/115     RL28-8-H-400-IR/47/105     RL28-8-H-400-IR/47/115     RL28-8-H-400-IR/47/74     RL28-8-H-400-IR/48/105     RL28-8-H-400-IR/48/115     RL28-8-H-400-IR/48/74     RL28-8-H-400-IR/49/105     RL28-8-H-400-IR/49/115     RL28-8-H-400-IR/49/74     RL28-8-H-400-IR/74/110     RL28-8-H-400-RT/105/110     RL28-8-H-400-RT/110/115     RL28-8-H-400-RT/47/105     RL28-8-H-400-RT/47/115     RL28-8-H-400-RT/47/74     RL28-8-H-400-RT/48/105     RL28-8-H-400-RT/48/115     RL28-8-H-400-RT/48/74     RL28-8-H-400-RT/49/105     RL28-8-H-400-RT/49/115     RL28-8-H-400-RT/49/74     RL28-8-H-400-RT/74/110     RL28-8-H-700-IR/105/110     RL28-8-H-700-IR/110/115     RL28-8-H-700-IR/47/105     RL28-8-H-700-IR/47/115     RL28-8-H-700-IR/47/74     RL28-8-H-700-IR/48/105     RL28-8-H-700-IR/48/115     RL28-8-H-700-IR/48/74     RL28-8-H-700-IR/49/105     RL28-8-H-700-IR/49/115     RL28-8-H-700-IR/49/74     RL28-8-H-700-IR/74     RL28-8-H-700-IR/74/110     RL28-8-H-700-RT/105/110     RL28-8-H-700-RT/110/115     RL28-8-H-700-RT/47/105     RL28-8-H-700-RT/47/115     RL28-8-H-700-RT/48/105     RL28-8-H-700-RT/48/115     RL28-8-H-700-RT/48/74     RL28-8-H-700-RT/49/105     RL28-8-H-700-RT/49/115     RL28-8-H-700-RT/49/74     RL28-8-H-700-RT/74/110     RL32-54/47/73c     RL32-55/47/73c     RL32-55-V-2450/47/73c     RL32-8-800/47/73c     RL32-8-H-400-2482/47/73c     RL32-8-H-800/47/73c     RL36-55-Ex/40b/116     RL36-8-2000-Ex/40b/116     RL39-54/30/40a/82a/116     RL39-54/32/40a/82a/116     RL39-54-AS-1/116     RL39-54-AS-1/73c     RL39-8-800/30/40a/82b/116     RL39-8-800/32/40a/82b/116     RL39-8-800-AS-1/116     RL39-8-800-AS-1/73c     RL5-LL/37/92     RL5-LL-1773     RL91-54-RT/25/38a/115     RL91-54-RT/25/38a/73c     RL91-54-RT/25/49/115     RL91-54-RT/25/49/73c     RL91-54-RT/38a/59/115     RL91-54-RT/38a/59/73c     RL91-54-RT/49/59/115     RL91-54-RT/49/5973c     RL91-6-IR/25/38a/115     RL91-6-IR/25/38a/73c     RL91-6-IR/25/49/115     RL91-6-IR/25/49/73c     RL91-6-IR/38a/59/115     RL91-6-IR/38a/59/73c     RL91-6-IR/49/59/115     RL91-6-IR/49/5973c     RLF21-54-1419/44/47/74     RLF21-8-800/1419/44/47/74     RLK21-54     RLK21-6     RLK21-8-800     RLK21-8-H-80     RLK23-8-H-1000-IR/31/100d     RLK23-8-H-1000-IR/31/100d/104     RLK23-8-H-1000-IR/31/104/116     RLK23-8-H-1000-IR/31/116     RLK23-8-H-2000-IR/31/100d     RLK23-8-H-2000-IR/31/100d/104     RLK23-8-H-2000-IR/31/104/116     RLK23-8-H-2000-IR/31/116     RLK23-8-H-500-RT/31/100d     RLK23-8-H-500-RT/31/116     RLK24-54/100D     RLK24-54/100D/104     RLK24-54/104/116     RLK24-54/106/116     RLK24-54/116     RLK24-55/100D     RLK24-55/100D/104     RLK24-55/104/116     RLK24-55/106/116     RLK24-55/116     RLK24-8-2000/100D     RLK24-8-H-150/100D     RLK24-8-H-150/116     RLK24-8-H-80/100D     RLK24-8-H-80/116     RLK25/116     RLK25/35/116     RLK25-8-2000/116     RLK25-8-800/116     RLK28-55/31/116     RLK28-55-Z/31/116      RLK29-55/25/116     RLK29-55/59/116     RLK39-54/31/40a/116     RLK39-54-Z/31/40a/116     RLK39-8-800/31/40a/116     RLK39-8-800-Z/31/40a/116     RLK91-54-RT/25/38a/115     RLK91-54-RT/38a/59/115     RLK91-6-IR/25/38a/115     RLK91-6-IR/38a/59/115     RL-UV3/32/92     RL-UV3/45/115     RL-UV3/H/9s/32/92     RL-UV4/32/92
M11/MV11/47/76a/112     M11/MV11/48/76a/112     M11/MV11-E/47/76a/112     M11/MV11-E/48/76b/112     M11/MV11-Ex/40b/112     M12/MV12-F1/76a/82b/115/128     M12/MV12-F1/76a/82b/124/128     M12/MV12-F1/76a/82b/95/128     M13/MV13/30/40b/115     M13/MV13/30/40b/73c     M13/MV13/30/40b/95     M13/MV13/32/40b/115     M13/MV13/32/40b/73c     M13/MV13/32/40b/95     M15/MV15/47/95     M15/MV15/48/95     M15/MV15/82b/95/103     M4.1/MV4.1/40b/95/110     M40/MV40-1365/47/115     M40/MV40-1365/47/92     M40/MV40-1365/48/115     M40/MV40-1365/48/92     M40/MV40-1365/49/115     M40/MV40-1365/49/92     M5/MV5/30/115     M5/MV5/32/115     M5/MV5-RT/30/115     M5/MV5-RT/32/115     ML4.1-54-F/40b/95/110     ML4.1-54-F/82b/95/110     ML4.1-8-400/40b/95/110     ML4.1-8-H-20-IR/95/110     ML4.1-8-H-20-RT/95/110     ML4.1-8-H-40-IR/95/110     ML4.1-8-H-40-RT/95/110     ML4.1-8-H-60-IR/95/110     ML4.1-8-H-60-RT/95/110     ML4.1-8-H-80-IR/95/110     ML5-54/30/115     ML5-54/32/115     ML5-6/30/115     ML5-6/32/115     ML5-6-RT/30/115     ML5-6-RT/32/115     ML5-8-400/30/115     ML5-8-400/32/115     MLV11-54/47/112     MLV11-54/48/112     MLV11-54-AS-I/112     MLV11-54-E/47/112     MLV11-54-E/48/112     MLV11-54-E-LAS/47/112     MLV11-54-Ex/40b/112     MLV11-54-G/47/112     MLV11-54-G/48/112     MLV11-54-G-AS-1/47/112     MLV11-54-G-E/47/112     MLV11-54-G-E/48/112     MLV11-54-LAS/47/112     MLV11-54-LAS/48/112     MLV11-8-500/47/112     MLV11-8-500/48/112     MLV11-8-500-AS-1/112     MLV11-8-500-Ex/40b/112     MLV11-8-E-500/47/112     MLV11-8-E-500/48/112     MLV11-8-E-500/4X/112     MLV11-8-H-150/47/76a/65a/112     MLV11-8-H-150/48/76a/65a/112     MLV11-8-H-E-150/47/76a/65a/112     MLV11-8-H-E-150/48/76a/65a/112     MLV11-8-LAS-150/47/112     MLV11-8-LAS-150/48/112     MLV11-8-LAS-150-AS-I/112     MLV11-8-LAS-300/47/112     MLV11-8-LAS-300/48/112     MLV11-8-LAS-300-AS-I/112     MLV11-LL-G/47/76a/112     MLV11-LL-G/48/76b/112     MLV11-LL-K/47/76a/112     MLV11-LL-K/47/76b/112     MLV12-54/32/82b/124     MLV12-54/47/124     MLV12-54/47/92     MLV12-54/49/124     MLV12-54/76b/115/128     MLV12-54/76b/124/128     MLV12-54/76b/95/128     MLV12-54-G/30/124/126g     MLV12-54-G/30/82g/124     MLV12-54-G/76b/115/128     MLV12-54-G/76b/124/128     MLV12-54-G/76b/95/128     MLV12-8-H-250-IR/65b/124/128     MLV12-8-H-250-RT/47/65b/124     MLV12-8-H-250-RT/47/65b/92     MLV12-8-H-250-RT/47/65b/95     MLV12-8-H-250-RT/65b/115/128     MLV12-8-H-250-RT/65b/124/128     MLV12-8-H-250-RT/65b/95/128     MLV13-54/30/40b/115     MLV13-54/30/40b/73c     MLV13-54/30/40b/95     MLV13-54/32/40b/115     MLV13-54/32/40b/73c     MLV13-54/32/40b/95     MLV13-8-400/30/40b/115     MLV13-8-400/30/40b/73c     MLV13-8-400/30/40b/95     MLV13-8-400/32/40b/115     MLV13-8-400/32/40b/73c     MLV13-8-400/32/40b/95     MLV15-54//47/95     MLV15-54//48/95     MLV15-54//82b/95/103     MLV15-6//82b/95/103     MLV15-6/47/95     MLV15-6/48/95     MLV15-8-300/47/95     MLV15-8-300/48/95     MLV15-8-300/82b/95/103     MLV40-54/40b/49/115     MLV40-54/47/115     MLV40-54/47/92     MLV40-54/48/92     MLV40-54/48115     MLV40-54/49/92     MLV40-54-1424     MLV40-54-G/40a/47/115     MLV40-54-G/40a/47/92     MLV40-54-G/40a/48/115     MLV40-54-G/40a/48/92     MLV40-54-G/40a/49/115     MLV40-54-G/40a/49/92     MLV40-54-G-1700     MLV40-6/40b/49/115     MLV40-6/47/115     MLV40-6/47/92     MLV40-6/48/115     MLV40-6/48/92     MLV40-6/49/92     MLV40-8-500/47/115     MLV40-8-500/47/92   MLV40-8-500/48/115     MLV40-8-500/48/92     MLV40-8-500/49/115     MLV40-8-500/49/92     MLV40-8-H-150-65/40a/47/115     MLV40-8-H-150-65/40a/47/92     MLV40-8-H-150-65/40a/48/115     MLV40-8-H-150-65/40a/48/92     MLV40-8-H-150-65/49/115     MLV40-8-H-150-65/49/92     MLV40-8-H-80/47/115     MLV40-8-H-80/47/92     MLV40-8-H-80/48/115     MLV40-8-H-80/48/92     MLV40-8-H-80/49/115     MLV40-8-H-80/49/92     MLV40-LL-IR/47/115     MLV40-LL-IR/47/92     MLV40-LL-IR/48/115     MLV40-LL-IR/48/92     MLV40-LL-IR/49/115     MLV40-LL-IR/49/92     MLV40-LL-RT/47/115     MLV40-LL-RT/47/92     MLV40-LL-RT/48/115     MLV40-LL-RT/48/92     MLV40-LL-RT/49/115     MLV40-LL-RT/49/92
上海配克 胡海涛 13853163389   QQ:250965738  欢迎新老客户来电洽谈!!展望合作!!!
优价供应倍加福P+F编码器,P+F传感器,P+F安全栅系
P+F KFD2-CD-EX1.32
P+F KFD2-STC4-EX1
P+F kfd2-pt2-ex1-5
P+F RVI178-10CALA31N-01500
P+F NEB6-12GM50-E2-V1
P+F KFD2-HMM-16
P+F KFD0-HMS-16
P+F K-HM14扁平电缆
P+F K-HM26扁平电缆
P+F FL-DO-Y37023
P+F KFU8-UFC-Ex1.D
P+F KFD2-VR4-EX1.26
P+F KFD2-RR-EX1
P+F KFA5-SR2-EX2.W
P+F KFA6-SR2-EX1.W.LB
P+F KFA6-SR2-Ex2.W
P+F KFD2-EB2.B
P+F KFD2-PT2-EX1
P+F KFD2-SR2-EX1.W
P+F KFD2-SR2-EX2 W
P+F KFD2-ST2-EX2
P+F KFD2-STC4-EX1
P+F KFD2-STC4-EX2
P+F KFD2-UFC-EX1.D
P+F KFD2-UT2-EX1
P+F KFD2-UT2-EX2
P+F KFU8-FSSP-1.D
P+F KFU8-UFC-EX1.D
P+F KT10-6-M4
P+F KW-10/10
P+F LA39/LK39/31/40A/116
P+F LFL3-BK-U-PVC10
P+F,NBB2,NBB4,NBN4,NJ4,NBB5,NBN8,NBB10,NBN15,NBB15等系列
P+F NBN4-12GK50-E0
P+F NBN4-12GK50-E2
P+F NBN4-12GM40-E0
P+F NBN4-12GM40-E0-V1
P+F NBN4-12GM40-E2
P+F NBN4-12GM40-E2-V1
P+F NBN4-12GM40-Z0
P+F NBN4-12GM40-Z0-V1
P+F NBN4-12GM40-Z3-V1
P+F NBN4-12GM50-E0
P+F NBN4-12GM50-E0-V1
P+F NBN4-12GM50-E2
P+F NBN4-12GM50-E2-V1
P+F NBN4-12GM60-A0
P+F NBN4-12GM60-A0-V1
P+F NBN4-12GM60-A2
P+F NBN4-12GM60-A2-V1
P+F NBN4-12GM60-WO
P+F NBN4-12GM60-WS
P+F NBN8-12GM50-E0
P+F NBN8-12GM50-E0-V1
P+F NBN8-12GM50-E2
P+F NBN8-12GM50-E2-V1
P+F NBN8-18GK50-E0
P+F NBN8-18GK50-E2
P+F NBN8-18GM40-Z0
P+F NBN8-18GM40-Z0-V1
P+F NBN8-18GM50-E0
P+F NBN8-18GM50-E0-V1
P+F NBN8-18GM50-E2
P+F NBN8-18GM50-E2-V1
P+F NBN8-18GM60-A0
P+F NBN8-18GM60-A0-V1
P+F NBN8-18GM60-A2
NBN8-18GM60-A2-V1
P+F NBN8-18GM60-WO
P+F NBN8-18GM60-WS
P+F NBN4-12GK50-E0
P+F NBN4-12GK50-E2
P+F NBN4-12GM40-E0
P+F NBN4-12GM40-E2
P+F NBN4-12GM40-Z0
P+F NBN4-12GM50-E0
P+F NBN4-12GM50-E2
P+F NBN4-12GM60-A0
P+F NBN4-12GM60-A2
P+F NBN4-12GM60-WO
P+F NBN4-12GM60-WS
P+F NBN8-12GM50-E0
P+F NBN8-12GM50-E2
P+F NBN8-18GK50-E0
P+F NBN8-18GK50-E2
P+F NBN8-18GM40-Z0
P+F NBN8-18GM50-E0
P+F NBN8-18GM50-E2
P+F NBN8-18GM60-A0
P+F NBN8-18GM60-A2
P+F NBN8-18GM60-A2-V1
P+F NBN8-18GM60-WO
P+F NBN8-18GM60-WS
PEPPERL+FUCHS编码器型号大全
P+F AVS58N-011AAROGN-0012
P+F AVM58N-011AAROBN-1212
P+F RVI50N-09BK0A3TN-01000
P+F RVI50N-09BKOA3TN-0600
P+F AVS58I-011AAROBN-0012
P+F AVM58I-011AAROBN-1212
P+F AVM58N-011K1R0GN-1213
P+F AVM58N-032K1R0GN-1212
P+F AVM58N-011K1R0GN-1212
P+F RVI58N-011AAA66N-01024
P+F RVI78N-10CK2A31N-3000
P+F RVI58N-011K1R61N-01024
P+F AVM58N-011AAKHGN-1212
P+F FVM58N-011K2R3GN-1213
P+F RVI58N-032K1R61N-5000
P +F RVI58N-011AAR6XN-5000
P+F RVI58N-032AAR66N-01024
P+F RHI58N-OBAK1R61N-1024
P+F HI58N-OBAK1R6XN-1024
P+F RVI58N-032K1R31N-00600
P+F RVI58N-032K1R31N-00500
P+F RHI90N-OHAAAR61N-1024
P+F PVS58N-011AGROBN-0013
P +F AVM58N-011K1RHCN-1212
P+F RHI58N-0BAR1R61N-1000
P+F RVI58N-011K1R61N-5000
P+F RVI50N-09BK0A3TN-1000
P+F PVM58N-011AGROBN-1213
P+F RVI78N-10CK2A31N-0100
P+F FHS58N-0BAK2RR4GN-0013
P+F RVI58N-011AAR6XN-01024
P+F DVM58N-011AGROBN-1213
P+F RVI50N-09BK0A3TN-00500
P+F RVI50N-09BK0A3TN-0500
P+F RVI58N-011AAR6XN-5000
P+F RHI58N-OBAK1R6XN-1024
P+F AVM58N-011K1RHCN-1212
倍加福P+F编码器,P+F安全栅,P+F传感器:
P+F NBN15-F11-E2
P+F NBN15-F11-E2-V1
P+F NBN40-L2-A0-V1
P+F NBN40-L2-A2-V1
P+F NBN40-L2-E0-V1
P+F NBN40-L2-E2-V1
P+F NBN40-L2M-A0-V1
P+F NBN40-L2M-A2-V1
P+F NBN40-L2M-E0-V1
P+F NBN40-L2M-E2-V1
P+F 基本/矩形/齐平安装系列
P+F NCB2-V3-N0
P+F NCB2-V3-N0-V5
P+F NCB15+U1+N0
P+F NCB15+U1+U
P+F NCB40-FP-A2-P1
P+F NCB40-FP-N0-P1
P+F NCB40-FP-W-P1
P+F 基本/矩形/非齐平安装系列
P+F NCN4-V3-N0
P+F NCN4-V3-N0-V5
P+F NCN15-M1K-E5
P+F NCN15-M1K-N0
P+F NCN15-M1K-Z2
P+F NCN20+U1+N0
P+F NCN20+U1+U
P+F NCN20+U1+Z2
P+F NCN25-F35-A2-250-V1
P+F NCN30+U1+N0
P+F NCN30+U1+U
P+F NCN30+U1+Z2
P+F 基本/矩形/非齐平安装系列
P+F NCN40+U1+A0
P+F NCN40+U1+A2
P+F NCN40+U1+E0
P+F NCN40+U1+E2
P+F NCN40+U1+N0
P+F NCN40+U1+U
P+F NCN40+U1+Z2
P+F NCN50-FP-A2-P1
P+F NCN50-FP-N0-P1
P+F NCN50-FP-W-P1
P+F NCN100-F23-E2-V1
P+F 原始型/矩形系列
P+F NJ   1,5-F-N
P+F NJ   2-F1-N
P+F NJ   2-F1-U?
