当前页面: 首页 >供求信息 >郑州高恩供应三菱FX系列可编程控制器及维修
供稿:weiyanbo13 2009/8/28 14:46:21
人气:67
  • 数量:10
  • 有效期:2083/12/31 0:00:00
FX1N-14MR-001  BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS  2,310.00
FX1N-14MT-001  BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS  2,400.00
FX1N-1DA-BD  1 CHANNEL D/A  1,170.00
FX1N-232-BD  RS-232C SERIAL PORT (1 CH)  390.00
FX1N-24MR-001  BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS  3,330.00
FX1N-24MR-D  BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 2,990.00
FX1N-24MT-001  BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS  3,400.00
FX1N-24MT-D  BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS  3,100.00
FX1N-2AD-BD  2 CHANNELS A/D  1,170.00
FX1N-2EYT-BD  EXT. BOARD WITH 2 TRANSISTOR OUTPUTS 470.00
FX1N-40MR-001  BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS  4,030.00
FX1N-40MR-D  BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,010.00
FX1N-40MT-001  BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS  4,130.00
FX1N-40MT-D  BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS  4,100.00
FX1N-422-BD  RS-485 SERIAL PORT (1 CH)  390.00
FX1N-485-BD  RS-422 SERIAL PORT (1 CH)  390.00
FX1N-4EX-BD  EXT. BOARD WITH 4 INPUTS  470.00
FX1N-5DM  DISPLAY MODULE FOR FX1S/1N PLC 450.00
FX1N-60MR-001  BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS  4,680.00
FX1N-60MR-D  BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS  4,490.00
FX1N-60MT-001  BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS  4,800.00
FX1N-60MT-D  BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS  4,600.00
FX1N-8AV-BD  MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS 390.00
FX1NC-16MT  BASE UNIT WITH 8 INPUTS/8 TRANISITOR OUTPUTS 2,550.00
FX1NC-32MT  BASE UNIT WITH 16 INPUTS/16 TRANISITOR OUTPUTS  3,550.00
FX1N-CNV-BD  FX0N MODULE TRANSFORM UNIT  390.00
FX1N-EEPROM-8L  PLC PROGRAM TRANSFER UNIT  710.00
FX1S-10MR-001  BASE UNIT WITH 6 INPUTS/4 RELAY OUTPUTS 1,580.00
FX1S-10MR-D  BASE UNIT WITH 6 INPUTS/4 RELAY OUTPUTS  1,530.00
FX1S-10MT-001  BASE UNIT WITH 6 INPUTS/4 TRANSISTOR OUTPUTS  1,620.00
FX1S-10MT-D  BASE UNIT WITH 6 INPUTS/4 TRANSISTOR OUTPUTS  1,570.00
FX1S-14MR-001  BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS 1,850.00
FX1S-14MR-D  BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS  1,850.00
FX1S-14MT-001  BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 1,900.00
FX1S-14MT-D  BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS  1,900.00
FX1S-20MR-001  BASE UNIT WITH 12 INPUTS/8 RELAY OUTPUTS 2,350.00
FX1S-20MR-D  BASE UNIT WITH 12 INPUTS/8 RELAY OUTPUTS 2,230.00
FX1S-20MT-001  BASE UNIT WITH 12 INPUTS/8 TRANSISTOR OUTPUTS  2,410.00
FX1S-20MT-D  BASE UNIT WITH 12 INPUTS/8 TRANSISTOR OUTPUTS  2,300.00
FX1S-30MR-001  BASE UNIT WITH 16 INPUTS/14 RELAY OUTPUTS 2,870.00
FX1S-30MR-D  BASE UNIT WITH 16 INPUTS/14 RELAY OUTPUTS  2,720.00
FX1S-30MT-001  BASE UNIT WITH 16 INPUTS/14 TRANSISTOR OUTPUTS 2,940.00
FX1S-30MT-D  BASE UNIT WITH 16 INPUTS/14 TRANSISTOR OUTPUTS 2,800.00
FX-20P-ADP-KIT  OFFLINE PROGRAMMING ADAPTOR 1,480.00
