当前页面: 首页 >供求信息 >馈电隔离器MCR-CPSS-I-I
馈电隔离器MCR-CPSS-I-I
2012/2/4 17:07:54
0 人气:8
  • 型号:MCR-CPSS-I-I
  • 数量:50
  • 制造商:菲尼克斯
  • 有效期:2018/2/19 0:00:00
1.模拟量馈电隔离器  2810900 MCR-CPSS-I-I-44-E 2814553 MCR-CPS-I-I-44-E
2.电压变送器  2835817 PI-EX-ME-U-I
3.输出隔离放大器  2835451 PI-EX-ME-IDS-I/I 2835749 PI-EX-ME-ID-UI-I 2835448 PI-EX-ME-ID-I/I 2835464 PI-EX-ME-2IDLP-I/I
4.数字量NAMUR隔离放大器  2835493 PI-EX-ME-2NAM/COC-24VDC 2835503 PI-EX-ME-2NAM/COC-230VAC 2835781 PI-EX-ME-2NAM/COC-120VAC 2835480 PI-EX-ME-2NAM/TO 2835778 PI-EX-ME-2NAM/TO-A
5.数字量电磁驱动器  2835477 PI-EX-ME-SD/24/65-C 2835752 PI-EX-ME-2SD/24/65-C 2835668 PI-EX-ME-SD-24/60-S
6.温度测量变送器  2835794 PI-EX-ME-RTD-I 2864587 MCR-FL-TS-LP-I-EX 2864574 MCR-FL-T-LP-I-EX 2864532 MCR-FL-HT-T-I-EX 2835707 PI-EX-ME-THC-I 2864587 MCR-FL-TS-LP-I-EX 2864574 MCR-FL-T-LP-I-EX 2864532 MCR-FL-HT-T-I-EX 2832551 FL HUB 8TX-ZF 2832564 FL HUB 16TX-ZF 2832810 FL SWITCH 4TX/FX 2832085 FL SWITCH 5TX 2832218 FL SWITCH 8TX 2832593 FL SWITCH SF 14TX/2FX 2832661 FL SWITCH SF 15TX/FX 2832726 FL SWITCH SF 7TX/FX 2832771 FL SWITCH SF 8TX 2832849 FL SWITCH SF 16TX 2832933 FL SWITCH SF 6TX/2FX 2832577 FL SWITCH SF 7TX/FX ST 2832603 FL SWITCH SF 4TX/3FX ST 2832674 FL SWITCH SF 6TX/2FX ST
2.模块化控制开关  2832328 FL SWITCH MM HS 2832331 FL MXT 2832522 FL SWITCH MM HS/M 2832535 FL MXT/M 2832344 FL IF 2TX VS-RJ-F 2832357 FL IF 2TX VS-RJ-D 2832742 FL IF 2HCS 100-D 2832852 FL IF 2POF 10/100-D 2832412 FL IF 2FX SC-F 2832425 FL IF 2FX SC-D 2832205 FL IF 2FX SM SC-D 2884033 FL IF 2FX ST-D 2832739 FL IF TX/HCS 100-D 2832807 FL IF TX/POF 10/100-D 2832470 FL CB IF 2832483 FL IF MEM 2TX-D 2832904 FL IF 2PSE-F Order No. Type Description
3.控制转换开关  2832700 FL SWITCH MCS 16TX 2832713 FL SWITCH MCS 14TX/2FX 4.PROFINET INTERBUS 代理服务器  2832111 FL PN/IBS
5.网关   2744490 FL COM SERVER RS232 2708740 FL COM SERVER RS485 2313041 FL COM SERVER RS232 PRO 2313054 FL COM SERVER RS485 PRO 2831060 FL IBS SC/I-T 2862327 FL IL 24 BK-B-PAC 2862314 FL IL 24 BK-PAC 2878816 FL IL 24 BK-PN-PAC 2863986 FL IL 24 BK ETH/IP-PAC
6.控制软件  2831044 FL SWT 2832166 FL SNMP OPC SERVER 2832179 FL OPC SNMP AGENT
7.媒体转换器   2708193 FL MC 10/100BASE-T/FO-660 2744513 FL MC 10BASE-T/FO POF 2744788 FL MC 10BASE-T/FO G850 2708164 FL MC 10/100BASE-T/FO G1300 2708986 FL MC 10/100 BASE-T/FO G1300ST 2708177 FL MC 10/100BASE-T/FO G1300 SM
8.SFN开关   2891851 FL SWITCH SFN 4TX/FX 2891453 FL SWITCH SFN 4TX/FX ST 2891152 FL SWITCH SFN 5TX 2891929 FL SWITCH SFN 8TX Order No. Type Description