P+F NJ   2-F1-US
NJ   2-V3-N
NJ   2-V3-N-V5
NJ   6-F-A
NJ   6-F-A2
NJ   6-F-E
NJ   6-F-E2
P+F NJ50-FP-E2-P1
P+F NJ8-18GK-N-150
P+F 9416
P+F RHI90N-0HAAAR61N-1024
P+F NJ20+U1+E
P+F NJ4-12GM40-E2
P+F NBB2-8GM50-E2
P+F NJ15+U1+E
P+F NBB5-18GM60-WS
P+F NJ2-12GK-N
P+F NBN15-30GM40-Z0
P+F NJ15+U1+E
P+F NBB2-V3-E2
P+F NJ4-12GM40-E2
P+F 9404 10X10我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F 9424-05M-24P-FXS
P+F FVS58N-011ADR3BN-0013
P+F CJ10-30GM-A
P+F NBN8-18GM40-Z0
P+F OBS2000-F28-E5
P+F RL39-54/32/400/320/116
P+F NJ20+U1+E2
P+F ML18-2397
P+F LVL-T1-G3S-E5PG-NA
P+F LA39/LK39-Z/31/40A/116
P+F RLK39-54-Z/31/14A/116
P+F RV178N-10CK2A31N-1024
P+F H50
P+F ML5-54/32/115
P+F UC500-30GM-E6R2-V15
P+F 10-11351-R-1024
P+F NJ15+U1+N-Z10
P+F NJ2-11-SN-G
P+F NJ4-12GM-N我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F UB2000-F42-U-V15
P+F V15-W-2M-PVC
P+F NJ50-FP-E2-P1
P+F ORR50
P+F RLK39-54-Z31/40a/116
P+F NJ15+U1+W
P+F NBB5-18GM50-E0
P+F KFD2-CD-EX1.32
P+F KFD2-SR2-EX2.W
P+F NJ50-FP-E2-P1
P+F NJ1.5-8GM40-E2
P+F NBB10-30GM60-WO
P+F NBB10-30GM60-WS
P+F NBB5-18GM60-WO
P+F RLK39-55/31/35/40A/116
P+F NJ10-30GK-E2-T
P+F IPCO3-50W
P+F IPT-FP我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F U-P6-B6
P+F NBN8-18GM60-W0
P+F OBT200-18GM60-E4
P+F RVI50N-09BKOA3TN-1000
P+F NCB1.5-18GM60-E2-D
P+F 10-11631-R-1024
P+F NJ2-12GM40-E2
P+F NJ4-12GM40-E2-V1
P+F RLK39-54-Z/31/40A/116
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F NJ1.5-8GM40-E2-V1
P+F KFD2-SD-EX1.36
P+F NBN2-8GM50-A2-V1
P+F NBN2-8GM50-E2-V3
P+F NBB2-12GM50-E2-V1
P+F LFL2-BK-U-CHSM
P+F NBB10-30GM50-WS
P+F NJ20+U1+E2
P+F NJ1.5-18GM-N-D-V1
P+F NJ2-11-N
P+F V1-G-2M-PVC
P+F OBS4000-18GM60-E5
P+F GLV12-8-200/37/40B/115
P+F LD391/V39/30/40A/116/126
P+F NBB10-30GM50-E0
P+F NBB4-12GM50-E0
P+F 940110X10我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F RVI58N-011K1R61N-1024
P+F NCB1.5-18GM-E2-D5
P+F NJ4-12GM-N
P+F NBB2-12GM50-E2
P+F UC4000-30GM-IUR2-V15
P+F V15-W-2M-PVC
P+F ML5-8-400-30-115 VB=10
P+F SJ15-E2 V=10-30V-1 J=200
P+F V15-W-2M-PVC
P+F ORR50
P+F SJ10-N
P+F NBB5-18GM50-E2
P+F KFA6-DWB-EX1.D
P+F KFA6-SR2-EX2.W
P+F KFD2-SR2-EX2.W
P+F NBB1.5-8GM50-E2
P+F NBB20-L2-A0-V1
P+F NCB10-30GM40-N0-V1
P+F MLV40-8-500/47/15
P+F ORR60
P+F NJ15+U1+W
P+F AVM58N-011K1ROGN-1212
P+F NCB5-18GM40-N0我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NJ2-12GM50-WS
P+F NBB1.5-8GM50-E0-V3
P+F NJ8-18GK-N
P+F UB2000-30GM-E4-V15
P+F V15-G-2M-PVC
P+F NJ1.5-8GM-N
P+F NJ50-FP-E-P1
P+F NBB2-12GM50-E2
P+F NCN8-18GM40-N0-V1
P+F OBE10M-18GM60-SE4
P+F NCB4-12GM60-B3-V1
P+F NBN15-30GM50-E2-V1
P+F NBB5-18GM50-E2 10M
P+F NBB5-18GM-E2-V1
P+F NCN15-30GM40-Z0
P+F UB500-30GM-E5-V15
P+F NBB5-18GM50-E2
P+F NBB5-18GM50-E2-V1
P+F NBB2-8GM50-E0
P+F NBN8-18GM40-Z0
P+F RL39-8-2000/30/40A/116/2
P+F NJ30+U1+W
P+F LD39/LV39/30/42/116/126A
P+F 10-11321-R-600
P+F KFU8-FSSP-1.D
P+F NBB4-12GM50-E2-V1
P+F OBS4000-18GM60-E4
P+F NJ15+U1+E
P+F MLV40-54-G-1700
P+F KS11/KSE11/59/103/115
P+F V3-GM-5M-PVR
P+F MLV40-54-1371
P+F MLV40-8-H-1463-Q
P+F NBN15-30GM50-E2
P+F NJ15-30GK50-E
P+F NJ15-30GK-50-E2我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NBB10-30GM50-E2
P+F NJ4-12GM-N
P+F KFU8-DW-1.D
P+F RV158N-011K1R61N-1024
P+F 940110X10
P+F NJ4-12GK-N
P+F NJ6-22-N
P+F UB500-18GM75-U-V15
P+F NBB10-30GM50-E2-V1
P+F V1-G-2M-PVC
P+F NBN8-18GM60-W0
P+F NJ15+U1+2E2-NE/FE
P+F NJ2-12GM40-E2
P+F NJ2-12GM40-E2-V1
P+F NBB10-30GM60-WS
P+F NJ50-FP-E2-P1
P+F NBN8-18GM50-E2
P+F NJ50-FP-A2-P1
P+F KT10/33
P+F WE77-EX-1
P+F V1-W-2M-PVC
P+F NEB3-8GM45-E2
P+F NCB10-30GM40-Z0
P+F NCB15+U1+Z2 DC24V
P+F NCB5-18GM40-Z0
P+F LFL2-BK-U-CSM5
P+F NBB5-18GM50-E0
P+F NJ10-30GM-N
P+F NJ2-12GK-N
P+F NJ5-18GM-N
P+F NJ15-U1-E
P+F ML5-6/32/115
P+F ML5-8-400/32/115
P+F NBN8-18GM50-E0
P+F RL39-54/32/40A/82A/116
P+F LFL3-CK-U-PVC5我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
电源电压:10-30V
输出指示:LED黄色
可靠动作距离范围:0-3.24MM
开关频率:1000HZ
线制:3线制
防护等级:IP67
连接类型:2M,PVC电缆
空载电流;15MA
P+F NJ50-FP-E2-P1
P+F NJ8-18GK-N-150
P+F 9416
P+F NJ20+U1+E
P+F NJ4-12GM40-E2
P+F NBB2-8GM50-E2
P+F NJ15+U1+E
P+F NBB5-18GM60-WS
P+F NJ2-12GK-N
P+F NBN15-30GM40-Z0
P+F NJ15+U1+E
P+F NBB2-V3-E2
P+F NJ4-12GM40-E2
P+F 9404 10X10
P+F CJ10-30GM-A
P+F NBN8-18GM40-Z0
P+F OBS2000-F28-E5
P+F NJ20+U1+E2
P+F ML18-2397
P+F H50我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!P+F ML5-54/32/115
P+F 10-11351-R-1024
P+F NJ15+U1+N-Z10
P+F NJ2-11-SN-G
P+F NJ4-12GM-N
P+F V15-W-2M-PVC
P+F NJ50-FP-E2-P1
P+F ORR50
P+F NJ15+U1+W
P+F NBB5-18GM50-E0
P+F KFD2-CD-EX1.32
P+F KFD2-SR2-EX2.W
P+F NJ50-FP-E2-P1
P+F NJ1.5-8GM40-E2
P+F NBB10-30GM60-WO
P+F NBB10-30GM60-WS
P+F NBB5-18GM60-WO
P+F NJ10-30GK-E2-T
P+F IPCO3-50W
P+F IPT-FP
P+F U-P6-B6我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NBN8-18GM60-W0
P+F 10-11631-R-1024
P+F NJ2-12GM40-E2
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F KFD2-SD-EX1.36
P+F LFL2-BK-U-CHSM
P+F NBB10-30GM50-WS
P+F NJ20+U1+E2
P+F NJ2-11-N
P+F V1-G-2M-PVC
P+F NBB10-30GM50-E0
P+F NBB4-12GM50-E0我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F 940110X10
P+F NJ4-12GM-N
P+F NBB2-12GM50-E2
P+F V15-W-2M-PVC
P+F V15-W-2M-PVC
P+F ORR50
P+F SJ10-N
P+F NBB5-18GM50-E2
P+F KFA6-DWB-EX1.D
P+F KFA6-SR2-EX2.W
P+F KFD2-SR2-EX2.W
P+F NBB1.5-8GM50-E2
P+F NBB20-L2-A0-V1
P+F ORR60
P+F NJ15+U1+W
P+F NCB5-18GM40-N0
P+F NJ2-12GM50-WS
P+F NJ8-18GK-N
P+F V15-G-2M-PVC
P+F NJ1.5-8GM-N
P+F UC4000-30GM-IUR2-V15我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NJ50-FP-E-P1
P+F NBB2-12GM50-E2
P+F NBB5-18GM-E2-V1
P+F NCN15-30GM40-Z0
P+F NBB5-18GM50-E2
P+F NBB2-8GM50-E0
P+F NBN8-18GM40-Z0
P+F NJ30+U1+W
P+F 10-11321-R-600
P+F KFU8-FSSP-1.D
P+F NJ15+U1+E
P+F MLV40-54-G-1700
P+F V3-GM-5M-PVR
P+F MLV40-54-1371
P+F NBN15-30GM50-E2
P+F NJ15-30GK50-E
P+F NJ15-30GK-50-E2
P+F NBB10-30GM50-E2
P+F NJ4-12GM-N
P+F KFU8-DW-1.D我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!P+F RV158N-011K1R61N-1024
P+F 940110X10
P+F NJ4-12GK-N
P+F NJ6-22-N
P+F V1-G-2M-PVC
P+F NBN8-18GM60-W0
P+F NJ2-12GM40-E2
P+F NBB10-30GM60-WS
P+F NJ50-FP-E2-P1
P+F NBN8-18GM50-E2
P+F NJ50-FP-A2-P1
P+F KT10/33
P+F WE77-EX-1
P+F V1-W-2M-PVC
P+F NEB3-8GM45-E2
P+F NCB10-30GM40-Z0
P+F NCB5-18GM40-Z0
P+F LFL2-BK-U-CSM5
P+F NBB5-18GM50-E0
P+F NJ10-30GM-N
P+F NJ2-12GK-N
P+F NJ5-18GM-N我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NJ15-U1-E
P+F ML5-6/32/115
P+F NBN8-18GM50-E0
P+F LFL3-CK-U-PVC5
P+F NJ15+U1+DW1-10
P+F NCN20+U1+Z2
P+F NBB5-18GM50-E2
P+F RL39-8-2000/30/40A(备注)
P+F UC2000-30GM-IUR2-V15
P+F V1-G-5M-PVC
P+F NBN8-18GM60-W0
P+F NBB10-30GM50-E2
P+F NJ20+U1+W
P+F NJ40+U1+E2
P+F OBE10M-18GM60-SE5
P+F NJ50-FP-E-P1
P+F NJ15-M1-E2-V1
P+F RHI90N-0NAAAR61N-2048
P+F NCN4-12GM40-Z0
P+F NBB5-18GM60-WO
P+F NBB5-18GM50-E0
P+F NJ30+U1+W
P+F NJ2-12GK40-E2
P+F NJ25-50-N
P+F NJ40+U1+W
P+F NJ8-18GK-N
P+F SJ10-N
P+F KFD2-UFC-1.D
P+F V15-G-2M-PVC
P+F NBN8-18GM40-Z0
P+F NJ8-18GK-N-150
P+F RL10-8-2339
P+F NBB4-12GM50-E2
P+F NJ20+U1+E2
P+F NJ50-FP-E2-P1
P+F NJ1.5-6.5-40-E2
P+F MLV40-8-500/47/115我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NBN15-30GM40-Z0
P+F NJ1.5-6.5-N
P+F ML18-2397
P+F ML4-8-H-M-1348
P+F NBN8-18GM40-Z0
P+F NBB1.5-8GM50-E2
P+F NJ1.5-6.5N
P+F NBN8-18GM50-E0
P+F V15-G-2M-PVC
P+F NJ6-F-N
P+F KFA6-S0T2-EX2
P+F NCB15-U1-Z2
P+F NJ50-FP-E2-P1
P+F 9401
P+F NBB5-18GM50-E0
P+F NJ4-12GM-N-V1
P+F 30-4201IA-ID24
P+F PVM58I-011AGROBN-1213
P+F 30-4201IA-1024
P+F接近开关NBB5-18GM-E0/NBN4-12GM50-E2/
P+F KFD2-DWB-EX1.D
P+F KFD2-ST-EX2
P+F KFU8-UFC-EX1.D
P+F KFD2-SCD-EX1.LK
P+F KFD2-DWB-Ex1.D
P+F KFD2-PT2-EX1-5
P+F KFA6-SR2-Ex2.W
P+F KFD2-ST-EX2
P+F KFD2-RR-EX1
P+F KFD2-UFC-EX1.D
P+F KFD2-UFC-EX1.D
P+F KFD2-UFC-EX1.D 我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F KFD2-DWB-EX1.D
P+F NEB12-18GM50-E2
P+F KFA6-DWB-EX1.D
P+F WE77/EX2
P+F KFA6-DWB-Ex1.D
P+F KFU8-FSSP-1.D
P+F GJ10-30GM-E
P+F KFA6-SR2-EX1.W
P+F KFD2-UFC-EX1.D
我司代理的P+F产品
P+F VAA-2EA-G2-ZA/EA2
P+F KFA6-SR2-EX2.W
P+F VAZ-FK-S-BK
P+F NCN40+U1+N0
P+F KFU8-FSSP-1.D
P+F WE77/FX2
P+F KFD2-SR2-EX2.W
P+F WE77/EX2 220VAC
P+F KFD2-STC4-EX1
P+F KFD2-BR-1.PA.93
P+F KFU8-UFC-10
P+F NJ50-FP-E2-P1
P+F NJ8-18GK-N-150
P+F 9416
P+F NJ20+U1+E
P+F NJ4-12GM40-E2
P+F NBB2-8GM50-E2
P+F NJ15+U1+E
P+F NBB5-18GM60-WS
P+F NJ2-12GK-N
P+F NBN15-30GM40-Z0
P+F NJ15+U1+E
P+F NBB2-V3-E2
P+F NJ4-12GM40-E2
P+F 9404 10X10
P+F CJ10-30GM-A
P+F NBN8-18GM40-Z0
P+F OBS2000-F28-E5
P+F NJ20+U1+E2
P+F ML18-2397
P+F H50
P+F ML5-54/32/115
P+F 10-11351-R-1024
P+F NJ15+U1+N-Z10
P+F NJ2-11-SN-G
P+F NJ4-12GM-N
P+F V15-W-2M-PVC
P+F NJ50-FP-E2-P1
P+F ORR50我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!P+F RLK39-54-Z31/40a/116
P+F NJ15+U1+W
P+F NBB5-18GM50-E0
P+F KFD2-CD-EX1.32
P+F KFD2-SR2-EX2.W
P+F NJ50-FP-E2-P1
P+F NJ1.5-8GM40-E2
P+F NBB10-30GM60-WO
P+F NBB10-30GM60-WS
P+F NBB5-18GM60-WO
P+F NJ10-30GK-E2-T
P+F IPCO3-50W
P+F IPT-FP
P+F U-P6-B6
P+F NBN8-18GM60-W0
P+F 10-11631-R-1024
P+F NJ2-12GM40-E2
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F KFD2-SD-EX1.36
P+F LFL2-BK-U-CHSM
P+F NBB10-30GM50-WS
P+F NJ20+U1+E2
P+F NJ2-11-N
P+F V1-G-2M-PVC
P+F NBB10-30GM50-E0
P+F NBB4-12GM50-E0
P+F 940110X10
P+F NJ4-12GM-N
P+F NBB2-12GM50-E2
P+F V15-W-2M-PVC
P+F V15-W-2M-PVC
P+F ORR50
P+F SJ10-N我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NBB5-18GM50-E2
P+F KFA6-DWB-EX1.D
P+F KFA6-SR2-EX2.W
P+F KFD2-SR2-EX2.W
P+F NBB1.5-8GM50-E2
P+F NBB20-L2-A0-V1
P+F ORR60
P+F NJ15+U1+W
P+F NCB5-18GM40-N0
P+F NJ2-12GM50-WS
P+F NJ8-18GK-N
P+F V15-G-2M-PVC
P+F NJ1.5-8GM-N
P+F NJ50-FP-E-P1
P+F NBB2-12GM50-E2
P+F NBB5-18GM-E2-V1
P+F NCN15-30GM40-Z0
P+F NBB5-18GM50-E2
P+F NBB2-8GM50-E0
P+F NBN8-18GM40-Z0我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NJ30+U1+W
P+F 10-11321-R-600
P+F KFU8-FSSP-1.D
P+F NJ15+U1+E
P+F MLV40-54-G-1700
P+F V3-GM-5M-PVR
P+F MLV40-54-1371
P+F NBN15-30GM50-E2
P+F NJ15-30GK50-E
P+F NJ15-30GK-50-E2
P+F NBB10-30GM50-E2
P+F NJ4-12GM-N
P+F KFU8-DW-1.D
P+F 940110X10
P+F NJ4-12GK-N
P+F NJ6-22-N
P+F V1-G-2M-PVC我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NBN8-18GM60-W0
P+F NJ2-12GM40-E2
P+F NBB10-30GM60-WS
P+F NJ50-FP-E2-P1
P+F NBN8-18GM50-E2
P+F NJ50-FP-A2-P1
P+F KT10/33
P+F WE77-EX-1
P+F V1-W-2M-PVC
P+F NEB3-8GM45-E2
P+F NCB10-30GM40-Z0
P+F NCB5-18GM40-Z0
P+F LFL2-BK-U-CSM5
P+F NBB5-18GM50-E0
P+F NJ10-30GM-N
P+F NJ2-12GK-N
P+F NJ5-18GM-N
P+F NJ15-U1-E
P+F ML5-6/32/115
P+F NBN8-18GM50-E0
P+F LFL3-CK-U-PVC5
P+F NJ15+U1+DW1-10
P+F NCN20+U1+Z2
P+F NBB5-18GM50-E2
P+F V1-G-5M-PVC
P+F NBN8-18GM60-W0
P+F NBB10-30GM50-E2
P+F NJ20+U1+W
P+F NJ40+U1+E2
P+F NJ50-FP-E-P1
P+F NJ15-M1-E2-V1
P+F NCN4-12GM40-Z0
P+F NBB5-18GM60-WO
P+F NBB5-18GM50-E0
P+F NJ30+U1+W
P+F NJ2-12GK40-E2
