- 型号:ACS800-01-0003-3+P901
- 数量:100000
- 制造商:日本
- 有效期:2088/3/26 0:00:00
以下为部分产品型号以及参数供大家参考,详情请来电咨询! 谢谢!
3ABD00015741-D | ACS510-01-03A3-4 | 1.1 | 3.3 | R1 | |
3ABD00015742-D | ACS510-01-04A1-4 | 1.5 | 4.1 | ||
3ABD00015743-D | ACS510-01-05A6-4 | 2.2 | 5.6 | ||
3ABD00015744-D | ACS510-01-07A2-4 | 3 | 7.2 | ||
3ABD00015745-D | ACS510-01-09A4-4 | 4 | 9.4 | ||
3ABD00015746-D | ACS510-01-012A-4 | 5.5 | 11.9 | ||
ACS800-01-0025-3+P901 | ACS510-01-017A-4 | 7.5 | 17 | R2 | |
ACS800-01-0030-3+P901 | ACS510-01-025A-4 | 11 | 25 | ||
3ABD00015749-D | ACS510-01-031A-4 | 15 | 31 | R3 | |
3ABD00015750-D | ACS510-01-038A-4 | 18.5 | 38 | ||
3ABD00021615-D | ACS510-01-046A-4 | 22 | 46 | ||
3ABD00015752-D | ACS510-01-060A-4 | 30 | 60 | R4 | |
3ABD00015753-D | ACS510-01-072A-4 | 37 | 72 | ||
3ABD00021616-D | ACS510-01-088A-4 | 45 | 88 | ||
3ABD00019055-D | ACS510-01-125A-4 | 55 | 125 | R5 | |
3ABD00015756-D | ACS510-01-157A-4 | 75 | 157 | R6 | |
3ABD00015757-D | ACS510-01-180A-4 | 90 | 180 | ||
3ABD00015758-D | ACS510-01-195A-4 | 110 | 205 | ||
3ABD00022031-D | ACS510-01-246A-4 | 132 | 245 | ||
输入电压: 三相AC380V-480V(频率:50/60Hz;价格不含控制盘;防护等级 IP54) | |||||
Square Torque | Frame | ||||
Code No. | Type | 平方转矩应用 | Size | ||
产品代号 | 产品型号 | PN(kW) | I2N(A) | 规格 | |
电机额定功率 | 额定输出电流 | ||||
3ABD00015759-D | ACS510-01-03A3-4+B055 | 1.1 | 3.3 | R1 | |
3ABD00015760-D | ACS510-01-04A1-4+B055 | 1.5 | 4.1 | ||
3ABD00015761-D | ACS510-01-05A6-4+B055 | 2.2 | 5.6 | ||
3ABD00015762-D | ACS510-01-07A2-4+B055 | 3 | 7.2 | ||
3ABD00015763-D | ACS510-01-09A4-4+B055 | 4 | 9.4 | ||
3ABD00015764-D | ACS510-01-012A-4+B055 | 5.5 | 11.9 | ||
3ABD00015765-D | ACS510-01-017A-4+B055 | 7.5 | 17 | R2 | |
3ABD00015766-D | ACS510-01-025A-4+B055 | 11 | 25 | ||
3ABD00015767-D | ACS510-01-031A-4+B055 | 15 | 31 | R3 | |
3ABD00015768-D | ACS510-01-038A-4+B055 | 18.5 | 38 | ||
3ABD00021617-D | ACS510-01-046A-4+B055 | 22 | 46 | ||
3ABD00015770-D | ACS510-01-060A-4+B055 | 30 | 60 | R4 | |
3ABD00015771-D | ACS510-01-072A-4+B055 | 37 | 72 | ||
3ABD00021618-D | ACS510-01-088A-4+B055 | 45 | 88 | ||
3ABD00019056-D | ACS510-01-125A-4+B055 | 55 | 125 | R5 | |
3ABD00015774-D | ACS510-01-157A-4+B055 | 75 | 157 | R6 | |
3ABD00015775-D | ACS510-01-180A-4+B055 | 90 | 180 | ||
3ABD00015776-D | ACS510-01-195A-4+B055 | 110 | 205 | ||
3ABD00022032-D | ACS510-01-246A-4+B055 | 132 | 245 | ||
ACS510可选项 Option | |||||
Code No. | Option Name | Type | |||
产品代号 | 可选项名称 | 产品型号 | |||
3ABD64739000 | 基本控制盘 Basic Control Panel | ACS-CP-C | |||
3ABD68232902 | 高级中文控制盘 Assistant Control Panel for Asia | ACS-CP-D | |||
3ABD68294673 | 螺钉式控制盘安装组件,含一根3米长电缆,一个密封垫, | ACS/H-CP-EXT | |||
固定螺钉和安装模板 | |||||
3ABD00014656 | 托架式控制盘安装组件,含一根3米长电缆,一个塑料固定 | ACS/H-CP-CABINET | |||
托架 | |||||
3ABD68300029 | 控制盘3米连线 | OCAT-02 | |||
3AUA0000002040-D | 继电器输出扩展模块 Relay output extension | OREL-01 | |||
3AUA0000003489-D | (110/230V)/24V数字输入转换模块 | OHDI-01 | |||
