- 型号:XMTF-6511,XMTF-6512,XMTF-6711,XMTF-6712,XMTF-6331,XMTF-6332,XMTF-6031
- 数量:1000
- 制造商:宁波阳明YANGMING
- 有效期:2028/9/28 0:00:00
宁波阳明YANGMING温控器,深圳总代理经销
面板尺寸96×96;48*48,48*96,72*72,80*160,96*48,控制模式分为位式控制、时间比例、两位PID、脉冲PID;输入分为热电偶、热电阻,输出分为继电器输出、逻辑电平输出。仪表安装于以下环境:
系列型号:XMTA-1001,XMTA-1002,XMTA-1301,XMTA-1302,XMTA-2002,XMTA-2001
XMTD-1001,XMTD-1002,XMTD-2001,XMTD-1301,XMTD-1302,XMTD-2002
XMTE-1001,XMTE-1002,XMTE-1301,XMTE-1302,XMTE-2002,XMTE-2001
XMTG-1001,XMTG-1002,XMTG-2001,XMTG-1301,XMTG-1302,XMTG-2002
XMT-1001,XMT-1002,XMT-2001,XMT-1301,XMT-1302,XMT-2002
XMTA-6301,XMTA-6302,XMTA-6001,XMTA-6002,XMTA-6801,XMTA-6802,XMTA-6501,XMTA-6502,XMTA-6701,XMTA-6702,XMTA-6311,XMTA-6312,XMTA-6011,XMTA-6012,XMTA-6811,XMTA-6812,XMTA-6511,XMTA-6512,XMTA-6711,XMTA-6712,XMTA-6331,XMTA-6332,XMTA-6031,XMTA-6012,XMTA-66831,XMTA-6832,XMTA-66531,XMTA-6531,XMTA-6532,XMTA-6731,XMTA-6732,XMTA-6321,XMTA-6322,XMTA-6021,XMTA-6022,XMTA-6821,XMTA-6822XMTA-6521,XMTA-6522,XMTA-6721,XMTA-6722
XMT-6301,XMT-6302,XMT-6001,XMT-6002,XMT-6801,XMT-6802,XMT-6501,XMT-6502,XMT-6701,XMT-6702,XMT-6311,XMT-6312,XMT-6011,XMT-6012,XMT-6811,XMT-6812,XMT-6511,XMT-6512,XMT-6711,XMT-6712,XMT-6331,XMT-6332,XMT-6031,XMT-6012,XMT-66831,XMT-6832,XMT-66531,XMT-6531,XMT-6532,XMT-6731,XMT-6732,XMT-6321,XMT-6322,XMT-6021,XMT-6022,XMT-6821,XMT-6822,XMT-6521,XMT-6522,XMT-6721,XMT-6722
XMTD-6301,XMTD-6302,XMTD-6001,XMTD-6002,XMTD-6801,XMTD-6802,XMTD-6501,XMTD-6502,XMTD-6701,XMTD-6702,XMTD-6311,XMTD-6312,XMTD-6011,XMTD-6012,XMTD-6811,XMTD-6812,XMTD-6511,XMTD-6512,XMTD-6711,XMTD-6712,XMTD-6331,XMTD-6332,XMTD-6031,XMTD-6012,XMTD-66831,XMTD-6832,XMTD-66531,XMTD-6531,XMTD-6532,XMTD-6731,XMTD-6732,XMTD-6321,XMTD-6322,XMTD-6021,XMTD-6022,XMTD-6821,XMTD-6822,XMTD-6521,XMTD-6522,XMTD-6721,XMTD-6722
XMTE-6301,XMTE-6302,XMTE-6001,XMTE-6002,XMTE-6801,XMTE-6802,XMTE-6501,XMTE-6502,XMTE-6701,XMTE-6702,XMTE-6311,XMTE-6312,XMTE-6011,XMTE-6012,XMTE-6811,XMTE-6812,XMTE-6511,XMTE-6512,XMTE-6711,XMTE-6712,XMTE-6331,XMTE-6332,XMTE-6031,XMTE-6012,XMTE-66831,XMTE-6832,XMTE-66531,XMTE-6531,XMTE-6532,XMTE-6731,XMTE-6732,XMTE-6321,XMTE-6322,XMTE-6021,XMTE-6022,XMTE-6821,XMTE-6822,XMTE-6521,XMTE-6522,XMTE-6721,XMTE-6722