FX-20P-CADP  UNIVERSAL ADAPTOR CABLE 0.3M  250.00
FX-20P-E-SET0  HANDY PROGRAMMING PANEL FOR FX0S,FX0N,FX2N SERIES CPU 2,740.00
FX-20P-RWM  ROM WRITER FOR FX-20P-E 3,380.00
FX-232CAB-1  DATA TRANSFER CABLE BETWEEN COMPUTER AND FGOT 1,140.00
FX-25DU-E  DATA ACCESS UNIT (LCD GRAPHIC TYPE)  5,400.00
FX2N-10GM  1 AXIS POSITION CONTROL UNIT 4,480.00
FX2N-10PG  PULSE TRAIN OUTPUT BLOCK (1 CH-1MHz)  5,250.00
FX2N-128MR-001  BASE UNIT WITH 64 INPUTS/64 RELAY OUTPUTS 10,120.00
FX2N-128MT-001  BASE UNIT WITH 64 INPUTS/64 TRANSISTOR OUTPUTS  10,330.00
FX2N-16CCL-M  COMPUTER AND COMMUNICATION LINKmasterBLOCK 2,700.00
FX2N-16EX  EXTENSION UNIT WITH 16 INPUTS 1,370.00
FX2N-16EYR  EXTENSION UNIT WITH 8 RELAY OUTPUTS 1,530.00
FX2N-16EYT  EXTENSION UNIT WITH 8 TRANSISTOR OUTPUTS 1,530.00
FX2N-16LNK-M  REMOTE I/O SYSTEMmasterBLOCK 2,160.00
FX2N-16MR-001 BASE UNIT WITH 8 INPUTS/8 RELAY OUTPUTS 4,150.00
FX2N-16MT-001  BASE UNIT WITH 8 INPUTS/8 TRANSISTOR OUTPUTS 4,240.00
FX2N-1HC  HIGH SPEED COUNTER BLOCK (1 CH)  3,170.00
FX2N-1PG-E  PULSE TRAIN OUTPUT BLOCK (1 CH-100KHz)  4,270.00
FX2N-1RM-E-SET  PROGRAMMABLE CAM MODULE INCLUDE RESOLVER 8,770.00
FX2N-20GM  2 AXIS POSITION CONTROL UNIT  8,860.00
FX2N-232-BD  RS-232C SERIAL PORT (1 CH)  400.00
FX2N-232IF  RS-232 COMMUNICATION BLOCK (1 CH)  4,480.00
FX2N-2AD  2 CHANNELS A/D 1,740.00
FX2N-2DA  2 CHANNELS D/A 2,100.00
FX2N-2LC  2 CHANNELS TEMPERATURE CONTROL BLOCK  4,450.00
FX2N-32ASI-M  AS-INTERFACEmasterBLOCK  4,230.00
FX2N-32CCL  COMPUTER AND COMMUNICATION LINK INTERFACE BLOCK 2,490.00
FX2N-32ER  EXTENSION UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 3,060.00
FX2N-32ET  EXTENSION UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS  3,060.00
FX2N-32MR-001 BASE UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 5,180.00
FX2N-32MR-D  BASE UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 5,180.00
FX2N-32MT-001  BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 5,290.00
FX2N-422-BD  RS-422 SERIAL PORT (1 CH)  400.00
FX2N-485-BD  RS-485 SERIAL PORT (1 CH)  400.00
FX2N-48ER  EXTENSION UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 4,190.00
FX2N-48ET  EXTENSION UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS 4,190.00
FX2N-48MR-001 BASE UNIT WITH 24 INPUTS/24 RELAY OUTPUTS  5,490.00
FX2N-48MR-D  BASE UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 5,490.00
FX2N-48MT-001  BASE UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS  5,600.00
FX2N-4AD  4 CHANNELS A/D 2,310.00
FX2N-4AD-PT  4 CHANNELS TEMPERATURE INPUTS, PT TYPE  3,270.00
FX2N-4AD-TC  4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE 3,270.00
FX2N-4DA  4 CHANNELS D/A 3,270.00
FX2N-5A  4 CHANNEL A/D, 1 CHANNEL D/A 3,400.00
FX2N-64MR-001  BASE UNIT WITH 32 INPUTS/32 RELAY OUTPUTS 6,280.00
FX2N-64MR-D  BASE UNIT WITH 32 INPUTS/32 RELAY OUTPUTS 6,280.00
FX2N-64MT-001  BASE UNIT WITH 32 INPUTS/32 TRANSISTOR OUTPUTS 6,410.00
FX2N-80MR-001  BASE UNIT WITH 40 INPUTS/40 RELAY OUTPUTS  7,030.00
FX2N-80MR-D  BASE UNIT WITH 40 INPUTS/40 RELAY OUTPUTS 7,030.00
FX2N-80MT-001  BASE UNIT WITH 40 INPUTS/40 TRANSISTOR OUTPUTS 7,180.00
