- 数量:100
- 有效期:2810/12/9 0:00:00
ORTEC核电子学仪器
广州莱捷电器有限公司
广州莱捷电器有限公司代理销售ORTEC核电子学仪器
产品描述:
ORTEC核电子学仪器种类齐全,性能稳定,为广大科研工作者提供了最广泛的选择,在国内外都以得到广泛应用。
PL Subsection Name Amplifiers | |
FTA820A | Octal Fast-Timing Amplifier (200 gain, non-inverting) |
427A | Delay Amplifier |
460 | Delay Line Amplifier (with standard 1-μs delay lines) |
474 | Timing Filter Amplifier |
533 | Dual Sum and Invert Amplifier |
570 | Spectroscopy Amplifier |
572A | Spectroscopy Amplifier |
575A | Spectroscopy Amplifier |
579 | Fast-Filter Amplifier |
590A | Amplifier and Timing SCA |
671 | Spectroscopy Amplifier |
672 | Spectroscopy Amplifier (with AUTO-PZ) |
673 | Spectroscopy Amplifier and Gated Integrator |
855 | Dual Spectroscopy Amplifier |
863 | Quad Timing Filter Amplifier |
9302 | Amplifier and Discriminator |
9327 | 1-GHz Amplifier and Timing Discriminator |
Counters, Timers, and Ratemeters | |
Model No. | Description |
449 | Log/Lin Ratemeter |
449-2 | Log/Lin Ratemeter with audible output option |
661 | Ratemeter |
871 | Timer and Counter (non-printing) |
974 | CCNIM Quad 100-MHz Counter/Timer |
994 | CCNIM Dual Counter and Timer (requires interface option for computer operation) |
995 | CCNIM Dual Counter (requires interface option for computer operation) |
996 | CCNIM Timer and Counter (requires interface option for computer operation) |
99X-1 | 994, 995, and 996 Options - RS-232-C Interface Option (requires C-75 Cable) |
99X-2 | 994, 995, and 996 Options - IEEE-488 Interface Option (requires C-488-2 or C-488-4 Cable) |
99X-4 | 994 and 995 Options - Internal +6 V Supply Option |
9349 | Log/Lin Ratemeter |
Delays, Gate and Delay Generators, Logic Modules, and Linear Gates | |
CO4020 | Quad 4-Input Logic Unit (requires 6 V) |
DB463 | Delay Box |
GG8020 | Octal Gate and Delay Generator (requires 6 V) |
414A | Fast Coincidence |
416A | Gate and Delay Generator |
418A | Universal Coincidence |
425A | Nanosecond Delay |
426 | Linear Gate |
542 | Linear Gate and Stretcher |
Fast-Timing Discriminators | |
CF8000 | Octal Constant-Fraction Discriminator |
CFD-DELAY-5NS | Delay Plug-in (CF8000 Options) |
CFD-DELAY-10NS | Delay Plug-in |
CFD-DELAY-30NS | Delay Plug-in |
CFD-DELAY-50NS | Delay Plug-in |
583B | Constant-Fraction Differential Discriminator/SCA (requires 6 V) |
584 | Constant-Fraction Discriminator |
935 | Quad 200-MHz Constant-Fraction Discriminator (requires 6 V) |
9307 | pico-TIMING Discriminator (requires 6 V) |
HV Bias/NIM Power Supplies and Bins | |
428 | Detector Bias Supply |
495 | Power Supply (6 V) |
556 | High-Voltage Power Supply (3 kV) |
556H | High-Voltage Power Supply (3 kV) |
659 | 5-kV Detector Bias Supply |
660 | Dual 5-kV Detector Bias Supply |
710 | Quad 1-kV Bias Supply |
4001A | NIM Bin |
4001A/4002A | NIM Bin and 96-W Power Supply (with ±12 V, ±24 V) |
4001A/4002D | NIM Bin and 160-W Power Supply (with ±6 V, ±12 V, ±24 V) |