XMTF-6301,XMTF-6302,XMTF-6001,XMTF-6002,XMTF-6801,XMTF-6802,XMTF-6501,XMTF-6502,XMTF-6701,XMTF-6702,XMTF-6311,XMTF-6312,XMTF-6011,XMTF-6012,XMTF-6811,XMTF-6812,XMTF-6511,XMTF-6512,XMTF-6711,XMTF-6712,XMTF-6331,XMTF-6332,XMTF-6031,XMTF-6012,XMTF-66831,XMTF-6832,XMTF-66531,XMTF-6531,XMTF-6532,XMTF-6731,XMTF-6732,XMTF-6321,XMTF-6322,XMTF-6021,XMTF-6022,XMTF-6821,XMTF-6822,XMTF-6521,XMTF-6522,XMTF-6721,XMTF-6722
XMTG-6301,XMTG-6302,XMTG-6001,XMTG-6002,XMTG-6801,XMTG-6802,XMTG-6501,XMTG-6502,XMTG-6701,XMTG-6702,XMTG-6311,XMTG-6312,XMTG-6011,XMTG-6012,XMTG-6811,XMTG-6812,XMTG-6511,XMTG-6512,XMTG-6711,XMTG-6712,XMTG-6331,XMTG-6332,XMTG-6031,XMTG-6012,XMTG-66831,XMTG-6832,XMTG-66531,XMTG-6531,XMTG-6532,XMTG-6731,XMTG-6732,XMTG-6321,XMTG-6322,XMTG-6021,XMTG-6022,XMTG-6821,XMTG-6822,XMTG-6521,XMTG-6522,XMTG-6721,XMTG-6722
YMA-7301,YMA-7302,YMA-7601,YMA-7602,YMA-7801,YMA-7802,YMA-7311,YMA-7312,YMA-7611,YMA-7811YMA-7812,YMA-7331,YMA-7332,YMA-7631,YMA-7831,YMA-7832
YMD-7301,YMD-7302,YMD-7601,YMD-7602,YMD-7801,YMD-7802,YMD-7311,YMD-7312,YMD-7611,YMD-7811,YMD-7812,YMD-7331,YMD-7332,YMD-7631,YMD-7831,YMD-7832
YME-7301,YME-7302,YME-7601,YME-7602,YME-7801,YME-7802,YME-7311,YME-7312,YME-7611,YME-7811,YME-7812,YME-7331,YME-7332,YME-7631,YME-7831,YME-7832
YMG-7301,YMG-7302,YMG-7601,YMG-7602,YMG-7801,YMG-7802,YMG-7311,YMG-7312,YMG-7611,YMG-7811,YMG-7812,YMG-7331,YMG-7332,YMG-7631,YMG-7831,YMG-7832
XMTA-8011,XMTA-8431,XMTA-8531,XMTA-8012,XMTA-8432,XMTA-8901,XMTA-8902,XMTA-8701,XMTA-8702,XMTA-8O21,XMTA-8411,XMTA-8521,XMTA-8022,XMTA-8412,XMTA-8911,XMTA-8711,712,XMTA-8031,XMTA-8421,XMTA-8511,XMTA-8032,XMTA-8422,XMTA-8921,XMTA-8922,XMTA-8731,XMTA-8732,XMTA-8001,XMTA-8401,XMTA-8501,XMTA-8002,XMTA-8402,XMTA-8402,XMTA-8931,XMTA-8932,XMTA-8721,XMTA-8722
