- 型号:涡轮流量计(HM)
- 数量:/
- 有效期:2050/4/12 0:00:00
涡轮流量计(HM)
燃料,轻质燃料,热燃料,化工溶液,自来水和去离子水等的
流量测量特殊型号可以测量制冷剂。
测量范围从 0.03 到 48,000 l/min.
标准型粘度范围 0.5 - 100 mm2/s
Turbine Flow Meters (HM)
Turbine Flow Meter with Flange Ends (HM-F)
Turbine Flow Meters with Female Inch Threads (HM-R)
Turbine Flow Meters with Ermeto Fittings (HM-E)
Turbine Flow Meters for Pharmaceutical Applications (HM-FT)
Turbine Flow Meter for Solvents and DI-Water (HM-TCR)
Turbine Flow Meters for High Pressure Applications (HM-HP)
Turbine Flow Meters for Temperature Control Units (HM-P)
Aluminium Turbine Flow Meters (HM-U)
- 电话:021-64849352-803
- 传真:021-64827259
- email:2680241089@qq.com
更多内容请访问 wangmengmeng88(http://home.gongkong.com/profile/?uid=2011113011294400001)
下一篇:德国KEM 浊度计(KPS)