4001C | NIM Bin (with copper bus bars) |
4001C/4002D | NIM Bin (with copper bus bars) and 160-W Power Supply (with ±6 V, ±12 V, ±24 V) |
4001C/4002E | NIM Bin (with copper bus bars) and BLACK MAX PS (with ±6 V, ±12 V, ±24 V) |
4002A | 96-W Power Supply for NIM Bin (with ±12 V, ±24 V) |
4002D | 160-W Power Supply for NIM Bin (with ±6 V, ±12 V, ±24 V) |
4002E | BLACK MAX Power Supply for NIM Bin (with ±6 V, ±12 V, ±24 V) |
4002P | Portable Power Supply (with ±12 V, ±24 V) |
4002P-C1 | Preamp Power Fan-Out Cable (for 4002P) |
4003 | Preamplifier Power Output |
4006 | Mini Bin and Power Supply |
NIM MCA/MCB,PCI Card MCA | |
919E | EtherNIM 4-Input Multichannel Buffer |
919-OPT1 | Pigtail Cable |
920E | EtherNIM 16-Input Multichannel Buffer |
920-16-OPT1 | Pigtail Cable |
921E | EtherNIM High-Rate Multichannel Buffer |
926 | 8k ADCAM Multichannel Buffer |
926-M32 | 8k ADCAM Multichannel Buffer with MAESTRO-32 Software |
926-USB | 8k ADCAM Multichannel Buffer with USB Interface |
926-M32-USB | 8k ADCAM Multichannel Buffer with USB Interface and MAESTRO-32 Software |
926-C-2 | Interface and Cable for NIM MCB - Printer Port Cable, male to female, 25 pin conductor; 2-ft length |
926-C-10 | Interface and Cable for NIM MCB - Printer Port Cable, male to female, 25 pin conductor; 10-ft length |
ASPEC-927 | Dual 16k Multichannel Buffer with MAESTRO-32 Software and 10-ft. USB Cable |
DPM-USB | Dual-Port Memory to USB Interface Converter, 15-ft. Cable |
918-OPTC5 | Dual-Port Memory Cable, 5-ft shielded ribbon cable |
C-DPM-10 | Dual-Port Memory Cable, 10-ft shielded ribbon cable |
918A-OPTB | PC-Bus Interface |
TRUMP-PCI-2K | 2k MCA PCI Plug-In Card with MAESTRO-32 Software |
TRUMP-PCI-8K | 8k MCA PCI Plug-In Card with MAESTRO-32 Software |
CAMAC ADCs and Memory | |
AD114 | CAMAC 16k ADC |
AD413A | CAMAC Quad 8k ADC |
CMC203 | CAMAC FERA Driver, Memory, and Histogrammer |
HM413 | CAMAC FERAbus Histogramming Memory |
C-ECLBUS | Cable Kit for FERAbus readout with Models AD114, AD413A, CMC203, and HM413 |
Multichannel Scalers and/or Multiple-Stop Time Spectrometers | |
MCS-PCI | Multichannel Scaler with A73-B32 software, documentation, and FullShot software |
MCS-PCI-OPT2 | Fan-Out Cable for MCS-PCI |
9353 | 100-ps Time Digitizer/MCS with 9353-B32 software |
9353-FANOUT | Fan-out Cable for the 9353 9-pin D Connector |
Pulse Generators | |
419 | Precision Pulse Generator |
480 | Pulser |
Special Instruments | |
439 | Digital Current Integrator |
Single-Channel Pulse-Height Analyzers | |
550A | Single-Channel Analyzer |
551 | Timing Single-Channel Analyzer |
552 | Pulse-Shape Analyzer/Timing SCA |
850 | Quad Single-Channel Analyzer (requires 6 V) |
Time-to-Amplitude Converters and Time Calibrator | |
462 | Time Calibrator |
566 | Time-to-Amplitude Converter |
567 | Time-to-Amplitude Converter/SCA |
- 电话:020-87268766
- 传真:020-87268766
- email:gzlaijie@163.com
上一篇:厦门漳州空压机油