XMTD-8011,XMTD-8431,XMTD-8531,XMTD-8012,XMTD-8432,XMTD-8901,XMTD-8902,XMTD-8701,XMTD-8702,XMTD-8O21,XMTD-8411,XMDT-8521,XMTD-8022,XMTD-8412,XMTD-8911,XMTD-8711,XMTD-8712,XMTD-8031,XMTD-8421,XMTD-8511,XMTD-8032,XMTD-8422,XMTD-8921,XMTD-8922,XMTD-8731,XMTD-8732,XMTD-8001,XMTD-8401,XMTD-8501,XMTD-8002,XMTD-8402,XMTD-8402,XMTD-8931,XMTD-8932,XMTD-8721,XMTD-8722
XMTE-8011,XMTE-8431,XMTE-8531,XMTE-8012,XMTE-8432,XMT-8901,XMTE-8902,XMTE-8701,XMTE-8702,XMTE-8O21,XMTE-8411,XMTE-8521,XMTE-8022,XMTE-8412,XMTE-8911,XMTE-8711,XMTE-8712,XMTE-8031,XMTE-8421,XMTE-8511,XMTE-8032,XMTE-8422,XMT-8921,XMT-8922,XMT-8731,XMT-8732,XMT-8001,XMT-8401,XMT-8501,XMT-8002,XMTE-8402,XMTE-8402,XMTE-8931,XMTE-8932,XMTE-8721,XMTE-8722
XMTF-8011,XMTF-8431,XMTF-8531,XMTF-8012,XMTF-8432,XMTF-8901,XMTF-8902,XMTF-8701,XMTF-8702,XMTF-8O21,XMTF-8411,XMTF-8521,XMTF-8022,XMTF-8412,XMTF-8911,XMTF-8711,XMTF-8712,XMTF-8031,XMTF-8421,XMTF-8511,XMTF-8032,XMTF-8422,XMTF-8921,XMTF-8922,XMTF-8731,XMTF-8732,XMTF-8001,XMTF-8401,XMTF-8501,XMTF-8002,XMTF-8402,XMTF-8402,XMTF-8931,XMT-8932,XMTF-8721,XMTF-8722
XMT-8011,XMT-8431,XMT-8531,XMT-8012,XMT-8432,XMT-8901,XMT-8902,XMT-8701,XMT-8702,XMT-8O21,XMT-8411,XMT-8521,XMT-8022,XMT-8412,XMT-8911,XMT-8711,XMT-8712,XMT-8031,XMT-8421,XMT-8511,XMT-8032,XMT-8422,XMT-8921,XMT-8922,XMT-8731,XMT-8732,XMT-8001,XMT-8401,XMT-8501,XMT-8002,XMT-8402,XMT-8402,XMT-8931,XMT-8932,XMT-8721,XMT-8722
XMTG-8011,XMTG-8431,XMTG-8531,XMTG-8012,XMTG-8432,XMTG-8901,XMTG-8902,XMTG-8701,XMTG-8702,XMTG-8O21,XMTG-8411,XMTG-8521,XMTG-8022,XMTG-8412,XMTG-8911,XMTG-8711,XMTG-8712,XMTG-8031,XMTG-8421,XMTG-8511,XMTG-8032,XMTG-8422,XMTG-8921,XMTG-8922,XMTG-8731,XMTG-8732,XMTG-8001,XMT-8401,XMTG-8501,XMTG-8002,XMTG-8402,XMTG-8402,XMTG-8931,XMTG-8932,XMTG-8721,XMTG-8722
多种突波吸收电路,供电子设备、通讯设备、电子计算机控制设备、自动化控制装置等动作切换电路及扩大控制范围之用.
* 自由型电源电压 DC 12~240V 或 AC 24~240V
大容量输出继电器 3A/250VAC
台湾FOTEK阳明光电近接开关/放大器/感应器全系列工控产品 。具CE国际认证产品质保二年。
光电近接开关
A3系列
型 式 型 号 检测距离 输出方式
扩散反射型
A3R-30X 2~30CM 继电器1a1b
A3R-1MX 10~100CM
A3R-2MX 20~200CM
A3R-30XB 2~30CM 继电器1a1b
A3R-1MXB 10~100CM
A3R-2MXB 20~200CM
镜面反射型
A3G-2MR 2~200CM 随包装附镜片MR-1、MR-2自选不购镜片,价格相同 继电器1a1b
A3G-2MRS 200CM
A3G-4MX 400CM
A3G-4MRE 偏极光
A3G-2MRB 2~200CM
A3G-2MRSB 200CM
A3G-4MXB 400CM
