- 数量:100
- 制造商:横河
- 有效期:2099/12/31 0:00:00
本公司长期提供质优价廉的横河停产型号DCS卡件,并备有大量的现货欢迎新老客户来电咨询,联系方式:13400698437,QQ:943828869,肖先生
型号/订货号 | 描述 | Q''ty | |
1 | 701250 | High-Speed 10MS/s 12bit ISOLATION MODULE | 11 |
2 | 32DA31038M | 触摸屏框 | 1 |
3 | A1164UY | THE RMAINK RibboN ECHU3 | 25 |
4 | AAB841-S00 | ANALOG CARD | 7 |
5 | AAP135-S00 | ANALOG CARD | 1 |
6 | AAT141-S00 | ANALOG CARD | 7 |
7 | AAV141-S00 | ANALOG CARD | 4 |
8 | ADV161-P00 | ANALOG CARD | 9 |
9 | ADV561-P00 | ANALOG CARD | 6 |
10 | AFG30D | FIELD CONTROL UNIT 50/60Hz 100-120VAC~400VA | 1 |
11 | AIP532 | 2 | |
12 | AIP502 | COUPLER | 2 |
13 | ALR111-S00 | ANALOG CARD | 1 |
14 | ANB10D | NODE INTERFACE UNIT 50/60Hz 100-120VAC~220VA | 5 |
15 | AS S9362BE OPK-CTL3 | 4 | |
16 | BARD-400*A | 2 | |
17 | CA0*A | MODULE | 3 |
18 | CNB-22C | Printer Converter | 2 |
19 | CP333D Style:S3 | 12 | |
20 | CP345-S1 | PROCESSOR BD | 2 |
21 | CP81B*C | 2 | |
22 | CP92*A | 1 | |
23 | CPL-6 | 4 | |
24 | CR5-PA*A | MODULE | 1 |
25 | CR5-PD*A | MODULE | 6 |
26 | DP88*D | PC BOARD | 2 |
27 | DP97*B | PC BOARD | 3 |
28 | DU85*B | PC BOARD(14"CRT) | 1 |
29 | DW200-11-1M | DARWIN STYLE:S8 SUFFIX:M1 SUPPLY:100-120VAC/200-240VAC 50-60Hz | 1 |
30 | EA0*A | OUTPUT ISOLATOR CARD | 8 |
31 | EA1*A | SIGNAL CONDITIONER NEST | 44 |
32 | EA9*A | I/O NONISOLATED DISTRIBUTOR | 95 |
33 | EC0*A | SIGNAL CONDITIONER NEST | 8 |
34 | EP1*A | SIGNAL CONDITIONER NEST | 12 |
35 | ER5*B | SIGNAL CONDITIONER NEST | 16 |
36 | EX1*A | I/O THROUGH CARD | 16 |
37 | F3AD04-0N | ANALOG INPUT MODULE, 0 TO 5VDC, 1 TO 5VDC | 1 |
38 | F3AD04-0N | ANALOG INPUT MODULE, 0 TO 5VDC, 1 TO 5VDC | 1 |
39 | F3AD08-1R | ANALOG INPUT MODULE, 0 TO 5VDC, 1 TO 5VDC | 27 |
40 | F3BA20-0N | 1 | |
41 | F3BP20-0N | CPU BASIC 120K TASK MEM 1024PT | 3 |
42 | F3BU06-0N | POWER SUPPLY PLUS MODULE 6 SLOTS CPU AND I/O | 1 |
43 | F3CR04-0N | RTD CONTROL MODULE | 8 |
44 | F3CT04-0N | TEMPERATURE CONTROL MODULE | 7 |
45 | F3CX04-0N | TEMPERATURE MONITORING MODULE, (TC, RTD OR DC) | 63 |
46 | F3DA02-0N | ANALOG OUTPUT MODULE, -10 TO 10VDC, 4 TO 20 MA DC | 1 |
47 | F3DA04-1N | ANALOG OUTPUT MODULE, -10 TO 10VDC, 4 TO 20 MA DC | 6 |
48 | F3DA08-5N | ANALOG OUTPUT MODULE, -10 TO 10 V, 8-CHANNEL | 13 |
49 | F3LC11-1F | PERSONAL COMPUTER LINK MODULE, 1 RS-232C PORT | 5 |
