- 型号:BAD51系列
- 数量:按客户的需求销售
- 有效期:2030/12/31 0:00:00
BAD51-B100隔爆型防爆灯,BAD52-Z125隔爆型防爆灯,BAD54-L150隔爆型防爆灯
订购热线:138 6878 4267 联系人:胡工
一、BAD51隔爆型防爆灯使用范围 1.爆炸性气体环境危险场所:1区、2区;
2.可燃性气体、蒸气级别:ⅡA、ⅡB;
3.温度组别:T1~T4;
4.可配装白炽灯;
5.户内、户外(IP54,可按用户要求达到IP65)。
1.For the dangerous sites with explosive air mixture: 1division, 2division;
2.Flammable gas, steam class: ⅡA、ⅡB;
3.Temperatures classification: T1~T4;
4.Suitable for incandescent lamp;
5.Indoor and outdoor (IP54, It could be designed as IP65 according to user"s requirements).
二、BAD51隔爆型防爆灯性能特点
1.铸铝合金外壳,表面喷塑;
2.压铸成形,结构紧凑,外形美观;
3.壳上设有散热片,散热效果好;
4.灯盖与灯体采用螺钉联接,松开螺灯,旋转灯体,可快速开盖;
5.钢管或电缆布线;
6.镇流器,吊灯盒由用户选配。
7.符合GB3836-2000、IEC60079, GB12476.1-2000,IEC61241标准要求。
1.Diecasted A1-alloy shell with plasic-sprayed surface;
2.Moulded shaped outline with a pleacant out looking;
3.There is no radiating fin on the shell.It has good radiating result;
4.The light cap connects with light body with bolt. Loosening the bolt and rotating the light body can make rapid cap opening.
5.Steelpipe and cable wiring;
6.The ballast and ceiling lamp-box can be matched by users" choice.
7.Suitable for GB3836-2000、 IEC60079、GB12476.1-2000、IEC61241 standard request.
三、BAD51隔爆型防爆灯光源种类 功率 进线口螺纹/电缆外径
B:白炽灯 200W
Z:自镇汞 12W5,160W
G:外镇汞灯 125W
N:高压钠灯 70,100, 110 G3/4/Φ10~Φ15
NZ:中显色钠灯 70,100, 110
NG:高显色钠灯 70,100, 110
L:金属卤灯 100, 150
防护等级 防爆标志 防腐等级 灯头型号 电压(V) 质量(kg)
IP54 Exd Ⅱ BT4 WF1,WF2 E27 AC220 3.5 .
- 电话:138 6878 4267
- 传真:0577-62618387
- email:1464380266@qq.com