P+F NJ25-50-N
P+F NJ40+U1+W我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NJ8-18GK-N
P+F SJ10-N
P+F KFD2-UFC-1.D
P+F V15-G-2M-PVC
P+F NBN8-18GM40-Z0
P+F NJ8-18GK-N-150
P+F RL10-8-2339
P+F NBB4-12GM50-E2
P+F NJ20+U1+E2
P+F NJ50-FP-E2-P1
P+F NJ1.5-6.5-40-E2
P+F NBN15-30GM40-Z0
P+F NJ1.5-6.5-N
P+F ML18-2397
P+F ML4-8-H-M-1348
P+F NBN8-18GM40-Z0
P+F NBB1.5-8GM50-E2
P+F NJ1.5-6.5N
P+F NBN8-18GM50-E0
P+F V15-G-2M-PVC
P+F NJ6-F-N
P+F KFA6-S0T2-EX2
P+F NCB15-U1-Z2
P+F NJ50-FP-E2-P1
P+F 9401
P+F NBB5-18GM50-E0
P+F NJ4-12GM-N-V1
P+F 30-4201IA-ID24
P+F 30-4201IA-1024
德国倍加福P+F产品品牌 型号                  P+F TDR-GK100-RZ(RVI78N-10CK2A31N-0100) 物流中心产品P+F 9278 物流中心产品P+F SB3.5-E2 物流中心产品P+F RVI50N-09BK0A3TN-00500 物流中心产品P+F NCN15-30GM60-Z0(NCN15-30GM40-Z0) 物流中心产品P+F NJ30+U1+E2 物流中心产品P+F NEB12-18GM50-E2-V1 物流中心产品P+F NEB6-12GM50-E2 物流中心产品P+F NBN25-30GM50-E0 物流中心产品P+F UB6000-30GM-E5-V15 物流中心产品P+F V15-W-2M-PVC 物流中心产品P+F UC-6000-30GM-IUR2-V15 物流中心产品P+F 30-3641IA-1024 物流中心产品P+F NBN4-12GM40-Z0 物流中心产品P+F NJ30+U1+A2 物流中心产品P+F NBN8-18GM50-E2-C-V1 物流中心产品P+F RL28/55/47/82B/105 物流中心产品P+F NBB5-18GM60-WS 物流中心产品P+F LCR18-3.2-2.0-K5 物流中心产品P+F NJ1.5-8GM40-E2-V1 物流中心产品P+F V1-W 物流中心产品P+F NBN4-12GM40-Z0-V1 物流中心产品P+F NBB0.8-5GM25-E2 物流中心产品P+F NEB22-30GM60-E2-V1 物流中心产品P+F NBN15-30GM50-E2 物流中心产品P+F NBN8-18GM50-E2 物流中心产品P+F LFL3-BK-U-PVC5 物流中心产品P+F NBN4-12GM40-Z0-V1 物流中心产品P+F NJ0.6-3-22-E2 物流中心产品P+F NJ5-11-N-G 物流中心产品P+F NBB15-30GM50-E2 物流中心产品P+F MLV40-6/47/92 物流中心产品P+F LLR04-1.6-1.0-WC3 物流中心产品P+F MLV40-LL-1R/47/92 物流中心产品P+F CJ8-18GM-E2-V1 物流中心产品P+F GLV12-8-200/37/40B/92 物流中心产品P+F V1-W-E2-10M-PUR(10米长) 物流中心产品P+F OCS5000-F8-UKT(RLK39-54-Z/31/40A/116) 物流中心产品P+F NBB5-18GM50-E2 物流中心产品P+F NEB6-12GM50-E2-V1 物流中心产品P+F RVI50N-09BK0A3TN-0500 物流中心产品P+F NJ6-F-A 物流中心产品P+F NJ5-11-N 物流中心产品P+F NJ2-11-N 物流中心产品P+F NJ1.5-6.5-N 物流中心产品P+F NJ8-18GM50-A2-V1 物流中心产品P+F NBN15-30GM50-E2-V1 物流中心产品P+F DVM58N-011AGROBN-1213 物流中心产品P+F NJ40+U1+E2 物流中心产品P+F RVI58N-011AAR6XN-01024 物流中心产品P+F NCB5-18GM60-B3-V1 物流中心产品P+F NCB5-18GM60-B3 物流中心产品P+F NBB5-18GM50-E2-V1 物流中心产品P+F NJ50-FP-E2-P1 物流中心产品P+F 9401   8*8 物流中心产品P+F NBB6-F-B3 物流中心产品P+F NJ20+U1+E2 物流中心产品P+F NJ15+U1+W 物流中心产品P+F NBB5-18GM50-E0 物流中心产品P+F NBB5-18GM50-E2 物流中心产品P+F TRD-J1000-RZ(RIV50N-09BK0A3TN-01000) 物流中心产品P+F NJ1.5-18GM-N-D-V1 物流中心产品P+F OBT500-18GM60-E5 物流中心产品P+F NJ15+U1+E2 物流中心产品P+F NJ30+U1+W 物流中心产品P+F LFL2-BK-U-PVC3 物流中心产品P+F 30-3641-R-1024 物流中心产品P+F NBB6-F-B3 物流中心产品P+F RL10S/7B/25/46 物流中心产品P+F FHS58N-0BAK2RR4GN-0013 物流中心产品P+F NBB10-30GM…P+F TDR-GK100-RZ(RVI78N-10CK2A31N-0100)
P+F 9278
P+F SB3.5-E2
P+F NJ30+U1+E2
P+F NEB6-12GM50-E2
P+F NBN25-30GM50-E0
P+F V15-W-2M-PVC
P+F 30-3641IA-1024
P+F NBN4-12GM40-Z0
P+F NJ30+U1+A2
P+F NBB5-18GM60-WS
P+F V1-W
P+F NBB0.8-5GM25-E2
P+F NBN15-30GM50-E2
P+F NBN8-18GM50-E2我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F LFL3-BK-U-PVC5
P+F NJ0.6-3-22-E2
P+F NJ5-11-N-G
P+F NBB15-30GM50-E2
P+F MLV40-6/47/92
P+F CJ8-18GM-E2-V1
P+F NBB5-18GM50-E2
P+F NJ6-F-A
P+F NJ5-11-N
P+F NJ2-11-N
P+F NJ1.5-6.5-N
P+F NJ40+U1+E2
P+F NCB5-18GM60-B3
P+F NJ50-FP-E2-P1
P+F 9401 8*8
P+F NBB6-F-B3
P+F NJ20+U1+E2
P+F NJ15+U1+W
P+F NBB5-18GM50-E0
P+F NBB5-18GM50-E2
P+F NJ15+U1+E2
P+F NJ30+U1+W我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F LFL2-BK-U-PVC3
P+F 30-3641-R-1024
P+F NBB6-F-B3
P+F RL10S/7B/25/46
P+F NBB10-30GM50-E0
P+F NBB4-12GM50-E0
P+F NJ20+U1+W-T
P+F NBB3-V3-Z4
P+F NBB5-18GM40-Z0
P+F NCN4-12GM35-N0-V1
P+F V1-G-N-5M-PUR
P+F OCT2000-F8-UK(RLK39-8-2000/31/40A/116)
P+F NJ10-30GK-E-T
P+F NJ10-30GK-E2-T
P+F NJ15-30GM-N
P+F NBN40-L2-E0-V1
P+F V1-G
P+F NMB5-18GM65-Z0-FE-V1
P+F NBN15-30GM40-Z0
P+F OBT200-12GM55-E5(GLV12-8-200/37/40B/115)
P+F RLK23-8-H-2000-IR/31/104/116
P+F NJ1.5-18GM-N-D
P+F NCN20+U1P+F 10-15631-R-1024 P+F 10-15631-R-1024 P+F 9401 10*10 P+F AVM58N-032AAROBN-1213 P+F CJ40-FP-A2-P1 P+F CJ8-18GM-E2-V1 P+F KCD2-E P+F KFA6-SR2-EX2.W P+F KFD2-SD-EX1.36 P+F KFU8-UFC-EX1.D P+F LVL-S1-G3S-E5V1-NA P+F...
P+F倍加福部分型号:
NJ15+U1+E2、NBN15-30GM60-WO 220、LT500G、RLK39-54-Z/31/40A/116、NBN15-F11-EO、IA8-30GM-I3、LA39/LK39-Z/31/40A/116、KS11/KSE11/59/98A/102 2M、KS11/KSE11/59/103/115、V3-GM-5M-PVR、NBB2-12GM60-A2-V1、NJ50-FP-E2-P1
P+F NJ8-18GK-N-150
P+F NJ20+U1+E
P+F NJ4-12GM40-E2
P+F NBB2-8GM50-E2
P+F NJ15+U1+E
P+F NBB5-18GM60-WS
P+F NJ2-12GK-N
P+F NBN15-30GM40-Z0
P+F NJ15+U1+E
P+F NBB2-V3-E2
P+F NJ4-12GM40-E2
P+F CJ10-30GM-A
P+F NBN8-18GM40-Z0我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!P+F OBS2000-F28-E5
P+F NJ20+U1+E2
P+F ML18-2397
P+F ML5-54/32/115
P+F 10-11351-R-1024
P+F NJ15+U1+N-Z10
P+F NJ2-11-SN-G
P+F NJ4-12GM-N
P+F V15-W-2M-PVC
P+F NJ50-FP-E2-P1
P+F NJ15+U1+W
P+F NBB5-18GM50-E0
P+F KFD2-CD-EX1.32
P+F KFD2-SR2-EX2.W
P+F NJ50-FP-E2-P1
P+F NJ1.5-8GM40-E2
P+F NBB10-30GM60-WO
P+F NBB10-30GM60-WS
P+F NBB5-18GM60-WO
P+F NJ10-30GK-E2-T
P+F NBN8-18GM60-W0
P+F 10-11631-R-1024
P+F NJ2-12GM40-E2
P+F NJ15-30GK-SN
P+F NJ15-U1-A2
P+F NJ15-U1-W
P+F NJ15-30GK-SN
P+F NJ15-U1-W
P+F KFD2-SD-EX1.36
P+F LFL2-BK-U-CHSM
P+F NBB10-30GM50-WS
P+F NJ20+U1+E2
P+F NJ2-11-N我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F V1-G-2M-PVC
P+F NBB10-30GM50-E0
P+F NBB4-12GM50-E0P+F RVI58N-011K1R61N-1024
P+F NJ4-12GM-N
P+F NBB2-12GM50-E2
P+F NBB5-18GM50-E2
P+F KFA6-DWB-EX1.D
P+F KFA6-SR2-EX2.W
P+F KFD2-SR2-EX2.W
P+F NBB1.5-8GM50-E2
P+F NBB20-L2-A0-V1
P+F NJ15+U1+W
P+F NCB5-18GM40-N0
P+F NJ2-12GM50-WS
P+F NJ8-18GK-N
P+F NJ1.5-8GM-N
P+F NJ50-FP-E-P1
P+F NBB2-12GM50-E2
P+F NBB5-18GM-E2-V1
P+F NCN15-30GM40-Z0
P+F NBB5-18GM50-E2
P+F NBB2-8GM50-E0
P+F NBN8-18GM40-Z0
P+F NJ30+U1+W
P+F KFU8-FSSP-1.D
P+F OBS4000-18GM60-E4我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NJ15+U1+E
P+F MLV40-54-G-1700
P+F MLV40-54-1371
P+F NBN15-30GM50-E2
P+F NJ15-30GK50-E
P+F NJ15-30GK-50-E2
P+F NBB10-30GM50-E2
P+F NJ4-12GM-N
P+F KFU8-DW-1.D
P+F NJ4-12GK-N
P+F NJ6-22-N
P+F NBN8-18GM60-W0
P+F NJ2-12GM40-E2
P+F NBB10-30GM60-WS
P+F NJ50-FP-E2-P1
P+F NBN8-18GM50-E2
P+F NJ50-FP-A2-P1
P+F WE77-EX-1
P+F NEB3-8GM45-E2
P+F NCB10-30GM40-Z0
P+F NCB5-18GM40-Z0
P+F LFL2-BK-U-CSM5
P+F NBB5-18GM50-E0
P+F NJ10-30GM-N
P+F NJ2-12GK-N
P+F NJ5-18GM-N
P+F NJ15-U1-E
P+F ML5-6/32/115
P+F NBN8-18GM50-E0
P+F LFL3-CK-U-PVC5
P+F NJ15+U1+DW1-10
P+F NCN20+U1+Z2
P+F RL39-54/32/40A/82A/116我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F NBB5-18GM50-E2
P+F NBN8-18GM60-W0
P+F NBB10-30GM50-E2
P+F NJ20+U1+W
P+F NJ40+U1+E2
P+F NJ50-FP-E-P1
P+F NJ15-M1-E2-V1
P+F NCN4-12GM40-Z0
P+F NBB5-18GM60-WO
P+F NBB5-18GM50-E0
P+F NJ30+U1+W
P+F NJ2-12GK40-E2
P+F NJ25-50-N
P+F NJ40+U1+W
P+F NJ8-18GK-N
P+F KFD2-UFC-1.D
P+F NBN8-18GM40-Z0
P+F NJ8-18GK-N-150我公司销售倍加福全系列产品,价格最优。(传感器、自控元件:接近开关、光电开关、物位传感器、编码器、总线模块、光栅、安全栅等品牌型号)上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F RL10-8-2339
P+F NBB4-12GM50-E2
P+F NJ20+U1+E2
P+F NJ50-FP-E2-P1
P+F NJ1.5-6.5-40-E2
P+F NBN15-30GM40-Z0
P+F NJ1.5-6.5-N
P+F ML18-2397
P+F ML4-8-H-M-1348
P+F NBN8-18GM40-Z0
P+F NBB1.5-8GM50-E2
P+F NJ1.5-6.5N
P+F NBN8-18GM50-E0
P+F V15-G-2M-PVC
P+F KFA6-S0T2-EX2
P+F NCB15-U1-Z2
P+F NJ50-FP-E2-P1
P+F NBB5-18GM50-E0
P+F NJ4-12GM-N-V1
P+F 30-4201IA-ID24
P+F NJ50-FP-E2-P1
P+F NJ8-18GK-N-150
P+F 9416  P+F RHI90N-0HAAAR61N-1024
P+F NJ20+U1+E
P+F NJ4-12GM40-E2
P+F NBB2-8GM50-E2
P+F NJ15+U1+E
P+F NBB5-18GM60-WS
P+F NJ2-12GK-N
P+F NBN15-30GM40-Z0
P+F NJ15+U1+W
P+F NBB2-V3-E2
P+F NJ4-12GM40-E2
P+F 9404 10X10
P+F CJ10-30GM-A
P+F NBN8-18GM40-Z0
P+F OBS2000-F28-E5
P+F NJ20+U1+E2
P+F ML18-2397
P+F H50
P+F ML5-54/32/115
P+F 10-11351-R-1024
P+F NJ15+U1+N-Z10
P+F NJ2-11-SN-G
P+F NJ4-12GM-N
KFD2-SR2-EX2W
KFD2-SR2-EX1.W
KFD2-SD-EX1.48-90A
KFD2-GU-EX1           倍加福全系列产品
KFD2-CR-EX1.30-200
KFD2-CD-EX1.32
KFD2-ST2-EX1LB
KFD2-STC4-1
KFU8-UFT-EX2.D
KFD2-UFC-EX1.D
KFD2-STC4-EX1
KFD2-VT-EX1   接近开关 光电开关编码器
KFD2-STC4-Ex1
KFD2-EB-R2A.B
P+F KFD2-CD-EX1.32
P+F KFD2-SR2-EX2.W
P+F KFA6-DWB-EX1.D量大价优,库存多多
P+F KFA6-SR2-EX2.W
P+F KFD2-SR2-EX2.W
P+F KFU8-FSSP-1.D
KFD2-SR2-EX2W
KFD2-SR2-EX1.W
KFD2-SD-EX1.48-90A
KFD2-GU-EX1   量大价优,库存多多
KFD2-CR-EX1.30-200
KFD2-CD-EX1.32
KFD2-ST2-EX1LB
KFD2-STC4-1
KFU8-UFT-EX2.D
KFD2-UFC-EX1.D 倍加福光电开关 接近开关 编码器
KFD2-STC4-EX1
KFD2-VT-EX1
KFD2-STC4-Ex1KFD2-EB-R2A.B   量大价优,库存多多
P+F AVS58I-011AAROBN-0012  倍加福光电开关 接近开关 编码器
P+F AVM58N-032K1R0GN-1212量大价优,库存多多
P+F RVI58N-011K1R61N-01024  倍加福光电开关 接近开关 编码器
P+F RHI58N-OBAK1R61N-1024量大价优,库存多多
P+F RVI58N-032K1R31N-00600  P+F RVI58N-032K1R31N-00500
P+F RHI90N-OHAAAR61N-1024  倍加福光电开关 接近开关 编码器
P+F RHI58N-0BAR1R61N-1000量大价优,库存多多
P+F DVM58N-011AGROBN-1213  倍加福光电开关 接近开关 编码器
P+F RVI50N-09BK0A3TN-0500量大价优,库存  P+F AVS58N-011AAROGN-0012
P+F AVM58N-011AAROBN-1212  倍加福光电开关 接近开关 编码器P+F RVI50N-09BK0A3TN-01000
P+F AVM58I-011AAROBN-1212   倍加福编码器
P+F AVM58N-011K1R0GN-1213量大价优,库存多多
P+F AVM58N-011K1R0GN-1212倍加福光电开关 接近开关 编码器
P+F RVI58N-011K1R61N-01024量大价优,库存多多
P+F RVI58N-032AAR66N-01024倍加福光电开关 接近开关 编码器
P+F RHI90N-OHAAAR61N-1024         量大价优,库存多多
销售P+FRVI50N,RVI58N编码器    上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
P+F RVI58N-011K1R61N-01024            销售P+FRVI50N,RVI58N编码器
P+F RHI90N-0HAAAR61N-1000
P+F RHI90N-0HAAAR61N-512
P+F RHI58N-OBAK1R31N-1300
P+F RHI58N-0BAK1R66N-1024
P+F RVI58N-032K1R61N-1500
P+F RVI58N-032AAR61N-2048
P+F RVI78N-10CK2A31N-0300
P+F PVS58I-011AGR0BN-0013
P+F PVM58I-011AGR0BN-1213
P+F RVI78N-10CK2A31N-01000
P+F RHI58N-OBAK1R66N-01024
P+F RVI58N-011K1A66N-2048
P+F FVM58N-011AEA3GN-0813
P+F RVI50P-09BAAR3TN-01024
P+F RHI58N-OAAK1R61N-01000
P+F RHI58N-0BAK1R66N-01024
P+F ASM58N-02AK1ROGN-1213
P+F RVI78N-10CK2A31N-3000          销售P+FRVI50N,RVI58N编码器
P+F RVI50N-09BK0A3TN-00500           销售P+FRVI50N,RVI58N编码器 现货特卖P+F光电开关系列,上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
光电开关(反射型)
OBT200-18GM70-E4或
OBT200-18GM60-E4
OBT200-18GM70-E5或
OBT200-18GM60-E5
OBT400-F28-E4或
OBT400-F28-E5
OCT800-F8-E4或
RL39-8-800/30-10A/116/126A
OCT800-F8-E5或
RL39-8-800/32-10A/82A/116
光电开关(反射板型)
OBS2000-18GK70-E4
OBS2000-18GK70-E5
OCS5000-F28-E4
OCS5000-F28-E5
OCS5000-F8-UK或
RLK39-55/31/40A/116
OCS5000-F8-URT或
RLK39-55-Z/31/40A/116
光电开关(对射型)
OBE5000-18GM70-SE4或
OBE5000-18GM60-SE4
OBE5000-18GM70-SE5
OBE5000-18GM60-SE5
OBE5000-F28-SE4
OBE5000-F28-SE5
OBE5000-F8-SUK或
OBE5000-F8-SUKT或
接近开关
HTL-Q05N1E
HTL-Q05P1E
接近开关
NBB5-18GM50-E0
NBB5-18GM50-E2
NBB2-12GM50-E0
NBB2-12GM50-E2
接近开关
NBN15-30GM50-E2
NBN15-20GM50-E0
接近开关
NJ20+U1+W
NJ40+U1+W
NJ15+U1+E2
NJ20+U1+E2
NJ30+U1+E2
NBB20-L2-E2-V1
接插式接近开关
与V1插头V1-G  V1-W
NBN4-12GM50-E0-V1
NBN4-12GM50-E2-V1
NBN8-18GM50-E0-V1
NBN8-18GM50-E2-V1
NBN8-18GM60-WS
AVM58N-011AGROBN-1213
UB2000-30GM-H3
RHI58N-0BAK1R61N-1024
NBN5-F7-E2
NBN5-F7-E0
NCN25-F25-350-A2-V1
WE77/EX2
KFD2-DBW-EX1.D
 现货供应P+F系列,上海配克 胡海涛 13853163389   QQ:250965738 展望合作!