制动斩波器(外装)和制动电阻 Brake choppers(separate kit) and brake resistor | |||||
3ABD00017551 | 法兰安装件用于R1 | Flange Mounting Set, R1 | FMS-R1 | ||
3ABD00017550 | 法兰安装件用于R2 | Flange Mounting Set, R2 | FMS-R2 | ||
3ABD00017549 | 法兰安装件用于R3 | Flange Mounting Set, R3 | FMS-R3 | ||
3ABD00017548 | 法兰安装件用于R4 | Flange Mounting Set, R4 | FMS-R4 | ||
3ABD00017552 | 法兰安装件用于R5 | Flange Mounting Set, R5 | FMS-R5 | ||
3ABD00017553 | 法兰安装件用于R6 | Flange Mounting Set, R6 | FMS-R6 | ||
输出滤波器 du/dt Filter | |||||
Type | Output Choke | ||||
产品型号 | 输出滤波器型号 | ||||
ACS510-01-03A3-4 | NOCH0016-6X | ||||
ACS510-01-04A1-4 | |||||
ACS510-01-05A6-4 | |||||
ACS510-01-07A2-4 | |||||
ACS510-01-09A4-4 | |||||
ACS510-01-012A-4 | |||||
ACS510-01-017A-4 | |||||
ACS510-01-025A-4 | NOCH0030-6X | ||||
ACS510-01-031A-4 | |||||
ACS510-01-038A-4 | |||||
ACS510-01-046A-4 | NOCH0070-6X | ||||
ACS510-01-060A-4 | |||||
ACS510-01-072A-4 | |||||
ACS510-01-088A-4 | |||||
ACS510-01-125A-4 | NOCH0120-6X | ||||
ACS510-01-157A-4 | FOCH0260-70 | ||||
ACS510-01-180A-4 | |||||
ACS510-01-195A-4 | |||||
ACS510-01-246A-4 |
Code No. | Type | 一般应用 | 重载应用 | Size | Chopper | ||
产品代号 | 产品型号 | PN(kW) | I2N(A) | PN(kW) | I2N(A) | 规格 | 制动斩波器 |
电机额定功率 | 额定输出电流 | 电机额定功率 | 额定输出电流 | ||||
3AUA0000003385-D | ACS550-01-03A3-4 | 1.1 | 3.3 | 0.75 | 2.4 | R1 | 内含 |
3AUA0000003386-D | ACS550-01-04A1-4 | 1.5 | 4.1 | 1.1 | 3.3 | ||
3AUA0000003387-D | ACS550-01-05A4-4 | 2.2 | 5.4 | 1.5 | 4.1 | ||
3AUA0000002415-D | ACS550-01-06A9-4 | 3 | 6.9 | 2.2 | 5.4 | ||
3AUA0000002419-D | ACS550-01-08A8-4 | 4 | 8.8 | 3 | 6.9 | ||
3AUA0000002420-D | ACS550-01-012A-4 | 5.5 | 11.9 | 4 | 8.8 | ||
3AUA0000002412-D | ACS550-01-015A-4 | 7.5 | 15.4 | 5.5 | 11.9 | R2 | |
ACS800-01-0025-3+P901 | ACS550-01-023A-4 | 11 | 23 | 7.5 | 15.4 | ||
ACS800-01-0030-3+P901 | ACS550-01-031A-4 | 15 | 31 | 11 | 23 | R3 | 无内含 |
3AUA0000002431-D | ACS550-01-038A-4 | 18.5 | 38 | 15 | 31 | ||
3AUA0000012789-D | ACS550-01-045A-4 | 22 | 45 | 18.5 | 38 | ||
3AUA0000002546-D | ACS550-01-059A-4 | 30 | 59 | 22 | 44 | R4 | |
3AUA0000002547-D | ACS550-01-072A-4 | 37 | 72 | 30 | 59 | ||
3AUA0000013108-D | ACS550-01-087A-4 | 45 | 87 | 37 | 77 | ||
3ABD68589657 | ACS550-01-125A-4 | 55 | 125 | 45 | 96 | R5 | |
3ABD64726820 | ACS550-01-157A-4 | 75 | 157 | 55 | 124 | R6 | |
3ABD64726838 | ACS550-01-180A-4 | 90 | 180 | 75 | 156 | ||
3ABD68294479 | ACS550-01-195A-4 | 110 | 205 | 90 | 162 | ||
3AUA0000014490-D | ACS550-01-246A-4 | 132 | 245 | 110 | 192 | ||
输入电压: 三相AC380V~480V(频率: 50/60Hz;价格不含控制盘;防护等级 IP54) | |||||||
Normal Use | Heavy Duty Use | Frame | Brake | ||||
3AUA0000004217-D | ACS550-01-03A3-4+B055 | 1.1 | 3.3 | 0.75 | 2.4 | R1 | 内含 |
3AUA0000004220-D | ACS550-01-04A1-4+B055 | 1.5 | 4.1 | 1.1 | 3.3 | ||
3AUA0000004223-D | ACS550-01-05A4-4+B055 | 2.2 | 5.4 | 1.5 | 4.1 | ||
3AUA0000004224-D | ACS550-01-06A9-4+B055 | 3 | 6.9 | 2.2 | 5.4 | ||
3AUA0000004227-D | ACS550-01-08A8-4+B055 | 4 | 8.8 | 3 | 6.9 | ||
