供应LBZ防爆操作柱/BZC51防爆操作柱
2011/3/18 8:49:16
0 人气:142
- 型号:LBZ系列/BZC系列
- 数量:按客户的要求生产
- 制造商:顺新防爆
- 有效期:2020/12/31 0:00:00
LBZ防爆操作柱/BZC51防爆操作柱
CBC51-DIP/BZC8050系列防爆防腐操作柱(IIC)
LBZ防爆操作柱/BZC51防爆操作柱适用范围
20区、21区、22区危场所。
含有爆炸性或可燃性粉尘环境.
LBZ防爆操作柱/BZC51防爆操作柱产品特点
铸铝合金外壳,表面喷塑。
产品具有防、防尘等性能。
按钮、开关、指示灯、电流表等组
成多种功能,由用户自由选择.
电流表量程由用户指定。
符合GB12476,IEC61241标准要求
1区、2区危险场所.
IIA、IIB、类爆炸性气体环境.
Can be used in Zone 1and Zone 2 dangerous places.
Can be used in IIA、IIB group explosive atmosphere.
型号含义 Model implication
LBZ防爆操作柱/BZC51防爆操作柱总单元含义 Applicatinon of chief part
第一单元含义 Application of first part 第二单元 Application of second part
第三单元 Application of third pqrt 第四单元 Application of third part
LBZ防爆操作柱/BZC51防爆操作柱产品特点 Features
■ 铸铝合金外壳,表面喷塑. ◆ Al-alloy diecasted shell with plastic-sprayed surface
■ 内装万能转换开关、按钮、电流表(可按用要求 ◆ Inside is mounted univeral changeover swith,button,ammeter(can mountother
装其他仪表)、指示灯. instruments according to user's requirement)and indicator,etc.
■ 转换开关有30多种功能可由用户自由选择,可根据 ◆ There are more than 30 functions of changeover switch available to be chosen
要求特制.
■ 万能开关操纵机构经过优化设计,可以自动找正,能 ◆ Can be customized according to user's requirement.
能保证转动灵活,无卡滞现象.
■ 电流表量程由用户指定. ◆ The ammeter'smeasuring range can be determinedby users.
■ 钢管或电缆布线均可. ◆ Suitable for steel pipe and cable wiring.
■ 产品出厂铭牌上只体现总单元内容,名分单元代号 ◆ The marker of product when ex-factory only reflect the content of chief part,
为订货参数. ◆ The code of other parts is ordering parameter.
■ 符合GB3836-2000,IEC60079标准要求. ◆ Suitable for GB3836-2000,IEC60079 standard request.
LBZ防爆操作柱/BZC51防爆操作柱主要技术参数 Main te chnical parameters
使用类别 额定电压(v) 额定电流 (A) 防爆标志 防护等级 防腐等级 时线口螺纹(G") 电缆外径(¢,mm)
Using sort Rated voltage Rated current Ex-mark Protection Corrosion-proof Inlet's thread Cable's outer
category Grade
AC-3 220/380 10 Exde II Bt6 Ip55 Wf1 1 12-17
AC-4
订货举例 Notice if ordering
1 、一表一开关立式,开关代号为K,表量程为200/5应 1 、One meter one switch vertictype,the code of the switch is K,one
标注为: meter the measuring range is 200/5
CBC51-B1K1L CBC51-B1K1L
B1-1(200/5) B1-1(200/5)
K1-1A K1-1A
2 、二钮一表二灯挂式,表量程为100/5,指示灯为220V 2 、Two buttons one meter pendant type,two lamps one meter,the
红绿各1个,2个按钮规格为一常开一常闭.标注为: Meas wring range is 100/5,one red indiator,one green indicator,
CBC51-A2B1D2G the voltage is 220V,two bottons are 1NO+1NC.
A2-2I CBC51-A2B1D2G
B1-1(100/5) A2-2I
D2-1Rd/1Gd B1-1(100/5)
D2-1Rd/1Gd
按钮代号 Button code
代号 Code I II III IV V
按扭触头型式 一常开一常闭 二常开 二常闭 一常开 一常闭
Form of button contact 1NO+1NO 2NO 2NC 1NO 1NC
LBZ防爆操作柱/BZC51防爆操作柱代号指示灯 Indicator Code
代号Code a b c d e
电压Voltage(v) 12 24 36 220 380
代号Code R B Y W
颜色 Color 红色red 绿色Green 黄色 Yellow 白色 White
LBZ防爆操作柱/BZC51防爆操作柱
- 电话:0577-62618206
- 传真:0577-62900320
- email:1464380266@qq.com
工控宝APP下载安装