FX2N-8AD  8 CHANNELS A/D 7,630.00
FX2N-8AV-BD  MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS  400.00
FX2NC-16EX  EXTENSION UNIT WITH 16 INPUTS  1,360.00
FX2NC-16EX-T  EXTENSION UNIT WITH 16 INPUTS  1,080.00
FX2NC-16EYR-T  EXTENSION UNIT WITH 8 RELAY OUTPUTS  1,320.00
FX2NC-16EYT  EXTENSION UNIT WITH 16 TRANSISTOR OUTPUTS 1,660.00
FX2NC-16MT  BASE UNIT WITH 8 INPUTS/8 TRANISITOR OUTPUTS  3,220.00
FX2NC-32BL  BATTERY FOR F930GOT(-K)/ HANDY GOT  330.00
FX2NC-32EX  EXTENSION UNIT WITH 32 INPUTS 2,410.00
FX2NC-32EYT  EXTENSION UNIT WITH 32 TRANSISTOR OUTPUTS  2,560.00
FX2NC-32MT  BASE UNIT WITH 16 INPUTS/16 TRANISITOR OUTPUTS 4,230.00
FX2NC-64MT  BASE UNIT WITH 32 INPUTS/32 TRANISITOR OUTPUTS 6,610.00
FX2NC-96MT  BASE UNIT WITH 48 INPUTS/48 TRANISITOR OUTPUTS 8,760.00
FX2N-CNV-BC  EXTENSION CABLE CONVERTOR  400.00
FX2N-CNV-BD  FX0N MODULE TRANSFORM UNIT  400.00
FX2N-CNV-IF  EXTENSION CABLE CONVERTOR (FX2 TO FX2N)  400.00
FX2N-ROM-E1  INVERTER INSTRUCTION CASSETTE  1,460.00
FX2N-RS-5CAB  SIGNAL CABLE BETWEEN FX2N-1RM AND F2-720RSV 620.00
FX-2PIF  2 TO 1 INTERFACE FOR FX-20P-E, DATA ACCESS UNIT AND FX PLC  4,490.00
FX-30DU-E  DATA ACCESS UNIT (LCD GRAPHIC TYPE)  6,590.00
FX3U-232ADP  RS232 COMMUNICATION MODULE 1,590.00
FX3U-232-BD  RS-232C SERIAL PORT (1 CH)  590.00
FX3U-32BL  BACKUP BATTERY FOR FX3UC CPU  470.00
FX3U-425-BD  RS-422 SERIAL PORT (1 CH)  590.00
FX3U-485ADP  RS485 COMMUNICATION MODULE WITH MULTI-DROP FUNCTION  1,590.00
FX3U-485-BD  RS-485 SERIAL PORT (1 CH)  590.00
FX3U-4AD-ADP  4 CHANNELS A/D  6,810.00
FX3U-4AD-PT-ADP  4 CHANNELS TEMPERATURE INPUTS, PT TYPE  3,490.00
FX3U-4AD-TC-ADP  4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE  3,490.00
FX3U-4DA-ADP  4 CHANNELS D/A 6,810.00
FX3U-7DM-HLD  DISPLAY PANEL HOLDER  700.00
FX3UC-1PS-5V  DC 5V 2A POWER SUPPLY UNIT  1,880.00
FX3UC-32MT-LT  BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS  9,400.00
FX3UC-4AD  4 CHANNELS A/D (16BIT)  2,590.00
FX3U-CNV-BD  FX3U MODULE TRANSFORM UNIT  350.00
FX3U-FLROM-64 64K  FLASH ROM MEMORY CASSETTE  2,350.00
FX3U-USB-BD  USB COMMUNICATION PORT (FOR ALL FX SERIES PLC)  1,170.00
FX-40CRW-E  SERIAL TYPE ROM WRITER FOR DATA ACCESS UNIT  9,830.00
FX-485PC-IF  RS232/RS485 CONVERTER  1,360.00
FX-EEPROM-16 16K  EEPROM MEMORY CASSETTE  1,020.00
FX-EEPROM-4 4K  EEPROM MEMORY CASSETTE  490.00
FX-EEPROM-4C  4K EEPROM MEMORY CASSETTE WITH REAL TIME CLOCK 620.00
FX-EEPROM-8 8K  EEPROM MEMORY CASSETTE  620.00
FX-EEPROM-8C  8K EEPROM MEMORY CASSETTE WITH REAL TIME CLOCK 1,010.00
FX-EPROM-8 8K  EPROM MEMORY CASSETTE  490.00
FX-PCS/WIN-C  PROGRAMMING SOFTWARE FOR WINDOW (CHINESE)  950.00
FX-PCS/WIN-C-SET  WINDOWS PROGRAMMING SOFTWARE WITH MANUAL & SC09 2,630.00
FX-PCS/WIN-E  PROGRAMMING SOFTWARE FOR WINDOW (ENGLISH)  950.00
FX-PCS-VPS/WIN-E  GM GRAPHICAL PROGRAMMING SOFTWARE  1,070.00
FX-RAM-8 8K  RAM MEMORY CASSETTE  550.00
FX-RAM-8C 8K  RAM MEMORY CASSETTE WITH REAL TIME CLOCK 810.00
FX-RTC  REAL TIME CLOCK  450.00
FX-USB-AW  RS422/USB CONVERTER, USB CABLE AND DRIVER SOFTWARE  2,300.00
  • 电话:0371-63897587
  • 传真:0371-63897587
  • email:weiyanbo13@163.com
