- 型号:BXM(D)
- 数量:10000
- 制造商:顺新
- 有效期:2042/5/28 0:00:00
1.1区、2区危险场所;
1.Hazardousidivision 1&2:
2.II A. IIB、IIC类爆炸性气体环境;
2. Explosive gas atmosphere: class II A、 II B、 II C;
3.户内、户(IP54,IP65”。
3.Indoor or outdoor(IP54, IP65*).
4.可燃性粉尘环境20区、21区、22区;
4.Combustible dust environment 20 zone, 21 zone, 22 zone;
5.石油石化、化工、酿酒、医药、油漆、纺织、印染、军工设施等爆炸性危险环境。
5.Petroleum andpetrochemical, chemical, brewing, pharmaceutical, textile, printing and dyeing, paint, military facilities and other explosive dangerous environment。
二、BXM(D)防爆照明动力配电箱产品特点:Features
1.铝合金外外壳压铸成型•表面喷塑,外形美观:
1.Enclosure is cast with aluminium alloy, surfacc is sprayed with plastic, fine outline;
2.内装DZ47,NMI及S250S高分断小型断路器、M6II 或GV2电动机保器CJX2交流接 触器、NMI塑壳断路器及信号灯等组件;
2.Built-in DZ47, NM1 and S250S high disjunction mini-circuil breaker, M6II or GV2 motor ptotcctor. CJX2 contactors. NM1 plastic moulded circuit breaker and signal lamp;
3.具有过载、短路保护功能;
3.With overload and shoit circuit protection functions;
4.模块结构,各种回路可根据需要自由组装:
4.Mould structure, each branch circuit can be assembled freely;
5.可根据用户要求特制•如加装电涌保护器、电流表.电压表等:
5.It can be made on request, including adding clcctric surge protcctcr. ammeter and voltmeter and so on ;Also con configure wi(h padlock handles in addition;
6•钢管或电缆布线。
6.Wiring with steel lube or cablc.
三、BXM(D)防爆照明动力配电箱主要技术参数:Main technical parameters
型号 |
额定电压 |
主回路电流 |
支路数 |
主回路开关数(台) |
支路电流 |
防爆标志 |
管螺纹 |
电缆外径 |
防护等级 |
进线 |
出线 |
进线 |
出线 |
BXM(D)-4 |
220 380 |
10—225 |
4 |
1 2 4 6 10 16 20 25 32 40 50 63 |
ExdeIIB T6/T5/T4 ExdeIIC T6/T5/T4 |
G1 - G3 |
G1/2 - G1 /2 |
14 - 56 |
8 - 30 |
IP54 IP65 |
BXM(D)-6 |
6 |
BXM(D)-8 |
8 |
BXM(D)-10 |
10 |
BXM(D)-12 |
12 |
BXM(D)-4K |
4 |
1 |
BXM(D)-6K |
6 |
BXM(D)-8K |
8 |
BXM(D)-10K |
10 |
BXM(D)-12K |
12 |
乐清市顺新防爆专业生产防爆电器设备,欢迎来询主要产品:防爆对讲机,防爆电话(带耦合器),防爆仪表,防爆挠性连接管,防爆穿线盒,防爆接线箱,防爆吊灯盒,防爆接线盒。BXM(D)防爆照明动力配电箱,BXM防爆照明配电箱生产厂家,BXD防爆动力配电箱多少钱?公司网站:www.sxinfb.com www.sxfangbao.com
- 电话:13588991453
- 传真:0577-62618387
- email:2683508593@qq.com
