- 型号:PNOZ
- 数量:10000
- 制造商:PILZ/皮尔磁
- 有效期:2020/11/1 0:00:00
尊敬的客户:
您好!我司(上海诚屿商贸有限公司)是德国皮尔磁(PILZ)公司一级代理,长期优价供应皮尔磁PNOZ X、PNOZ X7、PNOZ 16、PNOZ 11、PNOZ EX、PNOZ X3等系列安全继电器;PSEN me1S、PSEN me1M、PSEN me1.2S、PSEN me1、PSEN me3、PSEN me4、PSEN1.1p等安全开关;PSEN op4F、PSEN op2H、PSEN op4F-s、PSEN op4F-b、PSEN op4F-m、PSEN op4F-bm、PSEN op4F-sl等安全光栅;PSEN me1、PSEN cs等安全光栅; S1SW P、S1UM、S1IM、S3UM、S3UM/E、S1MS、PMD s10等电子监控继电器.
无论是从备货库存或价格都是相当有优势。特别是在物流,目前为止已经有2400多万的备货库存,随时都可以满足您的现货需求!如果您有这方面的工程项目、零售、备件都可以向我询价、比比价,相信我们的物流、价格和服务能给您带来更多的利润。真诚希望与您合作!
374280 PNOZ X Set plug in screw terminals P1+P2
374281 PNOZ X Set plug in screw terminals P3+P4
374282 PNOZ X Set plug in screw terminals P5+P5
374290 PNOZ X Set spring loaded terminals P1+P2
374291 PNOZ X Set spring loaded terminals P3+P4
374292 PNOZ X Set spring loaded terminals P5+P5
374400 H-PAD-15/15-SI800-Cable
374410 H-PAD-15/15-SI611D
374420 H-PAD-15/15-DZF03.1M-Cable
374430 H-PAD-25/15-SI611D/840-Cable
400100 PIT es1.11 operator red
400101 PIT es1.12 key-operator red
400102 PIT es1.13 operator illuminated red
400104 PIT es1.15 operator IP69K
400110 PIT es2.11 operator black
400111 PIT es2.12 key-operator black
400112 PIT es2.13 operator illuminated black
400200 PIT es box 72 x 72 x 61 mm
400300 PIT esb2.1 contact block 1 n/c
400301 PIT esb1.2 safe contact block 2 n/c
400302 PIT esb2.2 contact block 2 n/c
400303 PIT esb2.3 contact block 2 n/c 1n/o
400304 PIT esb1.3 safe contact block 2n/c 1n/o
400305 PIT esb1.1 safe contact block 1 n/c
400306 PIT esb2.4 contact block 1 n/c 1 n/o
400307 PIT esb1.4 safe contact block 1 n/c 1n/o
400310 PIT esc3 contact block 1 n/o
400315 PIT esc1 safe contact block 1 n/c
400320 PIT esc2 contact block 1 n/c
400330 PIT MHR3 holder for 3 contact blocks
400340 PIT MHR5 holder for 5 contact blocks
400410 PIT es Set1.1: es1.11 / 2 n/c
400411 PIT es Set1.2: es1.11 / 2 n/c 1n/o
400420 PIT es Set2.1: es1.11 / box / 2 n/c
400421 PIT es Set2.2: es1.11 / box / 2 n/c 1n/o
400500 PIT es3.11 operator red
400502 PIT es3.13 operator iluminated red
400504 PIT es3.15 operator IP69K
400510 PIT es Set3.1: es3.11 / 2 n/c
400511 PIT es Set3.2: es3.11 / 2 n/c 1 n/o
400520 PIT es Set4.1: es3.11 / box / 2 n/c
400521 PIT es Set4.2: es3.11 / box / 2 n/c 1 n/
400600 PIT es5.11 standard operator protect
400601 PIT es5.12 key operator protect
400602 PIT es5.13 illuminated protect
401100 PIT js2
401200 PIT js holder
502210 PSEN 2.1p-10/PSEN2.1-10/3mm 1unit
502211 PSEN 2.1p-11/PSEN2.1-10/LED/3mm/ 1unit
502220 PSEN 2.1p-20/PSEN 2.1-20 /8mm/1unit
502221 PSEN 2.1p-21/PSEN 2.1-20 /8mm/LED/1unit
502224 PSEN 2.1p-24/PSEN2.1-20/8mm/LED/EX/1unit
502226 PSEN 2.1a-20/PSEN 2.1-20/8mm /5m/1unit
502227 PSEN 2.1b-20/PSEN 2.1-20 /8mm/10m/1unit
502230 PSEN 2.1p-30/PSEN2.1-10/6mm 1unit
502231 PSEN 2.1p-31/PSEN2.1-10/LED/6mm 1unit
502234 PSEN 2.1p-34/PSEN 2.1-10/6mm/LED/ATEX
502250 PSEN 2.1b-26/PSEN2.1-20/8mm/10m/EX/1unit
503220 PSEN 2.2p-20/PSEN2.2-20/8mm 1unit
503221 PSEN 2.2p-21/PSEN2.2-20/LED/8mm 1unit
503224 PSEN 2.2p-24/PSEN2.2-20/LED/8mm/ATEX
504210 PSEN 1.1p-10/PSEN 1.1-10/3mm 1unit
504212 PSEN 1.1p-12/PSEN 1.1-10/3mm/ix1/ 1unit
504220 PSEN 1.1p-20/PSEN 1.1-20/8mm/ 1unit
504222 PSEN 1.1p-22/PSEN 1.1-20/8mm/ix1/ 1unit
504223 PSEN 1.1p-23/PSEN 1.1-20/8mm/ATEX/ 1unit
504225 PSEN 1.1p-25/PSEN 1.1-20/8mm/ATEX/ix1
504226 PSEN 1.1a-20/PSEN 1.1-20 /8mm/5m/1unit
504227 PSEN 1.1b-20/PSEN 1.1-20/8mm/10m/1unit
504228 PSEN 1.1a-22/PSEN 1.1-20 /8mm/5m/ix1/1un
504229 PSEN 1.1b-22/PSEN 1.1-20 /8mm/10m/ix1/1u
504250 PSEN 1.1b-23/PSEN1.1-20/8mm/10m/EX/1unit
504251 PSEN 1.1b-25/PSEN1.1-20/8mm/10m/EX/1unit
505220 PSEN 1.2p-20/PSEN 1.2-20/8mm/ 1unit
505222 PSEN 1.2p-22/PSEN 1.2-20/8mm/ix1/ 1unit
505223 PSEN 1.2p-23/PSEN 1.2-20/8mm/ATEX/ 1unit
505225 PSEN 1.2p-25/PSEN 1.2-20/8mm/ATEX/ix1
506220 PSEN ma1.3a-20/PSEN ma1.3-08/8mm/1unit
506221 PSEN ma1.3a-22/PSEN ma1.3-08/8mm/1unit
506222 PSEN ma1.3b-20/PSEN ma1.3-08/8mm/1unit
506223 PSEN ma1.3b-22/PSEN ma1.3-08/8mm/1unit
506224 PSEN ma1.3b-23/PSEN ma1.3-08/8mm/1unit
506225 PSEN ma1.3b-25/PSEN ma1.3-08/8mm/1unit
512110 PSEN 2.1-10 / 1 actuator / 1 unit
512120 PSEN 2.1-20/1actuator/1unit
513120 PSEN 2.2-20 / 1 actuator / 1 unit
514110 PSEN 1.1-10 / 1 actuators / 1 unit
514120 PSEN 1.1-20 / 1 actuators / 1 unit
515120 PSEN 1.2-20 / 1 actuators / 1 unit
516120 PSEN ma1.3-08/1actuator
522110 PSEN 2.1p-10 / 3mm / 1 switch / 1 unit
522111 PSEN 2.1p-11 / LED/ 3mm/1 switch/1unit
522120 PSEN 2.1p-20/8mm/1switch/1unit
522121 PSEN 2.1p-21/8mm/LED/1switch /1unit
