- 型号:BXK
- 数量:按客户的需求销售
- 制造商:顺新防爆
- 有效期:2020/12/31 0:00:00
【防爆控制箱】//【防爆控制箱】//【防爆控制箱】
顺新防爆是专业生产防爆控制箱的防爆厂家,本公司拥有专业的设计研发团队,对防爆控制箱已经有三年多的研发历史,先阶段顺新防爆可以设计出满足市场任何需要的防爆控制箱,欢迎广大客户前来本公司商榷我们将竭诚为您服务。
防爆控制箱一般为复合型结构,外壳采用增 ■The control box is flame-proof structure of formed up of shell and flame-proof or
安型结构,内装元件采用隔爆型元件或增安 safety-increased components,the shell is of safety-increased structure which
型的元件,或一个隔爆型主腔内装各种元件; adopts diecasted AiI-alloy with plastic-sprayed surface.Inside is installed
或两种结构结合成一体;外壳采用采用高强 flame-proof control switch,control button,explosion-proof signal lamp and
度铸铝合金制成,外表面静电喷塑,内装的元 instrument for overload,The inward components cnbe freely aranged to perform
件有按钮,控制开关,仪表,继电器或各种功 multi functions.Control switches have several specifications to select,signal
能模块,其中按钮控制开关,电流表和电压 lamps are classified as Red ,Green Yellow and White,and the istrument includes
表,指示灯均为防爆元件,控制箱内部元件 ammeter,voltmeter,temperature controller,rotary speed indicator.The mode of
功能,控制开关有多种功能可供选择.指示 inlet or outlet is flexible to be selected as required and locately or remotely
可根据用户的要求进行排列,可实现多种 controlling is available.
灯也有多种颜色可供选择,由于该产品变
化多端订货时请提供线路图.
※符合GB3836-2000,IEC60079标准要求 ※ Suitable for GB3836-2000.IEC60079 standard request.
主要技术参数不清Main technical parameters |
使用类别 额定电压(V) 额定电流 (A) 防护等级 防爆标志 防腐等级 进线口螺纹及电缆外径(¢,mm) Usage Rated voltage Rated current Protection grade Ex-mark Corrosion Inlet thread and cable outer proof grade diameter Exd II Bt6 AC-3 220 Ip54 Exde II Bt6 WF1 G3/4" Φ10-Φ26 AC-4 380 10 *Ip65 Exde II Ct6 |
- 电话:0577-62618206
- 传真:0577-62618387
- email:1464380266@qq.com
