- 数量:90
- 有效期:2019/6/27 0:00:00
产品名称:BLACK BOX KVM延长器ACUMREM
型号:ACUMREM
品牌:BLACK BOX
BLACK BOX切换器ACUMREM;BLACK BOX延长器ACUMREM;BLACK BOX KVM延长器;ACUMREM
Rackmount CAT5 KVM Extender Hubs
KVM extensions up to 300 metres - plus dual-access, remote switching, and skew compensation!
These hubs combine multiple extenders. It's like getting 6 or 12 units in one box! They'll save you money and space.
Put your keyboard, monitor and mouse up to 300 m from a CPU or ServSwitch?. Or, if you need extensions over a shorter distance 50-m, choose our ACUMREM.
The Dual-Access Hub (ACU1006DRA) enables you to attach a local and remote KCM console to each server.
To add switching capabilities at a remote station, order the ACUREMSW remote unit.
Fully adjustable video equalisation including DeSkew for the best possible video quality.
Multi-head video remote units also available.
规格:
Clamping Voltage - Up to 15 volts
Compatibility - Keyboard: PC/AT?, PS/2?;
Monitor: VGA, Super VGA, XGA?;
Mouse: PS/2 mouse only (user)
Resolution (Maximum) -
ACUREM, ACUREMSW:
1600 x 1280: 60-m;
1280 x 1024: 90-m;
1024 x 768: 300 m;
ACUMREM: 1280 x 1024: 50-m;
ACUR001A-2A, 4A: 1600 x 1200: 200-m
Connectors -
ACU1006RA, ACU1012RA: Interconnect: (6) or (12) RJ-45;
CPU: (6) or (12) DB25 F;
ACU1006DRA: Interconnect: (6) RJ-45;
CPU: (6) DB25 F;
Keyboard and mouse: (12) 6-pin mini DIN F;
Monitor: (6) HD15 F;
ACUR001A: (1) HD15 F, (2) 6-pin mini DIN F, (1) RJ-45, (2) 3.5-mm jack F, (1) DB9 M
ACUR002A: (2) HD15 F, (2) 6-pin mini DIN F, (2) RJ-45;
ACUR004A: (4) HD15 F, (4) RJ-45 F, (2) 6-pin mini DIN F
ACUREM, ACUMREM:
Interconnect: (1) RJ-45;
Keyboard and mouse: (2) 6-pin mini DIN F;
Monitor: (1) HD15 F;
ACUREMSW: Interconnect: (1) RJ-45;
Switch: (1) DB25 F;
Power — Hubs: 100-240 VAC, 50-60 Hz, external, autosensing, with IEC connector and power cord;
Remote Units: External power supply unit 100-240 VAC, autosensing (included)
Dimensions -
ACU1006RA, ACU1012RA, ACU1006DRA, ACU1006MRA: 4.4(H) x 48.3(W) x 11.4(D) cm;
ACUREM, ACUREMSW: 3.6(H) x 17.8(W) x 9.9(D) cm;
ACUMREM: 3.8(H) x 7.9(W) x 10.9(D) cm;
ACUR001A-02A: 2.9(H) x 14(W) x 14.5(D) cm;
ACUR004A: 2.9(H) x 27.4(W) x 14.5(D) cm
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
上一篇:连接线、端子线束、线束连接线检测