50 | F3LC11-1N | LINK MODULE PC COMPUTER SERIAL HALF-DUPLEX | 4 |
51 | F3LE01-5T | ETHERNET INTERFACE MODULE 10BASE5/10BASE-T | 4 |
52 | F3LE11-0T | ETHERNET INTERFACE MODULE, 10/100M BPS, 10 BASE-T | 4 |
53 | F3LP01-0N | 5 | |
54 | F3LR01-0N | FIBER OPTIC INTERFACE MODULE, 7 STATIONS MAX. | 25 |
55 | F3NC02-0N | 2 | |
56 | F3NC11-0N | POSITIONING MODULE, 1 AXIS, 250 KPPS MAX. | 5 |
57 | F3NC12-0N | POSITIONING MODULE, 2 AXES, 250 KPPS MAX. | 23 |
58 | F3PU20-0N | POWER SUPPLY 120/240VAC 50/60HZ SUPPLY 4.3AMP OUT | 16 |
59 | F3PU30-0N | POWER SUPPLY MODULE 100-240VAC LINE POWER | 4 |
60 | F3PU30-0S | POWER SUPPLY MDULE 100-240VAC LINE POWER | 11 |
61 | F3RS41-0N | COMMUNICATION MODULE, 19,200 BPS MAX. | 5 |
62 | F3RZ81-0N | COMMUNICATION MODULE, 19,200 BPS MAX, | 4 |
63 | F3SP08-5P | 1 | |
64 | F3SP21-0N | SEQUENCE CPU MODULE LADDER LOGIC 10K STEPS/MEMORY | 3 |
65 | F3SP25-2N | SEQUENCE CPU MODULE, LADDER 10K STEPS, 0.12MS | 4 |
66 | F3SP28-3N | CPU MODULE | 2 |
67 | F3SP28-3S | SEQUENCE CPU MODULE, LADDER 30K STEPS, 0.045MS | 3 |
68 | F3SP30-0N | 1 | |
69 | F3SP35-5N | CPU | 3 |
70 | F3SP38-6N | SEQUENCE CPU MODULE, LADDER 120K STEPS, 0.045MS | 3 |
71 | F3SP38-6S | SEQUENCE CPU MODULE, LADDER 120K STEPS, 0.045MS | 2 |
72 | F3SPVB-6S | 3 | |
73 | F3WD64-3F | 3 | |
74 | F3XC08-0N | NO-VOLTAGE CONTACT INPUT MODULE, 8 POINTS | 5 |
75 | F3XD08-6F | DC INPUT MODULE SINK/SOURCE, 12 TO 24 V DC, 8 PTS | 1 |
76 | F3XD16-3F | DC INPUT MODULE SINK/SOURCE, 24 V DC, 16 POINTS | 8 |
77 | F3XD16-3N | DC INPUT MODULE SINK/SOURCE, 24 V DC, 16 POINTS | 2 |
78 | F3XD32-3N | INPUT MODULE 32PT 24VDC | 8 |
79 | F3XD32-5N | TTL INPUT MODULE, 5VDC, 32 POINTS | 4 |
80 | F3XD64 | DC INPUT MODULE | 1 |
81 | F3XD64-3F | DC INPUT MODULE SINK/SOURCE, 24VDC, 64 POINTS | 1 |
82 | F3XD64-3N | INPUT MODULE 64POINT 24VDC INPUT SINK/SOURCE | 21 |
83 | F3XH04-3N | HIGH-SPEED INPUT MODULE WITH PULSE CATCH,24 V DC, | 2 |
84 | F3XP01-0H | UP/DOWN COUNTER MODULE | 1 |
85 | F3YC08-0C | RELAY OUTPUT MODULE (24VDC, 100 TO 240VAC), 2AMP | 1 |
86 | F3YC08-0N | RELAY OUTPUT MODULE (24VDC, 100 TO 240VAC), 2AMP | 6 |
87 | F3YC16-0N | RELAY OUTPUT MODULE (24VDC, 100 TO 240VAC), 2AMP | 10 |
88 | F3YD08-6A | TRANSISTOR OUTPUT MODULE SINK TYPE 12 TO 24VDC, 1A | 1 |
89 | F3YD14-5A | TRANSISTOR OUTPUT MODULE SINK TYPE 12 TO 24VDC | 9 |