522126 PSEN 2.1a-20/8mm/5m /1switch/1unit
522127 PSEN 2.1b-20/8mm/10m/ 1switch/1unit
522130 PSEN 2.1p-30 /6mm 1 switch / 1 unit
522131 PSEN 2.1p-31/LED/6mm/1 switch/ 1 unit
522140 PSEN 2.1p-40 1 switch 1 Unit
523120 PSEN 2.2p-20 /8mm 1 switch / 1 unit
523121 PSEN 2.2p-21/LED/8mm 1 switch / 1 unit
524110 PSEN 1.1p-10/3mm 1 switch 1unit
524112 PSEN 1.1p-12/3mm/ix1/ 1 switch / 1 unit
524120 PSEN 1.1p-20/8mm/ 1 switch 1unit
524126 PSEN 1.1a-20 /8mm/5m/1switch/1unit
524127 PSEN 1.1b-20 /8mm/10m/1switch/1unit
524128 PSEN 1.1a-22 /8mm/5m/ix1/1switch/1unit
524129 PSEN 1.1b-22/8mm /10m/ix1/1switch/1unit
525120 PSEN 1.2p-20/8mm/ 1 switch 1unit
525122 PSEN 1.2p-22/8mm/ix1/ 1 switch / 1 unit
526120 PSEN ma1.3a-20/1switch
526121 PSEN ma1.3a-22/1switch
526122 PSEN ma1.3b-20/1switch
526123 PSEN ma1.3b-22/1switch
532110 PSEN Winkel / bracket
533110 PSEN Kabel Winkel/cable angleplug 2m
533111 PSEN Kabel Gerade/cable straightplug 2m
533120 PSEN Kabel Winkel/cable angleplug 5m
533121 PSEN Kabel Gerade/cable straightplug 5m
533130 PSEN Kabel Winkel/cable angleplug 10m
533131 PSEN Kabel Gerade/cable straightplug 10m
533140 PSEN Kabel Winkel/cable angleplug 30m
533141 PSEN Kabel Gerade/cable straightplug 30m
534310 PSEN Distanzplatte / spacer 10 unit
534320 PSEN reverse spacer
535110 PSEN i1 Interface für 4 PSEN 2
535120 PSEN ix1 Interface für 4 PSEN 1
535130 PSEN im 1
540000 PSEN cs1.1p / PSEN cs1.1 1 Unit
540005 PSEN cs1.13p / PSEN cs1.1 / ATEX 1 Unit
540050 PSEN cs1.1p 1 switch 1 Unit
540080 PSEN cs1.1 1 actuator 1 Unit
540100 PSEN cs2.1p / PSEN cs2.1 1 Unit
540105 PSEN cs2.13p / PSEN cs2.1 / ATEX 1 Unit
540150 PSEN cs2.1p 1 switch 1 Unit
540180 PSEN cs2.1 1 actuator 1 Unit
540200 PSEN cs2.2p / PSEN cs2.1 1 Unit
540319 PSEN cable axial M12 8-pole 3m
540320 PSEN cable axial M12 8-pole 5m
540321 PSEN cable axial M12 8-pole 10m
540322 PSEN cable angle M12 8-pole 3m
540323 PSEN cable angle M12 8-pole 5m
540324 PSEN cable angle M12 8-pole 10m
540325 PSEN cable angle M12 8-pole 30m
540326 PSEN cable axial M12 8-pole 30m
570000 PSEN me1S / 1AS
570001 PSEN me1S / 1AR
570002 PSEN me1.1S / 1AS
570003 PSEN me1.1S / 1AR
570004 PSEN me1M / 1AS
570005 PSEN me1M / 1AR
570101 PSEN me1AS
570102 PSEN me1AR
570200 PSEN me2 / 2AS
570201 PSEN me2 / 2AR
570202 PSEN me2.1 / 2AS
570205 PSEN me2AS
570206 PSEN me2AR
570210 PSEN me3 / 2AS
570211 PSEN me3.01 / 2AS
570212 PSEN me3 / 2AR
570213 PSEN me3.02 / 2AS
570214 PSEN me3.02 / 2AR
570220 PSEN me3.1 / 2AS
570222 PSEN me3.1 / 2AR
570230 PSEN me3.2 / 2AS
570231 PSEN me3.21 / 2AS
570232 PSEN me3.2 / 2AR
570240 PSEN me4 / 4AS
570241 PSEN me4.01 / 4AS
570245 PSEN me4.1 / 4AS
570246 PSEN me4.11 / 4AS
570250 PSEN me4.21 / 4AS
570251 PSEN me4.2 / 4AS
570260 PSEN me4AS
630050 PSEN op4F-14-015
630051 PSEN op4F-14-030
630052 PSEN op4F-14-045
630053 PSEN op4F-14-060
630054 PSEN op4F-14-075
630055 PSEN op4F-14-090
630100 PSEN op2H-30-015
630101 PSEN op2H-30-030
630102 PSEN op2H-30-045
630103 PSEN op2H-30-060
630104 PSEN op2H-30-075
630105 PSEN op2H-30-090
630106 PSEN op2H-30-105
630107 PSEN op2H-30-120
630108 PSEN op2H-30-135
630109 PSEN op2H-30-150
630150 PSEN op4H-30-015
630151 PSEN op4H-30-030
630152 PSEN op4H-30-045
630153 PSEN op4H-30-060
630154 PSEN op4H-30-075
630155 PSEN op4H-30-090
630156 PSEN op4H-30-105
630157 PSEN op4H-30-120
630158 PSEN op4H-30-135
630159 PSEN op4H-30-150
630160 PSEN op4H-30-165
630200 PSEN op2B-2-050
630201 PSEN op2B-3-080
630202 PSEN op2B-4-090
630203 PSEN op2B-4-120
630250 PSEN op4B-2-050
630251 PSEN op4B-3-080
630252 PSEN op4B-4-090
630253 PSEN op4B-4-120
630280 PSEN op cable axial M12 5-p. shield.0,5m
630281 PSEN op cable axial M12 5-p. shield. 1m
630282 PSEN op cable M12 4-p. 0,75m L-Muting
630285 PSEN op connector M12 5-p.
630295 PSEN op cableset
630296 PSEN op cable axial M12 4-pole 30m
630297 PSEN op cable axial M12 5-pole 30m
630300 PSEN op cable axial M12 4-pole 3m
630301 PSEN op cable axial M12 4-pole 5m
630302 PSEN op cable axial M12 4-pole 10m
630303 PSEN op cable axial M12 4-p. shield. 3m
630304 PSEN op cable axial M12 4-p. shield. 5m
630305 PSEN op cable axial M12 4-p. shield. 10m
630306 PSEN op cable angle M12 4-p. shield. 3m
630307 PSEN op cable angle M12 4-p. shield. 5m
630308 PSEN op cable angle M12 4-p. shield. 10m
630309 PSEN op cable axial M12 4-p. shield. 30m
630310 PSEN op cable axial M12 5-pole 3m
630311 PSEN op cable axial M12 5-pole 5m
630312 PSEN op cable axial M12 5-pole 10m
630313 PSEN op cable axial M12 8-p. shield. 3m