NBN4-12GM50-E0
NBN8-18GM50-E2
NBN8-18GM50-E0
NBB8-18GM60-A2-V1
KFD2-DWB-EX1.D
NBB1.5-8GM50-E0
NBB1.5-8GM50-E2
NBN4-12GM50-E2
KFD2-SR2-EX2.W
NCN8-18GM40-NO-V1
RVI50N-09BK6A3TN-500
RVI78N-10CALA31N-1000
RVI78N-10CK2A31N-1024
RVI78N-10CK2A31N-1000
NBB5-18GM50-E0
NBB5-18GM50-E2
9401 10*10
NJ15+U1+E2
NBN4-12GM50-E2-V1
NJ30+U1+E2
OBT200-18GM60-E5
NCN4-12GM35-N0
NJ15-30GM50-A2-V1
RL-10*10
CN1446
OBE10M-18GM60-S-V1
OBE10M-18GM60-SE5
NBN15-30GM40-Z0
NJ20+U1+W
V1-G-2M-PVC
NBN8-18GM60-WS
V1-W-2M-PVC
OBT200-18GM60-E4
LVL-T1-G3S-E5PG-NA
NBB15-30GM50-WS
NJ40+U1+E2
KFD2-STC4-EX1
V15-G-2M-PVC
KFD2-STC4-EX2
9401 8*8
KFD2-SR2-EX1.W
NJ15+U+W
NCN25-F35-A2-250-V1
KFD2-CD-EX1.32
NBN5-F7-E2
KFD2-CD-EX1.32
V15-W-2M-PVC
HTL-Q05NIE
NBB1.5-8GM60-A0
NBB2-12GM50-E0(6M)
NBB2-12GM50-E0 PUR(3M)
NBB2-12GM50-E2(6M)
NBB2-12GK50-E2
NBN4-12GM50-E0(6M)
NBN4-12GM50-E0(10M)
NBB5-18GM50-E0
NBB5-18GM50-E2(12.10.5.6M
NBN8-18GM50-E2
NJ1.5-8GM-N(10M)
NJ1.5-8GM50-E(5M)
NJ8-18GM50-E
NJ8-18GM50-A2
HTL-Q05NIS
CJ40-FP-A2-P1
10-116511A-1024
RVI50N-09BK6A3TN-500(6M)
RVI50N-09BK6A3TN-1000
RVI50N-09BAAR3TN-1000
NBB5-18GM60-WS
UJ1000-30GM-H-12
NJ0.8-4.5-N
85-10381-R-1000
ATS48C41Q
OBT200-E4
NBN5-F7-E0/E2
NBN8-18GM60-WS
UJ1000-30GM-H-12
NJ0.8-4.5-N
85-10381-R-1000
ATS48C41Q
ML5-8-400/32/115
ML5-8-400/30/115
UC500-30GM-IUK2-V15
V1-W-E2-5M-PUR
NBB1.5-8GM50-E0
NBB1.5-8GM50-E2
NCB50-FP-A2-P1
NJ15+U1+E2
OBT200-18GM60-E4
OBT500-18GM60-E5
UB300-18GM40-I-V1
RVI50N-09BK0A3TN-00360
85-10381-R-1000
9401 6*6
CJ6-18GK-N
LFL3-CK-U-PVC5
NBB0.8-5GM25-E2
NBB5-18GM50-E2-V1
NBN2-8GM50-E2-V3
NBN4-12GM60-A2
NCB1.5-6.5M25-N0-V1
NCB2-12GM40-Z1
V1-W-5M-PUR
NJ2-12GM40-E2
NJ2-12GM40-E2-V1
NBN15-30GM50-E0
NCN4-12GM40-Z0
NJ2-8GM40-E2
NJ5-18GM50-E2
NJ8-18GM50-A
NJ8-18GM50-A2
NJ10-30GK-N
NCN20+U1+Z2
OBT500-18GM70-E4
OBT500-18GM60-E4
RJ21-N
KFD2-STC4-EX1
UJ1000-30GM-H12
V1-W-N-5M-PUR
V3-GM-5M-PUR
NJ0.8-4.5-N
KFD2-GR-EX1
KFD2-STV4-EX1.20-1
KFD2-STV4-EX2-1
Z788
KFA5-SR2-EX1.W
KFD0-CC-EX1
PW2-P.PTP
KFD2-GUT-EX1.D
KFD2-RR-EX1
ML5-8-400/32/115
NBB4-12GM50-E0
NBN8-18GM60-WS
SL3010-X1/GS130-333
V1-G
NJ15+U1+W-T
NBB2-12GM50-E2
NBB2-12GM50-E0
NBN8-18GM50-E0-V1
CJ8-18GM-E2-V1
NBB10-30GM50-E0
M5/MV5/30/115
M5/MV5/32/115
NBB8-18GM50-E2-V1
NBB2-8GM50-E0
NCB1.5-12GM45-E2-D-V1
NCB1.5-18GM60-E2-D-V1
NJ2-12GK-N
H50
PR-03
KFD2-EB.R4A.B-Y
SJ5-N
PW2-PK-KE-USB
NBN8-18GM50-E2-V1
NBN4-12GM40-Z0
NBB8-18GM50-E2
NBB10-30GM50-E2
RVI58N-011K1A61N-1000
RVI58N-011K1R61N-1000
RVI50N-09BKOA3TN-600
RVI50N-09BKOA3TN-2000
RVI50N-09BKOA3TN-2048
NBN15-30GM40-Z0
NBN8-18GM40-Z0
NBN4-12GM50-E0
NBB10-30GM40-Z0
NJ4-12GM-N
9402 8*8
9409 10*10
9416
42306C
V1-W
V1-G
9401 10*10
9401 8*8
KW 10*10
KW 8*8
9401 12*12
NJ4-12GM-N1
NJ20+U1+A2  NJ40+U10+E2  MLV11-54-G/47/112  RL39-55/32/35/40A/82A/116
RL39-54/32/40A/82A/116  MVL11-54-G/47/112  RLK39-54-Z/3/40a/116
NBB20-L2-A2-V1  VAA-4E4A-KE-ZE/E2  VAA-4E4A-KE-ZE/R
NJ20+U10+E2  PVS58N-011AGROBN-0013
■奧地利Kraus&Naimer中字藍系列開關:
CA10-A007、CA10-A058、CA10-A200、CA10-A201、CA10-A211、CA20、CH10、CH16、KG125、KG250、KH、C43-316、C32、CG4、CG8、L350-L2000、L600、AD11S、CAD11等,部份産品有大量庫存,歡迎来電諮詢或訂貨!
CA10-A058
CA10-A007
CA10-A262-620E
CA10-A211-603E
CA10-A200-620E
CA10-A201-620E
CA10-A212-603E
CA10-A202-603E
CA10-A004
CA10-A222
CA10-A220
CA10 PKZ026(127)
CA10 PKZ026(128)
CA10 PKZ026(126)
CA10 PKZ038EG
CA10 PKZ058
CG4 A202-620FS2
U20313/001 A021
KG32 T203/33KL1
CA10B RC3426 U31776/001
一,C,CA,,CAD,CH,系列开关10A-315A,L开关350-2400A.C开关为一般应用而设计,建议用于仪表,隔离器和马达控制;L开关为通,断负载而设计的 ,通常用于阻性负载或低感性负载。型号:CA4,CA4-1,CA10,CA11,CA20,CA25,CAD11,CAD12,CA10B,CA11B,CA20B,CA25B,C26,C32,C42,C43,C80,C125,L350,L351,L630,L631,L1000,L1001,L1250,L1251,C315,C316,L400,L600,L800,L1200,L1600,L2000.
二,A和AD系列开关6A-40A.A开关每层有4对触点,这些开关有各种不同的功能,且只需很短的安装深度,可达36个开关位置,每个开关柱12层有48对触点。型号:AD11,AD12,A11,A14,A11C,A14C,A30.
三,主开关和急停开关25A-1250A;维修开关25A-250A;隔离开关25A-315A;型号:KG10,KG10A,KG10B,KH16,KH16B,KG20,KG20A,KG20B,KH20,KH20B,KG32,KG32A,KG32B,KH32,KG41,KG41B,KH40,KG64,KG64B,KH63,KG80,KG80C,KH80,KG100,KG100C,KG125,KG160,KG210,KG250,KG315,C316.
四,CG开关10A-25A.CG开关紧凑小巧,适用于控制及仪表应用,CG系列开关的接点依照VDE0106,第100部分的标准,设计成“护指”,接点容易接线及取出,CG4开关的触点均为镀金,故特别适合电子线路以及有化学腐蚀性的环境中。型号:CG4,CG4-1,CG6,CG7,CG8,CG9,CG10,CG11,CG12,CG16,CH10B,CH16B,CHR10B,CHR16B.
五,D系列开关,至25A.D系列开关具有独特的抗腐蚀触点,并可再30mV的低压情况下使用,常用于校准和半导体电路,也用于控制继电器和接触器。型号:DH10,DH11,DH12,DHR10,DHR11,DHR12,DK10,DK11,DK12,DKR10,DKR11,DKR12,DH10B,DH11B,DH12B,DHR10B,DHR11B,DHR12B.
六,KG开关25A-250A,K开关63A-3000A.KG系列开关和K系列均是很好的断路器,他们具有完美的通断性能,尤其适用作器械工具,分布系统及开关柜的隔离开关和安全开关。KG“通/断”型开关具有独特的大接点绝缘距离,且易于接线。“通/断”开关最多可至8极,而双掷开关最高可至3极。型号:KG10,KG20,KG32,KG41,KG64,KG80,KG100,KG126,KG127,KG161,KG162,KG251,KG316,KF401,KF631,KF801,KF1251.
七,X系列开关63A-630A.X开关通常用于负载,抽头及强电开关,其每层有6对触点,这种紧密结构使其长度极小,安装方便。型号:X63,X160,X100,X200,X400.
八,密封盒和附件。有大量的附件供选用:门互锁,推—拉几个,钥匙和挂锁机制,控制和指示机构,交流马达驱动等,以及大量塑料的或金属的密封盒。
主开关和急停开关25A-250A
维修开关25A-250A
按IEG947-3,IEC204,VDE0113
隔离开关25A -315A
按IEC947-3,VDE0660标准
C-,CA-,CAD-,CH- 开关10A-315A,L开关350A-2400A
C开关为一般应用而设计,建议用于仪表,隔离器,双掷和马达控制
L开关为通,断负载而设计的,通常用于阻性负载或低感性负载
密封盒和附件
有大量的附件供选用:门互锁,推-拉机构,钥匙和挂锁机构,控制和指示机构,交流马达驱动等,以及大量塑料的或金属的密封盒
A-和AD- 开关6A-40A
A开关每层有4对触点,这些开关有各种不同的功能,且只须很短的安装深度,可达36个开关位置,每个开关柱12层有48对触点。
CG- 开关10A-35A
紧密小巧的CG-开关适用于控制及仪表应用,CG-开关的接点依照VDE0106,第100部分的标准,设计成“护指”,接点容易接线及取出。CG4开关的触点均镀金,故特别适合电子线路以及有化学腐蚀性的环境使用。
D-开关至25A
D-开关具有独特的抗腐蚀触点,并可在30mV低压情况下使用,这种带保护性的密封触点可由把手转动操作,D-开关常用于校准和半导体电路,也用于控制继电器和接触器。
X-开关至63A-630A
X-开关常用于负载,抽头及强电开关,其每层有6对触点,这种紧密结构使其长度极小,安装方便。
KG-开关24A-250A和K-开关63A-3000A
KG-开关和K-开关均是很好的断路器,他们具有完美的通断功能,尤其适用作机械工具,分布系统及开关柜的隔离开关和安全开关。KG“通/断”型开关具独特的大接点绝缘距离,且易于接线。“通/断”开关最多可至8极,而双掷开关最高可至3极。
接触器16A-125A和马达启动器4KW-55KW
包括控制继电器,马达接触器。二极和四极输出接触器,热接触器,热过载继电器。
接触器140A-500A和热过载继电器50A-610A
包括三极输出接触器和相应的热过载继电器,用于马达,变压器和电容器。
P-系列,按钮及指示器
全系列的按钮和指示器包括三种基本颜色黑,灰和金属色,圆或方形,触点座和附件可快速耦合至本体上,常开和常闭触点特别适合于电子的应用。这些开关用途广泛,适用于:机械制造、自控系统、仪器及仪表、船舶制造、航天航海工业、建筑物配电系统、汽车工业及通讯电源等
CA10,CA11,CA20,CA25,CAD11,CAD12,CA10B,CA11B,CA20B,CA25B,C26,C32,C42,C43,C80,C125,L350,L351,L630,L631,L1000,L1001,L1250,L1251,C315,C316,L400,L600,L800,L1200,L1600,L2000.AD11,AD12,A11,A14,A11C,A14C,A30KG10,KG10A,KG10B,KH16,KH16B,KG20,KG20A,KG20B,KH20,KH20B,KG32,KG32A,KG32B,KH32,KG41,KG41B,KH40,KG64,KG64B,KH63,KG80,KG80C,KH80,KG100,KG100C,KG125,KG160,KG210,KG250,KG315,C316.CG4,CG4-1,CG6,CG7,CG8,CG9,CG10,CG11,CG12,CG16,CH10B,CH16B,CHR10B,CHR16B.DH10,DH11,DH12,DHR10,DHR11,DHR12,DK10,DK11,DK12,DKR10,DKR11,DKR12,DH10B,DH11B,DH12B,DHR10B,DHR11B,DHR12B63A-3000A.KG10,KG20,KG32,KG41,KG64,KG80,KG100,KG126,KG127,KG161,KG162,KG251,KG316, KF401,KF631,KF801,KF1251 CA20 A291-600E/S0V840D CG4 A233-600FS2 CH10 A200-600E CH10 A220-600E CH10 A200FT2/V750D KG160 T203/04E KG160 T203/09VE A14 A476-600E/S1V840A CG4 SGH051-FS2 S00 V750D CG4 SGH052-FS2 S00 V750D CA20X A202/220E K2H053/C K2H052/C CA10 A117-F51289 CA10 A220-F51289 CA10 A731-F51289 CA10 A214-F51289 CA10 A178-F51289 CA4 PC6382-3E CA10 A230-600E CA10 A290-600FS2S00V750D/EFO CA10 231-600E C26 SG4746/D120E CH10 A210-600-FT2 CH10 A220-600-FT2 CH10 A230-A600-FT2 CH10 A231-A600-FT2 CH10 A232-A600-FT2 CH10 A233-A600-FT2 CH10 A8188-500-FT2+G211 CH10 A214-A600-FT2+G211 CH10 A200-500-FT2V750D3 C125 T203/08E C125 T203/08E C125 C117750SF98454/004DES 380V/160A X63 A242 F26851/004DES 4档500V/63A (X63 A242-600E) KG32B T303-VE24 (T203/8G20002VE) KG160 T203/SGZ0002VE DH11B PC6020-1E DH11B PC4800-2E DH11B PC3263-2E DH11B PC3379-3E/SOM470 C32 A202*ER/S1 M275-CA10 A341-000*E CA10 PC3034-3 E24 CA10 PC6328-2 E24 CA10 PC8386-1 E24 CA10 PC8413-3 E24 CH10 A220-614E22 CH10 A214-609EF CH10 D-636*01EF CH10 D-636*02EF CH10 D-630*01E22 KG315 T203/05 E24 3P/315A CG4 A233-600F32
CA4,CA10,CA11,CA20,CAD11,CA10B,CA20B开关:
CA4 ,CA4-1,CL4,CA10,CA10R,CA11,CA20,CA20R,CA25,CAD11,CAD11R,CAD12,CAD12R,CL10,CA10B,CA11B,CA20B,CA25B,CA40,CA50,CA63,C26,C32,C42,C43,C80,C125,L350,L351,L630,L631,L1000,L1001,L1250,L1251,C315,C316,L400,L600,L800,L1200,L1600,L2000
CG4,CG8,CH10,CH10R,CH11,CH16,CHR10,CHR16开关:CG4,CG4-1,CGD4-1,CG6,CH6,CHR6,CG8,CG8R,CH10,CH10R,CH11,CH12,CH16,CH16R,CHR10,CHR10R,CHR11,CHR12,CHR16,CHR16R,CH10B,CH16B,CHR10B,CHR16B
DH10,DH10B,DHR10,DH11,DH11B,DHR11开关:
DH10,DH10B,DHR10,DHR10B,DK10,DKR10,DH11,DH11B,DHR11,DHR11B,DK11,DKR11,DH12,DH12B,DHR12,DHR12B,DK12,DKR12,D14,D14P,D14R
KC开关 :
KC16,KC16B,KC20,KC20B,KC25,KC25B,KC32,KC32B ; ; ; ; 开关 ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ;
KG10A,KG20,KG20B,KG32,KG64,KG80,KG125开关:
KG10A ,KG10B,KG20 ; ; ,KG20A,KG20B ; ; ,KG32 ; ; ,KG32A ; ; ; ,KG32B,KG41,KG41B,KG64,KG64B,KG80,KG80C,KG100,KG100C,KG105,KG105C,KG125,KG126 ,KG127,KG160,KG161,KG162,KG210,KG211,KG212,KG250,KG251,KG252,KG315,KG316,KG317 ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ;
KH,KHR开关:
KH16,KH20,KH25,KHR16,KHR20,KHR25,KH16B,KH20B,KH25B,KHR16B,KHR20B,KHR25B,KH32,KH40,KHR32,KHR40,KH63,KH80,KHR63,KHR80
A开关:
AD11,AD12,A11,A14,A11C,A14C开关
X开关:
X63,X160,X100,X200,X400,X630开关CA系列,CA10 PC3005-1、CA10 A023-620E、CA10 A201-600*FT2 V750D/3H、
CA10 C65391、CA10 HKA271、CA10 SF3262 PR1、CA10A A210-600FT2、CA10B A8189-600FT2+G211、 CA4 US6038、C42X 1-A205-FS1-V、
CG系列:CG4 A206、CG8 PC6012-2 FS2、CG16B A-8550-600EGAF*A-GN15、
CH系列:CH10 PC3196-2EF/M470/G211、CH10 D-K747*01 KN2、
转换开关主要型号:
KC系列:KC10A T203/04、KC125A T206/SG2002VE
KG系列:KG10A T203/04E、KG20B T103/09VE、KG41 T303/SGZ621E
非常规系列:C32 C3675-920*DF、D11A A210-600E、DH11B A220、SO V845
蓝系列开关的型号是非常有规律的,比如CA10这是一个系列的意思,10代表的是电流多少的意思、即10的额定电流是10A,
 ; ; ; CA10B的B代表它的弹簧是加强型的,KG10A的A是一般型的,当然了B的价格相对于其它型号就要贵些。
CA10 PC5034-5E SIV760/A2
CA10 PC9010-2E
CA10 PC9100-4E
CA10 PC5205-2E SIV760/A2
KG41 T303/D-A094 PFD4
CA10 U619251003 PC9016
PC6369-5E24
PC6371-7E24
PC6721-2E24
PC6722-3E24
CA10 PC4003
CA10 PC5095-2E S1V760/A2
CA10 PC9019-3E
KG125 T103104E
CA10 XD0095-4
CA10 PC4003-1E
CA10 PC4404-5
CA10 PC5043-1E S1V760/A2
CA10 PC9010-2
CA10 PC9014-3
CA10 PC9016-3
CA10 PC9092-4
CA10 PC9100-4
CA10 PC5034-5E S1V760/A2
CA10A007-600E24
CA10A200-600E24
CA10A210-600E24
CA10A714-600E24
CA10 A007-G001-EG
CAD11-A211-600E/SOV110VA
CA10-A292-621VE1
CA10 A200-600E
CA10 A211-600E
CA10 A261-620E
CA10 A362-600E
CA10 PC5031-5E S0V760/A2
DH12D-B904-03FT2
CA10 PC9024-3
CA10 PC9100-4E
CA10 XD0095-4
CA10 XD0129-7
CA20 A220 603 EF
CA10-A292-621VE1
CA10 PC4003
CA10 PC4404
CA10 PC9014
CA10 PC9016-3
CA10 A200-600E
CA10 A211-600E
CA10 A261-620E
CA10 A362-600E
CA10-A007
CA10-A262-620E
CA10-A211-603E
CA10-A200-620E
CA10-A201-620E
CA10-A212-603E
CA10-A202-603E
CA10-A004
CA10-A222
CA10-A220
CA10 PKZ026(127)
CA10 PKZ026(128)
CA10 PKZ026(126)
CA10 PKZ038EG
CA10 PKZ058
CG4 A202-620FS2
U20313/001 A021
KG32 T203/33KL1
常用型号: CG4 CG4-1 CA10 CA10B CA11 CA11B CA20 CA20B CH10 CH20 CH11 C26 C32 C42 C43 C80 C125 C316 C315 L350 L351 L400 L600 L630 L631 L800 L1000 L1001 L1200 L1250 L1251 L1600 L2000 CAD11 CAD12 KG10B KG20B KG32B KG41B KG64B KG80 KG80C KG100 KG100C KG10A KG20A KG32A CA10 CA11,CA20,CA25,CAD11, ,CA10B,CA11B,CA20B,CA25B,C26,C32,C4 2,C43,C80,C125,L350,L351,L630,L631,L1000,L10 01,L1250,L1251,C315,C316,L400,L600,L800,L120 0,L1600,L2000.AD11,AD12,A11,A14,A11C,A14C,A3 0KG10,KG10A,KG10B,KH16,KH16B,KG20,KG20A,KG20 B,KH20,KH20B,KG32,KG32A,KG32B,KH32,KG41,KG41 B,KH40,KG64,KG64B,KH63,KG80,KG80C,KH80,KG100 ,KG100C,KG125,KG160,KG210,KG250,KG315,C316.C G4,CG4- 1,CG6,CG7,CG8,CG9,CG10,CG11,CG12,CG16,CH10B, CH16B,CHR10B,CHR16B.DH10,DH11,DH12,DHR10,DHR 11,DHR12,DK10,DK11,DK12,DKR10,DKR11,DKR12,DH 10H11B,DH12B,DHR10B,DHR11B,DHR12B63A- 3000A.KG10,KG20,KG32,KG41,KG64,KG80,KG100,KG 126,KG127,KG161,KG162,KG251,KG316, KF401,KF631,KF801,KF1251 CA20 A291- 600E/S0V840D CG4 A233-600FS2 CH10 A200-600E CH10 A220-600E CH10 A200FT2/V750D KG160 T203/04E KG160 T203/09VE A14 A476- 600E/S1V840A CG4 SGH051-FS2 S00 V750D CG4 SGH052-FS2 S00 V750D CA20X A202/220E K2H053/C K2H052/C CA10 A117-F51289 CA10 A220-F51289 CA10 A731-F51289 CA10 A214- F51289 CA10 A178-F51289 CA4 PC6382-3E CA10 A230-600E CA10 A290-600FS2S00V750D/EFO CA10 231-600E C26 SG4746/D120E CH10 A210-600-FT2 CH10 A220-600-FT2 CH10 A230-A600-FT2 CH10 A231-A600-FT2 CH10 A232-A600-FT2 CH10 A233- A600-FT2 CH10 A8188-500-FT2+G211 CH10 A214- A600-FT2+G211 CH10 A200-500-FT2V750D3 C125 T203/08E C125 T203/08E C125 C117750SF98454/004DES 380V/160A X63 A242 F26851/004DES 4档500V/63A (X63 A242-600E) KG32B T303-VE24 (T203/8G20002VE) KG160 T203/SGZ0002VE DH11B PC6020-1E DH11B PC4800- 2E DH11B PC3263-2E DH11B PC3379-3E/SOM470 C32 A202*ER/S1 M275-CA10 A341-000*E CA10 PC3034-3 E24 CA10 PC6328-2 E24 CA10 PC8386- 1 E24 CA10 PC8413-3 E24 CH10 A220-614E22 CH10 A214-609EF CH10 D-636*01EF CH10 D- 636*02EF CH10 D-630*01E22 KG315 T203/05 E24 3P/315A CG4 A233-600F32
