BLACK BOX KVM延长器ACS253A-U-SM
2012/6/28 11:04:48
0 人气:14
- 数量:90
- 有效期:2019/7/13 0:00:00
产品名称:BLACK BOX KVM延长器ACS253A-U-SM
型号:ACS253A-U-SM
品牌:BLACK BOX
BLACK BOX切换器ACS253A-U-SM;BLACK BOX延长器ACS253A-U-SM;BLACK BOX KVM延长器;ACS253A-U-SM
ServSwitch? DVI/VGA Fibre Extenders with USB
Extend DVI and VGA video over fibre—and control it all with a USB mouse and keyboard.
Combine VGA and DVI video in your KVM extension applications.
Include Type A connectors for your USB keyboards, mice and peripherals.
Multimode and single-mode versions available.
Remote units support up to four USB version 1.1 devices.
Access video equipment locally and remotely.
规格:
Chassis - Each Unit: Metal Case
Distance (maximum) - ACS253A-U-MM: 200-m with 62.5-/125-μm cable, 400-m with 50-/125-μm cable; ACS253A-U-SM: 10km with 9-/125-μm cable;
Operating Temperature - 10 to 45° C;
Operating Humidity - 80% non-condensing
Rackmount Kit - Optional ACS253A-RMK
Resolution (Maximum) - Monitor: VGA, DVI: 1600 x 1200 at 60Hz;
Local Access:
VGA: 1600 x 1200;
DVI: 1280 x 1024
Video Compatibility - Analogue: VGA to UXGA (separate sync, composite sync, or sync-on-green);
Digital: DVI
Connectors - Local Unit:
CPU: (1) USB Type A F;
Programming: (1) RJ-11;
Monitor: (1) DVI-I M;
Interconnect: (1) pair of SC;
Remote Unit:
USB ports: (4) USB Type A F, output to USB 1.1-compatible devices;
Keyboard and mouse: (2) USB Type A F;
Power - Both local and remote modules: 90-240VAC, 47-63 Hz, autosensing, external, with IEC 320 connector and power cord
Dimensions - 4.4(H) x 17(W) x 13.2(D) cm
Weight - Each Unit: 1 kg
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
下一篇:JFW功分器50PD-638
工控宝APP下载安装