630314 PSEN op cable axial M12 8-p. shield. 5m
630315 PSEN op cable axial M12 8-p. shield. 10m
630316 PSEN op cable angle M12 8-p. shield. 3m
630317 PSEN op cable angle M12 8-p. shield. 5m
630318 PSEN op cable angle M12 8-p. shield. 10m
630319 PSEN op cable angle M12 4-p. shield. 30m
630320 PSEN op1.3 Reflex pnp no/nc M12
630321 PSEN op1.1 Receiver pnp no/nc M12
630322 PSEN op1.2 Emitter M12
630323 PSEN op Reflector
630324 PSEN op Bracket
630325 PSEN op Bracket kit
630326 PSEN op Bracket kit adjustable
630327 PSEN op Bracket kit antivibration
630328 PSEN op cable axial M12 8-p. shield. 30m
630329 PSEN op cable angle M12 8-p. shield. 30m
630330 PSEN op Stand 1000mm
630331 PSEN op Stand 1200mm
630332 PSEN op Stand 1500mm
630333 PSEN op Stand 1800mm
630335 PSEN op Mirror 550mm
630336 PSEN op Mirror 700mm
630337 PSEN op Mirror 900mm
630338 PSEN op Mirror 1000mm
630339 PSEN op Mirror 1270mm
630340 PSEN op Laser pointer
630341 PSEN op cable angle M12 4-pole 3m
630342 PSEN op cable angle M12 4-pole 5m
630343 PSEN op cable angle M12 4-pole 10m
630344 PSEN op cable angle M12 4-pole 30m
630345 PSEN op Testpiece F 14m
630346 PSEN op Testpiece H 30mm
630347 PSEN op cable angle M12 5-pole 3m
630348 PSEN op cable angle M12 5-pole 5m
630349 PSEN op cable angle M12 5-pole 10m
630350 PSEN op cable angle M12 5-pole 30m
630351 PSEN opSB-4F-14-030
630352 PSEN opSB-4F-14-045
630353 PSEN opSB-4F-14-060
630354 PSEN opSB-4F-14-075
630355 PSEN opSB-4F-14-090
630360 PSEN op Mirror 1600mm
630361 PSEN op Mirror 1800mm
630370 PSEN iop 1
630380 PSEN op2S-1-1
630381 PSEN op4S-1-1
630382 PSEN op4S-1-2
630451 PSEN opSB-4H-30-030
630452 PSEN opSB-4H-30-045
630453 PSEN opSB-4H-30-060
630454 PSEN opSB-4H-30-075
630455 PSEN opSB-4H-30-090
630456 PSEN opSB-4H-30-105
630457 PSEN opSB-4H-30-120
630458 PSEN opSB-4H-30-135
630459 PSEN opSB-4H-30-150
630460 PSEN opSB-4H-30-165
630550 PSEN opSB-4B-2-050
630551 PSEN opSB-4B-3-080
630552 PSEN opSB-4B-4-090
630553 PSEN opSB-4B-4-120
630600 PSEN op4F-s-14-015
630601 PSEN op4F-s-14-030
630602 PSEN op4F-s-14-045
630603 PSEN op4F-s-14-060
630604 PSEN op4F-s-14-075
630605 PSEN op4F-s-14-090
630606 PSEN op4F-s-14-105
630607 PSEN op4F-s-14-120
630610 PSEN op4H-s-30-015
630611 PSEN op4H-s-30-030
630612 PSEN op4H-s-30-045
630613 PSEN op4H-s-30-060
630614 PSEN op4H-s-30-075
630615 PSEN op4H-s-30-090
630616 PSEN op4H-s-30-105
630617 PSEN op4H-s-30-120
630618 PSEN op4H-s-30-135
630619 PSEN op4H-s-30-150
630620 PSEN op4H-s-30-165
630621 PSEN op4F-b-14-015
630622 PSEN op4F-b-14-030
630623 PSEN op4F-b-14-045
630624 PSEN op4F-b-14-060
630625 PSEN op4F-b-14-075
630626 PSEN op4F-b-14-090
630627 PSEN op4F-b-14-105
630628 PSEN op4F-b-14-120
630630 PSEN op4H-b-30-015
630631 PSEN op4H-b-30-030
630632 PSEN op4H-b-30-045
630633 PSEN op4H-b-30-060
630634 PSEN op4H-b-30-075
630635 PSEN op4H-b-30-090
630636 PSEN op4H-b-30-105
630637 PSEN op4H-b-30-120
630638 PSEN op4H-b-30-135
630639 PSEN op4H-b-30-150
630640 PSEN op4H-b-30-165
630641 PSEN op4F-m-14-015
630642 PSEN op4F-m-14-030
630643 PSEN op4F-m-14-045
630644 PSEN op4F-m-14-060
630645 PSEN op4F-m-14-075
630646 PSEN op4F-m-14-090
630647 PSEN op4F-m-14-105
630648 PSEN op4F-m-14-120
630650 PSEN op4H-m-30-015
630651 PSEN op4H-m-30-030
630652 PSEN op4H-m-30-045
630653 PSEN op4H-m-30-060
630654 PSEN op4H-m-30-075
630655 PSEN op4H-m-30-090
630656 PSEN op4H-m-30-105
630657 PSEN op4H-m-30-120
630658 PSEN op4H-m-30-135
630659 PSEN op4H-m-30-150
630660 PSEN op4H-m-30-165
630661 PSEN op4F-bm-14-015
630662 PSEN op4F-bm-14-030
630663 PSEN op4F-bm-14-045
630664 PSEN op4F-bm-14-060
630665 PSEN op4F-bm-14-075
630666 PSEN op4F-bm-14-090
630667 PSEN op4F-bm-14-105
630668 PSEN op4F-bm-14-120
630670 PSEN op4H-bm-30-015
630671 PSEN op4H-bm-30-030
630672 PSEN op4H-bm-30-045
630673 PSEN op4H-bm-30-060
630674 PSEN op4H-bm-30-075
630675 PSEN op4H-bm-30-090
630676 PSEN op4H-bm-30-105
630677 PSEN op4H-bm-30-120
630678 PSEN op4H-bm-30-135
630679 PSEN op4H-bm-30-150
630680 PSEN op4H-bm-30-165
630681 PSEN op4F-sl-14-015
630682 PSEN op4F-sl-14-030
630683 PSEN op4F-sl-14-045
630684 PSEN op4F-sl-14-060
630685 PSEN op4F-sl-14-075
630686 PSEN op4F-sl-14-090
630687 PSEN op4F-sl-14-105
630688 PSEN op4F-sl-14-120
630690 PSEN op4H-sl-30-015
630691 PSEN op4H-sl-30-030
630692 PSEN op4H-sl-30-045
630693 PSEN op4H-sl-30-060
630694 PSEN op4H-sl-30-075
630695 PSEN op4H-sl-30-090
630696 PSEN op4H-sl-30-105
630697 PSEN op4H-sl-30-120
630698 PSEN op4H-sl-30-135
