STT130GK12B
2012/3/22 19:53:42
0 人气:9
- 型号:STT130GK12B
- 数量:333
- 制造商:法国
- 有效期:2018/4/6 0:00:00
STT130GK12B“一触即发”。但是,如果阳极或控制极外加的是反向电压,晶闸管就不能导通。
控制极的作用是通过外加正向触发脉冲使晶闸管导通,
却不能使它关断。那么,用什么方法才能使导通的晶闸管关断呢?使导通的晶闸管关断,
可以断开阳极电源(图3中的开关S)或使阳极电流小于维持导通的最小值(称为维持电流)。
如果晶闸管阳极和阴极之间外加的是交流电压或脉动直流电压,那么,在电压过零时,
晶闸管会自行关断。
编辑本段怎样测试晶闸管的好坏
法国可控硅
STT49GK16
STT49GK12
STT49GK08
STT27GK18
STT27GK16
STT27GK12
STT27GK08
STT18GK18
STT18GK16
STT18GK12
STT18GK08
STT800GK18B
STT800GK16B
STT800GK12B
STT800GK08B
STT500GK18B
STT500GK16B
STT500GK12B
STT500GK08B
STT430GK18B
STT430GK16B
STT430GK12B
STT430GK08B
STT320GK18B
STT320GK16B
STT320GK12B
STT320GK08B
STT250GK18B
STT250GK16B
STT250GK12B
STT250GK08B
STT200GK18B
STT200GK16B
STT200GK12B
STT200GK08B
STT181GK18B
STT181GK16B
STT181GK12B
STT181GK08B
STT165GK18B
STT165GK16B
STT165GK12B
STT165GK08B
STT130GK18B
STT130GK16B
STT130GK12B
三菱IPM
PM30RSF060
PM75RSD060
PM30RMC060
PM75RSE060
PM30RHC060
PM100RLA060
PM50RHB060
PM150RLA060
PM50RSK060
PM100RSA060
PM75RSK060
PM100RVA060
PM50VHA060
PM100RRS060
PM50RSA060
PM100RSD060
PM50RLB060
PM100RSE060
PM50RSD060
PM300RSD060
PM150RSA060
PM150RVA060
PM50RSE060
PM150RSD060
PM50RHA060
PM150RSE060
PM75RLB060
PM200RSD060
PM75VHA060
PM200RSE060
PM75RSA060
PM75RVA060
PM75RRA060
PM300RSE060
PM75RHA060
PM150RRA060
PM75RLA060
PM200RRA060
PM75BWA060
PM200RLA060
PM75EHS060
PM900HSA060
PM100EHS060
PM800HSA060
PM600HVA200
PM600HHA060
PM100DHA060
PM300DHA060
PM400DSA060
PM400DVA060
PM100DKA060
PM600DVA060
PM150DKA060
PM400DHA060
PM150DHA060
PM600DSA060S
PM200DSA060
PM200DHA060
PM200DKA060
PM300DSA060
PM10CSJ060
PM15CSJ060
PM75CSD060
PM20CSJ060
PM75CSE060
PM30CSJ060
PM20CTM060
PM100CSA060
PM100CVA060
PM15CTM060
PM100CSD060
PM20CTM060-3
PM100CSE060
PM150CSA060
PM150CVA060
PM20CEF060-5
PM150BVA060
三菱2单元IGBT
CM50DY-12H
CM50DY-12E
CM50E3Y-12E
CM50E3U-12E
CM75DY-12H
CM75DY-12E
CM75DU-12H
CM75DU-12E
CM75E3Y-12E
CM75E3U-12E
CM100DY-12H
CM100DY-12E
CM100DU-12H
CM100DU-12E
CM100E3Y-12E
CM100E3U-12E
CM150DY-12H
CM150DY-12E
CM150DU-12H
CM150DU-12E
CM150E3Y-12E
CM150E3U-12E
CM200DY-12H
CM200DY-12E
CM200DU-12H
CM200DU-12E
CM200E3Y-12E
CM200E3U-12E
CM300DY-12H
CM300DY-12E
CM300DU-12H
CM300DU-12E
CM300E3Y-12E
CM300E3U-12E
CM400DY-12H
CM75DY-28H
CM400DY-12H
CM400DY-12E
CM400DU-12H
CM400DU-12E
CM400DY1-12E
CM600DY-12NF
CM350DU-5F
CM400DU-5F
CM600DU-5F
CM110YE4-12F/
CM150YE4-12F
CM165YE4-12F
CM200YE4-12F
CM300YE2N-12F
CM300YE2P-12F
CM400YE2P-12F
CM400YE2N-12F
CM600YE2N-12F
CM600YE2P-12F
CM50DY-24H/
CM50DY-24E
CM50DU-24H
CM50DU-24E
艾赛斯可控硅
MCD312-16io1.
MCD312-18io1
MCD500-12io1
MCD500-14io1
MCD500-16io1
MCD500-18io1
MCD500-22io1
MCD501-12io1
MCD501-16io1
MCD501-18io1
MCD501-22io1
MCD700-12io1W
MCD700-16io1W
MCD700-18io1W
供应全新原装IXYS二极管模块
供应全新原装IXYS二极管模块
MDA72-08N1B
MDA72-14N1B
MDA72-16N1B
MDD26-08N1B
MDD26-12N1B
MDD26-14N1B
MDD26-16N1B
MDD26-18N1B
MDD44-08N1B
MDD44-12N1B
MDD44-14N1B
MDD44-16N1B
MDD44-18N1B
MDD56-08N1B
MDD56-12N1B
MDD56-14N1B
MDD56-16N1B
MDD56-18N1B
MDD72-08N1B
MDD72-12N1B
MDD72-14N1B
MDD72-16N1B
MDD72-18N1B
MDD95-08N1B
MDD95-12N1B
- 电话:0512-86887767
- 传真:0512-82092168
- email:linyiling888@126.com手机:18962681747
上一篇:STT130GK16B
下一篇:STT130GK08B
工控宝APP下载安装
