Agilent频谱分析仪8595E
2012/6/18 9:51:12
0 人气:4
- 数量:900
- 有效期:2019/7/3 0:00:00
产品名称:Agilent频谱分析仪8595E
品牌:Agilent
型号:8595E
性能
输入阻抗:50Ω
最低频率:9KHz
最高频率:6.5 GHz
零跨度:YES
最小跨度:10KHz
最大跨度:6.5GHz
最小扫描时间:20ms
最大扫描时间:100s
最小分辨率带宽1 kHz时
最大分辨率带宽:3MHz
分辨率带宽步骤:1/3/10
最小的视频带宽:1 Hz
最大视频带宽:1 MHz
视频带宽步骤:1/3/10
最小的单边带噪声为:-105 dBc / Hz
最大单边带噪声:-90 dBc / Hz
最高安全AC输入:1 dBm
最大直流输入向:0 V
最小显示的平均噪声:-127 dBm
最大显示的平均噪声达:-110 dBm
最大振幅的不确定性:3%
触发源 :External,Internal
连接器类型(主信号):N型(F)
CAL输出连接器类型:BNC(F)
探头电源:YES
外部参考频率:10MHZ
噪声源驱动器:NO
描述
Agilent Technologies 8595E Portable Spectrum Analyzer, 9kHz to 6.5 GHz
The Agilent Technologies 8595E spectrum analyzer is a wide band, very sensitive receiver. It works on the principle of "super-heterodyne receiver" to convert higher frequencies (normally ranging up to several 10s of GHz) to measurable quantities. The received frequency spectrum is slowly swept through a range of pre-selected frequencies, converting the selected frequency to a measurable DC level (usually logarithmic scale), and displaying the same on the CRT of the Agilent Technologies 8595E. The CRT displays received signal strength (y-axis) against frequency ( x-axis).
Some applications for Agilent Technologies 8595E Spectrum Analyzers include Site Monitoring: Verify that the frequency and signal strength of your transmitter is accurate. Interference: Before a system is installed you use a Agilent Technologies 8595E spectrum analyzer to verify that the frequencies (you plan to use) are not occupied or if the presence of a very strong signal will interfere with your new setup. Interference can be created by a number of different situations. Other tests that utilize the Agilent Technologies 8595E spectrum analyzer features include antenna isolation, co-channel interference, adjacent channel power, occupied bandwidth, intermodulation, microwave or satellite antenna alignment, and characterization of components
Agilent 8595E是易于使用的RF频谱分析仪,它具有很宽的性能特性范围,可选符合您测量要求的能力。可下载的测量专用件与可选的插卡性能相结合,提供适合您应用的量身定制解决方案。
用支持各种应用,如有线电视/广播、元件测试、电磁兼容性、光波和无线应用的
测量专用件快捷地执行复杂的测试
4 槽的插卡槽
屏幕分割显示
单键测量例程
先进测量功能
双接口
内置迹线发生器
E4444A BenchLink 软件 E4444A BenchLink 软件
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
工控宝APP下载安装