630699 PSEN op4H-sl-30-150
630700 PSEN op4H-sl-30-165
630701 PSEN op4B-T-2-050
630702 PSEN op4B-T-3-080
630703 PSEN op4B-L-2-050
630704 PSEN op4B-L-3-080
630705 PSEN op4B-S-2-050
630706 PSEN op4B-S-3-080
630707 PSEN op1.4 L-Reflex
630708 PSEN op1.5 L-Reflector
630709 PSEN op1.6 T-Reflex
630710 PSEN op1.7 T-Reflector
720300 PST 4 24 V DC 6S4?
720301 PST 4 24 V AC 6S4?
720303 PST 4 42 V AC 6S4?
720308 PST 4 110 V AC 6S4?
720309 PST 4 230 V AC 6S4?
720310 PST 4 240VAC 6S 4?
750002 PNOZ s Set screw terminals 12,5mm
750003 PNOZ s Set screw terminals 17,5mm
750004 PNOZ s Set screw terminals 22,5mm
750008 PNOZ s Set1 screw terminals 45mm
750012 PNOZ s Set2 screw terminals 45mm
750020 PNOZ s connector (10 pieces)
750101 PNOZ s1 24VDC 2 n/o
750102 PNOZ s2 24VDC 3 n/o 1 n/c
750103 PNOZ s3 24VDC 2 n/o
750104 PNOZ s4 24VDC 3 n/o 1 n/c
750105 PNOZ s5 24VDC 2 n/o 2 n/o t
750106 PNOZ s6 24VDC 3 n/o 1 n/c
750107 PNOZ s7 24VDC 4 n/o 1 n/c
750108 PNOZ s8 24VDC 2 n/o
750109 PNOZ s9 24VDC 3 n/o t 1 n/c t
750110 PNOZ s10 24VDC 4 n/o 1 n/c
750111 PNOZ s11 24VDC 8 n/o 1 n/c
750124 PNOZ s4.1 24VDC 3 n/o 1 n/c
750126 PNOZ s6.1 24VDC 3 n/o 1 n/c
750134 PNOZ s4 48-240VACDC 3 n/o 1 n/c
750135 PNOZ s5 48-240VACDC 2 n/o 2 n/o t
750136 PNOZ s6 48-240VACDC 3 n/o 1 n/c
750154 PNOZ s4.1 48-240VACDC 3 n/o 1 n/c
750167 PNOZ s7.1 24VDC 3 n/o cascade
750177 PNOZ s7.2 24VDC 4 n/o 1 n/c expand
751002 PNOZ s Set spring loaded terminals 12,5m
751003 PNOZ s Set spring loaded terminals 17,5m
751004 PNOZ s Set spring loaded terminals 22,5m
751008 PNOZ s Set1spring loaded terminals 45mm
751012 PNOZ s Set2 spring loaded terminals 45mm
751101 PNOZ s1 C 24VDC 2 n/o
751102 PNOZ s2 C 24VDC 3 n/o 1 n/c
751103 PNOZ s3 C 24VDC 2 n/o
751104 PNOZ s4 C 24VDC 3 n/o 1 n/c
751105 PNOZ s5 C 24VDC 2 n/o 2 n/o t
751106 PNOZ s6 C 24VDC 3 n/o 1 n/c
751107 PNOZ s7 C 24VDC 4 n/o 1 n/c
751108 PNOZ s8 C 24VDC 2 n/o
751109 PNOZ s9 C 24VDC 3 n/o t 1 n/c t
751110 PNOZ s10 C 24VDC 4 n/o 1 n/c
751111 PNOZ s11 C 24VDC 8 n/o 1 n/c
751124 PNOZ s4.1 C 24VDC 3 n/o 1 n/c
751126 PNOZ s6.1 C 24VDC 3 n/o 1 n/c
751134 PNOZ s4 C 48-240VACDC 3 n/o 1 n/c
751135 PNOZ s5 C 48-240VACDC 2 n/o 2 n/o t
751136 PNOZ s6 C 48-240VACDC 3 n/o 1 n/c
751154 PNOZ s4.1 C 48-240VACDC 3 n/o 1 n/c
751156 PNOZ s6.1 C 48-240VACDC 3 n/o 1 n/c
751167 PNOZ s7.1 C 24VDC 3 n/o cascade
751177 PNOZ s7.2 C 24VDC 4 n/o 1 n/c expand
751185 PNOZ s5 C 24VDC 2 n/o 2 n/o t coated
773050 PNOZmulti Systemhandbuch D
773100 PNOZ m1p base unit
773105 PNOZ m1p base unit coated version
773110 PNOZ m0p base unit not expandable
773120 PNOZ m2p base unit press function
773200 PNOZ pps1p 100-240VAC
773300 PNOZ p1p 24VDC 2so
773400 PNOZ mi1p 8 input
773405 PNOZ mi1p 8 inputs coated version
773410 PNOZ mi2p 8 standard input
773500 PNOZ mo1p 4 so
773505 PNOZ mo1p 4so coated version
773510 PNOZ mo3p 2so
773520 PNOZ mo2p 2n/o
773525 PNOZ mo2p 2n/o coated version
773536 PNOZ mo4p 4n/o
773537 PNOZ mo4p 4n/o coated version
773540 PNOZ ml1p safe link
773630 PNOZ po3.1p 8n/o
773631 PNOZ po3.2p 4n/o
773632 PNOZ po3.3p 3n/o
773634 PNOZ po3p 3n/o 1n/c
773635 PNOZ po4p 4n/o
773700 PNOZ mc1p
773705 PNOZ mc1p coated version
773720 PNOZ mc0p Powersupply
773721 PNOZ mc3p Profibus
773722 PNOZ mc4p DeviceNet
773723 PNOZ mc5p INTERBUS
773724 PNOZ mc6p CANopen
773725 PNOZ mc7p CC-Link coated version
773726 PNOZ mc7p CC-Link
773727 PNOZ mc6p CANopen coated version
773728 PNOZ mc5.1p Interbus LWL / Fiberoptic
773729 PNOZ mc4p DeviceNet coated version
773730 PNOZ mc8p Ethernet IP / Modbus TCP
773731 PNOZ mc9p Profinet IO
773800 PNOZ ms1p standstill / speed monitor
773810 PNOZ ms2p standstill / speed monitor
773812 PNOZ ma1p 2 Analog Input
773839 PNOZ msi1Bp Adapter Si/Ha 25/25 5m
773840 PNOZ msi1Ap Adapter Si/Ha 25/25 2,5m
773841 PNOZ msi1Bp Adapter Si/Ha 25/25 2,5m
773842 PNOZ msi3Ap Adapter Si/Ha 15/15 2,5m
773843 PNOZ msi3Bp Adapter Si/Ha 15/15 2,5m
773850 PNOZ msi1p Adapter Si/Ha 25/25 2,5m
773844 PNOZ msi1AP Adapter Si/Ha 25/25 5m
773854 PNOZ msi10p adapter cable 2,5m
773855 PNOZ msi11p adapter cable 1,5m
773856 PNOZ msi 9p adapter cable 5m
773857 PNOZ msi5p Adapter Bos/Rex 15/15 2,5m
773858 PNOZ msi5p Adapter Bosc/Rex 15/15 1,5m
773859 PNOZ msi6p Adapter Elau 9/9 7,5m
773860 PNOZ msi6p Adapter Elau 9/9 2,5m
773861 PNOZ msi6p Adapter Elau 9/9 1,5m
773862 PNOZ msi8p Adapter Lenze 9/9 2,5m
773863 PNOZ msi8p Adapter Lenze 9/9 1,5m
773864 PNOZ msi7p Adapter SEW 15/15 2,5m
773865 PNOZ msi7p Adapter SEW 15/15 1,5m
