BLACK BOX延长器ACS4004A-R2
2012/6/4 10:30:21
0 人气:6
- 数量:90
- 有效期:2019/6/19 0:00:00
产品名称:BLACK BOX延长器ACS4004A-R2
型号:ACS4004A-R2
品牌:BLACK BOX
BLACK BOX切换器ACS4004A-R2;BLACK BOX延长器ACS4004A-R2;BLACK BOX KVM延长器;ACS4004A-R2
ServSwitch? DVI-D Extender USB HID
Extend high resolution DVI video plus USB up to 125 metres from your PC
Superior digital video at 1920 x 1200 over 125-m.
Options for single/dual & quad video and USB 2.0 peripherals.
DDC emulation or DDC read from monitor supported.
Compatible with all O/Ss and many KVM switches.
19" rack mount and DIN-Rail mounting kits available.
Warranty — 2 Years.
规格:
Maximum Resolution - 1920 x 1200 @60 Hz; 1280 x 1024@ 75Hz; 24 bit colour depth
Maximum Distance - 125m for CAT5, CAT5e CAT6 or CAT7 with AWG24; 60m with AWG26
Connectors -
Local units:
ACS4001A-R2/ACS4004A-R2 (2) DVI-I F, (2) USB Type B (K/M), (1) RJ-45 (link), (1) barrel (power);
ACS4022A-R2 same as ACS4001A-R2 but also has (1) DB9 M (RS-232 19.20Kbps, 6 lines), (2) 3.5mm audio jacks;
ACS4002A-R2/ACS4201A-R2 (2) DVI-I F, (2) USB Type B F (K/M + USB 2.0), (2) RJ-45 (link), (1) barrel (power);
ACS4222A-R2 like ACS4201A-R2 but also has (1) MiniDIN 8-pin M (RS-232 19.2Kbps, RX/TX/SGnD with no handshake and audio);
ACS4204A-R2 (4) DVI-I F, (2) USB Type B F (K/M), (2) RJ-45 (link), (1) barrel (power)
ACS4422A-R2 (4) DVI-I F in, (4) DVI-I F out, (1) USB Type B F (in), (1) MiniDIN8 (RS-232 and audio in), (1) MiniDIN6 (K/M via Y-cable out), (5) RJ-45 (link), (1) IEC320 (power)
Remote Units:
ACS4001A-R2 (1) DVI-I F, (2) USB Type A F HID, (1) RJ-45 (link), (1) barrel (power);
ACS4022A-R2 like ACS4001A-R2 but also has (1) DB9 M (RS-232 up to 19.2Kbps), (2) 3.5mm audio jacks;
ACS4002A-R2 (1) DVI-I F, (2) USB Type A F HID, (4) USB Type A F USB 2.0, (2) RJ-45 (link), (1) barrel (power);
ACS4004A-R2 (1) DVI-I F, (4) USB Type A F HID, (1) USB Type B F programmable, (1) RJ-45 (link), (1) barrel (power);
ACS4201A-R2 (2) DVI-I F, (2) USB Type A F HID, (2) RJ-45 (link), (1) barrel (power);
ACS4222A-R2 like ACS4201A-R2 but also has (1) DB9 M (RS-232 19.2Kbps, RX/TX/SgnD with no handshake), (2) 3.5mm audio jacks;
ACS4204A-R2 (2) DVI-I F, (4) USB Type A F HID, (1) USB Type A F programmable, (2) RJ-45 (link), (1) barrel (power);
ACS4422A-R2 (4) DVI-I F, (2) USB Type A F, (2) MiniDIN6 (K/M), (2) 3.5mm audio jacks, (1) DB9 M (RS-232/RX/TX/SGnD), (4) LC (link), (1) IEC320;
ACS4442A-R2 (4) DVI-I F, (2) USB Type A F (HID), (4) USB Type (USB 2.0), (2) MiniDIN6 (K/M), (2) 3.5mm audio jacks, (1) DB9 M (RS-232/TX/RX/SGnD), (5) RJ-45 (link), (1) IEC320 (power)
Power - all ACS40xxA-R2/ACS42xxA-R2 remote units: 90-240VAC, 47-63Hz, auto sensing, external, with IEC320 connector and cord;
ACS44x2A-R2 remote and local: 90-240VAC, 47-63Hz ,auto sensing, internal
Dimensions - ACS4001A-R2: 2.9(H) x 10.3(W) x 14.3(D) cm;
ACS4022A-R2/ACS4002A-R2/ACS4004A-R2/ACS4201A-R2 and ACS4222A-R2: 4.3(H) x 10.3(W) x 14.3(D) cm;
ACS44x2A-R2: 4.3(H) x 41.2(W) x 14.3(D) cm
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
上一篇:Arra衰减器F4674-30
工控宝APP下载安装
