- 型号:PNOZ s11 24VDC 8 n/o 1 n/c
- 数量:100
- 有效期:2023/1/19 0:00:00
欢迎来电垂询0592-5222302传真:0592-5507930 手机:15959295713 QQ: 599299757
751104 | PNOZ s4 C 24VDC 3 n/o 1 n/c |
751105 | PNOZ s5 C 24VDC 2 n/o 2 n/o t |
751106 | PNOZ s6 C 24VDC 3 n/o 1 n/c |
751107 | PNOZ s7 C 24VDC 4 n/o 1 n/c |
751108 | PNOZ s8 C 24VDC 2 n/o |
751109 | PNOZ s9 C 24VDC 3 n/o t 1 n/c t |
751110 | PNOZ s10 C 24VDC 4 n/o 1 n/c |
751111 | PNOZ s11 C 24VDC 8 n/o 1 n/c |
751124 | PNOZ s4.1 C 24VDC 3 n/o 1 n/c |
751126 | PNOZ s6.1 C 24VDC 3 n/o 1 n/c |
751134 | PNOZ s4 C 48-240VACDC 3 n/o 1 n/c |
751135 | PNOZ s5 C 48-240VACDC 2 n/o 2 n/o t |
751136 | PNOZ s6 C 48-240VACDC 3 n/o 1 n/c |
751154 | PNOZ s4.1 C 48-240VACDC 3 n/o 1 n/c |
751156 | PNOZ s6.1 C 48-240VACDC 3 n/o 1 n/c |
751167 | PNOZ s7.1 C 24VDC 3 n/o cascade |
751177 | PNOZ s7.2 C 24VDC 4 n/o 1 n/c expand |
751185 | PNOZ s5 C 24VDC 2 n/o 2 n/o t coated |
773050 | PNOZmulti Systemhandbuch D |
773100 | PNOZ m1p base unit |
773105 | PNOZ m1p base unit coated version |
773110 | PNOZ m0p base unit not expandable |
773120 | PNOZ m2p base unit press function |
773200 | PNOZ pps1p 100-240VAC |
773300 | PNOZ p1p 24VDC 2so |
773400 | PNOZ mi1p 8 input |
773405 | PNOZ mi1p 8 inputs coated version |
773410 | PNOZ mi2p 8 standard input |
773500 | PNOZ mo1p 4 so |
773505 | PNOZ mo1p 4so coated version |
773510 | PNOZ mo3p 2so |
773520 | PNOZ mo2p 2n/o |
773525 | PNOZ mo2p 2n/o coated version |
773536 | PNOZ mo4p 4n/o |
773537 | PNOZ mo4p 4n/o coated version |
773540 | PNOZ ml1p safe link |
773630 | PNOZ po3.1p 8n/o |
773631 | PNOZ po3.2p 4n/o |
773632 | PNOZ po3.3p 3n/o |
773634 | PNOZ po3p 3n/o 1n/c |
773635 | PNOZ po4p 4n/o |
773700 | PNOZ mc1p |
773705 | PNOZ mc1p coated version |
773720 | PNOZ mc0p Powersupply |
773721 | PNOZ mc3p Profibus |
773722 | PNOZ mc4p DeviceNet |
773723 | PNOZ mc5p INTERBUS |
773724 | PNOZ mc6p CANopen |
773725 | PNOZ mc7p CC-Link coated version |
773726 | PNOZ mc7p CC-Link |
773727 | PNOZ mc6p CANopen coated version |
773728 | PNOZ mc5.1p Interbus LWL / Fiberoptic |
773729 | PNOZ mc4p DeviceNet coated version |
773730 | PNOZ mc8p Ethernet IP / Modbus TCP |
773731 | PNOZ mc9p Profinet IO |
773800 | PNOZ ms1p standstill / speed monitor |
773810 | PNOZ ms2p standstill / speed monitor |
773812 | PNOZ ma1p 2 Analog Input |
773839 | PNOZ msi1Bp Adapter Si/Ha 25/25 5m |
773840 | PNOZ msi1Ap Adapter Si/Ha 25/25 2,5m |