对射型 A3T-3MX 300CM 继电器1a1b
A3T-10MX 1000CM
A3T-20MX 2000CM
A3T-100MX 10000CM
A3T-3MXB 300CM 继电器1a1b
A3T-10MXB 1000CM
A3T-20MXB 2000CM
A3T-100MXB 10000CM
订购品 A3□-□□□-3M 标准线长2米5C特殊线长,以上售价另加
A3□-□□□-5M
A3□-□□□-7M
A3□-□□□-P 防水型,以上售价另加
A3□-□□□-投光 单购投光
A3□-□□□-受光 单购受光
联系人:郭浩 手机:15817409928
M18系列
型 式 型 号 检测距离 输出方式
直接反射型 M124R接头线另购
CDR-10X-M12 0~10CM NPN+PNP/NO
CDR-10XB-M12 NPN+PNP/NC
CDR-30X-M12 0~30CM NPN+PNP/NO
CDR-30XB-M12 NPN+PNP/NC
直接反射型 M124R接头线另购
CDM-2MX-M12 0~200CM NPN+PNP/NO
CDM-2MXB-M12 NPN+PNP/NC
CDM-2MX-V-M12 NPN+PNP/NO
CDM-2MXB-V-M12 NPN+PNP/NC
直接反射型 M124R接头线另购
CDT-10MX-M12 10M NPN+PNP/NO
CDT-10MXB-M12 NPN+PNP/NC
CDT-6MX-V-M12 6M NPN+PNP/NO
CDT-6MXB-V-M12 NPN+PNP/NC
直接反射型
CDR-10X 0~10CM NPN+PNP/NO
CDR-10XB NPN+PNP/NC
CDR-30X 0~30CM NPN+PNP/NO
CDR-30XB NPN+PNP/NC
CDR-30N NPN NO/NC
CDR-30X-V NPN+PNP/NO
CDR-30XB-V NPN+PNP/NC
镜面反射型 随包装附镜片MR-1可另选MR-2不购镜片,价格相同
DM-1MN 200CM NPN/NO
DM-1MR 0~200CM NPN+PNP/NO
CDM-2MX NPN+PNP/NO
CDM-2MXB NPN+PNP/NC
CDM-2MX-V 0~200CM NPN+PNP/NO
CDM-2MXB-V NPN+PNP/NC
对射型 CDT-10MX 10M NPN+PNP/NO
CDT-10MXB NPN+PNP/NC
CDT-6MX-V 6M NPN+PNP/NO
CDT-6MXB-V NPN+PNP/NC
AC90-250V 直接反射型
CAR-10X 10CM SCR/NO
CAR-10XB SCR/NC
CAR-10X-V SCR/NO
CAR-10XB-V SCR/NC
AC90-250V 镜面反射型
CAM-2MX 2M SCR/NO
CAM-2MXB SCR/NC
CAM-2MX-V SCR/NO
CAM-2MXB-V SCR/NC
E3系列
型 式 型 号 输出状态 输出延时 检测距离
扩散反射型
E3R-60X NO 无 5-60CM
E3R-60XB NC
M3R-60X NO 0-1秒可调
M3R-60XB NC
镜面反射型
E3G-8MX NO 无 8M
E3G-8MXB NC
M3G-8MX NO 0-1秒可调
M3G-8MXB NC
E3G-6MRE NO 无 6M
E3G-6MREB NC
M3G-6MRE NO 0-1秒可调
M3G-6MREB NC
对射型 E3T-10MX NO 无 10M
E3T-10MXB NC
E3T-30MX NO 无 30M
E3T-30MXB NC
E3T-50MX NO 无 50M
E3T-50MXB NC
M3T-30MX NO 0-1秒可调 30M
M3T-30MXB NC
M3T-50MX NO 0-1秒可调 50M
M3T-50MXB NC
R18系列
型 式 型 号 检测距离 输出方式
金属外壳 直接反射型 M12接头不附线
PDR-10X 0~10CM NPN+PNP/NO
PDR-10XB NPN+PNP/NC
PDR-30X 0~30CM NPN+PNP/NO
PDR-30XB NPN+PNP/NC
金属外壳 镜面反射型 M12接头不附线
PDM-2MX 0~200CM NPN+PNP/NO
PDM-2MXB NPN+PNP/NC
PDM-2MX-V NPN+PNP/NO
PDM-2MXB-V NPN+PNP/NC
金属外壳 对射型 M12接头不附线
PDT-10MX 10M NPN+PNP/NO
PDT-10MXB NPN+PNP/NC
PDT-6MX-V 6M NPN+PNP/NO
PDT-6MXB-V NPN+PNP/NC
M18 金属外壳 直接反射型
MDR-10X 0~10CM NPN+PNP/NO
