当前页面: 首页 >供求信息 >ORTEC核电子学仪器 广州莱捷电器有限公司
供稿:gzlaijie 2012/10/11 20:45:06
人气:82
  • 有效期:2212/10/26 0:00:00
ORTEC核电子学仪器
广州莱捷电器有限公司
产品型号:ORTEC核电子学
产品描述:
 ORTEC核电子学仪器种类齐全,性能稳定,为广大科研工作者提供了最广泛的选择,在国内外都以得到广泛应用。
Preamplifiers
Model No. Description
VT120A Fast-Timing Preamplifier (200 gain, non-inverting)
VT120B Fast-Timing Preamplifier (200 gain, inverting)
VT120C Fast-Timing Preamplifier (20 gain, non-inverting)
C-VT120 Power Cable Assembly for VT120A/B/C (3-m length)
113 Scintillation Preamplifier
142A Preamplifier
142B Preamplifier
142C Preamplifier
142AH Preamplifier
142IH Preamplifier
142PC Preamplifier
9301 Fast Preamplifier
9305 Fast Preamplifier
9306 1-GHz Preamplifier
9326 Fast Preamplifier with 3-m DC power cable
PL Subsection Name Amplifiers
FTA820A Octal Fast-Timing Amplifier (200 gain, non-inverting)
427A Delay Amplifier
460 Delay Line Amplifier (with standard 1-μs delay lines)
474 Timing Filter Amplifier
533 Dual Sum and Invert Amplifier
570 Spectroscopy Amplifier
572A Spectroscopy Amplifier
575A Spectroscopy Amplifier
579 Fast-Filter Amplifier
590A Amplifier and Timing SCA
671 Spectroscopy Amplifier
672 Spectroscopy Amplifier (with AUTO-PZ)
673 Spectroscopy Amplifier and Gated Integrator
855 Dual Spectroscopy Amplifier
863 Quad Timing Filter Amplifier
9302 Amplifier and Discriminator
9327 1-GHz Amplifier and Timing Discriminator
Counters, Timers, and Ratemeters
449 Log/Lin Ratemeter
449-2 Log/Lin Ratemeter with audible output option
661 Ratemeter
871 Timer and Counter (non-printing)
974 CCNIM Quad 100-MHz Counter/Timer
994 CCNIM Dual Counter and Timer (requires interface option for computer operation)
995 CCNIM Dual Counter (requires interface option for computer operation)
996 CCNIM Timer and Counter (requires interface option for computer operation)
99X-1 994, 995, and 996 Options - RS-232-C Interface Option (requires C-75 Cable)
99X-2 994, 995, and 996 Options - IEEE-488 Interface Option (requires C-488-2 or C-488-4 Cable)
99X-4 994 and 995 Options - Internal +6 V Supply Option
9349 Log/Lin Ratemeter
Delays, Gate and Delay Generators, Logic Modules, and Linear Gates
CO4020 Quad 4-Input Logic Unit (requires 6 V)
DB463 Delay Box
GG8020 Octal Gate and Delay Generator (requires 6 V)
414A Fast Coincidence
416A Gate and Delay Generator
418A Universal Coincidence
425A Nanosecond Delay
426 Linear Gate
542 Linear Gate and Stretcher
Fast-Timing Discriminators
CF8000 Octal Constant-Fraction Discriminator
CFD-DELAY-5NS Delay Plug-in (CF8000 Options)
CFD-DELAY-10NS Delay Plug-in
CFD-DELAY-30NS Delay Plug-in
CFD-DELAY-50NS Delay Plug-in
583B Constant-Fraction Differential Discriminator/SCA (requires 6 V)
584 Constant-Fraction Discriminator
935 Quad 200-MHz Constant-Fraction Discriminator (requires 6 V)
9307 pico-TIMING Discriminator (requires 6 V)
HV Bias/NIM Power Supplies and Bins
428 Detector Bias Supply
495 Power Supply (6 V)
556 High-Voltage Power Supply (3 kV)
556H High-Voltage Power Supply (3 kV)
