- 型号:防爆检修箱BXX51|防爆动力检修箱BXX51
- 数量:999
- 制造商:浙江环泰防爆电气有限公司
- 有效期:2020/4/30 0:00:00
防爆检修箱BXX51|防爆动力检修箱BXX51|移动式防爆检修箱|防爆动力检修箱BXX-2/100XDG|防爆动力检修箱BXX-4/100XDM|防爆动力检修配电箱|不锈钢防爆动力检修箱 0577-27855807 13567765864
您好!环泰防爆电器有限公司专业生产批发防爆灯具,防爆电器,质量可靠,价格合理。如贵公司需要我公司产品请联系我。如有打搅,请见谅!顺祝您生意红红火火!
How do you do! The new explosion-proof electric appliance Co., LTD is specialized in the production wholesale explosion-proof lamps, explosion-proof electric appliance, the quality is reliable, the price is reasonable. If you need my company products please contact me. If there is disturbed, please forgive me! The wish you the business prosperous!
一、防爆检修箱BXX51|防爆动力检修箱BXX51|移动式防爆检修箱|防爆动力检修箱BXX-2/100XDG|防爆动力检修箱BXX-4/100XDM|防爆动力检修配电箱|不锈钢防爆动力检修箱适用范围:
A, suitable for:
1、1区、2区危险场所
1, 1 division, 2 division dangerous places
2、ⅡA、ⅡB、ⅡC类爆炸性气体环境。*要求ⅡC类时请注明。
2, ⅡA, ⅡB, ⅡC explosive gases. * required ⅡC class, please make a note.
二、防爆检修箱BXX51|防爆动力检修箱BXX51|移动式防爆检修箱|防爆动力检修箱BXX-2/100XDG|防爆动力检修箱BXX-4/100XDM|防爆动力检修配电箱|不锈钢防爆动力检修箱产品特点:
The product features:
1、铸铝合金外壳或钢板焊接而成,表面高压静电喷塑;
1, diecasted al-alloy shell or steel welding and become, the surface high-pressure electrostatic pensu;
2、主腔内装塑壳式断路器;
2 and the Lord cavity molded case circuit breaker with type;
3、不锈钢外露紧固件;
3, stainless steel fasteners exposed;
4、电缆或钢管布线均可;
4, cable or steel pipe wiring;
5、符合GB3836-2000,IEC60079标准要求。
5, accord with GB3836-2000, IEC60079 standard requirements.
三、防爆检修箱BXX51|防爆动力检修箱BXX51|移动式防爆检修箱|防爆动力检修箱BXX-2/100XDG|防爆动力检修箱BXX-4/100XDM|防爆动力检修配电箱|不锈钢防爆动力检修箱主要技术参数:
Three, main technical parameters:
1、防爆标志:ExdeⅡBT4、*ExdeⅡCT4
1, explosion-proof sign: Exde ⅡBT4, * Exde ⅡCT4
2、防护等级:IP55、*IP65
2, the protective level: IP55, * IP65
3、防腐等级:WF1
3, the anti-corrosion class: WF1
4、额定电压:AC380V
4, rated voltage: AC380V
5、支回路:最大电流100A
5, A loop: maximum current 100 A
6、进线口螺纹:G2”~G3”
6, the inlet thread: G2 "~ G3"
7、出线口螺纹:G1 1/2”
7, outlet thread: G1 1/2"
在您购买我公司防爆产品前请与我公司销售人员联系,了解清楚防爆产品的技术参数。由于此种产品的型号繁多,在购买前一定要确认好型号。如有问题欢迎来电咨询,敬期与您的合作!
Buy in you my company flameproof products with me before you sales people to contact, understand the technical parameters of explosion protection products. Because this product type is various, before buy must confirm good model. Welcome to inquire if there is a problem, and issue the cooperation with you!
环泰防爆主营产品:
The new explosion-proof product information:
防爆电器类:防爆空调,防爆除湿机,防爆电铃,防爆插接装置,防爆插销,防爆镇流器,防爆变压器,防爆轴流屋顶风机,防爆壁式排风扇,防爆轴流风机,防爆吊风扇,防爆变频调速箱,防爆软起动器,防爆自耦减压电磁起动箱,防爆综合电磁起动器,防爆电磁起动器,防爆控制按钮,防爆行程开关,防爆转换开关,防爆照明开关,防爆断路器,防爆控制箱,防爆配电柜,防爆检修电源插座箱,防爆动力电磁启动配电箱,防爆照明动力配电箱,防爆检修箱,防爆操作柱。防爆检修箱BXX51|防爆动力检修箱BXX51|移动式防爆检修箱|防爆动力检修箱BXX-2/100XDG|防爆动力检修箱BXX-4/100XDM|防爆动力检修配电箱|不锈钢防爆动力检修箱
Explosion-proof electric appliance class: explosion-proof air conditioning, explosion-proof dehumidifier, explosion-proof bells, explosion-proof plug-and-socket device, explosive bolt, explosion-proof ballast, explosion-proof transformer, explosion-proof axial flow fan roof, explosion-proof mural type ventilator, explosion-proof axial flow fan, explosion-proof hang fan, explosion-proof variable frequency speed control box, explosion-proof soft starter, explosion-proof autoformer decompression electromagnetic starter box, explosion-proof comprehensive electromagnetic starter, explosion-proof electromagnetic starter, explosion-proof control button, explosion-proof travel switch, explosion-proof converted, explosion proof lighting switch, explosion-proof circuit breaker, explosion-proof control box, explosion-proof distribution cabinets, explosion-proof maintenance power outlet box, explosion-proof power distribution box electromagnetic actuators, explosion proof lighting power distribution box, explosion-proof overhaul box, explosion-proof operation column.
防爆全塑类:防爆防腐电表,防爆防腐接线箱,防爆防腐电源插座箱,防爆防腐插接装置,防爆防腐断路器,防爆防腐照明动力配电箱,防爆防腐转换开关,防爆防腐照明开关,防爆防腐主令控制器,防爆防腐控制箱,防爆防腐操作柱。防爆检修箱BXX51|防爆动力检修箱BXX51|移动式防爆检修箱|防爆动力检修箱BXX-2/100XDG|防爆动力检修箱BXX-4/100XDM|防爆动力检修配电箱|不锈钢防爆动力检修箱
Explosion-proof product categories: explosion-proof electric meter anticorrosive, explosion-proof anticorrosive junction boxes, explosion-proof anticorrosive power outlet box, explosion-proof anticorrosive plug-and-socket device, explosion-proof anticorrosive circuit breaker, explosion-proof anticorrosive lighting power distribution box, explosion-proof anticorrosive converted, explosion-proof anticorrosive lighting switch, explosion-proof anticorrosive Lord command controller, explosion-proof corrosion control box, explosion-proof anti-corrosion operation column.
- 电话:0577-61733623
- 传真:0577-61725753
- email:2358920547@qq.com
