BLACK BOX延长器KV1401A
2012/6/15 10:11:49
0 人气:17
- 数量:900
- 有效期:2019/6/30 0:00:00
产品名称:BLACK BOX延长器KV1401A
型号:KV1401A
品牌:BLACK BOX
BLACK BOX切换器KV1401A;BLACK BOX延长器KV1401A;BLACK BOX KVM延长器;KV1401A
ServSwitch? CATmix KVM Extender
Compact and cost effective KVM extension over CATx
Small form factor.
Easy video fine tuning over keyboard hotkeys.
Uni-directional and DeSkew options.
Choose between PS/2 single and USB dual receivers.
Place server up to 50-m away from the switch.
Flash upgradable.
Order one unit for each server-to-switch connection.
规格:
Receivers:
Dimensions -
All PS/2 Receivers: 2.5(H) x 7.5(W) x 12.5(D) cm
All USB Receivers: 2.6(H) x 7.5(W) x 17(D) cm
Interface -
KV04-REM: (1) RJ-45F, (1) HD15F, (2) 6-pin MiniDin F;
KV04A-REM, KV04AS-REM: (1) 3.5-mm audio, (1) 2.1-mm power F 5-VDC;
KV04U-REM: (2) RJ-45F, (1) HD15F, (2) USB Type A;
KV04AU-REM, KV04AUS-REM: (1) 3.5-mm audio, (1) 2.1-mm power F 5-VDC
SAMs:
Dimensions 2.5(H) x 4.5(W) x 6.5(D) cm with attached 30-cm pigtail cable for KVM(A)
Weight - Without Audio:100g;
With Audio:150g
Interface - All: (1) RJ-45F, (1) HD15M
KV1400A, KV1402A also: (2) 6-pin MiniDin M;
KV1401A, KV1403A also: (1) USB Type A;
KV1402A, KV1403A also: (1) 3.5-mm audio
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
工控宝APP下载安装