MDR-10XB NPN+PNP/NC
MDR-30X 0~30CM NPN+PNP/NO
MDR-30XB NPN+PNP/NC
MDR-30X-V NPN+PNP/NO
MDR-30XB-V NPN+PNP/NC
M18 金属外壳 镜面反射型
MDM-2MX 0~200CM NPN+PNP/NO
MDM-2MXB NPN+PNP/NC
MDM-2MX-V NPN+PNP/NO
MDM-2MXB-V NPN+PNP/NC
M18 金属外壳 对射型
MDT-10MX 10M NPN+PNP/NO
MDT-10MXB NPN+PNP/NC
MDT-6MX-V 6M NPN+PNP/NO
MDT-6MXB-V NPN+PNP/NC
M18超短型 直接反射型
R18-10X 0~10CM NPN+PNP/NO
R18-10XB NPN+PNP/NC
M18超短型 镜面反射型
M18-2MX 0~200CM NPN+PNP/NO
M18-2MXB NPN+PNP/NC
M18超短型 对射型
T18-30MX 30M NPN+PNP/NO
T18-30MXB NPN+PNP/NC
MF/F/LT/C系列
型 式 型 号 检测距离 响应时间
微电脑 光纤放大器
MF-06R 0.4ms
MF-06R-M8 M83R线另购
MF-06RT 内附OFD0.2秒
光纤维型
FF-01G 0.4ms
FF-03R 0.4ms
FF-03X 0.4ms
FF-06R 2ms
FF-06X 2ms
直接反射型
FR-1MX 10-100CM 2ms
FR-2MX 20-200CM
FR-1MX-V 10-100CM
FR-2MX-V 20-200CM 2ms
对射型 FT-10MX 10M 2ms
FT-20MX 20M
FT-10MX-V 10M
FT-20MX-V 20M
镜面反射型 附MR-1
FG-3MX 10cm-3M 2ms
FG-3MX-V
窄光反射型
FN-10R 10-100mm 2ms
FN-30X 20-300mm
标志检出型
FM-01R/G 10mm 0.5ms
FM-01PR/PG 10mm 2ms
FM-03R/G 30mm 2ms
FM-10R 100mm 2ms
微电脑式 标志检出
MS-02W 泛用型 M124R线另购 0.2ms
MS-02W-M12
MS-02W-H 高速型 M124R线另购 0.1ms
MS-02W-H-M12
长距离 对射型
LT-40MX 40M NPN 5ms
LT-80MX 80M
LT-150MX 150M
控制器
C-1 AND AC110V/ AC220V
C-1-24V OUT DC24VLC 系列专用
C-2 OND或OST或OFD
C-3 OND+C-2
C-6-□□□V NON AC110V AC220V AC380V
C-10-□□□V OFD
C-11-□□□V OND或OST
C-12-□□□V OND+OFD
AS/SU系列
型 式 型 号 说 明
标志检出型 直接发射
SR-07G 56×25×17 NPN/PNP TWO OUT 1K HZ
标志检出U型 感度可调
SU-07W
SU-07R
SU-07G
标志检出U型
SU-02X 60×35×14 NPN 10K HZ
SU-02R
超高速U型
SU-07X 55×25×16 NPN 5K HZ
SU-07XP 55×25×16 PNP 5K HZ
放大器 A-8 AC110V/220V 2ms
A-9
感应器分离器 FS-50 2ms
与线水平式 光电头
SH-10 21×12×8 10CM 2¢
SH-15 21×12×8 15CM 0.5¢
SH-30 21×12×8 30CM 1¢
SH-50 21×12×8 50CM 2¢
SH-2M 21×12×8 2M 2¢
与线垂直式 光电头
SV-10 21×22×8 10CM 2¢
SV-15 21×22×8 15CM 0.5¢
SV-30 21×22×8 30CM 1¢
SV-50 21×22×8 50CM 2¢
SV-2M 21×22×8 2M 2¢
M8圆筒型 光电头
SC-10 M8×25 10CM 2¢
SC-15 M8×25 15CM 0.5¢
SC-30 M8×25 30CM 1¢
SC-50 M8×25 50CM 2¢
SC-2M M8×25 2M 2¢
直接反射式 光电头
SB-03 12×23×10 3CM 2¢
SB-10 12×23×10 10CM 1¢
订购品 SU-□□-□M 标准线长2米 每增1米原售价另加
SU□-□□-□M 光电头隔离线标准长2米 每组对每增1米原售价另加
火花消除器
SQ-115P 单相AC110V 0.1μF/50Ω
SQ1-211W 单相AC250V 0.1μF/100Ω