773867 PNOZ msi16p ADAPTER Baumuell 15/15 2,5m
773868 PNOZ msi12p Rockwell 15/15 2,5m
773869 PNOZ msi13p Fanuc 20/20 2,5m
773870 PNOZ msi S09
773871 PNOZ msi S15
773872 PNOZ msi S25
773874 PNOZ msi15p Adapter Tendo 15/15 2,5m
773875 PNOZ msi17p Bos/Rex 15/15 4,0m
773878 PNOZ msi14p Leroy 15/15 2,5m
773880 PNOZ msi b1 Box 15p
773881 PNOZ msi b0 cable 15/RJ45
773882 PNOZ msi b1 Box 9p
773883 PNOZ msi b1 Box 25p
773884 PNOZ msi b0 cable 25/RJ45
773890 PNOZ mli1p 5m screw
773891 PNOZ mli1p 10m screw
773892 PNOZ mli1p 50m screw
773893 PNOZ mli1p 5m spring
773894 PNOZ mli1p 10m spring
773895 PNOZ mli1p 50m spring
773900 PNOZ pe1p
773950 PNOZ p1vp 30s
773951 PNOZ p1vp 300s
774000 PNOZ 10 24VAC 6n/o 4n/c
774001 PNOZ 10 42VAC 6n/o 4n/c
774002 PNOZ 10 48VAC 6n/o 4n/c
774003 PNOZ 10 110-120VAC 6n/o 4n/c
774006 PNOZ 10 230-240VAC 6n/o 4n/c
774009 PNOZ 10 24VDC 6n/o 4n/c
774012 PNOZ 2VJ 24VDC 3n/o 1n/c 2n/o t
774013 PNOZ 2VQ 24VDC 3n/o 1n/c 2n/o t
774015 PZW 30/110-120VAC 1n/o 2n/c
774017 PZW 30/230VAC 1n/o 2n/c
774019 PZW 30/24VDC 1n/o 2n/c
774020 PZA 300/24VAC 1n/o 2n/c
774021 PZA 300/42VAC 1n/o 2n/c
774023 PZA 300/110-120VAC 1n/o 2n/c
774026 PZA 300/230VAC 1n/o 2n/c
774028 PZA 600/24VDC 1n/o 2n/c
774029 PZA 300/24VDC 1n/o 2n/c
774030 PZA 30/24VDC 1n/o 2n/c
774031 PZA 30/24VAC 1n/o 2n/c
774035 PZA 30/110-120VAC 1n/o 2n/c
774038 PZA 3/230VAC 1n/o 2n/c
774040 PZA 30/230VAC 1n/o 2 n/c
774041 PZA 3/24VDC 1n/o 2n/c
774042 PZW 3/24VDC 1n/o 2n/c
774044 PZW 3/110-120VAC 1n/o 2n/c
774048 PZW 3/230VAC 1n/o 2n/c
774049 PNOZ X7 48VAC 2n/o
774050 PNOZ 15 24VDC 3n/o 1n/o 1n/c
774051 PNOZ X7.1 24VAC/DC 1n/o 1n/c
774053 PNOZ X7 110VAC 2n/o
774054 PNOZ X7 115VAC 2n/o
774055 PNOZ X7 120VAC 2n/o
774056 PNOZ X7 230VAC 2n/o
774057 PNOZ X7 240VAC 2n/o
774058 PNOZ X7 42VAC 2n/o
774059 PNOZ X7 24VACDC 2n/o
774060 PNOZ 16 24VAC 24VDC 2n/o
774061 PNOZ 16 42VAC 24VDC 2n/o
774062 PNOZ 16 48VAC 24VDC 2n/o
774063 PNOZ 16 110VAC 24VDC 2n/o
774064 PNOZ 16 115VAC 24VDC 2n/o
774065 PNOZ 16 120VAC 24VDC 2n/o
774066 PNOZ 16 230VAC 24VDC 2n/o
774067 PNOZ 16 240VAC 24VDC 2n/o
774070 PNOZ 16S 24VAC 24VDC 2n/o 2so
774071 PNOZ 16S 42VAC 24VDC 2n/o 2so
774072 PNOZ 16S 48VAC 24VDC 2n/o 2so
774073 PNOZ 16S 110VAC 24VDC 2n/o 2so
774074 PNOZ 16S 115VAC 24VDC 2n/o 2so
774075 PNOZ 16S 120VAC 24VDC 2n/o 2so
774076 PNOZ 16S 230VAC 24VDC 2n/o 2so
774077 PNOZ 16S 240VAC 24VDC 2n/o 2so
774080 PNOZ 11 24VAC 24VDC 7n/o 1n/c
774081 PNOZ 11 42VAC 24VDC 7n/o 1n/c
774082 PNOZ 11 48VAC 24VDC 7n/o 1n/c
774085 PNOZ 11 110-120VAC 24VDC 7n/o 1n/c
774086 PNOZ 11 230-240VAC 24VDC 7n/o 1n/c
774090 SCHUTZKAPPE P-93 (VE 20 St.)
774100 PNOZ EX 230VAC 3n/o 1n/c
774104 PNOZ EX 115VAC 3n/o 1n/c
774105 PNOZ EX 120VAC 3n/o 1n/c
774106 PNOZ EX 115VAC 3n/o 1n/c FM/USA
774107 PNOZ EX 120VAC 3n/o 1n/c FM/USA
774108 PNOZ EX 230VAC 3n/o 1n/c FM/USA
774120 PNOZ K2.1 24VDC 2n/o Sonderger?t
774125 P2HZ K3 24VDC 2n/o 1n/c Ger?t o. CE
774130 PNOZ e1p 24VDC 2so
774131 PNOZ e1vp 10/24VDC 1so 1so t
774132 PNOZ e1vp 300/24VDC 1so 1so t
774133 PNOZ e1.1p 24VDC 2so
774135 PNOZ e2.2p 24VDC 2so
774136 PNOZ e2.1p 24VDC 2so
774137 PNOZ e3vp 10/24VDC 1so 1so t
774138 PNOZ e3vp 300/24VDC 1so 1so t
774139 PNOZ e3.1p 24VDC 2so
774140 PZE 9 24VAC 8n/o 1n/c
774141 PZE 9 42VAC 8n/o 1n/c
774142 PZE 9 48VAC 8n/o 1n/c
774143 PZE 9 110-120VAC 8n/o 1n/c
774144 PZE 9 120 Vac 8n/o 1n/c
774148 PZE 9 230-240VAC 8n/o 1n/c
774150 PZE 9 24VDC 8n/o 1n/c
774180 PNOZ e4.1p 24VDC 2so
774181 PNOZ e4vp 10/24VDC 1so 1so t
774190 PNOZ e5.11p 24VDC 2so
774191 PNOZ e5.13p 24VDC 2so
774192 PNOZ e6.1p 24VDC 4n/o 2so
774193 PNOZ e6vp 24VDC 4n/o 1so 1so t
774195 Terminal block filter 1
774196 Terminal block filter 2
774300 PNOZ X1 24VAC/DC 3n/o 1n/c
774303 PNOZ X2 24VAC/DC 2n/o
774304 PNOZ X2C 24VAC/DC 2n/o
774305 PNOZ X2.1C 24VAC/DC 2n/o
774306 PNOZ X2.1 24VAC/DC 2n/o
774309 PNOZ X3.2 230VAC 24VDC 3n/o 1n/c 1so
774310 PNOZ X3 24VAC 24VDC 3n/o 1n/c 1so
774311 PNOZ X3 42VAC 24VDC 3n/o 1n/c 1so
774312 PNOZ X3 48VAC 24VDC 3n/o 1n/c 1so
774314 PNOZ X3 110VAC 24VDC 3n/o 1n/c 1so
774315 PNOZ X3 115VAC 24VDC 3n/o 1n/c 1so
774316 PNOZ X3 120VAC 24VDC 3n/o 1n/c 1so
774318 PNOZ X3 230VAC 24VDC 3n/o 1n/c 1so
774319 PNOZ X3 240VAC 24VDC 3n/o 1n/c 1so
774321 PNOZ X3.1 230VAC 24VDC 3n/o 1n/c 1so
774322 PNOZ X3.1 240VAC 24VDC 3n/o 1n/c 1so
774323 PNOZ X5J 24VDC 2n/o
774324 PNOZ X5.1 24VDC 2n/o
774325 PNOZ X5 24VACDC 2n/o
774326 PNOZ X5 12VDC 2n/o
774327 PNOZ X5 12VDC 2n/o coated version
774330 P2HZ X1 24VAC 3n/o 1n/c
774331 P2HZ X1 42VAC 3n/o 1n/c
