- 数量:1000
- 有效期:2020/8/31 0:00:00
接近开关/接近传感器:
HYP-8R1.5NA HYP-8R1.5PA HYP-8R1.5NC HYP-8R1.5PC HYP-8R2NA HYP-8R2PA HYP-8R2NC HYP-8R2PC HYP-12R2NA HYP-12R2PA HYP-12R2NC HYP-12R2PC HYP-12R4NA HYP-12R4PA HYP-12R4NC HYP-12R4PC HYP-18R5NA HYP-18R5PA HYP-18R5NC HYP-18R5PC HYP-18R8NA HYP-18R8PA HYP-18R8NC HYP-18R8PC HYP-18RL5NA HYP-18RL5PA HYP-18RL5NC HYP-18RL5PC HYP-18RL8NA HYP-18RL8PA HYP-18RL8NC HYP-18RL8PC HYP-30R10NA HYP-30R10PA HYP-30R10NC HYP-30R10PC HYP-30R15NA HYP-30R15PA HYP-30R15NC HYP-30R15PC HYP-30RL10NA HYP-30RL10PA HYP-30RL10NC HYP-30RL10PC HYP-30RL15NA HYP-30RL15PA HYP-30RL15NC HYP-30RL15PC HYP-18S5NAF HYP-18S5PAF HYP-18S5NCF HYP-18S5PCF HYP-18S8NAF HYP-18S8PAF HYP-18S8NCF HYP-18S8PCF HYP-18S5NAU HYP-18S5PAU HYP-18S5NCU HYP-18S5PCU HYP-18S8NAU HYP-18S8PAU
HYP-18S8NCU HYP-18S8PCU HYP-25S5NA HYP-25S5PA HYP-25S5NC HYP-25S5PC HYP-25S8NA HYP-25S8PA HYP-25S8NC HYP-25S8PC HYP-25S12NA HYP-25S12PA HYP-25S12NC HYP-25S12PC HYP-30S10NA HYP-30S10PA HYP-30S10NC HYP-30S10PC HYP-30S15NA HYP-30S15PA HYP-30S15NC HYP-30S15PC HYP-40S20NA HYP-40S20PA HYP-40S20NC HYP-40S20PC HYP-12R2AA HYP-12R2AC HYP-12R4AA HYP-12R4AC HYP-18R5AA HYP-18R5AC HYP-18R8AA HYP-18R8AC HYP-30R10AA HYP-30R10AC HYP-30R15AA HYP-30R15AC HYP-18RL5AA HYP-18RL5AC HYP-18RL8AA HYP-18RL8AC HYP-30RL10AA HYP-30RL10AC HYP-30RL15AA HYP-30RL15AC HYP-25S5AA HYP-25S5AC HYP-25S8AA HYP-25S8AC HYP-30S10AA HYP-30S10AC HYP-30S15AA HYP-30S15AC HYP-40S20AA HYP-40S20AC HCP-18R8NA HCP-18R8NC HCP-18R8PA HCP-18R8PC HCP-18RP8NA HCP-18RP8NC HCP-18RP8PA HCP-18RP8PC HCP-30R15NA HCP-30R15NC HCP-30R15PA HCP-30R15PC HCP-30RP15NA HCP-30RP15NC HCP-30RP15PA HCP-30RP15PC HCP-18R8AA HCP-18R8AC HCP-18RP8AA HCP-18RP8AC HCP-30R15AA HCP-30R15AC HCP-30RP15AA HCP-30RP15AC
1) 检测距离:按指定方法移动检测物体,从基准位置(基准面)到测定动作(复位的距离),检测距离是使用标准检测物体时的数值。
2) 差动距离:到动作的距离和复位的距离的绝对值。
3) 设定距离:包括(温度,振动,灰尘)等在检测距离的70%的位置设定检测物体。
4) 响应时间:检测物体在动作领域内,从接近开关动作的状态到显现输出时的时间。离开动作领域到输出消失为止的时间。
5) 响应频率(HZ):把最快的反复接近检测物体时,能得出跟踪它的输出的每秒次数。
6) 常开(Normal open):接近开关的输出在不检测物体时不输出的状态(open态)下,检测物体时发生输出的状态。
常闭(Normal close):非检测物体时输出,检测时不输出(做Nomal open型反对动作)。
- 电话:0512-57995281
- email:hulihui_1981@yahoo.com.cn
相关推荐
