DRA480-24 DRA480-48 Features: ? AC/DC DIN Rail mountable power supply ? Compact design ? High efficiency up to 90% ? Active P.F.C. function ? Parallel function available (switch) ? Universal input voltage ? 3 years warranty
CASE SIZE
Screw Terminal Type: 124.5 x 175.5 x 123.6mm ( 4.9 x 6.91 x 4.87 inches )
Detachable Connector Type: 143.5 x 175.5 x 123.6mm ( 5.65 x 6.91 x 4.87 inches)
CASE MATERIAL
Metal
WEIGHT
1920g
WRA960-24 WRA960-48
Features: ? AC/DC DIN Rail mountable power supply ? 3 phase AC input voltage ? Compact design ? High efficiency up to 93% ? Parallel function available (switch) ? 3 years warranty
CASE SIZE
Screw Terminal Type: 126.2 x 275.8 x 118.8mm ( 4.97 x 10.86 x 4.68 inches )
CASE MATERIAL
Metal
WEIGHT
3400g
MODEL NO.
INPUT VOLTAGE
OUTPUT VOLTAGE
OUTPUT CURRENT
EFF. (min.)
EFF. (typ.)
*** Single Output Models ***
WRA960-24
3? 340~575 VAC
+ 24 VDC
40 A
90%
92%
WRA960-24L
3? 340~575 VAC
+ 24 VDC
40 A
90%
92%
WRA960-48
3? 340~575 VAC
+ 48 VDC
20 A
91%
93%
WRA480-24 WDR480-48
Features:
? AC/DC DIN Rail mountable power supply ? 3 phase AC Input voltage ? Compact design ? High efficiency up to 91% ? Parallel function available (switch) ? 3 years warranty
CASE SIZE
Screw Terminal Type: 124 x 150 x 118.8mm ( 4.88 x 5.91 x 4.68 inches )
