- 型号:CP1L-L20DT1-D CP1L-M30DR-A
- 数量:1000
- 制造商:欧姆龙
- 有效期:2099/5/31 0:00:00
销售产品包括:低压配电(接触器、断路器、PLC变频器、软起动),传感元件,变频调速及PLC产品,开关电源,液压气动,仪器仪表,成套设备
CP1L-L14DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DT-D
CP1L-L14DR-D
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-L14DT-D
CP1L-L20DT1-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-L14DT1-D
CP1L-L20DT1-D
CP1L-L14DT1-D
CP1L-L20DR-A
CP1L-L14DR-A
CP1L-M30DR-D
CP1L-L20DT-D
CP1L-L14DR-D
CP1L-L20DR-A
CP1L-L20DR-D
CP1L-L14DT-D
CP1L-M30DR-A
CP1L-M30DR-D
CP1L-L14DR-A
CP1L-L14DR-A
CP1L-L14DR-D
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-L14DT-D
CP1L-L14DR-A
CP1L-L20DR-D
CP1L-L20DT-D
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-L20DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-L20DT-D
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-L20DT-D
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-L14DR-A
CP1L-L20DR-A
CP1L-L14DT-D
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-L14DR-A
CP1L-M30DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-L20DR-A
CP1L-L14DR-A
CP1L-L14DR-D
CP1L-M30DR-A
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-L20DR-D
CP1L-M30DR-A
CP1L-L14DT-D
CP1L-L14DT-D
CP1L-L20DR-A
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-L14DT-D
CP1L-L14DR-D
CP1L-L20DR-A
CP1L-L14DR-D
CP1L-M30DR-D
CP1L-L20DR-D
CP1L-L20DT-D
CP1L-L14DT-D
CP1L-L14DR-A
CP1L-L20DR-A
CP1L-M30DR-A
CJ1W-PA205R
CJ1W-IC101
CJ1W-II101
CJ1W-TER01
CJ1W-CLK21
CJ1W-ETN11
CJ1W-TC001
CJ1W-TC101
CJ1W-DRM21
CJ1W-NC213
CJ1W-NC413
CJ1H-CPU65H
CJ1G-CPU45H
CJ1G-CPU44H
CJ1G-CPU42H
CJ1W-SRM21
CJ1W-OD201
CJ1W-PD025
CJ1M-CPU12
CJ1M-CPU13
CJ1M-CPU22
CJ1M-CPU23
CJ1W-CIF11
CJ1W-AD081-V1
CJ1W-DA041
CJ1W-DA021
CJ1W-ETN21
CJ1W-CLK21-V1
CJ1M-CPU11
CJ1W-SCU21-V1
CJ1W-SCU41-V1
CJ1M-CPU11-ETN
CJ1M-CPU13-ETN
CJ1W-ID211
CJ1W-OD211
CJ1W-OD212
CJ1W-OC211
CJ1W-DA08C
CJ1W-DA08V
CJ1W-ID231
CJ1W-ID232
CJ1W-ID261
CJ1W-ID262
CJ1W-OC201
CJ1W-OD231
CJ1W-OD232
CJ1W-OD263
CP1L-L14DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DT-D
CP1L-L14DR-D
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-L14DT-D
CP1L-L20DT1-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-L14DT1-D
CP1L-L20DT1-D
CP1L-L14DT1-D
CP1L-L20DR-A
CP1L-L14DR-A
CP1L-M30DR-D
CP1L-L20DT-D
CP1L-L14DR-D
CP1L-L20DR-A
CP1L-L20DR-D
CP1L-L14DT-D
CP1L-M30DR-A
CP1L-M30DR-D
CP1L-L14DR-A
CP1L-L14DR-A
CP1L-L14DR-D
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-L14DT-D
CP1L-L14DR-A
CP1L-L20DR-D
CP1L-L20DT-D
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-L20DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-L20DT-D
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-L20DR-A
CP1L-M30DR-A
CP1L-L20DT-D
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-L14DR-A
CP1L-L20DR-A
CP1L-L14DT-D