SQ1-511W 单相AC550V 0.1μF/100Ω
SQ3-351W 三相AC250V 0.47μF/47Ω
SQ3-511W 三相AC550V 0.1μF/100Ω
MS系列
型 式 型 号 检测距离 输出方式
直接反射型
MR-10NE 0~10CM NPN NO/NC
MR-10X NPN+PNP/NO
MR-10XB NPN+PNP/NC
MR-30X 0~30CM NPN+PNP/NO
MR-30XB NPN+PNP/NC
MR-30N NPN NO/NC
MR-60X 0~60CM NPN+PNP/NO
MR-60XB NPN+PNP/NC
MR-60N NPN NO/NC
防水型 直接反射型
MR-30XP 0~30CM NPN+PNP/NO
MR-60XP 0~60CM NPN+PNP/NC
镜面反射型
MG-2MX 0~200M NPN+PNP/NO
MG-2MXB NPN+PNP/NC
镜面反射型 防水型
MG-2MXP 0~200M NPN+PNP/NO
MG-2MXBP NPN+PNP/NC
对射型 MT-6MX 0~600CM NPN+PNP/NO
MT-6MXB NPN+PNP/NC
对射型 防水型
MT-6MXP 0~600CM NPN+PNP/NO
MT-6MXBP NPN+PNP/NC
注: 光电开关标准线长2米
型 式 型 号 说 明
光纤维线 (对射式)
FPT-01 ¢ 0.5/M4
FPT-02-1M ¢ 1.0/M4线长1米
FPT-02 ¢ 1.0/M4
FPT-04 ¢ 1.0/M4+40mm
FPT-05 ¢ 1.0/M4+90mm
FPT-06 ¢ 0.5/M3
光纤维线 (直接反射式)
FPR-51-1M ¢ 1.0×2/M6线长1米
FPR-51 ¢ 1.0×2/M6
FPR-52-1M ¢ 1.0×2/M6M同轴式线长1米
FPR-52 ¢ 1.0×2/M6 同轴式
FPR-54 ¢ 0.5×2/M4
FPR-55S ¢ 1.0×2/M6+40mm
FPR-55 ¢ 1.0×2/M6+90mm
FPR-56S ¢ 0.5×2/M4+40mm
FPR-56 ¢ 0.5×2/M4+90mm
光纤镜头
FX-LE1(FL-1)一个 ¢ 4.0×8.0 平行式
FX-SV1(FL-2)一个 ¢ 4.0×9.5 垂直式
FX-MR1 ¢ 4.0平行 焦点式
FX-MR5 ¢ 4.0垂直 焦点式
光纤维线
F-0.5-1 日制光纤线 ¢ 0.5/1每米
F-1.0-1 ¢ 1.0/1每米
F-0.5-2 ¢ 0.5/2每米
F-1.0-2 ¢ 1.0/1每米
光纤维线切断器 FA-C 日制光纤刀
耐曲折 耐油电缆线
3R-M4 3C电缆线外径M4 基本单位
4R-M5 4C电缆线外径M5 200米
5R-M6 5C电缆线外径M6 每米单价
M8连接线
M83R-2M M8接头式2米线
M83R-3M M8接头式3米线
M83R-5M M8接头式5米线
M12连接线
M124R-3M M12接头式3米线
M124R-5M M12接头式5米线
M124R-3M-L M12垂直接头式3米线
M124R-5M-L M12垂直接头式5米线
反射镜片 MR-1 115×60×P100mm
反射镜片 MR-2 42×35×P25mm
美国镜片 M-80 52×62×P30mm
60齿轮片 60TDISK 固定孔M3×4
¢100mm 中心孔¢24mm
计米器
型 号 单 位 输 出
WE-M1 1米 A相
WE-M2 0.1米(10cm)
WE-M3 0.01米1cm
WE-M2T 0.1米(1cm) A、B相
WE-M3T 0.01米1cm
WE-M4T 0.001米1mm
WE-Y1 1码 A相
WE-Y2 0.1码
WE-Y3 0.01码
WE-Y2T 0.1码 A、B相
WE-Y3T 0.01码
WE-Y4T 0.001码
WE-M 米轮 每个
WE-Y 码轮
WE-□□-3M 标准线长2米3C、4C
WE-□□-5M 特殊线长,
WE-□□-7M 以上售价另加
外 型 型 号 负荷型式 响应频率 感应距离
长条型 12×12×50
PS-04N NPN/NO 2K HZ 4.0MM
PS-04P PNP/NO
PS-04N-V NPN/NO
PS-04P-V PNP/NO
微动开关型 30×10.5×16.4
BS-02N NPN/NO 2K HZ 2.0MM
BS-02P PNP/NO
BS-04N NPN/NO 4.0MM
BS-04P PNP/NO
扁平型 上方感应 PP 25×10×50 LS 12×12×35 SP 18×10×30
PP-05N NPN/NO 800HZ 5.0MM
PP-05P PNP/NO
PP-08N NPN/NO 8.0MM
