JFW同轴开关50S-1463
2012/6/14 10:00:10
0 人气:8
- 数量:90
- 有效期:2019/6/29 0:00:00
产品名称:JFW同轴开关50S-1463
型号:50S-1463
频率范围:10-1000 MHz
构造:1P2T
阻抗:50 Ohms nominal
驻波比:1.4:1 maximum
插入损耗:0.50 dB maximum (10-500 MHz)
0.75 dB maximum (500-1000 MHz)
隔离度:50 dB minimum (10-500 MHz)
40 dB minimum (500-1000 MHz)
开关速度:40 microseconds
(50% TTL to 10% or 90% RF)
输入功率:30 Watts average Cold switch
30 Watts average Hot switch
控制电压 :TTL "Low" Common to J1
TTL "High" Common to J2
直流供电:+15 Vdc @ 250 mA
and
+5 Vdc @ 40 mA
射频连接器形式: BNC, SMA, TNC or N female
工作温度:-20℃ to +70℃
存储温度:-55℃ to +85℃
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
下一篇:K&L腔体滤波器
相关推荐
工控宝APP下载安装