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-L14DR-A
CP1L-M30DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-L20DR-A
CP1L-L14DR-A
CP1L-L14DR-D
CP1L-M30DR-A
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-L20DR-D
CP1L-M30DR-A
CP1L-L14DT-D
CP1L-L14DT-D
CP1L-L20DR-A
CP1L-L14DR-D
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L20DT-D
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-M30DR-A
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L20DT-D
CP1L-L14DR-A
CP1L-L14DT-D
CP1L-L20DR-D
CP1L-L20DR-A
CP1L-L14DT-D
CP1L-L14DR-D
CP1L-L20DR-A
CP1L-L14DR-D
CP1L-M30DR-D
CP1L-L20DR-D
CP1L-L20DT-D
CP1L-L14DT-D
CP1L-L14DR-A
CP1L-L20DR-A
CP1L-M30DR-A
以下欧姆龙OMRON产品在正火热促销:
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-A 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DR-D 一体化PLC
CP1L-L14DT1-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L14DT-D 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-A 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DR-D 一体化PLC
CP1L-L20DT1-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-L20DT-D 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-A 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DR-D 一体化PLC
CP1L-M30DT1-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M30DT-D 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-A 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DR-D 一体化PLC
CP1L-M40DT1-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
CP1L-M40DT-D 一体化PLC
E3F2-7B4 2M
E3F2-7B4-P1
E3F2-7C4 2M
E3F2-7C4 2M
E3F2-7DB4-P1 BY OMG
E3F2-7DB4-P1
E3F3-D31 2M BY OMC
E3F3-D11 2M BY OMC
E3F3-D32 2M BY OMC
E3F3-D32 2M BY OMC
E3F3-D12 2M BY OMC
E3F3-R81 2M BY OMC
E3F3-R61 2M BY OMC
E3F3-T81 2M BY OMC
E3F3-T61 2M BY OMC
E3F3-T11 2M BY OMC
E3F3-T31 2M BY OMC
E3F3-T11 0.2M BY OMC
你好:
公司以雄厚的技术实力和良好信誉,与世界著名工控产品厂商法国施耐德、日本OMRON、富士、瑞典ABB、松下电工、德国西门子、金钟穆勒、魏德米勒、倍加福、美国A-B、美国GE、美国派克、英国C.T公司、诺冠、威图、台湾研华、苏州特雷卡、深圳华为、三菱、三肯、SMC,FESTO等公司建立了长期稳定的技术和商务合作关系。我公司为电气自动化行业“全国一级”代理商,价格优惠,特价、批发价供应。
仪器仪表
压力仪表,压力变送器,液位变送器,示波器,数显仪表,温控器,
伺服传动
液位控制
调压阀,节流阀,电磁阀,机械阀,顾虑器,滤芯,电动或气动驱动器,
PLC
PLC本体,可编程终端,数字量输入模块,CPU单元,数字量输出模块,连接电缆,一体化PLC,模拟量输入模块,存储器盒,
变频传动
高压变频器,高性能通用变频器,风泵变频器,工程型变频器,电机软启动器,变频器面板,
低压配电
微型断路器,塑壳断路器,框架断路器,控制变压器,漏电保护装置,熔断器,
低压控制,
交流接触器,热过载继电器,中间继电器,固态继电器,时间继电器,
传感器
接近、光电开关,限位开关,行程开关,液位开关,压力开关,温度传感器,微动开关,
控制元件
凸轮开关,选择开关,按钮,指示灯,报警灯,开关插座,
电气安装
接线端子,固定端子,PCB产品,安装工具,接线端子附件,配电箱体,
在众多的工控产品中,您是否为了寻找性价比高的产品而烦恼?现在,您只要一个电话,剩下的事情我来办。
我们是国内最大的自动化元器件提供商之一,拥有网络化的物流管理系统,代理经销国内外数百种品牌的自动化产品,能随时提供百万种的产品供您选择.
一流的质量,优异的价格,,方便、快捷的物流体系,是您最佳的选择!欢迎来电来函垂询,我们必将竭诚为您服务!
以上为我公司近期特价促销产品 ,由于型号众多,无法一一列出,敬请谅解,我将竭诚为您服务!欢迎各界朋友来电咨询或询价,谢谢!
请问你要的数量是多少,可以直接向我发一份询价单或来电咨询吗?我会为你提供一个好价格的!!!
一定要联系我哦!!!
商祺!!!!
联系人:刘德博
企业报价邮箱: 敬请注意详细联系方式见下方!
dianqizidonghua@163.com
- 电话:13179619961
- 传真:0512-82098826
- email:dianqizidonghua@163.com
