- 型号:BXD
- 数量:10000
- 制造商:顺新
- 有效期:2038/5/12 0:00:00
BXD防爆动力配电箱 BXM防爆照明动力配电箱 防爆动力电器箱厂家 防爆动力电器箱多少钱
一、BXD防爆动力配电箱产品特点Features 1、转盘及防爆插销壳体为铸铝合金•表面喷塑: 2、内可装带漏电保护小型断路器; 3、插销上有分、合指示•插头上接地触头比主触头长, 插入时接地触头先接•拔脱时,接地触头后脱离; 4、插座与插头设有联锁装置.断电后方能插拔: 5、电缆盘转动炅活,移动时有托架及行走轮.移动方便 6、电缆长度标准配置为 7、电缆布线。 1、The rotary plate and the enclosure of explosion-proof bolt are cast with aluminium alloy, the surface is sprayed with plastic; 2、Built-in creepage protection mini circuit breaker: 3、There are open&close indication, the earthing contact is longer than the main contact, when pluging. the earth plug first; when pulling out.die earth contact later; 4、The sockct and plug arc interlocked, so they arc drawn out after cutting (he power; 5、The cable plate can be turned actively and moved easily because of the bracket and moving wheels; 6、Cable length (standard): 7、Wiring with cable. 二、BXD防爆动力配电箱适用范围Applications 1、I区、2区危检场所: 2、II A. IIB类爆炸性气体环境; 4、户内、户外(IP54, IP65*) 1、Hazardous : division I&2; 2、Explosive gas atmospheres : class II A, IIB; 3、Indoor or outdoor (IP54.IP65*).
额定电流(A) 额定电压 带总开关电流(A) 防爆标志 防护等级 出线口螺纹 电缆外径 16x2 220/380 32 Exde II BT6 IP54 3/4 10-14 32x2 63 ExdeIIBT5/T4 IP65# 1 1/4 18-22
•:订货时需提出
乐清市顺新防爆专业生产防爆电器设备,欢迎来询主要产品:
防爆电器类:防爆空调,防爆除湿机,防爆电铃,防爆插接装置,防爆插销,防爆镇流器,防爆变压器,防爆轴流屋顶风机,防爆照明开关,防爆断路器,防爆控制箱,防爆配电柜,防爆检修电源插座箱,防爆动力电磁启动配电箱,防爆照明动力配电箱,防爆检修箱,防爆操作柱
- 电话:13588991453
- 传真:0577-62618387
- email:2683508593@qq.com