3AUA0000004230-D | ACS550-01-012A-4+B055 | 5.5 | 11.9 | 4 | 8.8 | ||
3AUA0000004233-D | ACS550-01-015A-4+B055 | 7.5 | 15.4 | 5.5 | 11.9 | R2 | |
3AUA0000004236-D | ACS550-01-023A-4+B055 | 11 | 23 | 7.5 | 15.4 | ||
3AUA0000004239-D | ACS550-01-031A-4+B055 | 15 | 31 | 11 | 23 | R3 | 无内含 |
3AUA0000004242-D | ACS550-01-038A-4+B055 | 18.5 | 38 | 15 | 31 | ||
3AUA0000012787-D | ACS550-01-045A-4+B055 | 22 | 45 | 18.5 | 38 | ||
3AUA0000004248-D | ACS550-01-059A-4+B055 | 30 | 59 | 22 | 44 | R4 | |
3AUA0000004251-D | ACS550-01-072A-4+B055 | 37 | 72 | 30 | 59 | ||
3AUA0000013240-D | ACS550-01-087A-4+B055 | 45 | 87 | 37 | 77 | ||
3ABD68632994 | ACS550-01-125A-4+B055 | 55 | 125 | 45 | 96 | R5 | |
3ABD68265312 | ACS550-01-157A-4+B055 | 75 | 157 | 55 | 124 | R6 | |
3ABD68265339 | ACS550-01-180A-4+B055 | 90 | 180 | 75 | 156 | ||
3ABD68294487 | ACS550-01-195A-4+B055 | 110 | 205 | 90 | 162 | ||
3AUA0000015782-D | ACS550-01-246A-4+B055 | 132 | 245 | 110 | 192 | ||
控制盘、连线和安装组件 Control Panel/Cable/Mounting Platform | |||||||
Code No. | Option Name | Type | |||||
产品代号 | 可选项名称 | 产品型号 | |||||
3ABD64738984 | HVAC 控制盘 HVAC Control Panel | ACH-CP-B | |||||
3ABD64739000 | 基本控制盘 Basic Control Panel | ACS-CP-C | |||||
3ABD68232902 | 高级中文控制盘 Assistant Control Panel for Asia | ACS-CP-D | |||||
3ABD68294673 | 螺钉式控制盘安装组件,含一根3米长电缆,一个密封垫,固定螺钉和安装模板 | ACS/H-CP-EXT | |||||
3ABD00014656 | 托架式控制盘安装组件,含一根3米长电缆,一个塑料固定托架 | ACS/H-CP-CABINET | |||||
3ABD68300029 | 控制盘3米连线 | OCAT-02 | |||||
可选适配器模块 Option Modules | |||||||
3AUA0000002040-D | 继电器输出扩展模块 Relay output extension | OREL-01 | |||||
3AUA0000003489-D | (110/230V)/24V 数字输入转换模块 110/230 V Digital Input Module | OHDI-01 | |||||
3AUA0000002051-D | 脉冲编码器接口模块 Pulse Encoder Interface Module | OTAC-01 | |||||
参见ACS800 | 总线适配器DeviceNet Adapter | RDNA-01 | |||||
参见ACS800 | 总线适配器LonWorks Adapter | RLON-01 | |||||
参见ACS800 | 总线适配器Profibus DP Adapter | RPBA-01 | |||||
参见ACS800 | 总线适配器CANOpen Adapter | RCAN-01 | |||||
参见ACS800 | 总线适配器ControlNet Adapter | RCNA-01 | |||||
参见ACS800 | 总线适配器Ethernet Adapter | RETA-01 |
输出滤波器 du/dt filter | ||||||
Type | ||||||
产品型号 | ||||||
ACS550-01-03A3-4 | NOCH0016-6X | |||||
ACS550-01-04A1-4 | ||||||
ACS550-01-05A4-4 | ||||||
ACS550-01-06A9-4 | ||||||
ACS550-01-08A8-4 | ||||||
ACS550-01-012A-4 | ||||||
ACS550-01-015A-4 | ||||||
ACS550-01-023A-4 | NOCH0030-6X | |||||
ACS550-01-031A-4 | ||||||
ACS550-01-038A-4 | ||||||
ACS550-01-045A-4 | NOCH0070-6X | |||||
ACS550-01-059A-4 | ||||||
ACS550-01-072A-4 | ||||||
ACS550-01-087A-4 | ||||||
ACS550-01-125A-4 | NOCH0120-6X | |||||
ACS550-01-157A-4 | FOCH0260-70 | |||||
ACS550-01-180A-4 | ||||||
ACS550-01-195A-4 | ||||||
ACS550-01-246A-4 | ||||||
额外加装EMC滤波器 EMC Filter | ||||||
Code No. | Type | Remark | ||||
产品代号 | 型号 | 备注 | ||||
3ABD63998702 | ACS400-IF11-3 | ACS550 R1,EMC filter, max cable length 100 m | ||||
3ABD63998711 | ACS400-IF21-3 | ACS550 R2,EMC filter, max cable length 100 m | ||||