1 图尔克产品大全, 全国最好的价位
 货号 型号 价格
69049 B 8141-0 (GERADE) 10068 BI20-G47-Y1
17193 MP -10D-AN7
69048 B 8241-0 (WINKEL) 14043 BI20R-W30-
DAN6X-H1141 17093 MP -10D-AP7
23100 BC10-M30-AZ3X 14042 BI20R-W30-DAP6X-
H1141 10078 MP -10D-Y1
23098 BC10-M30-RZ3X 13427 BI25-G47SR-FZ3X2
13263 MP -10H-UZ3X
25021 BC10-M30-VN4X 15748 BI25-G47SR-VN4X2
15770 MP -10H-VN4X
25020 BC10-M30-VP4X 15648 BI25-G47SR-VP4X2
15670 MP -10H-VP4X
23104 BC10-P30SR-FZ3X2 4602140 BI2-EG08-
AN6X 17194 MP -15D-AN7
25051 BC10-P30SR-VN4X2 4602160 BI2-EG08-
AN6X-H1341 17094 MP -15D-AP7
25050 BC10-P30SR-VP4X2 4602150 BI2-EG08-
AN6X-V1131 10079 MP -15D-Y1
20100 BC10-S30-Y1X 4602040 BI2-EG08-AP6X
13264 MP -15H-UZ3X
23105 BC20-CP40-FZ3X2 4602060 BI2-EG08-AP6X-H1341
15771 MP -15H-VN4X
25161 BC20-CP40-VN4X2 4602050 BI2-EG08-AP6X-V1131
15671 MP -15H-VP4X
25160 BC20-CP40-VP4X2 4669500 BI2-EG08K-AN6X
69452 MW 47 MONTAGEWINKEL
23103 BC20-K40SR-FZ3X2 4669560 BI2-EG08K-
AN6X-H1341 2580102 NC50-CP80-VN4X2
25101 BC20-K40SR-VN4X2 4669550 BI2-EG08K-
AN6X-V1131 2580202 NC50-CP80-VP4X2
25100 BC20-K40SR-VP4X2 4669400 BI2-EG08K-
AP6X 46473 NI 15-G30-AN6
26201 BC5-Q08-AN6X2 4669460 BI2-EG08K-AP6X-
H1341 47403 NI10-G18-AN7
26211 BC5-Q08-AN6X2-V1131 4669450 BI2-EG08K-
AP6X-V1131 47402 NI10-G18-AP7
26200 BC5-Q08-AP6X2 4612300 BI2-EH6,5-AN6X
43301 NI10-G18-AZ3
26210 BC5-Q08-AP6X2-V1131 4612320 BI2-EH6,5-
AN6X-V1131 43311 NI10-G18SK-AZ3X
25035 BC5-S185-AP4X 4612200 BI2-EH6,5-AP6X
43313 NI10-G18SK-RZ3X
25030 BC5-S18-AP4X 4612220 BI2-EH6,5-AP6X-
V1131 40161 NI10-G18SK-Y1X
20060 BC5-S18-Y1X 4610100 BI2-EH6,5K-AN6X
10061 NI10-G18-Y1
4602340 BI1,5-EG08-AN6X 4610120 BI2-EH6,5K-AN6X-
V1131 40151 NI10-G18-Y1X
4602360 BI1,5-EG08-AN6X-H1341 4610000 BI2-EH6,5K
-AP6X 46641 NI10-K20-AN6X
4602350 BI1,5-EG08-AN6X-V1131 4610020 BI2-EH6,5K
-AP6X-V1131 46640 NI10-K20-AP6X
4602240 BI1,5-EG08-AP6X 4635500 BI2-G12-AN6X
43585 NI10-K20-AZ3X
4602260 BI1,5-EG08-AP6X-H1341 47301 BI2-G12-AN7
43586 NI10-K20-RZ3X
4602220 BI1,5-EG08-AP6X-V1131 4635400 BI2-G12-
AP6X 46648 NI10-K20SK-AN6X
4669140 BI1,5-EG08K-AN6X 47300 BI2-G12-AP7
46646 NI10-K20SK-AP6X
4669150 BI1,5-EG08K-AN6X-H1341 47300 BI2-G12-AP7
43591 NI10-K20SK-AZ3X
4672540 BI1,5-EG08K-AN6X-V1131 40621 BI2-G12-D0
-2-RS4 43593 NI10-K20SK-RZ3X
4669040 BI1,5-EG08K-AP6X 40110 BI2-G12SK-
Y1X 10072 NI10-K20-Y1
4669050 BI1,5-EG08K-AP6X-H1341 10054 BI2-G12-Y1
40153 NI10-M18-Y1X-H1141
4672440 BI1,5-EG08K-AP6X-V1131 40100 BI2-G12-Y1X
43511 NI10-P18SK-AZ3X
1003600  BI1,5-EG08K-Y1  17705 BI2-H12-AN7
43513 NI10-P18SK-RZ3X
1003620 BI1,5-EG08K-Y1-H1341  17583 BI2-H12-AP7
40361 NI10-P18SK-Y1X
4612100 BI1,5-EH6,5-AN6X 10228 BI2-H12-Y1
10317 NI10-P18-Y0/S100
4612120 BI1,5-EH6,5-AN6X-V1131 46606 BI2-K11-AN6
4035121 NI10-P18-Y0X/S97
4612000 BI1,5-EH6,5-AP6X 46605 BI2-K11-AP6
10096 NI10-P18-Y1
4612020 BI1,5-EH6,5-AP6X-V1131 46609 BI2-K11-
AP6X 40351 NI10-P18-Y1X
4610640 BI1,5-EH6,5K-AN6X 46616 BI2-K11SK-
2 图尔克产品大全, 全国最好的价位
AN6X 1645420 NI12U-EG18SK-AN6X
4610840 BI1,5-EH6,5K-AN6X-V1131 46615 BI2-K11SK-
AP6X 1645400 NI12U-EG18SK-AP6X
4610540 BI1,5-EH6,5K-AP6X 10070 BI2-K11-Y1
1581560 NI12U-EM18-AN4X
4610740 BI1,5-EH6,5K-AP6X-V1131 16690 BI2-M12-
AP6X-H1141/S34 1581561 NI12U-EM18-AN4X-H1141
1004600 BI1,5-EH6,5K-Y1 46061 BI2-M12T-AN6X
1645320 NI12U-EM18-AN6X
4604501 BI1,5-GS880-AN6X 46060 BI2-M12T-
AP6X 1645350 NI12U-EM18-AN6X-H1141
4604401 BI1,5-GS880-AP6X 16402 BI2-M12-
VN6X 1581460 NI12U-EM18-AP4X
1004401 BI1,5-GS880-Y1 16302 BI2-M12-VP6X
1581461 NI12U-EM18-AP4X-H1141
4604301 BI1,5-HS865-AN6X 40102 BI2-M12-
Y1X-H1141 1645300 NI12U-EM18-AP6X
4604201 BI1,5-HS865-AP6X 40310 BI2-P12SK-
Y1X 1645340 NI12U-EM18-AP6X-H1141
1004201 BI1,5-HS865-Y1 10302 BI2-P12-Y0/S100
1581500 NI12U-M18-AN4X
4600510 BI1,5U-EG08-AN6X 4030021 BI2-P12-
Y0X/S97 1581550 NI12U-M18-AN4X-H1141
4600550 BI1,5U-EG08-AN6X-H1341 10093 BI2-P12-Y1
1645120 NI12U-M18-AN6X
4600530 BI1,5U-EG08-AN6X-V1131 40300 BI2-P12-Y1X
1645150 NI12U-M18-AN6X-H1141
4600500 BI1,5U-EG08-AP6X 16190 BI2-Q12-
AN6X-H1141 1581400 NI12U-M18-AP4X
4600540 BI1,5U-EG08-AP6X-H1341 16090 BI2-Q12-
AP6X-H1141 1581450 NI12U-M18-AP4X-H1141
4600520 BI1,5U-EG08-AP6X-V1131 13090 BI2-Q12-
AZ31 1645100 NI12U-M18-AP6X
4617030 BI10-EM30D-AP6X/S120 13200 BI2-Q12-
RZ31X 1645140 NI12U-M18-AP6X-H1141
4617035 BI10-EM30D-VP6X/S120 16195 BI2-Q21SR-
AN6X 1581551 NI12U-MT18-AN4X-H1141
44700 BI10F-Q26-AD4X/S34 16095 BI2-Q21SR-
AP6X 1645250 NI12U-MT18-AN6X-H1141
44710 BI10F-Q26-AD4X-H1141/S34 44530
BI2-S12-AD4X 1581451 NI12U-MT18-AP4X-H1141
46471 BI10-G30-AN6 46531 BI2-S12-AN6X
1645240 NI12U-MT18-AP6X-H1141
46954 BI10-G30-AN6X-B1141 46521 BI2-S12-
AN6X-H1141 1645720 NI12U-P18SK-AN6X
46958 BI10-G30-AN6X-B1441 46530 BI2-S12-
AP6X 1645700 NI12U-P18SK-AP6X
47501 BI10-G30-AN7 4653023 BI2-S12-AP6X/S100
1645520 NI12U-S18-AN6X
46470 BI10-G30-AP6 16645 BI2-S12-AP6X/S97
1645620 NI12U-S18-AN6X-H1141
46965 BI10-G30-AP6X-B1141 46520 BI2-S12-
AP6X-H1141 1645500 NI12U-S18-AP6X
46928 BI10-G30-AP6X-B1141/S34 13020 BI2-S12-
AZ31X 1645600 NI12U-S18-AP6X-H1141
46969 BI10-G30-AP6X-B1441 1302001 BI2-S12-
AZ31X/S100 15735 NI13F-Q34-AN4X2
47500 BI10-G30-AP7 1302002 BI2-S12-AZ31X/S97
15635 NI13F-Q34-AP4X2
43450 BI10-G30-AZ3 13120 BI2-S12-RZ31X
15736 NI13T-Q34-AN4X2
43722 BI10-G30-AZ3X-B1131 1580360 BI2U-EM12-
AN4X 15636 NI13T-Q34-AP4X2
43726 BI10-G30-AZ3X-B1431 1580361 BI2U-EM12-
AN4X-H1141 4417205 NI14-G18K-AD4X
43452 BI10-G30-RZ3 1580260 BI2U-EM12-AP4X
4430105 NI14-G18K-AG4X
43460 BI10-G30SK-AZ3X 1580261 BI2U-EM12-AP4X-
H1141 4617400 NI15-EM30D-AP6X/S120
43462 BI10-G30SK-RZ3X 1580300 BI2U-M12-AN4X
4617410 NI15-EM30D-VP6X/S120
40220 BI10-G30SK-Y1X 1580350 BI2U-M12-AN4X-H1141
47503 NI15-G30-AN7
10062 BI10-G30-Y1 1580200 BI2U-M12-AP4X
47502 NI15-G30-AP7
40200 BI10-G30-Y1X 1580250 BI2U-M12-AP4X-H1141
43451 NI15-G30-AZ3
4617010 BI10-M30-AP6X/S120 1580351 BI2U-MT12-
AN4X-H1141 46707 NI15-G30K-AP6X
3 图尔克产品大全, 全国最好的价位
 16694 BI10-M30-AP6X-H1141/S34 1580251 BI2U-MT12-
AP4X-H1141 43453 NI15-G30-RZ3
4316410 BI10-M30-AZ3X/S120 14045 BI30R-W30-
DAP6X-H1141 46483 NI15-G30SK-AN6X
15355 BI10-M30-LIU 4405030 BI3-G12K-AD4X
46482 NI15-G30SK-AP6X
46191 BI10-M30T-AN6X 4430000 BI3-G12K-AG4X
43461 NI15-G30SK-AZ3X
46190 BI10-M30T-AP6X 1620150 BI3-Q06-AN6X2
43463 NI15-G30SK-RZ3X
43170 BI10-M30T-AZ3X 1620100 BI3-Q06-AP6X2
40221 NI15-G30SK-Y1X
43172 BI10-M30T-RZ3X 1634420 BI3U-EG12SK-AN6X
10063 NI15-G30-Y1
15714 BI10-M30-VN4X 1634400 BI3U-EG12SK-AP6X
40201 NI15-G30-Y1X
15614 BI10-M30-VP4X 1634320 BI3U-EM12-AN6X
4617210 NI15-M30-AP6X/S120
40202 BI10-M30-Y1X-H1141 1634350 BI3U-EM12-
AN6X-H1141 16695 NI15-M30-AP6X-H1141/S34
16161 BI10NF-M30-AN6X 1634300 BI3U-EM12-AP6X
4316506 NI15-M30-AZ3X/S120
16061 BI10NF-M30-AP6X 1634340 BI3U-EM12-AP6X-
H1141 46192 NI15-M30T-AP6X
16215 BI10NF-S30-AN6X 1634120 BI3U-M12-AN6X
43171 NI15-M30T-AZ3X
16115 BI10NF-S30-AP6X 1634150 BI3U-M12-AN6X-H1141
43173 NI15-M30T-RZ3X
46596 BI10-P30SK-AN6X 1634100 BI3U-M12-AP6X
15715 NI15-M30-VN4X
46595 BI10-P30SK-AP6X 1634140 BI3U-M12-AP6X-H1141
15615 NI15-M30-VP4X
43560 BI10-P30SK-AZ3X 1634250 BI3U-MT12-AN6X-
H1141 40203 NI15-M30-Y1X-H1141
43562 BI10-P30SK-RZ3X 1634240 BI3U-MT12-AP6X-
H1141 43561 NI15-P30SK-AZ3X
40410 BI10-P30SK-Y1X 1634720 BI3U-P12SK-AN6X
43563 NI15-P30SK-RZ3X
16203 BI10-P30SR-AN6X 1634700 BI3U-P12SK-AP6X
40411 NI15-P30SK-Y1X
16116 BI10-P30SR-AP6X 1634520 BI3U-S12-AN6X
16204 NI15-P30SR-AN6X
13420 BI10-P30SR-FZ3X2 1634620 BI3U-S12-
AN6X-H1141 16117 NI15-P30SR-AP6X
15752 BI10-P30SR-VN4X2 1634500 BI3U-S12-
AP6X 13421 NI15-P30SR-FZ3X2
15652 BI10-P30SR-VP4X2 1634600 BI3U-S12-
AP6X-H1141 15753 NI15-P30SR-VN4X2
10233 BI10-P30-Y0/S100 15697 BI40-CP80-
VP4X2 15653 NI15-P30SR-VP4X2
1023322 BI10-P30-Y0X/S97 46070 BI4-M12-
AP6X-H1141 10227 NI15-P30-Y0/S100
10097 BI10-P30-Y1 46080 BI4-M12T-AP6X
4040101 NI15-P30-Y0X/S97 3M
40400 BI10-P30-Y1X 4614510 BI5-EM18D-AP6X/S120
10098 NI15-P30-Y1
14039 BI10R-W30-DAN6X-H1141 4614900 BI5-EM18D-
VP6X/S120 40401 NI15-P30-Y1X
14038 BI10R-W30-DAP6X-H1141 46952 BI5-G18-
AN6X-B1341 44592 NI15-S30-AD4X
44590 BI10-S30-AD4X 46956 BI5-G18-AN6X-B1441
46593 NI15-S30-AN6X
46591 BI10-S30-AN6X 47401 BI5-G18-AN7
46583 NI15-S30-AN6X-H1141
46581 BI10-S30-AN6X-H1141 46963 BI5-G18-
AP6X-B1341 46592 NI15-S30-AP6X
46590 BI10-S30-AP6X 46918 BI5-G18-AP6X-
B1341/S34 4659201 NI15-S30-AP6X/S100
4659002 BI10-S30-AP6X/S100 46967 BI5-G18-
AP6X-B1441 4658202 NI15-S30-AP6X/S97
4659003 BI10-S30-AP6X/S97 47400 BI5-G18-AP7
46582 NI15-S30-AP6X-H1141
46580 BI10-S30-AP6X-H1141 43720 BI5-G18-
AZ3X-B1331 43555 NI15-S30-AZ3X
43554 BI10-S30-AZ3X 43724 BI5-G18-AZ3X-B1431
13758 NI15-S30-AZ3X/S100
13719 BI10-S30-AZ3X/S100 40631 BI5-G18-D0
-2-RS4 1375803 NI15-S30-AZ3X/S97
4355421 BI10-S30-AZ3X/S97 46704 BI5-G18K-
AP6X 43557 NI15-S30-RZ3X
43556 BI10-S30-RZ3X 43310 BI5-G18SK-AZ3X
15141 NI15-S30-VP4X/S100
15140 BI10-S30-VP4X/S100 43312 BI5-G18SK-
4 图尔克产品大全, 全国最好的价位
RZ3X 1514110 NI15-S30-VP4X/S97
1512221 BI10-S30-VP4X/S97 40160 BI5-G18SK-
Y1X 44661 NI20-CP40-AD4X
44702 BI10S-Q26-AD4X/S34 10060 BI5-G18-Y1
16224 NI20-CP40-AN6X2
44712 BI10S-Q26-AD4X-H1141/S34 40150
BI5-G18-Y1X 16024 NI20-CP40-AP6X2
1636420 BI10U-EG30SK-AN6X 44145 BI5-M18-
AD4X-H1141 42232 NI20-CP40-FDZ30X2
1636400 BI10U-EG30SK-AP6X 4611030 BI5-M18-
AP6X/S120 13401 NI20-CP40-FZ3X2
1582360 BI10U-EM30-AN4X 16692 BI5-M18-AP6X-
H1141/S34 13441 NI20-CP40-FZ3X2/S100
1582361 BI10U-EM30-AN4X-H1141 4310410 BI5-M18-
AZ3X/S120 1340123 NI20-CP40-FZ3X2/S97
1636320 BI10U-EM30-AN6X 16900 BI5-M18L-AP6X-
H1141/S34 15791 NI20-CP40-VN4X2
1636350 BI10U-EM30-AN6X-H1141 1536000 BI5-M18-LIU
15691 NI20-CP40-VP4X2
1582260 BI10U-EM30-AP4X 1536021 BI5-M18-LIU/S90
15046 NI20-CP40-VP4X2/S100
1582261 BI10U-EM30-AP4X-H1141 46141 BI5-M18T-
AN6X 1569101 NI20-CP40-VP4X2/S97
1636300 BI10U-EM30-AP6X 46140 BI5-M18T-AP6X
1011121 NI20-CP40-Y0X/S100
1636340 BI10U-EM30-AP6X-H1141 43120 BI5-M18T-
AZ3X 10432 NI20-CP40-Y0X/S97
1582300 BI10U-G30-AN4X 43122 BI5-M18T-RZ3X
10111 NI20-CP40-Y1X
1582350 BI10U-G30-AN4X-H1141 15711 BI5-M18-
VN4X 4417220 NI20-G30K-AD4X
1582200 BI10U-G30-AP4X 15611 BI5-M18-VP4X
4430110 NI20-G30K-AG4X
1582250 BI10U-G30-AP4X-H1141 40152 BI5-M18-
Y1X-H1141 16226 NI20-K40SR-AN6X
1582351 BI10U-GT30-AN4X-H1141 43510 BI5-P18SK-
AZ3X 16026 NI20-K40SR-AP6X
1582251 BI10U-GT30-AP4X-H1141 43512 BI5-P18SK-
RZ3X 13424 NI20-K40SR-FZ3X2
1636120 BI10U-M30-AN6X 40360 BI5-P18SK-Y1X
15756 NI20-K40SR-VN4X2
1636150 BI10U-M30-AN6X-H1141 10245 BI5-P18-
Y0/S100 15656 NI20-K40SR-VP4X2
1636100 BI10U-M30-AP6X 1024504 BI5-P18-Y0X/S97
13284 NI20NF-CP40-FZ3X2
1636140 BI10U-M30-AP6X-H1141 10095 BI5-P18-Y1
15784 NI20NF-CP40-VN4X2
1636250 BI10U-MT30-AN6X-H1141 40350 BI5-P18-Y1X
15684 NI20NF-CP40-VP4X2
1636240 BI10U-MT30-AP6X-H1141 16006 BI5-Q08-
AN6X2-V1131 1646420 NI20U-EG30SK-AN6X
1636720 BI10U-P30SK-AN6X 16005 BI5-Q08-
AP6X2-V1131 1646400 NI20U-EG30SK-AP6X
1636700 BI10U-P30SK-AP6X 16002 BI5-Q08-
VN6X2 1582560 NI20U-EM30-AN4X
1608710 BI10U-Q14-AN6X2 16001 BI5-Q08-VP6X2
1582561 NI20U-EM30-AN4X-H1141
1608510 BI10U-Q14-AN6X2-V1131 44560 BI5-S18-
AD4X 1646320 NI20U-EM30-AN6X
1608700 BI10U-Q14-AP6X2 46525 BI5-S18-AN6X-H1141
1646350 NI20U-EM30-AN6X-H1141
1608500 BI10U-Q14-AP6X2-V1131 4656022 BI5-S18-
AP6X/S100 1582460 NI20U-EM30-AP4X
1636520 BI10U-S30-AN6X 4656025 BI5-S18-AP6X/S97
1582461 NI20U-EM30-AP4X-H1141
1636620 BI10U-S30-AN6X-H1141 46524 BI5-S18-
AP6X-H1141 1646300 NI20U-EM30-AP6X
1636500 BI10U-S30-AP6X 43504 BI5-S18-AZ3X
1646340 NI20U-EM30-AP6X-H1141
1636600 BI10U-S30-AP6X-H1141 13734 BI5-S18-
AZ3X/S100 1582500 NI20U-G30-AN4X
4417010 BI12-G30K-AD4X 1373410 BI5-S18-AZ3X/S97
1582550 NI20U-G30-AN4X-H1141
4430010 BI12-G30K-AG4X 43506 BI5-S18-RZ3X
1582400 NI20U-G30-AP4X
1537800 BI15-CK40-LIU-H1141 1513402 BI5-S18-
VP4X/S100 1582450 NI20U-G30-AP4X-H1141
44660 BI15-CP40-AD4X 1513420 BI5-S18-VP4X/S97
1582551 NI20U-GT30-AN4X-H1141
5 图尔克产品大全, 全国最好的价位
 16223 BI15-CP40-AN6X2 1635420 BI5U-EG18SK-AN6X
1582451 NI20U-GT30-AP4X-H1141
16023 BI15-CP40-AP6X2 1635400 BI5U-EG18SK-AP6X
1646120 NI20U-M30-AN6X
16542 BI15-CP40-AP6X2/S34 1581360 BI5U-EM18-
AN4X 1646150 NI20U-M30-AN6X-H1141
42231 BI15-CP40-FDZ30X2 1581361 BI5U-EM18-
AN4X-H1141 1646100 NI20U-M30-AP6X
13400 BI15-CP40-FZ3X2 1635320 BI5U-EM18-AN6X
1646140 NI20U-M30-AP6X-H1141
13440 BI15-CP40-FZ3X2/S100 1635350 BI5U-EM18-
AN6X-H1141 1646250 NI20U-MT30-AN6X-H1141
13447 BI15-CP40-FZ3X2/S34 1581260 BI5U-EM18-
AP4X 1646240 NI20U-MT30-AP6X-H1141
1341015 BI15-CP40-FZ3X2/S97 1581261 BI5U-EM18-
