当前页面: 首页 >供求信息 >BES516-300-S162-S4-D耐高压接近开关
供稿:li582586887 2013/5/7 8:15:28
人气:0
  • 型号:BES516-300-S205-D-PU、BES516-300-S152-S4-D、BES516-300-S149-S4-D、BES516-300-S156-S4-D、BES516-300-S149-D-PU
  • 数量:1000
  • 有效期:2023/5/22 0:00:00
1.具有良好的防水、防油, 高度抗干扰性能
2. 优质金属外壳及电缆全部采用进口元器件
3.
适用于各种恶劣环境(不锈钢)能承受500Bar高压
4.
多规格不同长度,适合您个性化的需求,
5.
具有多种出线方式(导线引出式,连接器式)
NJ1.5-18GM-E2-DNJ1.5-18GM-N-DNJ1.5-18GM-N-D
BES 516-300-S 164-S 4-D
BES 516-300-S 163-S 4-DBES 516-300-S 242-S 4-DBES 516-300-S 300-S 4-DBES 516-300-S 298-S 4-DBES 516-300-S 135-S 4-DBES 516-300-S 162-S 4-DBES 516-300-S 281-S 4-DBES 516-300-S 265-S 4-DBES 516-300-S 249-S 4-DBES 516-300-S 263-S 4-DBES 516-300-S 262-S 4-DBES 516-300-S 164-D-PUBES 516-300-S 135-D-PUBES 516-300-S 178-D-PUBES 516-300-S 240-D-PUBES 516-300-S 241-D-PUBES 516-300-S 215-D-PUBES 516-300-S 205-D-PUBES 516-300-S 152-S 4-DBES516-300-S 149-S 4-DBES 516-300-S 156-S 4-DBES 516-300-S 149-D-PUBES 516-300-S 284-S 4-DBES 516-300-S 284-D-PUBES 516-300-S 129-S 4-DBES 516-300-S 128-S 4-DBES 516-300-S 267-S 4BES 516-300-S 144-S 4-DBES 516-300-S 299-S 4-DBES 516-300-S 203BES 516-300-S 190-S 4BES 516-300-S 271-S 4BES 516-300-S 271BES 516-300-S 260-S 4-DBES 516-324-SA 17BES 516-300-S 289-B0-D-PUBES 516-300-S 292-B0-D-PUBES 516-300-S 290-B0-D-PUBES 516-300-S 293-B0-D-PUBES 516-300-S 270-S 4-DBES 516-300-S 291-S 4-DBES 516-325-SA 53BES 516-370-SA-9-E5-Y-S 4BES 516-325-SA 19BES 516-329-SA 14-A0-X BES 516-326-SA 23
DW-AS-501-P20
DW-AS-503-P20DW-AD-501-P20DW-AD-503-P20DW-AS-501-P18DW-AS-503-P18DW-AS-501-P12-624DW-AS-503-P12-624DW-AS-501-P12-630DW-AS-503-P12-630DW-AS-501-P12DW-AS-503-P12DW-AS-504-P12DW-AS-501-P12-627DW-AS-503-P12-627DW-AS-501-P12-621DW-AS-503-P12-621DW-AS-501-P12-635DW-AS-503-P12-635DW-AS-501-P12-622DW-AS-503-P12-622DW-AS-501-P12-639DW-AS-503-P12-639DW-AS-501-P12-625DW-AS-503-P12-625
  • 电话:18317108518
  • 传真:021-67816322
  • email:li582586887@163.com
更多内容请访问 li582586887(http://home.gongkong.com/profile/?uid=2012021317233700001)