90 | F3YD14-5B | TRANSISTOR OUTPUT MODULE SOURCE TYPE, 12 TO 24VDC | 1 |
91 | F3YD32-1A | OUTPUT MODULE 32PT TRANSIST. 1MS 12-24VDC 8PT COMM | 9 |
92 | F3YD32-1T | TTL OUTPUT MODULE, 5VDC, 16 MA, 32 POINTS | 3 |
93 | F3YD64-1A | OUTPUT MODULE 64POINT 24VDC INPUT SINK/SOURCE | 18 |
94 | FC81*A | 2 | |
95 | HD82*A | 1 | |
96 | IP91*A | 2 | |
97 | KB93*A | KeyBoard | 1 |
98 | LC82*B | RL-BUS Interface Card | 2 |
99 | M20HA | 8 | |
100 | MAC2*B | 1 | |
101 | MDK1*B | MODULE | 1 |
102 | MHC | Signal Cond | 5 |
103 | MHM | Signal Cond | 1 |
104 | MP38-1N | CPU | 1 |
105 | MP46-1NT | 2 | |
106 | MRO-114 | 2 | |
107 | MUD | TERMINAL BOARD | 1 |
108 | MV4*D | 1 | |
109 | NP53*C | CPU MODULE | 6 |
110 | NP54*C | 4 | |
111 | PM1*C | MXLII 多點脈衝輸入 | 1 |
112 | PM40-1N | POWER SUPPLY | 1 |
113 | PM40-1NT | 2 | |
114 | PMJ*C | 1 | |
115 | PS31*A | MXLII Power Supply | 6 |
116 | PS35*A | MODULE | 4 |
117 | PS63*A | 3 | |
118 | PS63-ADP | Power Supply | 1 |
119 | PS71*A | 5 | |
120 | PS71-ADP | Power Supply | 1 |
121 | PS84*B | 1 | |
122 | PW401 | 2 | |
123 | PW481-10 S1 | 10 | |
124 | PX1*A | MXLII SERIAL INTERFACE CARD | 2 |
125 | RB401-S4 | 2 | |
126 | RM81*A | 2 | |
127 | RS22-0N*A | RS232C INTERFACE | 1 |
128 | RS81*B | 3 | |
129 | SB301 S1 | INTERFACE CARD | 2 |
130 | SB401-10 S1 | 10 | |
131 | ST4*D | MXLII STATE OUTPUT CARD | 2 |
132 | ST5*A | MULTIPOINT STATUS I/O CARD | 2 |
133 | ST6*A | MULTIPOINT STATUS INPUT CARD | 7 |
134 | ST7*A | MULTIPOINT STATUS OUTPUT CARD | 2 |
135 | SV22-2N | SERVO | 3 |
136 | SV25-2N | 6 | |
137 | SWB-23 | RGB+KB分配器 | 4 |
138 | TD-200UEY-F(S9035UG) | 触控板 | 8 |
139 | UCFA-1 | 2 | |
140 | UCFM | 2 | |
141 | UD1A-200N | DD SERVO ACTUATOR 50/60Hz 200-230VAC | 1 |
142 | UT550 | CONTROLLER | 3 |
143 | VAJ1-S3 | VJA1-017-A6N0 | 35 |
144 | VJA1-S2 | VJA1-017-A6N0 | 16 |
145 | VJC1-S1 | 10 | |
146 | VM1*D | MULTIPOINT ANALOG INPUT CARD | 7 |
147 | VM2*D | MULTIPOINT ANALOG I/O CARD | 1 |
148 | VM4*D | MXLII 类比输出卡 | 1 |
149 | XD32-6N | CPU | 3 |
150 | XD32-6NT | 2 | |
151 | XD64-6N | DC INPUT | 1 |
152 | YD32-1AT | 2 | |
153 | YD32-5A | TRANSISTOR OUTPUT | 1 |
154 | YD64-1A | TRANSISTOR OUTPUT | 1 |
155 | YIR104-111*A | Printer | 2 |
156 | Color Hard Copy Model:YPR520 | 1 | |
Full color printer Model:CHC-545-2 | |||