AP4X-H1141 1646720 NI20U-P30SK-AN6X
15356 BI15-CP40-LIU 1635300 BI5U-EM18-AP6X
1646700 NI20U-P30SK-AP6X
15790 BI15-CP40-VN4X2 1635340 BI5U-EM18-AP6X-
H1141 1646520 NI20U-S30-AN6X
15690 BI15-CP40-VP4X2 1581300 BI5U-M18-AN4X
1646620 NI20U-S30-AN6X-H1141
15045 BI15-CP40-VP4X2/S100 1581350 BI5U-M18-
AN4X-H1141 1646500 NI20U-S30-AP6X
15090 BI15-CP40-VP4X2/S34 1635120 BI5U-M18-
AN6X 1646600 NI20U-S30-AP6X-H1141
15058 BI15-CP40-VP4X2/S97 1635150 BI5U-M18-
AN6X-H1141 1537802 NI25-CK40-LIU-H1141
10396 BI15-CP40-Y0X/S100 1581200 BI5U-M18-
AP4X 15746 NI25-G47-AN4X
10397 BI15-CP40-Y0X/S97 1581250 BI5U-M18-
AP4X-H1141 15646 NI25-G47-AP4X
10110 BI15-CP40-Y1X 1635100 BI5U-M18-AP6X
13089 NI25-G47-AZ3X
46185 BI15-M30-AP6X-H1141 1635140 BI5U-M18-
AP6X-H1141 13184 NI25-G47-RZ3X
46180 BI15-M30T-AP6X 1581351 BI5U-MT18-AN4X-
H1141 10069 NI25-G47-Y1
14041 BI15R-W30-DAN6X-H1141 1635250 BI5U-MT18-
AN6X-H1141 1538300 NI25U-CK40-AN4X2-H1141
14040 BI15R-W30-DAP6X-H1141 1581251 BI5U-MT18-
AP4X-H1141 1625710 NI25U-CK40-AN6X2-H1141
1538100 BI15U-CK40-AN4X2-H1141 1635240 BI5U-MT18-
AP6X-H1141 1538200 NI25U-CK40-AP4X2-H1141
1625610 BI15U-CK40-AN6X2-H1141 1635720 BI5U-P18SK
-AN6X 1625700 NI25U-CK40-AP6X2-H1141
1538000 BI15U-CK40-AP4X2-H1141 1635700 BI5U-P18SK
-AP6X 1623710 NI25U-CP40-AN6X2
1625600 BI15U-CK40-AP6X2-H1141 1635520 BI5U-S18-
AN6X 1623700 NI25U-CP40-AP6X2
1623510 BI15U-CP40-AN6X2 1635620 BI5U-S18-
AN6X-H1141 13425 NI30-K40SR-FZ3X2
1623500 BI15U-CP40-AP6X2 1635500 BI5U-S18-
AP6X 15758 NI30-K40SR-VN4X2
1540510 BI15U-CP40-VN4X2 1635600 BI5U-S18-
AP6X-H1141 15658 NI30-K40SR-VP4X2
1540500 BI15U-CP40-VP4X2 14037 BI6R-W30-
DAN6X-H1141 16225 NI35-CP40-AN6X2
1608810 BI15U-Q20-AN6X2 14036 BI6R-W30-DAP6X-
H1141 16025 NI35-CP40-AP6X2
1608610 BI15U-Q20-AN6X2-H1141 4414540 BI7-G18K-
AD4X 42235 NI35-CP40-FDZ30X2
1608800 BI15U-Q20-AP6X2 4430005 BI7-G18K-AG4X
13403 NI35-CP40-FZ3X2
1608600 BI15U-Q20-AP6X2-H1141 46150 BI8-M18-
AP6X-H1141 15794 NI35-CP40-VN4X2
42270 BI15W-CM40-FDZ30X2 46160 BI8-M18T-
AP6X 15694 NI35-CP40-VP4X2
15461 BI15W-CM40-VN4X2 1688003 BID2-G180-
AP6/S212 4602840 NI3-EG08-AN6X
15460 BI15W-CM40-VP4X2 16885 BID2-G180-
AP6-H1141/S212 4602860 NI3-EG08-AN6X-H1341
4609840 BI1-EG05-AN6X 1088003 BID2-G180-Y1/S212
上海配克机电设备有限公司是专业化的工控元件集成商、设备制造商和各种自控工程、工业计算机应用系统集成商。一级代理倍福(Beckhoff)。以下是Beckhoff面板式PC和控制面板类型号。如有需要,欢迎致电上海配克胡海涛 13853163389 传真:021-61638368  邮件myway860104@126.com 或者登陆公司网站www.growelec.com 您的关怀对我们很重要。展望合作!
BK1120
BK1250
BK2000
BK2010
BK2020
BK2500
BK3000
BK3010
BK3100
BK3110
BK3120
BK3150
BK3500
BK3520
LC3100
BK4000
BK4010
BK4020
BK4500
BK5000
BK5100
BK5110
BK5120
BK5150
BK5151
LC5100
BK5200
BK5210
BK5220
BK5250
LC5200
BK7000
BK7150
BK7300
BK7350
BK7420
BK7500
BK7520
BK8000
BK8100
BK9000
BK9050
BK9100
BK9103
BK9105
BK9500
BC2000
BC3100
BC3150
BC4000
BC5150
BC5250
BC7300
BC8000
BC8100
BC8150
BC9000
BC9020
BC9050
BC9100
BC9120
BX3100
BX5100
BX5200
BX8000
BX9000
KL1002
KS1002
KL1012
KS1012
KL1032
KS1032
KL1052
KS1052
KL1104
KS1104
KL1114
KS1114
KL1124
KS1124
KL1154
KS1154
KL1164
KS1164
KL1184
KS1184
KL1194
KS1194
KL1202
KS1202
KL1212
KS1212
KL1232
KS1232
KL1302
KS1302
KL1304
KS1304
KL1312
KS1312
KL1314
KS1314
KL1352
KS1352
KL1362
KS1362
KL1382
KS1382
KL1404
KS1404
KL1408
KS1408
KL1414
KS1414
KL1418
KS1418
KL1434
KS1434
KL1488
KS1488
KL1498
KS1498
KL1501
KS1501
KL1512
KS1512
KL1528
KS1528
KL1702
KS1702
KL1712
KS1712
KL1722
KS1722
KL1904
KL1934
KL2012
KS2012
KL2022
KS2022
KL2032
KS2032
KL2114
KS2114
KL2124
KS2124
KL2134
KS2134
KL2184
KS2184
KL2212
KS2212
KL2404
KS2404
KL2408
KS2408
KL2424
KS2424
KL2488
KS2488
KL2502
KS2502
KL2512
KS2512
KL2521
KS2521
KL2521-0024
KS2521-0024
KL2531
KS2531
KL2532
KS2532
KL2535
KS2535
KL2541
KS2541
KL2542
KS2542
KL2545
KS2545
KL2602
KS2602
KL2612
KS2612
KL2622
KS2622
KL2631
KS2631
KL2641
KL2652
KS2652
KL2692
KS2692
KL2702
KS2702
KL2712
KS2712
KL2722
KS2722
KL2732
KS2732
KL2751
KS2751
KL2751-1200
KS2751-1200
KL2761
KS2761
KL2784
KS2784
KL2794
KS2794
KL2934
KL2904
KL2964
KL3001
KS3001
KL3002
KS3002
KL3011
KS3011
KL3012
KS3012
KL3021
KS3021
KL3022
KS3022
KL3041
KS3041
KL3042
KS3042
KL3044
KS3044
KL3051
KS3051
KL3052
KS3052
KL3054
KS3054
KL3061
KS3061
KL3062
KS3062
KL3064
KS3064
KL3102
KS3102
KL3112
KS3112
KL3122
KS3122
KL3132
KS3132
KL3142
KS3142
KL3152
KS3152
KL3162
KS3162
KL3172
KS3172
KL3182
KS3182
KL3201
KS3201
KL3202
KS3202
KL3204
KS3204
KL3228
KS3228
KL3311
KL3312
KL3314
KL3351
KS3351
KL3356
KS3356
KL3361
KS3361
KL3362
KS3362
KL3403
KS3403
KL3404
KS3404
KL3408
KS3408
KL3444
KS3444
KL3448
KS3448
KL3454
KS3454
KL3458
KS3458
KL3464
KS3464
KL3468
KS3468
KL4001
KS4001
KL4002
KS4002
KL4004
KS4004
KL4011
KS4011
KL4012
KS4012
KL4021
KS4021
KL4022
KS4022
KL4031
KS4031
KL4032
KS4032
KL4034
KS4034
KL4112
KS4112
KL4132
KS4132
KL4404
KS4404
KL4408
KS4408
KL4414
KS4414
KL4418
KS4418
KL4424
KS4424
KL4428
KS4428
KL4434
KS4434
KL4438
KS4438
KL4494
KS4494
KL5001
KS5001
KL5051
KS5051
KL5101
KS5101
KL5111
KS5111
KL5121
KS5121
KL5151
KS5151
KL6001
KS6001
KL6011
KS6011
KL6021
KS6021
KL6023
KL6031
KS6031
KL6041
KS6041
KL6051
KS6051
KL6201
KS6201
KL6211
KS6211
KL6301
KS6301
KL6401
KS6401
KL6771
KS6771
KL6811
KS6811
KL6904
KL6934
KL8001
KL8601
KL8610
KL9010
KL9020
KL9050
KL9060
KL9070
KS9070
KL9080
KL9100
KS9100
KL9110
KS9110
KL9150
KS9150
KL9160
KS9160
KL9180
KS9180
KL9185
KS9185
KL9186
KS9186
KL9187
KS9187
KL9190
KS9190
KL9195
KS9195
KL9200
KL9210
KL9250
KL9260
KL9290
KL9300
KS9300
KL9301
KS9301
KL9302
KS9302
KL9400
KS9400
KL9505
KS9505
KL9508
KS9508
KL9510
KS9510
KL9512
KS9512
KL9515
KS9515
KL9520
KS9520
KL9528
KS9528
KL9540
KS9540
KL9550
KS9550
KL9560
KS9560
KM1002-0000
KM1002-0001
KM1002-0002
KM1002-0004
KM1012-0000
KM1012-0001
KM1012-0002
KM1012-0004
KM1004-0000
KM1004-0001
KM1004-0002
KM1004-0004
KM1014-0000
KM1014-0001
KM1014-0002
KM1014-0004
KM1008-0000
KM1008-0001
KM1008-0002
KM1008-0004
KM1018-0000
KM1018-0001
KM1018-0002
KM1018-0004
KM2002-0000
KM2002-0001
KM2002-0002
KM2002-0004
KM2004-0000
KM2004-0001
KM2004-0002
KM2004-0004
KM2008-0000
KM2008-0001
KM2008-0002
KM2008-0004
KM2604
KM2774
KM3701
KM3702
KM6551
ZB3100
ZB3101
ZB3102
ZS1031-3000
ZS1031-3500
ZB3200
ZB3300
ZB4100
ZB4101
ZB4200
ZB5100
ZB5200
ZB9010
ZB9020
ZB2601
BG1558
BG1559
BZ1000
BZ10xx
BZ1xxx
BZ1xxx
BZ1xxx-options
BZ3000
BZ3010
BZ5100
BK1120
BK1250
EK1000
EK1100
EK1101
EK1122
EK1501
EK1110
EL1002
ES1002
EL1004
ES1004
EL1008
ES1008
EL1012
ES1012
EL1014
ES1014
EL1018
ES1018
EL1024
ES1024
EL1034
ES1034
EL1084
ES1084
EL1088
ES1088
EL1094
ES1094
EL1098
ES1098
EL1104
ES1104
EL1114
ES1114
EL1124
ES1124
EL1134
ES1134
EL1144
ES1144
EL1202
ES1202
EL1252
ES1252
EL1262
ES1262
EL1502
ES1502
EL1512
ES1512
EL1702
ES1702
EL1712
ES1712
EL1722
ES1722
EL1904
EL2002
ES2002
EL2004
ES2004
EL2008
ES2008
EL2022
ES2022
EL2024
ES2024
EL2032
ES2032
EL2034
ES2034
EL2084
ES2084
EL2088
ES2088
EL2124
ES2124
EL2202
ES2202
EL2212
ES2212
EL2252
ES2252
EL2262
ES2262
EL2502
ES2502
EL2521
ES2521
EL2521-0024
ES2521-0024
EL2535
ES2535
EL2545
ES2545
EL2602
ES2602
EL2612
ES2612
EL2622
ES2622
EL2712
ES2712
EL2722
ES2722
EL2732
ES2732
EL2904
EL3001
ES3001
EL3002
ES3002
EL3004
ES3004
EL3008
ES3008
EL3011
ES3011
EL3012
ES3012
EL3014
ES3014
EL3021
ES3021
EL3022
ES3022
EL3024
ES3024
EL3041
ES3041
EL3042
ES3042
EL3044
ES3044
EL3048
ES3048
EL3051
ES3051
EL3052
ES3052
EL3054
ES3054
EL3058
ES3058
EL3061
ES3061
EL3062
ES3062
EL3064
ES3064
EL3068
ES3068
EL3101
ES3101
EL3102
ES3102
EL3104
ES3104
EL3111
ES3111
EL3112
ES3112
EL3114
ES3114
EL3121
ES3121
EL3122
ES3122
EL3124
ES3124
EL3141
ES3141
EL3142
ES3142
EL3144
ES3144
EL3151
ES3151
EL3152
ES3152
EL3154
ES3154
EL3161
ES3161
EL3162
ES3162
EL3164
ES3164
EL3201
ES3201
EL3202
ES3202
EL3204
ES3204
EL3311
EL3312
EL3314
EL3356
ES3356
EL3403
ES3403
EL3403-0010
ES3403-0010
EL3702
ES3702
EL3742
ES3742
EL4001
ES4001
EL4002
ES4002
EL4004
ES4004
EL4008
ES4008
EL4011
ES4011
EL4012
ES4012
EL4014
ES4014
EL4018
ES4018
EL4021
ES4021
EL4022
ES4022
EL4024
ES4024
EL4028
ES4028
EL4031
ES4031
EL4032
ES4032
EL4034
ES4034
EL4038
ES4038
EL4102
ES4102
EL4104
ES4104
EL4112
ES4112
EL4114
ES4114
EL4122
ES4122
EL4124
ES4124
EL4132
ES4132
EL4134
ES4134
EL4712
ES4712
EL4732
ES4732
EL5001
ES5001
EL5101
ES5101
EL5151
ES5151
EL6001
ES6001
EL6021
ES6021
EL6201
ES6201
EL6224
ES6224
EL6601
EL6614
EL6692
EL6731
EL6731-0010
EL6740-0010
EL6751
EL6751-0010
EL6752
EL6752-0010
EL6904
EL7031
ES7031
EL7041
ES7041
EL7332
ES7332
EL7342
ES7342
EL9010
EL9011
EL9080
EL9100
ES9100
EL9110
ES9110
EL9150
ES9150
EL9160
ES9160
EL9180
ES9180
EL9185
ES9185
EL9186
ES9186
EL9187
ES9187
EL9190
ES9190
EL9195
ES9195
EL9200
EL9210
EL9250
EL9260
EL9290
EL9400
ES9400
EL9505
ES9505
EL9508
ES9508
EL9510
ES9510
EL9512
ES9512
EL9515
ES9515
EL9520
ES9520
EL9560
ES9560
EM7004-0000
EM7004-0002
EM7004-0004
ZS1090-0003
ZB9010
ZB9020
ET1100-0000-0001
ET1100-0000-0012
ET1100-0000-0024
ET1100-0000-0048
ET1100-0000-0096
ET1100-0000-0192
ET1100-0000-0384
ET1100-0000-0768
ET1100-0000-1008
ET1200-0000-0001
ET1200-0000-0025
ET1200-0000-0075
ET1200-0000-0150
ET1200-0000-0300
ET1200-0000-0600
ET1200-0000-0900
ET1810
ET1815
ET1902
ET1903
EL9803
EL9820
EL9821
EL9830
EL9840
FB1111-0140
FB1111-0141
FB1111-0142
FB1122
FB1130
ET2000
ET9000
ET9200
ET9300
TR8100
TR8200
IP1000-B200
IP1001-B200
IP1002-B200
IP1010-B200
IP1011-B200
IP1012-B200
IP1502-B200
IP2000-B200
IP2001-B200
IP2002-B200
IP2020-B200
IP2021-B200
IP2022-B200
IP2040-B200
IP2041-B200
IP2042-B200
IP2300-B200
IP2301-B200
IP2302-B200
IP2310-B200
IP2311-B200
IP2312-B200
IP2320-B200
IP2321-B200
IP2322-B200
IP2330-B200
IP2331-B200
IP2332-B200
IP2400-B200
IP2401-B200
IP2512-B200
IP3102-B200
IP3112-B200
IP3202-B200
IP3312-B200
IP4112-B200
IP4132-B200
IP5009-B200
IP5109-B200
IP5209-B200
IP5209-B200-1000
IP6002-B200
IP6012-B200
IP6022-B200
IP1000-B310
IP1001-B310
IP1002-B310
IP1010-B310
IP1011-B310
IP1012-B310
IP1502-B310
IP2000-B310
IP2001-B310
IP2002-B310
IP2020-B310
IP2021-B310
IP2022-B310
IP2040-B310
IP2041-B310
IP2042-B310
IP2300-B310
IP2301-B310
IP2302-B310
IP2310-B310
IP2311-B310
IP2312-B310
IP2320-B310
IP2321-B310
IP2322-B310
IP2330-B310
IP2331-B310
IP2332-B310
IP2400-B310
IP2401-B310
IP2512-B310
IP3102-B310
IP3112-B310
IP3202-B310
IP3312-B310
IP4112-B310
IP4132-B310
IP5009-B310
IP5109-B310
IP5209-B310
IP5209-B310-1000
IP6002-B310
IP6012-B310
IP6022-B310
IP1000-B318
IP1001-B318
IP1002-B318
IP1010-B318
IP1011-B318
IP1012-B318
IP1502-B318
IP2000-B318
IP2001-B318
IP2002-B318
IP2020-B318
IP2021-B318
IP2022-B318
IP2040-B318
IP2041-B318
IP2042-B318
IP2300-B318
IP2301-B318
IP2302-B318
IP2310-B318
IP2311-B318
IP2312-B318
IP2320-B318
IP2321-B318
IP2322-B318
IP2330-B318
IP2331-B318
IP2332-B318
IP2400-B318
IP2401-B318
IP2512-B318
IP3102-B318
IP3112-B318
IP3202-B318
IP3312-B318
IP4112-B318
IP4132-B318
IP5009-B318
IP5109-B318
IP5209-B318
IP5209-B318-1000
IP6002-B318
IP6012-B318
IP6022-B318
IP1000-B400
IP1001-B400
IP1002-B400
IP1010-B400
IP1011-B400
IP1012-B400
IP1502-B400
IP2000-B400
IP2001-B400
IP2002-B400
IP2020-B400
IP2021-B400
IP2022-B400
IP2040-B400
IP2041-B400
IP2042-B400
IP2300-B400
IP2301-B400
IP2302-B400
IP2310-B400
IP2311-B400
IP2312-B400
IP2320-B400
IP2321-B400
IP2322-B400
IP2330-B400
IP2331-B400
IP2332-B400
IP2400-B400
IP2401-B400
IP2512-B400
IP3102-B400
IP3112-B400
IP3202-B400
IP3312-B400
IP4112-B400
IP4132-B400
IP5009-B400
IP5109-B400
IP5209-B400
IP5209-B400-1000
IP6002-B400
IP6012-B400
IP6022-B400
IP1000-B510
IP1001-B510
IP1002-B510
IP1010-B510
IP1011-B510
IP1012-B510
IP1502-B510
IP2000-B510
IP2001-B510
IP2002-B510
IP2020-B510
IP2021-B510
IP2022-B510
IP2040-B510
IP2041-B510
IP2042-B510
IP2300-B510
IP2301-B510
IP2302-B510
IP2310-B510
IP2311-B510
IP2312-B510
IP2320-B510
IP2321-B510
IP2322-B510
IP2330-B510
IP2331-B510
IP2332-B510
IP2400-B510
IP2401-B510
IP2512-B510
IP3102-B510
IP3112-B510
IP3202-B510
IP3312-B510
IP4112-B510
IP4132-B510
IP5009-B510
IP5109-B510
IP5209-B510
IP5209-B510-1000
IP6002-B510
IP6012-B510
IP6022-B510
IP1000-B518
IP1001-B518
IP1002-B518
IP1010-B518
IP1011-B518
IP1012-B518
IP1502-B518
IP2000-B518
IP2001-B518
IP2002-B518
IP2020-B518
IP2021-B518
IP2022-B518
IP2040-B518
IP2041-B518
IP2042-B518
IP2300-B518
IP2301-B518
IP2302-B518
IP2310-B518
IP2311-B518
IP2312-B518
IP2320-B518
IP2321-B518
IP2322-B518
IP2330-B518
IP2331-B518
IP2332-B518
IP2400-B518
IP2401-B518
IP2512-B518
IP3102-B518
IP3112-B518
IP3202-B518
IP3312-B518
IP4112-B518
IP4132-B518
IP5009-B518
IP5109-B518
IP5209-B518
IP5209-B518-1000
IP6002-B518
IP6012-B518
IP6022-B518
IP1000-B520