PP-08P PNP/NO
LS-04N NPN/NO 4.0MM
LS-04N-V PNP/NO
SP-05N NPN/NO 5.0MM
方型 17×17×30 PS-05N NPN/NO 800HZ 5.0MM
PS-05P PNP/NO
PS-08N NPN/NO 8.0MM
PS-08P PNP/NO
方型 17×17×35 PL-05N NPN/NO 800HZ 5.0MM
PL-05P PNP/NO
PL-08N NPN/NO 8.0MM
PL-08P PNP/NO
PS-05S SCR/NO 20HZ 5.0MM
PS-08S SCR/NO 8.0MM
方型 25×25×50 PS-10N NPN/NO 500HZ 10.0MM
PS-10P PNP/NO
PS-15N NPN/NO 15.0MM
PS-15P PNP/NO
PS-10S SCR/NO 20HZ 10.0MM
PS-15S SCR/NO 15.0MM
M18×71 静电容型
CP18-30N NPN/NO 100HZ 0-30MM
CP18-30P PNP/NO
M30×60 静电容型
CP30-50C NPN+PNP/NO 100HZ 0-50MM
CP30-50S SCR/NO 15HZ
圆筒型 近接开关
M08×48 PM-08-01N NPN 2.5K HZ 1.0MM
PM-08-01P PNP
M08×48 PM-08-02N NPN 2.0MM
PM-08-02P PNP
M12×52 PM12-02N NPN 2.5K HZ 2.5MM
PM12-02P PNP
M12×57 PM12-04N NPN 4.0MM
PM12-04P PNP
M12×37 PM12-02N-S NPN 2.5K HZ 2.5MM
PM12-02P-S PNP
M12×42 PM12-04N-S NPN 4.0MM
PM12-04P-S PNP
M12×52 TW12-02C 两线式 2.5K HZ 2.5MM
M12×57 TW12-04C 4.0MM
M18×50 PM18-05N NPN 800HZ 5.0MM
PM18-05P PNP
M18×56 PM18-08N NPN 8.0MM
PM18-08P PNP
M18×37 PM18-05N-S NPN 800HZ 5.0MM
PM18-05P-S PNP
M18×43 PM18-08N-S NPN 8.0MM
PM18-08P-S PNP
M18×50 TW18-05C 两线式 800HZ 5.0MM
M18×56 TW18-08C 8.0MM
M30×50 PM30-10N NPN 500HZ 10.0MM
PM30-10P PNP
M30×60 PM30-15N NPN 15.0MM
PM30-15P PNP
M30×35 PM30-10N-S NPN 500HZ 10.0MM
PM30-10P-S PNP
M30×45 PM30-15N-S NPN 15.0MM
PM30-15P-S PNP
M12×52 PM12-02S SCR 20HZ 2.5MM
M12×57 PM30-04S 4.0MM
M18×50 PM18-05S 20HZ 5.0MM
M18×56 PM18-08S 8.0MM
M30×50 PM30-10S 15HZ 10.0MM
M30×60 PM30-15S 15.0MM
KEYENCE基恩士光纤传感器特价销售FS-V21、FS-V22、FS-V21G、FS-V22G、FS-V21RP、FS-V22RP、FS-V21X、FS-V22X、FS-V21R、FS-V22R、FS-V20R、FS-V21RM、FS-H1D、FS-RS1、FS-V11、FS-V10、FS-V12、FS-V1(P)、EV-112M、EV-118M、PZ-101P、PZ2-61D、PZ-S10、A-2、AG-412、AG-413、FU-22X、FU-23X、FS-T1(P)、FS-T2(P)、FS-T1G、FS-M1(P)、FS-M2(P)、FS-M1H、FS-T0、FS-W0、FS-R0、FS-R3、FS-T20、FS2-60(P)、FS2-60G、FS-X18、FS-17(P)、FU-10、FU-11、FU-12、FU-13、FU-15、FU-16、FU-16Z、FU-18、FU-20、FU-21X、FU-24X、FU-25、FU-31、FU-32、FU-33、FU-34、FU-35FA、FU-35FZ、FS-L51、F-20、LV-11A、LV-20A、FU-35FG、FU-37、EV-130M、EV-112F、EV-118U、PZ2-42(P)、PZ2-61(P)、PZ2-62(P)、PZ2-41ECO、PZ-B761、A-4、AG-80、FU-38(V)、FU-38H、FU-38K、FU-38R、FU-38S/ FU-40 /FU-40G /FU-41IZ /FU-42 /FU-42T2、FU-43、FU-45X、FU-46、FU-48、FU-49X、FU-4F /FU-4F2、EV-130U、FU-50、FU-51TZ、FU-52TZ、FU-53TZ /FS2-62(P)、FS2-65(P)、FU-54TZ、FU-55、FU-56、FU-58、FU-59、FU-5F、FU-5F2、FU-61、FU-62Z、FU-63、FU-63T、FU-632、FU-65X、FU-66、FU-662、FU-67、FU-67G、FU-67V、FU-68、FU-6F、FU-69X、FU-71、FU-712、FU-73、FU-75F、EV-108M、PZ-61L(P)、PZ2-42D(P)、S-P11(12)、S-P01、PZ2-51(P)、EV-112U、EV-108U、FU-76F、FU-78、LV-H37、LV-H47、LV-H51、LV-H52、LV-H62、LV-H64、FU-79、FU-7F、FU-81C、FU-82C、FU-83C、FU-84C、FU-85、FU-852、FU-86、、FU-862、FU-87、FU-88、FU-91、FU-92、FU-93、FU-93Z、FU-94C、FU-95、FU-95H、FU-95Z、FU-95S、FU-96、F-1、F-2、F-4、F-5、F-2HA、LV-21A(P)、F-3HA、F-4HA、F-5HA、F-6HA、FS-L70、FS-L71、FS-L40、LV-H100、FS-L41、FS-L、PZ-B71150、LV-22A(P)、LV-21P.22P、LV-51M、LV51MP、LV-52、LV-52P、LV-H300、LV-H32、LV-H35、LV-H37 、LV-H47、LV-H51、LV-H52、LV-H62、LV-H64、PS-T1(P)、PS-T2(P)、PS-T0、PS-25、PS-26、PS2-61(P)、KEYENCE基恩士光纤传感器特价销售LV-H42、LV-H41、LV-H65、LV-H67、LV-L01、LV-L02、R-6、R-7、FU-77、FU-77G、075526055870、FU-77V、CZ-V1、CZ-10 /CZ-11、CZ-12、CZ-40、CZ-41、CZ-60、PS-X28、S-45、PS-46、PS-48、PS-52C、PS-55C /PS-55、ES-X38、PS-47、PS-49C、PS-49、PS-201、EH-11D、EH-11DS、EH-114、PS-52、PS-58、PS-47C、EH-308、ES-W1、ES-W2、EH-422、EH-430、EH-10B、PS-201C、PS-56、EH-308S、EH-402、EH-416、EH-290、EH-440、EH-605、EH-305S、EH-614A、EH-910、EZ-12M、EZ-18M、PS-205、PZ-41(P)、PZ-41L(P)、PZ-42(P)、EZ-8M、EH-302、EH-303A、PS-202、PS-206、PS-05、EH-305、EZ-30M、PZ-51(P)、PZ-61(P)、EZ-18T、EV-12M/ EV-18M、AG-410、PZ-42L(P)、PZ-51L(P)、EV-30M、EV-108M、PZ-61L(P)、PZ2-42D(P)、S-P11(12)、S-P01、PZ2-51(P)、EV-112U、EV-108U、EV-118F、EV-130F、PZ2-41(P)、PZ2-41D(P)、PZ2-42ECO、A-1、A-5、A-3、VP-91M、PZ2-S1ECO、EM-030(P)、EM-080(P)、EM-005(P) 、EM-010(P) 、ET-308、ET-110、ED-118M、PZ-S20、AG-411、PZ2-S1ECO、EM-038(P)、EM-014(P)、PZ-M51(W51P)、ET-305、PZ-M63、PZ-B31、PZ-B32、PZ-B41、PZ-B51、PZ-B701、PZ2-CTO5、EM-054(P)、PZ2-CHO5、PZ-M53、PZ-M61(M61P.M55)、PZ-V33、PZ-B01、PZ-B22、PZ-B61、ET-90、ED-118U、ED-130U 、TA-340、TH-305、TH-310、TH-315、TH-320、PZ-V71(V75)、PZ-B11、PZ-B21、VP-90、PZ-M71(M75)、ED-130M、TH-105、TH-107、PZ-V11(V11P.V15)、PZ-V31(V31P.V35)
- 电话:0755-81195571
- 传真:0755-27888846
- email:seekefotek@126.com