774332 P2HZ X1 48VAC 3n/o 1n/c
774340 P2HZ X1 24VDC 3n/o 1n/c
774341 P2HZ X1 26VDC 3n/o 1n/c
774345 P2HZ X2 24VAC 2n/o
774350 P2HZ X3 24VDC 2n/o 1n/c
774360 P1HZ X1 24VDC 2n/o
774400 PDZ 24VDC 2n/o 2n/c
774401 PAD/BO 512/6/5VDC
774402 PAD/SI 800/512I/5VDC
774403 PAD/SI 800/1024I/5VDC
774404 PAD/SI 800/2048I/5VDC
774405 PAD/SI 800/4096I/5VDC
774406 PAD/SI 840/512I/5VDC
774407 PAD/SI 840/1024I/5VDC
774408 PAD/SI 840/2048I/5VDC
774409 PAD/SI 840/4096I/5VDC
774410 PAD/SI 800/32I/5VDC
774411 PAD/SI 840/256I/5VDC
774412 PAD/SI 840/128I/5VDC
774413 PAD/SI 840/64I/5VDC
774414 PAD/SI 840/32I/5VDC
774415 PAD/SI 840/16I/5VDC
774420 PDZK WDP3-01 1000/20 24 Vdc
774434 P2HZ X1 110VAC 3n/o 1n/c
774435 P2HZ X1 115VAC 3n/o 1n/c
774436 P2HZ X1 120VAC 3n/o 1n/c
774438 P2HZ X1 230VAC 3n/o 1n/c
774439 P2HZ X1 240VAC 3n/o 1n/c
774500 PNOZ XV2 30/24VDC 2n/o 2n/o t
774502 PNOZ XV2 3/24VDC 2n/o 2n/o t
774504 PNOZ XV2 0.5/24VDC 2n/o 2n/o fix
774505 PNOZ XV2 3/24VDC 2n/o 2n/o fix
774506 PNOZ XV2 10/24VDC 2n/o 2n/o fix
774508 PNOZ XV2 300/24VDC 2n/o 2n/o t
774510 PNOZ XV2.1 30/24VAC 24VDC 2n/o 2n/o t
774515 PNOZ XV2.1 30/120VAC 24VDC 2n/o 2n/o t
774516 PNOZ XV2.1 30/230VAC 24VDC 2n/o 2n/o t
774517 PNOZ X2.4V 1/24VDC 4n/o 1so fix
774520 PNOZ XV2.1 3/24VAC 24VDC 2n/o 2n/o t
774524 PNOZ XV2.1 3/115VAC 24VDC 2n/o 2n/o t
774525 PNOZ XV2.1 3/120VAC 24VDC 2n/o 2n/o t
774526 PNOZ XV2.1 3/230VAC 24VDC 2n/o 2n/o t
774530 PNOZ XV3.1 30/24VDC 3n/o 1n/c 2n/o t
774532 PNOZ XV3.1 3/24VDC 3n/o 1n/c 2n/o t
774534 PNOZ XV3.1 0.5/24 Vdc 3n/o 1n/c 2n/o fix
774536 PNOZ XV2.1 0.5/230 Vac 24 Vdc 2n/o 2n/o f
774538 PNOZ XV3.1 300/24VDC 3n/o 1n/c 2n/o t
774540 PNOZ XV3 30/24VDC 3n/o 2n/o t
774541 PNOZ XV3 300/24VAC 3n/o 2n/o t
774542 PNOZ XV3 3/24VDC 3n/o 2n/o t
774544 PNOZ XV3 0.5/24VDC 3n/o 2n/o t fix
774545 PNOZ XV3 3/24VDC 3n/o 2n/o t fix
774546 PNOZ XV2.1 3/230 Vac/24 Vdc 2n/o 2n/o fix
774547 PNOZ XV3 10/24VDC 3n/o 2n/o t fix
774548 PNOZ XV3 300/24VDC 3n/o 2n/o t
774549 PNOZ X13 24VDC 5n/o 1n/c
774550 PNOZ XV2.1 30/24-240VACDC 2n/o 2n/o t
774552 PNOZ XV2.1 3/24-240VACDC 2n/o 2n/o t
774554 PNOZ XV2.1 0.5/24-240 VacDC 2n/o 2n/o fix
774558 PNOZ XV2.1 300/24-240VACDC 2n/o 2n/o t
774560 PNOZ XHCV 0,7/24VDC 2n/o fix
774573 MOD PS 85-265 Vac
774578 PPS 100-240VAC / 24VDC
774580 PZE X4V 0,5/24VDC 4n/o fix
774581 PZE X4V 1/24VDC 4n/o fix
774582 PZE X4V 2/24VDC 4n/o fix
774583 PZE X4V 3/24VDC 4n/o fix
774584 PZE X4V8 24VDC 4n/o
774585 PZE X4 24VDC 4n/o
774586 PZE X4V 0,7/24VDC 4n/o fix
774590 PZE X5V 3/48VDC 5n/o fix
774592 PZE X5V 1.5/24VDC 5n/o fix
774593 PZE X5V 3/24VDC 5n/o fix
774595 PZE X5 24VDC 5n/o
774601 PNOZ X9 42VAC 24VDC 7n/o 2n/c 2so
774605 PNOZ X9 100-120VAC 24VDC 7n/o 2n/c 2so
774606 PNOZ X9 200-230VAC 24VDC 7n/o 2n/c 2so
774607 PNOZ X2.2 24VAC/DC 2n/o
774608 PNOZ X9 200VAC 24VDC -774606
774609 PNOZ X9 24VAC 24VDC 7n/o 2 n/c 2so
774610 PNOZ XV3.1 30/24-240VACDC 3no 1nc 2no t
774612 PNOZ XV3.1 3/24-240VACDC 3no 1nc 2no t
774618 PNOZ XV3.1 300/24-240VACDC 3no 1nc 2no t
774638 END-XM
774639 KOP-XE
774640 KOP-XE coated
774662 PCANdn 24VDC
774665 CAN-CONNECT
774666 PCANop - HB
774667 PCANdn - HB
774700 PNOZ X10 24VAC 6n/o 4n/c 3LED
774701 PNOZ X10 42VAC 6n/o 4n/c 3LED
774703 PNOZ X10 110-120VAC 6n/o 4n/c 3LED
774706 PNOZ X10 230-240VAC 6n/o 4n/c 3LED
774709 PNOZ X10 24VDC 6n/o 4n/c 3LED
774721 PNOZ X6 42VAC 3n/o
774725 PNOZ X6 110-120VAC 3n/o
774726 PNOZ X6 230-240VAC 3n/o
774729 PNOZ X6 24VAC 24VDC 3n/o
774730 PNOZ X4 24VDC 3n/o 1n/c
774731 PNOZ X4 24VAC 3n/o 1n/c
774732 PNOZ X4 24 Vdc 3n/o 1n/c white box
774734 PNOZ X4 110VAC 3n/o 1n/c
774735 PNOZ X4 115VAC 3n/o 1n/c
774736 PNOZ X4 120VAC 3n/o 1n/c
774738 PNOZ X4 230VAC 3n/o 1n/c
774739 PNOZ X4 240VAC 3n/o 1n/c
774740 PNOZ X10.1 24 VAC 6n/o 4n/c 6LED
774741 PNOZ X10.1 42 VAC 6n/o 4n/c 6LED
774745 PNOZ X10.1 110-120VAC 6n/o 4n/c 6LED
774746 PNOZ X10.1 230-240VAC 6n/o 4n/c 6LED
774749 PNOZ X10.1 24VDC 6n/o 4n/c 6LED
774789 PNOZ V 3s 24VDC 3n/o 1n/c 1n/o (t)
774790 PNOZ V 30s 24VDC 3n/o 1n/c 1n/o (t)
774791 PNOZ V 300s 24VDC 3n/o 1n/c 1n/o (t)
775505 PU3Z 120-240VAC 3n/o 1n/c 6so
775510 PU3Z 24VDC 3n/o 1n/c 6so
775600 PNOZ 1 24VAC 3n/o 1n/c
775620 PNOZ 1 48VAC 3n/o 1n/c
775630 PNOZ 1 110-120VAC 3n/o 1n/c
775650 PNOZ 1 230-240VAC 3n/o 1n/c
775695 PNOZ 1 24VDC 3n/o 1n/c
775730 BUCH MASCHINENSICHERHEIT
775735 Buch Maschinensicherheit, spanisch
777053 PNOZ X7P 110-120VAC 2n/o
777056 PNOZ X7P 230-240VAC 2n/o
777059 PNOZ X7P 24VAC/DC 2n/o
777070 PNOZ 16SP 24VAC 24VDC 2n/o