IP1001-B520
IP1002-B520
IP1010-B520
IP1011-B520
IP1012-B520
IP1502-B520
IP2000-B520
IP2001-B520
IP2002-B520
IP2020-B520
IP2021-B520
IP2022-B520
IP2040-B520
IP2041-B520
IP2042-B520
IP2300-B520
IP2301-B520
IP2302-B520
IP2310-B520
IP2311-B520
IP2312-B520
IP2320-B520
IP2321-B520
IP2322-B520
IP2330-B520
IP2331-B520
IP2332-B520
IP2400-B520
IP2401-B520
IP2512-B520
IP3102-B520
IP3112-B520
IP3202-B520
IP3312-B520
IP4112-B520
IP4132-B520
IP5009-B520
IP5109-B520
IP5209-B520
IP5209-B520-1000
IP6002-B520
IP6012-B520
IP6022-B520
IP1000-B528
IP1001-B528
IP1002-B528
IP1010-B528
IP1011-B528
IP1012-B528
IP1502-B528
IP2000-B528
IP2001-B528
IP2002-B528
IP2020-B528
IP2021-B528
IP2022-B528
IP2040-B528
IP2041-B528
IP2042-B528
IP2300-B528
IP2301-B528
IP2302-B528
IP2310-B528
IP2311-B528
IP2312-B528
IP2320-B528
IP2321-B528
IP2322-B528
IP2330-B528
IP2331-B528
IP2332-B528
IP2400-B528
IP2401-B528
IP2512-B528
IP3102-B528
IP3112-B528
IP3202-B528
IP3312-B528
IP4112-B528
IP4132-B528
IP5009-B528
IP5109-B528
IP5209-B528
IP5209-B528-1000
IP6002-B528
IP6012-B528
IP6022-B528
IP1000-B730
IP1001-B730
IP1002-B730
IP1010-B730
IP1011-B730
IP1012-B730
IP1502-B730
IP2000-B730
IP2001-B730
IP2002-B730
IP2020-B730
IP2021-B730
IP2022-B730
IP2040-B730
IP2041-B730
IP2042-B730
IP2300-B730
IP2301-B730
IP2302-B730
IP2310-B730
IP2311-B730
IP2312-B730
IP2320-B730
IP2321-B730
IP2322-B730
IP2330-B730
IP2331-B730
IP2332-B730
IP2400-B730
IP2401-B730
IP2512-B730
IP3102-B730
IP3112-B730
IP3202-B730
IP3312-B730
IP4112-B730
IP4132-B730
IP5009-B730
IP5109-B730
IP5209-B730
IP5209-B730-1000
IP6002-B730
IP6012-B730
IP6022-B730
IP1000-B800
IP1001-B800
IP1002-B800
IP1010-B800
IP1011-B800
IP1012-B800
IP1502-B800
IP2000-B800
IP2001-B800
IP2002-B800
IP2020-B800
IP2021-B800
IP2022-B800
IP2040-B800
IP2041-B800
IP2042-B800
IP2300-B800
IP2301-B800
IP2302-B800
IP2310-B800
IP2311-B800
IP2312-B800
IP2320-B800
IP2321-B800
IP2322-B800
IP2330-B800
IP2331-B800
IP2332-B800
IP2400-B800
IP2401-B800
IP2512-B800
IP3102-B800
IP3112-B800
IP3202-B800
IP3312-B800
IP4112-B800
IP4132-B800
IP5009-B800
IP5109-B800
IP5209-B800
IP5209-B800-1000
IP6002-B800
IP6012-B800
IP6022-B800
IP1000-B810
IP1001-B810
IP1002-B810
IP1010-B810
IP1011-B810
IP1012-B810
IP1502-B810
IP2000-B810
IP2001-B810
IP2002-B810
IP2020-B810
IP2021-B810
IP2022-B810
IP2040-B810
IP2041-B810
IP2042-B810
IP2300-B810
IP2301-B810
IP2302-B810
IP2310-B810
IP2311-B810
IP2312-B810
IP2320-B810
IP2321-B810
IP2322-B810
IP2330-B810
IP2331-B810
IP2332-B810
IP2400-B810
IP2401-B810
IP2512-B810
IP3102-B810
IP3112-B810
IP3202-B810
IP3312-B810
IP4112-B810
IP4132-B810
IP5009-B810
IP5109-B810
IP5209-B810
IP5209-B810-1000
IP6002-B810
IP6012-B810
IP6022-B810
IL2300-B110
IL2301-B110
IL2302-B110
IL2300-B200
IL2301-B200
IL2302-B200
IL2300-B310
IL2301-B310
IL2302-B310
IL2300-B318
IL2301-B318
IL2302-B318
IL2300-B400
IL2301-B400
IL2302-B400
IL2300-B510
IL2301-B510
IL2302-B510
IL2300-B518
IL2301-B518
IL2302-B518
IL2300-B520
IL2301-B520
IL2302-B520
IL2300-B528
IL2301-B528
IL2302-B528
IL2300-B730
IL2301-B730
IL2302-B730
IL2300-B800
IL2301-B800
IL2302-B800
IL2300-B810
IL2301-B810
IL2302-B810
IL2300-B900
IL2301-B900
IL2302-B900
IL2300-B901
IL2301-B901
IL2302-B901
IL2300-B903
IL2301-B903
IL2302-B903
IL2300-B905
IL2301-B905
IL2302-B905
IL2300-C310
IL2301-C310
IL2302-C310
IL2300-C318
IL2301-C318
IL2302-C318
IL2300-C800
IL2301-C800
IL2302-C800
IL2300-C810
IL2301-C810
IL2302-C810
IL2300-C900
IL2301-C900
IL2302-C900
IE1000
IE1001
IE1002
IE1010
IE1011
IE1012
IE1502
IE2000
IE2001
IE2002
IE2020
IE2021
IE2022
IE2040
IE2041
IE2042
IE2300
IE2301
IE2302
IE2310
IE2311
IE2312
IE2320
IE2321
IE2322
IE2330
IE2331
IE2332
IE2400
IE2401
IE2403
IE2512
IE2808
IE3102
IE3112
IE3202
IE3312
IE4112
IE4132
IE5009
IE5109
IE6002
IE6012
IE6022
ZB9001
ZB9002
ZB3200
ZB3300
ZB5100
ZB5200
FC2001
FC2002
C1200-000
C1220-000
C1220-001
C1300-000
C1300-001
M1200-000
M1210-000
M1110-000
M1110-001
M1110-002
M1400-000
M1400-001
M1400-002
M1400-003
M1400-004
M1400-005
M1400-010
M1400-011
M1400-012
M1400-013
M1400-014
M1400-015
M1401-000
M1401-001
M1401-002
M1401-003
M1401-004
M1401-005
M1401-010
M1401-011
M1401-012
M1401-013
M1401-014
M1401-015
M1410-000
M1410-001
M1410-002
M2400-010
M2400-011
M2400-012
M2400-020
M2400-021
M2400-022
M2400-030
M2400-031
M2400-032
M2400-040
M2400-041
M2400-042
M2510-000
M2510-001
M3000-000
M3100-000
M3100-001
M3100-002
M3100-003
M3120-001
M3120-002
M3120-003
M3120-004
M3200-004
M3200-036
M3300-xyz
M6310-001
M6310-010
M6310-030
M6320-001
M6320-010
M6320-030
M6321-000
M6321-001
M6321-010
M6321-030
M6330-000
M6330-001
M6330-010
M6330-030
M6331-000
M6331-001
M6331-010
M6331-030
M6350-000
M6350-001
M6350-010
M6350-030
M6351-000
M6351-001
M6351-010
M6351-030
M9100-0
M9110-0
FC2001
FC2002
FC3101-0000
FC3101-0002
FC3102-0000
FC3102-0002
FC5101-0000
FC5101-0002
FC5102-0000
FC5102-0002
FC5201-0000
FC5201-0002
FC5202-0000
FC5202-0002
FC7501
FC7502
FC9001
FC9002
FC9004
FC3151-0000
FC3151-0002
FC5151-0000
FC5151-0002
FC5251-0000
FC5251-0002
FC7551-0000
FC7551-0002
FC9051-0000
FC9151-0000
CU2008
CU2016
ES2008
ES2016
KS2000
KS8000
TwinCAT PLC
TwinCAT I/O
 上海配克机电设备有限公司是专业化的工控元件集成商、设备制造商和各种自控工程、工业计算机应用系统集成商。一级代理倍福(Beckhoff)。以下是Beckhoff工控机(不含面板式PC)型号。如有需要,欢迎致电上海配克胡海涛 13853163389 传真:021-61638368  邮件myway860104@126.com 或者登陆公司网站www.growelec.com 您的关怀对我们很重要。展望合作!
C3320-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T304
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3320-0020
C9900-C550
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T304
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3320-0030
C9900-C527
C9900-R219
C9900-R221
C9900-P208
C9900-P209
C9900-U330
C9900-H143
C9900-M710
C9900-T304
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3330-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T304
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3330-0020
C9900-C550
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T304
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3330-0030
C9900-C527
C9900-R219
C9900-R221
C9900-P208
C9900-P209
C9900-U330
C9900-H143
C9900-M710
C9900-T304
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3340-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T308
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3340-0020
C9900-C550
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T308
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3340-0030
C9900-C527
C9900-R219
C9900-R221
C9900-P208
C9900-P209
C9900-U330
C9900-H143
C9900-M710
C9900-T308
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3350-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T308
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3350-0020
C9900-C550
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-M710
C9900-T308
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3350-0030
C9900-C527
C9900-R219
C9900-R221
C9900-P208
C9900-P209
C9900-U330
C9900-H143
C9900-M710
C9900-T308
C9900-T902
C9900-T400
C9900-E102
C9900-E123
C9900-E124
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3620-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-T306
C9900-T902
C9900-E105
C9900-E135
C9900-D168
C9900-D115
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3620-0020
C9900-C550
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-T306
C9900-T902
C9900-E108
C9900-E166
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3620-0030
C9900-C527
C9900-R219
C9900-R221
C9900-P208
C9900-P209
C9900-U330
C9900-T306
C9900-T902
C9900-E108
C9900-E166
C9900-D102
C9900-D111
C9900-E108
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3640-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-T310
C9900-T902
C9900-E135
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3640-0020
C9900-C550
C9900-R216
C9900-P208
C9900-P209
C9900-U330
C9900-T310
C9900-T902
C9900-E166
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C3640-0030
C9900-C527
C9900-R219
C9900-R221
C9900-P208
C9900-P209
C9900-U330
C9900-T310
C9900-T902
C9900-E166
C9900-M354
C9900-H143
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C5101-0020
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C9900-P208
C9900-P209
C9900-U330
C5102-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C5102-0020
C9900-C550
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C5102-0030
C9900-C527
C9900-R219
C9900-R221
C9900-A196
C9900-A197
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-M617
C9900-H143
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6110-0020
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C9900-P208
C9900-P209
C9900-U330
C6120-0020
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C9900-P208
C9900-P209
C9900-U330
C6130-0020
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C9900-P208
C9900-P209
C9900-U330
C6140-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6140-0020
C9900-C550
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6140-0030
C9900-C527
C9900-R219
C9900-R221
C9900-A196
C9900-A197
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-M350
C9900-H143
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6150-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6150-0020
C9900-C550
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6150-0030
C9900-C527
C9900-R219
C9900-R221
C9900-A196
C9900-A197
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-M350
C9900-H143
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6210-0020
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C9900-P208
C9900-P209
C9900-U330
C6220-0020
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C9900-P208
C9900-P209
C9900-U330
C6240-0010
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-M630
C9900-M639
C9900-E135
C9900-D168
C9900-D115
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6240-0020
C9900-C550
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-M630
C9900-M639
C9900-E166
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6240-0030
C9900-C527
C9900-R219
C9900-R221
C9900-A196
C9900-A197
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-M630
C9900-M639
C9900-D102
C9900-D111
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6250-0020
C9900-C515
C9900-C517
C9900-C522
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-M631
C9900-M635
C9900-M636
C9900-E135
C9900-D120
C9900-D130
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6250-0030
C9900-C550
C9900-R216
C9900-A159
C9900-A160
C9900-P208
C9900-P209
C9900-U330
C9900-M631
C9900-M635
C9900-M636
C9900-E166
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6250-0040
C9900-C527
C9900-R219
C9900-R221
C9900-A196
C9900-A197
C9900-P208
C9900-P209
C9900-U330
C9900-E166
C9900-M631
C9900-M635
C9900-M636
C9900-M617
C9900-H143
C9900-D120
C9900-D244
C9900-U120
C9900-M623
C9900-U122
C9900-M624
C6320-0030
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-M653
C9900-U209
C9900-U330
C6325-0030
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-M653
C9900-U209
C9900-U330
C6330-0030
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-M653
C9900-D113
C9900-U209
C9900-U330
C6335-0030
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-M653
C9900-D113
C9900-U209
C9900-U330
C6340-0030
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-M653
C9900-U209
C9900-U330
C6350-0030
C9900-C550
C9900-R216
C9900-Z411
C9900-Z413
C9900-M653
C9900-D113
C9900-U209
C9900-U330
C6920-0000
C9900-C550
C9900-R216
C9900-H115
C9900-H503
C9900-H504
C9900-H505
C9900-D174
C9900-H514
C9900-H515
C9900-H516
C9900-E159
C9900-R230
C9900-R231
C9900-R232
C9900-Z411
C9900-Z413
C9900-M653
C9900-U209
C9900-U330
C9900-S326-0031
C9900-S326-0033
C9900-S309
C9900-S370
C9900-S371
C9900-S701
C9900-S702
C9900-S705
C6920-0010
C9900-C527
C9900-R219
C9900-R221
C9900-H119
C9900-D178
C9900-H514
C9900-H515
C9900-H516
C9900-E159
C9900-R230
C9900-R231
C9900-R232
C9900-Z411
C9900-Z413
C9900-M653
C9900-U209
C9900-U330
C9900-S378
C9900-S379
C6925-0000
C9900-R216
C9900-H115
C9900-H503
C9900-H504
C9900-H505
C9900-D174
C9900-H514
C9900-H515
C9900-H516
C9900-E159
C9900-R230
C9900-R231
C9900-R232
C9900-Z411
C9900-Z413
C9900-M653
C9900-U209
C9900-U330
C9900-S326-0031
C9900-S326-0033
C9900-S309
C9900-S370
C9900-S371
C9900-S701
C9900-S702
C9900-S705
上海配克机电设备有限公司是专业化的工控元件集成商、设备制造商和各种自控工程、工业计算机应用系统集成商。一级代理倍福(Beckhoff)。以下是Beckhoff嵌入式PC型号。如有需要,欢迎致电上海配克胡海涛 13853163389 传真:021-61638368  邮件myway860104@126.com 或者登陆公司网站www.growelec.com 您的关怀对我们很重要。展望合作!
