- 数量:100
- 有效期:2021/12/31 0:00:00
三菱变频器,PLC找 李海萍 15898701471 FX2N-2AD 2 CHANNELS A/D 1,740.00
FX2N-2DA 2 CHANNELS D/A 2,100.00
FX2N-2LC 2 CHANNELS TEMPERATURE CONTROL BLOCK 4,450.00
FX2N-4AD 4 CHANNELS A/D 2,310.00
FX2N-4AD-PT 4 CHANNELS TEMPERATURE INPUTS, PT TYPE 3,270.00
FX2N-4AD-TC 4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE 3,270.00
FX2N-4DA 4 CHANNELS D/A 3,270.00
FX2N-5A 4 CHANNEL A/D, 1 CHANNEL D/A 3,400.00
FX2N-8AD 8 CHANNELS A/D 7,630.00
FX2N-1HC HIGH SPEED COUNTER BLOCK (1 CH) 3,170.00
FX2N-1PG-E PULSE TRAIN OUTPUT BLOCK (1 CH-100KHz) 4,270.00
FX2N-10GM 1 AXIS POSITION CONTROL UNIT 4,630.00
FX2N-10PG PULSE TRAIN OUTPUT BLOCK (1 CH-1MHz) 5,250.00
FX2N-20GM 2 AXIS POSITION CONTROL UNIT 8,860.00
E-20TP-E-SET0 PROGRAMMER FOR FX2N-10GM AND FX2N-20GM 5,260.00
E-GM-200CAB 2 M CABLE FOR SERVO DRIVER 360.00
E-GMJ2-200CAB1A 2 M CABLE FOR MR-J2 SERVO DRIVER 850.00
FX2N-1RM-E-SET PROGRAMMABLE CAM MODULE INCLUDE RESOLVER 8,770.00
F2-720RSV RESOLVER 3,360.00
F2-RS-5CAB EXTENSION CABLE FOR FX2N-RS-5CAB 710.00
FX2N-RS-5CAB SIGNAL CABLE BETWEEN FX2N-1RM AND F2-720RSV 620.00
FX-PCS-VPS/WIN-E GM GRAPHICAL PROGRAMMING SOFTWARE 1,070.00
FX2N-16CCL-M COMPUTER AND COMMUNICATION LINKmasterBLOCK 2,700.00
FX2N-16LNK-M REMOTE I/O SYSTEMmasterBLOCK 2,160.00
FX2N-32ASI-M AS-INTERFACE MODULE 4,230.00
FX2N-32CCL COMPUTER AND COMMUNICATION LINK INTERFACE BLOCK 2,490.00
FX2N-64CL-M CC-LINK/LTmasterBLOCK 2,560.00
FX2N-20PSU POWER SUPPLY UNIT (24DC, 2A) 1,670.00
FX2N-232IF RS-232 COMMUNICATION BLOCK (1 CH) 4,480.00
FX2N-CNV-IF EXTENSION CABLE CONVERTOR (FX2 TO FX2N) 400.00
-[FX2N ADAPTER BOARD]
FX2N-8AV-BD MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS 400.00
FX2N-232-BD RS-232C SERIAL PORT (1 CH) 400.00
FX2N-422-BD RS-422 SERIAL PORT (1 CH) 400.00
FX2N-485-BD RS-485 SERIAL PORT (1 CH) 400.00
FX2N-CNV-BC EXTENSION CABLE CONVERTOR 400.00
FX2N-CNV-BD FX0N MODULE TRANSFORM UNIT 400.00
-[FX2N SPECIAL FUNCTION UNIT]
FX2NC-232-ADP RS232 COMMUNICATION MODULE 1,230.00
FX2NC-485-ADP RS485 COMMUNICATION MODULE 1,550.00
FX2NC-CNV-IF INTERFACE ADAPTER 400.00
FX2N-PLC-(2/2)
Mitsubishi
Programmable Controller
EFFECTIVE FROM: 1st March, 2006
PRICE LIST
MITSUBISHI MELSEC-FX SERIES PROGRAMMABLE CONTROLLERS
[FX1N, FX1S Series]
(HK$)
MODEL DESCRIPTION UNIT PRICE
-[FX1N SERIES BASE UNIT]
FX1N-60MR-001 BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 4,680.00
FX1N-40MR-001 BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,030.00
FX1N-24MR-001 BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,330.00
FX1N-14MR-001 BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS 2,310.00
FX1N-60MR-D BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS (DC) 4,490.00
FX1N-40MR-D BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS (DC) 4,010.00
FX1N-24MR-D BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS (DC) 2,990.00
FX1N-60MT-001 BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS 4,800.00
FX1N-40MT-001 BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 4,130.00
FX1N-24MT-001 BASE UNIT WITH 14 INPUTS/10 TRANSISTOR OUTPUTS 3,400.00
FX1N-14MT-001 BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 2,400.00
FX1N-60MT-D BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS (DC) 4,600.00
FX1N-40MT-D BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS (DC) 4,100.00
FX1N-24MT-D BASE UNIT WITH 14 INPUTS/10 TRANSISTOR OUTPUTS (DC) 3,100.00
-[FX1NC SERIES BASIC UNIT]
- 电话:0533-3120773
- 传真:0533-3120973-806
- email:liuhaiwei77@163.com