773841 | PNOZ msi1Bp Adapter Si/Ha 25/25 2,5m |
773842 | PNOZ msi3Ap Adapter Si/Ha 15/15 2,5m |
773843 | PNOZ msi3Bp Adapter Si/Ha 15/15 2,5m |
773850 | PNOZ msi1p Adapter Si/Ha 25/25 2,5m |
773844 | PNOZ msi1AP Adapter Si/Ha 25/25 5m |
773854 | PNOZ msi10p adapter cable 2,5m |
773855 | PNOZ msi11p adapter cable 1,5m |
773856 | PNOZ msi 9p adapter cable 5m |
773857 | PNOZ msi5p Adapter Bos/Rex 15/15 2,5m |
773858 | PNOZ msi5p Adapter Bosc/Rex 15/15 1,5m |
773859 | PNOZ msi6p Adapter Elau 9/9 7,5m |
773860 | PNOZ msi6p Adapter Elau 9/9 2,5m |
773861 | PNOZ msi6p Adapter Elau 9/9 1,5m |
773862 | PNOZ msi8p Adapter Lenze 9/9 2,5m |
773863 | PNOZ msi8p Adapter Lenze 9/9 1,5m |
773864 | PNOZ msi7p Adapter SEW 15/15 2,5m |
773865 | PNOZ msi7p Adapter SEW 15/15 1,5m |
773867 | PNOZ msi16p ADAPTER Baumuell 15/15 2,5m |
773868 | PNOZ msi12p Rockwell 15/15 2,5m |
773869 | PNOZ msi13p Fanuc 20/20 2,5m |
773870 | PNOZ msi S09 |
773871 | PNOZ msi S15 |
773872 | PNOZ msi S25 |
773874 | PNOZ msi15p Adapter Tendo 15/15 2,5m |
773875 | PNOZ msi17p Bos/Rex 15/15 4,0m |
773878 | PNOZ msi14p Leroy 15/15 2,5m |
773880 | PNOZ msi b1 Box 15p |
773881 | PNOZ msi b0 cable 15/RJ45 |
773882 | PNOZ msi b1 Box 9p |
773883 | PNOZ msi b1 Box 25p |
773884 | PNOZ msi b0 cable 25/RJ45 |
773890 | PNOZ mli1p 5m screw |
773891 | PNOZ mli1p 10m screw |
773892 | PNOZ mli1p 50m screw |
773893 | PNOZ mli1p 5m spring |
773894 | PNOZ mli1p 10m spring |
773895 | PNOZ mli1p 50m spring |
773900 | PNOZ pe1p |
773950 | PNOZ p1vp 30s |
773951 | PNOZ p1vp 300s |
774000 | PNOZ 10 24VAC 6n/o 4n/c |
774001 | PNOZ 10 42VAC 6n/o 4n/c |
774002 | PNOZ 10 48VAC 6n/o 4n/c |
774003 | PNOZ 10 110-120VAC 6n/o 4n/c |
774006 | PNOZ 10 230-240VAC 6n/o 4n/c |
774009 | PNOZ 10 24VDC 6n/o 4n/c |
774012 | PNOZ 2VJ 24VDC 3n/o 1n/c 2n/o t |
774013 | PNOZ 2VQ 24VDC 3n/o 1n/c 2n/o t |
774015 | PZW 30/110-120VAC 1n/o 2n/c |
774017 | PZW 30/230VAC 1n/o 2n/c |
774019 | PZW 30/24VDC 1n/o 2n/c |
774020 | PZA 300/24VAC 1n/o 2n/c |
774021 | PZA 300/42VAC 1n/o 2n/c |
774023 | PZA 300/110-120VAC 1n/o 2n/c |
774026 | PZA 300/230VAC 1n/o 2n/c |
774028 | PZA 600/24VDC 1n/o 2n/c |
774029 | PZA 300/24VDC 1n/o 2n/c |
774030 | PZA 30/24VDC 1n/o 2n/c |
774031 | PZA 30/24VAC 1n/o 2n/c |
774035 | PZA 30/110-120VAC 1n/o 2n/c |
774038 | PZA 3/230VAC 1n/o 2n/c |
774040 | PZA 30/230VAC 1n/o 2 n/c |
- 电话:0592-5222302
- 传真:0592-5222302
- email:npliuqin12@163.com