CX100M-0CST
CX1000-0010
CX1000-0011
CX1000-0012
CX1000-0110
CX1000-0111
CX1000-0112
CX1001-0000
CX1001-0010
CX1001-0011
CX1001-0012
CX1001-0020
CX1001-0021
CX1001-0022
CX1001-0100
CX1001-0110
CX1001-0111
CX1001-0112
CX1001-0120
CX1001-0121
CX1001-0122
CX1000-N001
CX1000-N002
CX1000-N003
CX1000-N005
CX1010-0CST
CX1010-0000
CX1010-0010
CX1010-0011
CX1010-0012
CX1010-0020
CX1010-0021
CX1010-0022
CX1010-0100
CX1010-0110
CX1010-0111
CX1010-0112
CX1010-0120
CX1010-0121
CX1010-0122
CX1010-N010
CX1010-N020
CX1010-N030
CX1010-N040
CX1010-N031
CX1010-N041
CX1010-N060
CX1010-A001
CX1020-0CST
CX1020-0000
CX1020-0010
CX1020-0011
CX1020-0012
CX1020-0013
CX1020-0100
CX1020-0110
CX1020-0111
CX1020-0112
CX1020-0113
CX1020-0020
CX1020-0021
CX1020-0022
CX1020-0023
CX1020-0120
CX1020-0121
CX1020-0122
CX1020-0123
CX1020-N010
CX1020-N020
CX1020-N030
CX1020-N040
CX1020-N031
CX1020-N041
CX1020-N060
CX1020-A001
CX1030-0CST
CX1030-0000
CX1030-0010
CX1030-0011
CX1030-0012
CX1030-0013
CX1030-0100
CX1030-0110
CX1030-0111
CX1030-0112
CX1030-0113
CX1030-0020
CX1030-0021
CX1030-0022
CX1030-0023
CX1030-0120
CX1030-0121
CX1030-0122
CX1030-0123
CX1030-N010
CX1030-N020
CX1030-N030
CX1030-N040
CX1030-N031
CX1030-N041
CX1030-N060
CX1030-A001
CX1100-0001
CX1100-0002
CX1100-0003
CX1100-0004
CX1100-0012
CX1100-0013
CX1100-0014
CX1100-0900
CX1100-0910
CX1100-0920
CX1500-M200
CX1500-M310
CX1500-M510
CX1500-M520
CX1500-M750
CX1500-Mxxx-0001
CX1500-Mxxx-0002
CX1500-Mxxx-0003
CX1500-Mxxx-0004
CX1500-Mxxx-0005
CX1500-B200 *
CX1500-B310 *
CX1500-B510 *
CX1500-B520 *
CX1500-Bxxx-0001
CX1500-Bxxx-0002
CX1500-Bxxx-0003
CX1500-Bxxx-0004
CX1500-Bxxx-0005
CX900M-UC0T
CX9000-0000
CX9000-0001
CX9001-0000
CX9001-0001
CX9001-0002
CX9001-0100
CX9001-0101
CX9001-0102
CX9000-1000
CX9000-1001
CX9001-1000
CX9001-1001
CX9001-1002
CX9001-1100
CX9001-1101
CX9001-1102
CX9000-N010
CX9000-N030
CX9000-N031
CX9000-A001
CX9010-UC0T
CX9010-0000
CX9010-0001
CX9010-0002
CX9010-0100
CX9010-0101
CX9010-0102
CX9010-1000
CX9010-1001
CX9010-1002
CX9010-1100
CX9010-1101
CX9010-1102
CX9010-N010
CX9010-N030
CX9010-N031
CX9010-A001
CX1800-0100
CX1800-0100-0002
CX1800-0100-0003
CX1800-0100-0004
CX1800-0100-0005
CX1800-0101
CX1800-0101-0002
CX1800-0101-0003
CX1800-0101-0004
CX1800-0101-0005
CX1800-0101-0006
CX1800-0202
CX1800-0202-0002
CX1800-0202-0004
CX1800-0202-0005
CX1800-0299
CX1800-0300
CX1800-0001
CX1800-0002
CX1800-0003
CX1800-0004
CX1800-0005
CX1900-0023
CX1900-0025
CX1900-0027
CX1900-0201
CX1900-0202
CX1900-0101
CX1900-0200
CX1900-0102
CX1900-0103
CB1050-0000
CB1050-0001
CB1050-0002
CB1051-0000
CB1051-0001
CB1051-0002
CB1051-0003
CB2050-0002
CB2050-0003
CB3010-0001
CB3010-0002
CB3050-0001
CB3050-0002
CB3050-0003
CB3051-0001
CB3051-0002
CB3051-0003
CB3051-0004
CB3110-0001
CB3110-0002
CB3150-0001
CB4021-0001
CB4040-0001
CB4050-0001
CB4050-0002
CB4050-0003
CB6050-0001
CB6050-0002
CB6050-0003
上海配克机电设备有限公司是专业化的工控元件集成商、设备制造商和各种自控工程、工业计算机应用系统集成商。一级代理倍福(Beckhoff)。以下是Beckhoff伺服驱动类产品型号。如有需要,欢迎致电上海配克胡海涛 13853163389 传真:021-61638368  邮件myway860104@126.com 或者登陆公司网站www.growelec.com 您的关怀对我们很重要。展望合作!
AX5101-0000
AX5103-0000
AX5106-0000
AX5112-0000
AX5118-0000
AX5125-0000
AX5201-0000
AX5203-0000
AX5206-0000
AX5001
AX5021
AX5041
AX5801
AX5805
AX5901
AX5911
ZS4500-2001
ZS4500-2002
ZS4500-2003
ZS4500-2006
ZS4500-2007
ZS4500-2008
ZS4500-2010
ZS4500-2011
ZS4500-2012
ZS4500-2013
ZK1090-0101-0001
ZK1090-0101-0002
AX2090-BW50-0500
AX2090-BW50-1000
AX2090-BW50-2000
AX2090-BW50-6000
AX2090-MD50-0012
AX2090-MD50-0025
AX2090-NF50-0025
ZK4500-0003-zzzz
ZK4500-0003-0050
ZK4509-0003-zzzz
ZK4500-0023-zzzz
ZK4500-0023-0050
ZK4509-0023-zzzz
ZK4500-0004-zzzz
ZK4500-0004-0050
ZK4509-0004-zzzz
ZK4500-0024-zzzz
ZK4500-0024-0050
ZK4509-0024-zzzz
ZK4510-0000-zzzz
ZK4510-0000-0050
ZK4519-0000-zzzz
ZK4510-0020-zzzz
ZK4510-0020-0050
ZK4519-0020-zzzz
ZK4530-0000-zzzz
ZK4530-0000-0050
ZK4539-0000-zzzz
ZK4530-0020-zzzz
ZK4530-0020-0050
ZK4539-0020-zzzz
ZK4501-0003-zzzz
ZK4501-0003-0050
ZK4501-0023-zzzz
ZK4501-0023-0050
ZK4501-0004-zzzz
ZK4501-0004-0050
ZK4501-0024-zzzz
ZK4501-0024-0050
ZK4511-0000-zzzz
ZK4511-0000-0050
ZK4511-0020-zzzz
ZK4511-0020-0050
ZK4531-0000-zzzz
ZK4531-0000-0050
ZK4531-0020-zzzz
ZK4531-0020-0050
AX2003-0000-000z
AX2006-0000-000z
AX2010-0000-000z
AX2020-0000-000z
AX2040-0000-0001
AX2070-0000-0001
AX2003-B110-000z
AX2006-B110-000z
AX2010-B110-000z
AX2020-B110-000z
AX2040-B110-0001
AX2070-B110-0001
AX2003-B200-000z
AX2006-B200-000z
AX2010-B200-000z
AX2020-B200-000z
AX2040-B200-0001
AX2070-B200-0001
AX2003-B310-000z
AX2006-B310-000z
AX2010-B310-000z
AX2020-B310-000z
AX2040-B310-0001
AX2070-B310-0001
AX2003-B520-000z
AX2006-B520-000z
AX2010-B520-000z
AX2020-B520-000z
AX2040-B520-0001
AX2070-B520-0001
AX2003-B750-000z
AX2006-B750-000z
AX2010-B750-000z
AX2020-B750-000z
AX2040-B750-0001
AX2070-B750-0001
AX2003-B900-000z
AX2006-B900-000z
AX2010-B900-000z
AX2020-B900-000z
AX2040-B900-0001
AX2070-B900-0001
AX20xx-yyyy-0001
AX2503-B200-0000
AX2506-B200-0000
AX2513-B200-0000
AX2516-B200-0000
AX2523-B200-0000
AX2526-B200-0000
AX2503-B310-0000
AX2506-B310-0000
AX2513-B310-0000
AX2516-B310-0000
AX2523-B310-0000
AX2526-B310-0000
AX2503-B510-0000
AX2506-B510-0000
AX2513-B510-0000
AX2516-B510-0000
AX2523-B510-0000
AX2526-B510-0000
AX2503-B750-0000
AX2506-B750-0000
AX2513-B750-0000
AX2516-B750-0000
AX2523-B750-0000
AX2526-B750-0000
AX2503-B900-0000
AX2506-B900-0000
AX2513-B900-0000
AX2516-B900-0000
AX2523-B900-0000
AX2526-B900-0000
AX2090-L025
AM3011-wB00
AM3012-wC00
AM3013-wC00
AM3021-wCy0
AM3021-wCy1
AM3022-wCy0
AM3022-wCy1
AM3023-wCy0
AM3023-wCy1
AM3023-wDy0
AM3023-wDy1
AM3024-wCy0
AM3024-wCy1
AM3024-wDy0
AM3024-wDy1
AM3031-wCy0
AM3031-wCy1
AM3031-wEy0
AM3031-wEy1
AM3032-wCy0
AM3032-wCy1
AM3032-wDy0
AM3032-wDy1
AM3033-wCy0
AM3033-wCy1
AM3033-wEy0
AM3033-wEy1
AM3041-wCy0
AM3041-wCy1
AM3041-wEy0
AM3041-wEy1
AM3041-wHy0
AM3041-wHy1
AM3042-wEy0
AM3042-wEy1
AM3042-wGy0
AM3042-wGy1
AM3043-wEy0
AM3043-wEy1
AM3043-wGy0
AM3043-wGy1
AM3044-wEy0
AM3044-wEy1
AM3044-wGy0
AM3044-wGy1
AM3044-wJy0
AM3044-wJy1
AM3051-wEy0
AM3051-wEy1
AM3051-wGy0
AM3051-wGy1
AM3052-wGy0
AM3052-wGy1
AM3052-wKy0
AM3052-wKy1
AM3053-wGy0
AM3053-wGy1
AM3053-wKy0
AM3053-wKy1
AM3054-wKy0
AM3054-wKy1
AM3054-wLy0
AM3054-wLy1
AM3062-wKy0
AM3062-wKy1
AM3062-wMy0
AM3062-wMy1
AM3063-wKy0
AM3063-wKy1
AM3063-wMy0
AM3063-wMy1
AM3063-wNy0
AM3063-wNy1
AM3064-wKy0
AM3064-wKy1
AM3064-wLy0
AM3064-wLy1
AM3064-wPy0
AM3064-wPy1
AM3065-wKy0
AM3065-wKy1
AM3065-wMy0
AM3065-wMy1
AM3065-wNy0
AM3065-wNy1
AM3072-wKy0
AM3072-wKy1
AM3072-wMy0
AM3072-wMy1
AM3072-wPy0
AM3072-wPy1
AM3073-wMy0
AM3073-wMy1
AM3073-wPy0
AM3073-wPy1
AM3074-wLy0
AM3074-wLy1
AM3074-wPy0
AM3074-wPy1
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3xxx-option
AM3541-w0y0
AM3541-w0y1
AM3541-w1y0
AM3541-w1y1
AM3542-w0y0
AM3542-w0y1
AM3542-w1y0
AM3542-w1y1
AM3543-w0y0
AM3543-w0y1
AM3543-w1y0
AM3543-w1y1
AM3551-w0y0
AM3551-w0y1
AM3551-w1y0
AM3551-w1y1
AM3552-w0y0
AM3552-w0y1
AM3552-w1y0
AM3552-w1y1
AM3553-w0y0
AM3553-w0y1
AM3553-w1y0
AM3553-w1y1
AM3562-w0y0
AM3562-w0y1
AM3563-w0y0
AM3563-w0y1
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM35xx-option
AM217S-0000
AM217M-0000
AM217S-2000
AM217M-2000
AM227M-0000
AM227M-0001
AM227L-0000
AM227L-0001
AM237S-0000
AM237S-0001
AM237M-0000
AM237M-0001
AM237L-0000
AM237L-0001
AM247M-0000
AM247M-0001
AM247L-0000
AM247L-0001
AM257K-0000
AM257K-0001
AM257S-0000
AM257S-0001
AM257M-0000
AM257M-0001
AM257L-0000
AM257L-0001
AM277K-0000
AM277K-0001
AM277S-0000
AM277S-0001
AM277M-0000
AM277M-0001
AM297K-0000
AM297K-0001
AM297S-0000
AM297S-0001
AM297M-0000
AM297M-0001
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AM2xxx-option
AG2200-+LP050-M01-x-11y
AG2200-+LP050-M02-x-11y
AG2200-+LP070-M01-x-11y
AG2200-+LP070-M02-x-11y
AG2200-+LP090-M01-x-11y
AG2200-+LP090-M02-x-11y
AG2200-+LP120-M01-x-11y
AG2200-+LP120-M02-x-11y
AG2200-+LP155-M01-x-11y
AG2200-+LP155-M02-x-11y
AG2200-option
AG2200-option
AG2200-option
AG2200-option
AL2003-000x-000y
AL2006-000x-000y
AL2012-000x-000y
AL2015-000x-000y
AL2024-000x-000y
AL2030-000x-000y
AL20xx-option
AL20xx-option
AL20xx-option
AL20xx-option
AL2110-0000
AL2120-0000
AL2403-000x-000y
AL2406-000x-000y
AL24xx-option
AL24xx-option
AL24xx-option
AL2510-0000
AL2520-0000
AL2530-0000
AL2815-000x-000y
AL2830-000x-000y
AL2845-000x-0001
AL28xx-option
AL28xx-option
AL28xx-option
AL28xx-option
AL2910-0000
AL2920-0000
AL2200-000z
AL2200-000z-option
AL2200-000z-option
AL2250-0000
AL3803-000x-000y
AL3806-000x-000y
AL3809-000x-000y
AL3812-000x-000y
AL3818-0000-000y
AL38xx-option
AL38xx-option
AL38xx-option
AL38xx-option
AL3910-0000
AL3920-0000
AL3930-0000
AS1010-0000
AS1020-0000
AS1030-0000
AS1050-0000
AS1050-0110
AS1050-0120
AS1060-0000
AS1060-0110
AS1060-0120
AS10xx-option
AS10xx-option
AS10xx-option
AS10xx-option
AS10xx-option
AS10xx-option
AS10xx-option
AS10xx-option
AG1000-+PM052.x
AG1000-+PM081.x
ZK4000-6200-2010
ZK4000-6200-2030
ZK4000-6200-2050
ZK4000-6200-2100
ZK4000-5100-2010
ZK4000-5100-2030
ZK4000-5100-2050
ZK4000-5100-2100
ZK4000-2111-2050
ZK4000-2111-2100
ZK4000-2111-2150
ZK4000-2111-2200
ZK4000-2111-2250
ZK4000-2111-2300
ZK4000-2101-2zzz
ZK4000-2112-2050
ZK4000-2112-2100
ZK4000-2112-2150
ZK4000-2112-2200
ZK4000-2112-2250
ZK4000-2112-2300
ZK4000-2102-2zzz
ZK4000-2711-2050
ZK4000-2711-2100
ZK4000-2711-2150
ZK4000-2711-2200
ZK4000-2711-2250
ZK4000-2701-2zzz
ZK4000-2210-2050
ZK4000-2210-2100
ZK4000-2210-2150
ZK4000-2210-2200
ZK4000-2210-2250
ZK4000-2210-2300
ZK4000-2200-2zzz
ZK4000-2610-2050
ZK4000-2610-2100
ZK4000-2610-2150
ZK4000-2610-2200
ZK4000-2610-2250
ZK4000-2610-2300
ZK4000-2600-2zzz
ZK4000-2410-2050
ZK4000-2410-2100
ZK4000-2410-2150
ZK4000-2410-2200
ZK4000-2410-2250
ZK4000-2410-2300
ZK4000-2400-2zzz
ZK4000-2510-2050
ZK4000-2510-2100
ZK4000-2510-2150
ZK4000-2510-2200
ZK4000-2510-2250
ZK4000-2510-2300
ZK4000-2500-2zzz
ZK4000-2300-0030
ZK4000-2300-0050
ZS4000-2000
ZS4000-2001
ZS4000-2002
ZS4000-2003
ZS4000-2004
ZS4000-2005
ZS4000-2006
ZS4000-2007
ZS4000-2008
ZS4000-2009
ZS4000-2500
ZS4000-2501
ZS4000-2503
ZS4000-2504
ZS4000-2010
ZS4000-2020
ZS4000-2021
ZS4000-2030
ZS4000-2040
ZS4000-2050
ZS4000-2051
ZS4000-2060
ZS4000-2061
ZS4000-2062
ZS4000-2063
ZS4000-2070
ZS4000-2071
ZS4000-2080
ZS4000-2081
ZS4000-2090
ZS4000-2100
ZS4000-2101
AX2090-BW01-0250
AX2090-BW02-0500
AX2090-BW03-1500
AX2090-BW05-2000
AX2090-BW05-3000
AX2090-BW05-6000
AX2090-BW06-2000
AX2090-BW06-3000
AX2090-BW06-6000
AX2090-MD20
AX2090-ND60-0000
AX2090-ND60-0001
AX2090-ND75-0000
AX2090-ND130-0000
AX2090-NF05-0042
AX2090-NF06-0075
AX2090-NF06-0130
AX2090-L025
AX2090-I001
AX2090-PCM0
AX2090-S003
  • 电话:13853163389
  • 传真:021-61638368
  • email:peak-hht@163.com