9.电缆及附件  2832250 FL CAT5 PATCH 0,3 2832263 FL CAT5 PATCH 0,5 2832276 FL CAT5 PATCH 1,0 2832221 FL CAT5 PATCH 1,5 2832289 FL CAT5 PATCH 2,0 2832292 FL CAT5 PATCH 3,0 2832580 FL CAT5 PATCH 5,0 2832616 FL CAT5 PATCH 7,5 2832629 FL CAT5 PATCH 10,0 2744814 FL CAT5 HEAVY 2744827 FL CAT5 HEAVY CONF/ 2744830 FL CAT5 FLEX 2744843 FL CAT5 FLEX CONF/ 2744856 FL PLUG RJ45 GR/2 2744571 FL PLUG RJ45 GN/2 2744869 FL CRIMPTOOL 2744610 FL CAT5 TERMINAL BOX 2832991 FL RJ45 PROTECT CAP 2832496 FL PBX 8TX 2832506 FL PBX 6TX/4FX 2832865 FL SEC PAC 4TX 2832687 FL PF SEC 2TX 2832690 FL PF SEC 8TX 2891165 FL PF 2TX CAT5E 2891068 FL PF 2TX CAT 6 2891071 FL PF 8TX CAT 6 2891178 FL PF 8TX CAT5E
1.可组态三端隔离放大器  2864383 MINI MCR-SL-UI-UI 2864710 MINI MCR-SL-UI-UI-SP 2864150 MINI MCR-SL-UI-UI-NC 2864163 MINI MCR-SL-UI-UI-SP-NC 2865007 MINI MCR-SL-U-UI-NC 2810078 MINI MCR-SL-U-UI-SP-NC
2.标准三端隔离放大器  2864406 MINI MCR-SL-I-I 2864723 MINI MCR-SL-I-I-SP 2864684 MINI MCR-SL-U-U 2864697 MINI MCR-SL-U-U-SP 2813512 MINI MCR-SL-U-I-0 2813570 MINI MCR-SL-U-I-0-SP 2813525 MINI MCR-SL-U-I-4 2813583 MINI MCR-SL-U-I-4-SP 2813541 MINI MCR-SL-I-U-0 2813554 MINI MCR-SL-I-U-0-SP 2813538 MINI MCR-SL-I-U-4 2813567 MINI MCR-SL-I-U-4-SP
3.可组态信号倍增器  2864794 MINI MCR-SL-UI-2I 2864804 MINI MCR-SL-UI-2I-SP 2864176 MINI MCR-SL-UI-2I-NC 2864189 MINI MCR-SL-UI-2I-SP-NC
.馈电隔离器  2864422 MINI MCR-SL-RPS-I-I 2864752 MINI MCR-SL-RPS-I-I-SP
5./双通道无源隔离器  2864419 MINI MCR-SL-1CP-I-I 2864749 MINI MCR-SL-1CP-I-I-SP 2864655 MINI MCR-SL-2CP-I-I 2864781 MINI MCR-SL-2CP-I-I-SP
二、可组态温度测量变送器
1.可组态温度测量变送器(PT100  2864435 MINI MCR-SL-PT100-UI 2864736 MINI MCR-SL-PT100-UI-SP 2864273 MINI MCR-SL-PT100-UI-NC 2864286 MINI MCR-SL-PT100-UI-SP-NC 2864309 MINI MCR-SL-PT100-UI-200 2864192 MINI MCR-SL-PT100-UI-200-SP 2864370 MINI MCR-SL-PT100-UI-200-NC 2864202 MINI MCR-SL-PT100-UI-200-SP-NC
2.可组态温度测量变送器(JK  2864448 MINI MCR-SL-TC-UI 2864299 MINI MCR-SL-TC-UI-NC
三、信号转换器  2864095 MINI MCR-SL-R-UI 2810256 MINI MCR-SL-R-UI-SP
四、监测器
1.频率变送器  2864082 MINI MCR-SL-UI-F 2810243 MINI MCR-SL-UI-F-SP
2.可组态阈值开关  2864480 MINI MCR-SL-UI-REL 2864493 MINI MCR-SL-UI-REL-SP
3.Namur开关放大器  2864105 MINI MCR-SL-NAM-2RNO 2810269 MINI MCR-SL-NAM-2RNO-SP MINI-PS-100-240AC/ 5DC/3 MINI-PS-100-240AC/10-15DC/2 MINI-PS-100-240AC/10-15DC/8 MINI-PS-100-240AC/24DC/1 MINI-PS-100-240AC/24DC/2 MINI-PS-100-240AC/24DC/4 MINI-PS-100-240AC/2X15DC/1 MINI-SYS-PS-100-240AC/24DC/1.5 MKDS 1,5/ 2 PLC-OSC-24DC/24DC/2 EBR40 PLC-RSC-12DC/21 PLC-RSC-230UC/21
  • 电话:021-60546683
  • 传真:33250371
  • email:2209858823@qq.com
工控宝APP下载安装
