- 数量:90
- 有效期:2019/6/30 0:00:00
产品名称:JFW功分器50PD-660
型号:50PD-660
类型:4-way
频率范围:700-3000 MHz
阻抗:50 Ohms nominal
驻波比:1.5:1 maximum
插入损耗(above 6 dB split):1.2 dB maximum
0.21 dB typical @ 700 MHz
0.65 dB typical @ 3000 MHz
隔离度:18 dB minimum
> 20 dB typical
振幅跟踪:± 0.7 dB maximum
< 0.1 dB typical @ 3000 MHZ
相位跟踪:± 8o maximum
< 3°typical @ 3000 MHz
配输入功率:5 Watts average (divider)
1 Watts average (combiner)
连接器形式:SMA female
工作温度:-40℃ to +85℃
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
更多内容请访问 ouqiao2012(http://home.gongkong.com/profile/?uid=2012032613133600001)
相关推荐