3ABD64058401 | ACS400-IF31-3 | ACS550 R3,EMC filter, max cable length 100 m | ||||
3ABD64058428 | ACS400-IF41-3 | ACS550 R4,EMC filter, max cable length 100 m | ||||
3ABD64278118 | ACS400-IF22-3 | ACS550 IP21 R1/2, EMC filter, max.cable length 10 m | ||||
调试工具 Commissioning Tools | ||||||
Code No. | Name and Description | Type | ||||
产品代号 | 名称及描述 | 型号 | ||||
3ABD64532871 | DriveWindow Light 最新正版软件并包含 OPCA-02连线 | DriveWindow Light | ||||
3ABD68239745 | 计算机与ACS550 连线 PC-drive Cable Connection | OPCA-02 | ||||
制动斩波器和制动电阻 Brake Chopper & Brake Resistor | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Type | 制动斩波器 | 外置 | 制动电阻 | 斩波器和电阻 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
产品型号 | 配置 | 制动斩波器 | 型号 | 一体式套件 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-03A3-4 | 内置标配 | 不需要 | CBR-V 210 DT 281 200R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-04A1-4 | 内置标配 | 不需要 | CBR-V 210 DT 281 200R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-05A4-4 | 内置标配 | 不需要 | CBR-V 210 DT 281 200R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-06A9-4 | 内置标配 | 不需要 | CBR-V 460 DT 281 80R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-08A8-4 | 内置标配 | 不需要 | CBR-V 460 DT 281 80R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-012A-4 | 内置标配 | 不需要 | CBR-V 460 DT 281 80R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-015A-4 | 内置标配 | 不需要 | CBR-V 460 DT 281 80R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-023A-4 | 内置标配 | 不需要 | CBR-V 460 DT 281 80R | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-031A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | ACS - BRK - C | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-038A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | ACS - BRK - D | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-045A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | ACS - BRK - D | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-059A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | ACS - BRK - D | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-072A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | ACS - BRK - D | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-087A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | ACS - BRK - D | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-125A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-157A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-180A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-195A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS550-01-246A-4 | 外置可选 | NBRA系列(参考ACS800) | 匹配NBRA(参考ACS800) | 无 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACS - BRK - C;ACS - BRK - D和CBR-V系列电阻及其防护外罩转主菜单选 CompAC Options
- 电话:0512-82098825
- 传真:0512-82098825
- email:hy07990@163.com
更多内容请访问 顾先东_17(http://home.gongkong.com/profile/?uid=2008072618060000001)