659 5-kV Detector Bias Supply
660 Dual 5-kV Detector Bias Supply
710 Quad 1-kV Bias Supply
4001A NIM Bin
4001A/4002A NIM Bin and 96-W Power Supply (with ±12 V, ±24 V)
4001A/4002D NIM Bin and 160-W Power Supply (with ±6 V, ±12 V, ±24 V)
4001C NIM Bin (with copper bus bars)
4001C/4002D NIM Bin (with copper bus bars) and 160-W Power Supply (with ±6 V, ±12 V, ±24 V)
4001C/4002E NIM Bin (with copper bus bars) and BLACK MAX PS (with ±6 V, ±12 V, ±24 V)
4002A 96-W Power Supply for NIM Bin (with ±12 V, ±24 V)
4002D 160-W Power Supply for NIM Bin (with ±6 V, ±12 V, ±24 V)
4002E BLACK MAX Power Supply for NIM Bin (with ±6 V, ±12 V, ±24 V)
4002P Portable Power Supply (with ±12 V, ±24 V)
4002P-C1 Preamp Power Fan-Out Cable (for 4002P)
4003 Preamplifier Power Output
4006 Mini Bin and Power Supply
NIM MCA/MCB,PCI Card MCA
919E EtherNIM 4-Input Multichannel Buffer
919-OPT1 Pigtail Cable
920E EtherNIM 16-Input Multichannel Buffer
920-16-OPT1 Pigtail Cable
921E EtherNIM High-Rate Multichannel Buffer
926 8k ADCAM Multichannel Buffer
926-M32 8k ADCAM Multichannel Buffer with MAESTRO-32 Software
926-USB 8k ADCAM Multichannel Buffer with USB Interface
926-M32-USB 8k ADCAM Multichannel Buffer with USB Interface and MAESTRO-32 Software
926-C-2 Interface and Cable for NIM MCB - Printer Port Cable, male to female, 25 pin conductor; 2-ft length
926-C-10 Interface and Cable for NIM MCB - Printer Port Cable, male to female, 25 pin conductor; 10-ft length
ASPEC-927 Dual 16k Multichannel Buffer with MAESTRO-32 Software and 10-ft. USB Cable
DPM-USB Dual-Port Memory to USB Interface Converter, 15-ft. Cable
918-OPTC5 Dual-Port Memory Cable, 5-ft shielded ribbon cable
C-DPM-10 Dual-Port Memory Cable, 10-ft shielded ribbon cable
918A-OPTB PC-Bus Interface
TRUMP-PCI-2K 2k MCA PCI Plug-In Card with MAESTRO-32 Software
TRUMP-PCI-8K 8k MCA PCI Plug-In Card with MAESTRO-32 Software
CAMAC ADCs and Memory
AD114 CAMAC 16k ADC
AD413A CAMAC Quad 8k ADC
CMC203 CAMAC FERA Driver, Memory, and Histogrammer
HM413 CAMAC FERAbus Histogramming Memory
C-ECLBUS Cable Kit for FERAbus readout with Models AD114, AD413A, CMC203, and HM413
Multichannel Scalers and/or Multiple-Stop Time Spectrometers
MCS-PCI Multichannel Scaler with A73-B32 software, documentation, and FullShot software
MCS-PCI-OPT2 Fan-Out Cable for MCS-PCI
9353 100-ps Time Digitizer/MCS with 9353-B32 software
9353-FANOUT Fan-out Cable for the 9353 9-pin D Connector
Pulse Generators
419 Precision Pulse Generator
480 Pulser
Special Instruments
439 Digital Current Integrator
Single-Channel Pulse-Height Analyzers
550A Single-Channel Analyzer
551 Timing Single-Channel Analyzer
552 Pulse-Shape Analyzer/Timing SCA
850 Quad Single-Channel Analyzer (requires 6 V)
Time-to-Amplitude Converters and Time Calibrator
462 Time Calibrator
566 Time-to-Amplitude Converter
567 Time-to-Amplitude Converter/SCA
  • 电话:020-87268766
  • 传真:020-87269099
  • email:gzlaijie@163.com