Sinko Electric Co Ltd. | |||
157 | Hard Disk unit For Eops S9729UK | ||
50pin Quanfum 2.1s | |||
50pin Fujifsu M2612ES | |||
50pin M2681S XM Fujifsu
158 | PC10011 | POSITION CONTROLLER 14 | |
159 | SR1015B82 |
200-230VAC+10-15% 500VA 50/60Hz 5 |
- Model: MOPS-P221*C/EKMU/2-RL
- RL-BUS Interface Card Model: LC82*B
- Display Card Model: DP88B*A
- Processer Card Model: CP81D
2. OPERATOR STATION 1 SET
3. SERIAL PRINTER P/N: MXL // YPR104-221*A/KM10 2 SETS
4. FIELD CONTROL UNIT Model: MFCD-S520*A/FAN 2 SETS
5. FIELD CONTROL UNIT Model:MFCD-S520*A/2-RL/FAN 1 SET
6. POWER SUPPLY Model: PS53*A 6 SETS
7. Field Control Unit Model: S520*A/PAN 3 SETS
8. SIGNAL CONDITIONER NEST Model:MHM-30*A 3 SETS
9. SIGNAL CONDITIONER NESTS For I/O SIGNAL Model:MHC-30*A 9 SETS
10. TERMINAL BOARD Model: MUD*A 6 SETS
11. RELAY OUTPUT BOARD Model: MRO-214*A 3 SETS
12. RELAY OUTPUT BOARD Model: MRO-254*A 4 SETS
13. Model: EH1*A 1 PCS
型号/订货号 | 描述 | ||
1 | F3AD04-0N | ||
2 | F3CR04-0N | ||
3 | F3CT04-0N | ||
4 | F3DA02-0N | ||
5 | F3LC11-1N | ||
6 | F3LE01-5T | ||
7 | F3LP01-0N | ||
8 | F3LR01-0N | ||
9 | F3NC02-0N | ||
10 | F3NC11-0N | ||
11 | F3NC12-0N | ||
12 | F3PU20-0N | ||
13 | F3SP21-0N | ||
14 | F3SP25-2N | ||
15 | F3SP28-3N | ||
16 | F3SP35-5N | ||
17 | F3XD16-3N | ||
18 | F3XD32-3N | ||
19 | F3XD32-5N | ||
20 | F3XD64 | DC INPUT MODULE | |
21 | F3XD64-3N | ||
22 | F3XH04-3N | ||
23 | F3XP01-0H | ||
24 | F3YD08-6A | ||
25 | F3YD14-5A | ||
26 | F3YD32-1A | ||
27 | F3YD32-1T | ||
28 | F3YD64 | OUTPUT MODULE | |
29 | F3YD64-1A | ||
30 | MP46-1NT | ||
31 | PM40-1NT | ||
32 | SV25-2N | ||
33 | XD32-6NT | ||
34 | YD32-1AT |
订货号 | 描述 | ||
1 | AAB841-S00 S1 | ANALOG CARD | |
2 | AAB841-S00 S2 | ANALOG CARD | |
3 | AAP135-S00 S1 | ANALOG CARD | |
4 | AAT141-S00 S1 | ANALOG CARD | |
5 | AAT141-S00 S2 | ANALOG CARD | |
6 | AAV141-S00 S1 | ANALOG CARD | |
7 | AAV141-S00 S2 | ANALOG CARD | |
8 | ADV161-P00 S1 | ANALOG CARD | |
9 | ADV161-P00 S2 | ANALOG CARD | |
10 | ADV561-P00 S1 | ANALOG CARD | |
11 | ADV561-P00 S2 | ANALOG CARD | |
12 | ALR111-S00 S1 | ANALOG CARD | |
13 | PW481-10 S1 | ||
14 | SB401-10 S1 | INTERFACE MOD |
FIELDCONTROL UNIT AFG30D -H4113 S1 50/60Hz 100-120VAC~400VA
订货号
类型
描述
1
AIP502
S1
2
AIP532
S1
3
CP345
S1
4
PW301
S4
5
SB301
S1
- 电话:13400698437
- email:shuogulao@126.com
