- 型号:温州防爆箱 乐清防爆配电箱 柯铭BXM(D)8050防爆防腐配电箱
- 数量:200
- 制造商:乐清市柯铭防爆电器有限公司
- 有效期:2051/12/21 0:00:00
产品特点
1、本产品为复合型,外壳采用玻璃纤维增强不饱和聚脂树脂压制而成,内装断路器为我公司特制的防爆元件,外壳采用增安
型结构具有较好的防水、防尘和耐冲击等优良性能,由于产品主要部件均采用工程塑料,因此具有较强的防腐性能。
2、本产品经过科学的优化设计,产品结构轻巧,紧凑,但用户安装接线和维修空间较大。
3、具有过载短路保护功能,可根据要求增加漏电保护等功能。
4、钢管或电缆布线均可。
5、符合GB3836-2000,IEC60079标准要求。
Features
1. The products are combined type, the shell is made of glass-fiber and unsaturated polyester-resin, inner ciruit breaker is our company
special explosion-proof element, the shell is safety-increased structure, with the excellent functions of water-proof, dust-proof and
impulsion withstanding, because the main components all use enginering plastic, it has the function of strong corrosion-proof.
2. The product uses scientific optimized design, light and compact structure, but there is big space for the users to install and connect, maintain.
3. With the protection of overload, and short-circuit, it can add the protection offleakage according to the demand.
4. Suitable for steel pipe and cable wiring.
5. Suitable for GB3836-2000, IEC60079 standard request.
主要技术数据 Main technical Specification
型号 额定电压(V) 支路额定电流(A) 支路数 主回路总开关数 支路额定电流(A) 防爆标志 管螺纹 电缆外径(mm) 防护等级 防腐等级
BXM(D)8050-4 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-6 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-8 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-10 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-12 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-4K 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-6K 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-8K 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-10K 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
BXM(D)8050-12K 220/380v 63 4-12 1-2 1-60 Exed Ⅱ CT6 G11/4″~G2″ G1/2″~G11/2″ ip65 WF2
如需更多质料请咨询:13777741578 江宇先生
本产品由乐清柯铭防爆电器有限公司www.yqkmfb.com专业提供,禁止转载!
- 电话:0577-61780756
- 传真:0577-61780759
- email:1466908630@qq.com