777071 PNOZ 16SP 42VAC 24VDC 2n/o
777072 PNOZ 16SP 48VAC 24VDC 2n/o
777073 PNOZ 16SP 110VAC 24VDC 2n/o
777074 PNOZ 16SP 115VAC 24VDC 2n/o
777075 PNOZ 16SP 120VAC 24VDC 2n/o
777076 PNOZ 16SP 230VAC 24VDC 2n/o
777077 PNOZ 16SP 240VAC 24VDC 2n/o
777080 PNOZ X11P 24VAC 24VDC 7n/o 1n/c 2so
777083 PNOZ X11P 110-120VAC 24VDC 7n/o 1n/c 2so
777086 PNOZ X11P 230-240VAC 24VDC 7n/o 1n/c 2so
777100 PNOZ X1P 24VDC 3n/o 1n/c
777140 PZE 9P 24VACDC 8n/o 1n/c
777148 PZE 9P 24VACDC 100-240VACDC 8n/o 1n/c
777150 PZE X5P 24VDC 5n/o 2so
777300 PNOZ X2.9P 24VDC 3n/o 1n/c
777301 PNOZ X2.8P 24VACDC 3n/o 1n/c
777302 PNOZ X2.8P 24-240VAC/DC 3n/o 1n/c
777303 PNOZ X2P 24VACDC 2n/o
777304 PNOZ X2.3P 24VACDC 3n/o
777305 PNOZ X2.7P 24VACDC 3n/o 1n/c
777306 PNOZ X2.7P 24-240VAC/DC 3n/o 1n/c
777307 PNOZ X2P 48-240VACDC 2n/o
777308 PNOZ X2.5P 24VDC 2n/o 1so
777310 PNOZ X3P 24VDC 24VAC 3n/o 1n/c 1so
777313 PNOZ X3P 24-240VACDC 3n/o 1n/c 1so
777314 PNOZ X3.10P 24VACDC 3n/o 1n/c 1so
777330 P2HZ X1P 24VAC 3n/o 1n/c 2so
777331 P2HZ X1P 42VAC 3n/o 1n/c 2so
777332 P2HZ X1P 48VAC 3n/o 1n/c 2so
777340 P2HZ X1P 24VDC 3n/o 1n/c 2so
777341 P2HZ X1.10P 24VDC 3n/o 1n/c 2so
777354 P2HZ X4P 24VAC 3n/o 1n/c
777355 P2HZ X4P 24VDC 3n/o 1n/c
777434 P2HZ X1P 110VAC 3n/o 1n/c 2so
777435 P2HZ X1P 115VAC 3n/o 1n/c 2so
777436 P2HZ X1P 120VAC 3n/o 1n/c 2so
777438 P2HZ X1P 230VAC 3n/o 1n/c 2so
777439 P2HZ X1P 240VAC 3n/o 1n/c 2so
777500 PNOZ XV2P 30/24VDC 2n/o 2n/o t
777502 PNOZ XV2P 3/24VDC 2n/o 2n/o t
777503 PNOZ XV2P 1/24VDC 2n/o 2n/o fix
777504 PNOZ XV2P 0.5/24VDC 2n/o 2n/o fix
777510 PNOZ XV3P 30/24 VDC 3n/o 2n/o t
777511 PNOZ XV3.3P 30/24VDC 3n/o 2n/o t
777512 PNOZ XV3P 3/24 VDC 3n/o 2n/o t
777514 PNOZ XV3P 0.5/24VDC 3n/o 2n/o t fix
777515 PNOZ XV3P 3/24 Vdc 3n/o 2n/o t fix
777517 PNOZ XV3P 10/24 Vdc 3n/o 2n/o t fix
777518 PNOZ XV3P 300/24VDC 3n/o 2n/o t
777520 PNOZ XV3.1P 30/24VDC 3n/o 1n/c 2n/o t
777522 PNOZ XV3.1P 3/24VDC 3n/o 1n/c 2n/o t
777525 PNOZ XV3.1P 3/24VDC 3n/o 1n/c 2n/o t fix
777530 PNOZ XV3.1P 30/24-240VACDC 3no 1nc 2no t
777532 PNOZ XV3.1P 3/24-240VACDC 3no 1nc 2no t
777538 PNOZ XV3.1P 300/24-240VACDC 3no 1nc 2no
777540 PNOZ XV2.1P 30/24-240VACDC 2n/o 2n/o t
777542 PNOZ XV2.1P 3/24-240VACDC 2n/o 2n/o t
777544 PNOZ XV2.1P 0.5/24-240 VacDC 2n/o 2n/o fi
777545 PNOZ XV2.1P 3/24-240 VacDC 2n/o 2n/o fix
777547 PNOZ XV2.1P 10/24-240 VacDC 2n/o 2n/o fix
777548 PNOZ XV2.1P 300/24-240VACDC 2n/o 2n/o t
777580 PZE X4VP 0,5/24VDC 4n/o fix
777581 PZE X4VP 1/24VDC 4n/o fix
777582 PZE X4VP 2/24VDC 4n/o fix
777583 PZE X4VP 3/24VDC 4n/o fix
777584 PZE X4VP8 24VDC 4n/o
777585 PZE X4P 24VDC 4n/o
777586 PZE X4VP4 24VDC 4n/o
777587 PZE X4.1P 24VDC 4n/o
777588 PZE X4.1P 24-240VAC/DC 4n/o
777600 PNOZ X2.1VP 0.75/24VDC 1so 2n/o fix
777601 PNOZ XV1P 3/24VDC 2n/o 1n/o t
777602 PNOZ XV1P 30/24VDC 2n/o 1n/o t
777606 PNOZ X9P 24VDC 100-240VACDC 7no 2nc 2so
777607 PNOZ X9P 12VDC 7n/o 2n/c 2so
777609 PNOZ X9P 24VDC 7n/o 2n/c 2so
777750 PNOZ X10.11P 24VDC 6n/o 4n/c 6LED
777760 PNOZ X8P 24 VDC 3n/o 2n/c 2so
777764 PNOZ X8P 110VAC 3n/o 2n/c 2so
777765 PNOZ X8P 115VAC 3n/o 2n/c 2so
777766 PNOZ X8P 120VAC 3n/o 2n/c 2so
777768 PNOZ X8P 230VAC 3n/o 2n/c 2so
777770 PNOZ X8P 24VAC 3n/o 2n/c 2so
777949 PSWZ X1P 0,5V /24-240VACDC 2n/o 1n/c 2so
777950 PSWZ X1P 3V /24-240VACDC 2n/o 1n/c 2so
777951 PSWZ X1P 0,0075-0,5V/24-240VACDC
778010 PMUT X1P 24VDC 3n/o 1n/c 5so
779000 PNOZmulti Tool-Kit
779110 PNOZmulti Bus-Terminator
779112 PNOZmulti Bus-Terminator coated
779120 PNOZpower Bus-Terminator
779125 PNOZ pe2p Bus-Interface
779200 PNOZmulti Chipcard Set 10 pieces 8kB
779201 PNOZmulti Chipcard 1 piece 8kB
779211 PNOZmulti Chipcard 1 piece 32kB
779212 PNOZmulti Chipcard Set 10 pieces 32kB
779230 Chip Card Reader
779240 PNOZmulti Chipcard Holder (Sparepart)
779250 PNOZmulti Seal 10 pieces
783100 Set spring terminals PNOZ m0p/m1p/m2p
783400 Set spring term mi1p/mi2p/mo1p/mo3p/ml1p
783520 Set spring terminals PNOZ mo2p
783536 Set spring terminals PNOZ mo4p/mo5p
783537 10 Set spring terminals PNOZ mo4p/mo5p
783700 Set spring terminals PNOZ mc1p/ma1p
783800 Set spring terminals PNOZms1p/ms2p
784130 PNOZ e1p C 24VDC 2so
784131 PNOZ e1vp C 10/24VDC 1so 1so t
784132 PNOZ e1vp C 300/24VDC 1so 1so t
784133 PNOZ e1.1p C 24VDC 2so
784135 PNOZ e2.2p C 24VDC 2so
784136 PNOZ e2.1p C 24VDC 2so
784137 PNOZ e3vp C 10/24VDC 1so 1so t
784138 PNOZ e3vp C 300/24VDC 1so 1so t
784139 PNOZ e3.1p C 24VDC 2so
784180 PNOZ e4.1p C 24VDC 2so
784181 PNOZ e4vp C 10/24VDC 1so 1so t
784190 PNOZ e5.11p C 24VDC 2so
784191 PNOZ e5.13p C 24VDC 2so
784192 PNOZ e6.1p C 24VDC 4n/o 2so
784193 PNOZ e6vp C 24VDC 4n/o 1so 1so t
787053 PNOZ X7P C 110-120VAC 2n/o
787056 PNOZ X7P C 230-240VAC 2n/o
787059 PNOZ X7P C 24VAC/DC 2n/o
787070 PNOZ 16SP C 24VAC 24VDC 2n/o
787071 PNOZ 16SP C 42VAC 24VDC 2n/o
787072 PNOZ 16SP C 48VAC 24VDC 2n/o
787073 PNOZ 16SP C 110VAC 24VDC 2n/o
787074 PNOZ 16SP C 115VAC 24VDC 2n/o
787075 PNOZ 16SP C 120VAC 24VDC 2n/o
787076 PNOZ 16SP C 230VAC 24VDC 2n/o
787077 PNOZ 16SP C 240VAC 24VDC 2n/o
787080 PNOZ X11P C 24VAC 24VDC 7n/o 1n/c 2so
787083 PNOZ X11P C 110-120VAC 7n/o 1n/c 2so
787086 PNOZ X11P C 230-240VAC 7n/o 1n/c 2so
787100 PNOZ X1P C 24VDC 3n/o 1n/c
787140 PZE 9P C 24VACDC 8n/o 1n/c
787148 PZE 9P C 24VACDC 100-240VACDC 8n/o 1n/c
787150 PZE X5P C 24VDC 5n/o 2so
787250 DUMMY MODULE PNOZ DM X2.7P/X2.8P C
787251 DUMMY MODULE PZE DM 9P C
787252 DUMMY MODULE PZE DM X4P C
787253 DUMMY MODULE PNOZ DM XV3.1P C
787254 DUMMY MODULE PZE DM X4VP C
787300 PNOZ X2.9P C 24VDC 3n/o 1n/c
787301 PNOZ X2.8P C 24VACDC 3n/o 1n/c
787302 PNOZ X2.8P C 24-240VAC/DC 3n/o 1n/c
787303 PNOZ X2P C 24VACDC 2n/o
787304 PNOZ X2.3P C 24VACDC 3n/o
787305 PNOZ X2.7P C 24VACDC 3n/o 1n/c
787306 PNOZ X2.7P C 24-240VAC/DC 3n/o 1n/c
787307 PNOZ X2P C 48-240VACDC 2n/o
787308 PNOZ X2.5P C 24VDC 2n/o 1so
787310 PNOZ X3P C 24VDC 24VAC 3n/o 1n/c 1so
787313 PNOZ X3P C 24-240VACDC 3n/o 1n/c 1so
787314 PNOZ X3.10P C 24VACDC 3n/o 1n/c 1so
787330 P2HZ X1P C 24VAC 3n/o 1n/c 2so
787331 P2HZ X1P C 42VAC 3n/o 1n/c 2so
787332 P2HZ X1P C 48VAC 3n/o 1n/c 2so
787340 P2HZ X1P C 24VDC 3n/o 1n/c 2so
787341 P2HZ X1.10P C 24VDC 3n/o 1n/c 2so
787354 P2HZ X4P C 24VAC 3n/o 1n/c
787355 P2HZ X4P C 24VDC 3n/o 1n/c
787434 P2HZ X1P C 110VAC 3n/o 1n/c 2so
787435 P2HZ X1P C 115VAC 3n/o 1n/c 2so
787436 P2HZ X1P C 120VAC 3n/o 1n/c 2so
787438 P2HZ X1P C 230VAC 3n/o 1n/c 2so
787439 P2HZ X1P C 240VAC 3n/o 1n/c 2so
787500 PNOZ XV2P C 30/24VDC 2n/o 2n/o t
787502 PNOZ XV2P C 3/24VDC 2n/o 2n/o t
787503 PNOZ XV2P C 1/24VDC 2n/o 2n/o fix
787504 PNOZ XV2P C 0.5/24VDC 2n/o 2n/o fix
787510 PNOZ XV3P C 30/24 VDC 3n/o 2n/o t
787511 PNOZ XV3.3P C 30/24VDC 3n/o 2n/o t
787512 PNOZ XV3P C 3/24 VDC 3n/o 2n/o t
787518 PNOZ XV3P C 300/24VDC 3n/o 2n/o t
787520 PNOZ XV3.1P C 30/24VDC 3n/o 1n/c 2n/o t
787522 PNOZ XV3.1P C 3/24VDC 3n/o 1n/c 2n/o t
787530 PNOZ XV3.1P C 30/24-240VACDC 3no 1nc 2no
787532 PNOZ XV3.1P C 3/24-240VACDC 3no 1nc 2no
787538 PNOZ XV3.1P C300/24-240VACDC 3no 1nc 2no
787540 PNOZ XV2.1P C 30/24-240VACDC 2n/o 2n/o t
787542 PNOZ XV2.1P C 3/24-240VACDC 2n/o 2n/o t
787548 PNOZ XV2.1P C 300/24-240VACDC 2n/o 2n/o
787580 PZE X4VP C 0,5/24VDC 4n/o fix
787581 PZE X4VP C 1/24VDC 4n/o fix
787582 PZE X4VP C 2/24VDC 4n/o fix
787583 PZE X4VP C 3/24VDC 4n/o fix
787584 PZE X4VP8 C 24VDC 4n/o
787585 PZE X4P C 24VDC 4n/o
787586 PZE X4VP4 C 24VDC 4n/o
787587 PZE X4.1P C 24VDC 4n/o
787588 PZE X4.1P C 24-240VAC/DC 4n/o
787600 PNOZ X2.1VP C 0.75/24VDC 1so 2n/o fix
787601 PNOZ XV1P C 3/24VDC 2n/o 1n/o t
787602 PNOZ XV1P C 30/24VDC 2n/o 1n/o t
787606 PNOZ X9P C 24VDC 100-240VACDC 7no 2nc2so
787609 PNOZ X9P C 24VDC 7n/o 2n/c 2so
787750 PNOZ X10.11P C 24VDC 6n/o 4n/c 6LED
787760 PNOZ X8P C 24 VDC 3n/o 2n/c 2so
787764 PNOZ X8P C 110VAC 3n/o 2n/c 2so
787765 PNOZ X8P C 115VAC 3n/o 2n/c 2so
787766 PNOZ X8P C 120VAC 3n/o 2n/c 2so
787768 PNOZ X8P C 230VAC 3n/o 2n/c 2so
787770 PNOZ X8P C 24VAC 3n/o 2n/c 2so
787949 PSWZ X1P C 0,5V/24-240VACDC 2n/o 1n/c2so
787950 PSWZ X1P C 3V/24-240VACDC 2n/o 1n/c2so
787951 PSWZ X1P C 0,0075-0,5V/24-240VACDC
788010 PMUT X1P C 24VDC 3n/o 1n/c 5so
793100 Set screw terminals, PNOZ m0p/m1p/m2p
793300 PNOZ p1p Set plug in screw terminals
793305 PNOZ p1p inverse Set plug in screw term.
793400 Set screw term. mi1p/mi2p/mo1p/mo3p/ml1p
793520 Set screw terminals PNOZ mo2p
793536 Set screw terminals PNOZ mo4p/mo5p
793537 10 Set screw terminals PNOZ mo4p/mo5p
793631 PNOZ po3.2p Set plug in screw terminals
793700 Set screw terminals PNOZ mc1p/ma1p
793800 Set screw terminals PNOZms1p/ms2p
874640 PDIA 1 24VDC RS-232
874645 PDIA 2 24VDC PLC-Interface
874646 PDIA 2 - HB
874130B PNOZelog Driver CD
上海诚屿商贸有限公司
杭州办事处
电话:0571-88054165 联系人:周 星
传真:0571-88054165 手机:15868872358/18958128225
网址:http://www.two-way.cn
诚信通:http://fuda06610.com.cn
淘宝网:http://shop58844147.taobao.com
邮箱:weidmuller@vip.qq.com
MSN:weidmuller@vip.qq.com QQ:48578977
联系地址:浙江省杭州市湖墅南路148号6楼 邮编:310005
- 电话:0571-88054165
- 传真:0571-88054165
- email:weidmuller@vip.qq.com
