当前页面: 首页 >供求信息 >排线热压焊接
排线热压焊接
供稿:jingyiweld 2013/6/26 16:18:33
人气:7
  • 数量:10000
  • 制造商:东莞市寮步精亿自动焊接设备厂
  • 有效期:2063/8/18 0:00:00
一次完成排线多个焊点焊接,即刻提高焊接效率;恒温控制,保证焊锡均匀铺展;焊点光亮均匀;焊点牢固,一致性好;无手工焊接缺陷:如易短路,焊不牢,焊点不一致,不好操作等。主要应用于PCB基板、FPC、FFC的焊接,LCD和TCP的ACF连接,各种线圈的绝缘漆包线和端子的直接连接,可塑性塑料的加热接合等。运用该焊接方式不会发生虚焊现象,能够实现一次多点的焊接,可以不用顾及人员的操作技能,确保焊接质量。
Efficient welding; good welding quality; no manual weld defects: such as easy to short circuit, solder is not strong, spot inconsistencies, it is difficult to operate. Mainly used in PCB substrate, FPC, FFC welding, LCD and the TCP connection of ACF, all kinds of insulated copper magnet coils and the terminals of the direct connection of the heating junction plasticity, such as plastic. Use of the welding to achieve a multi-point welding, you can not take into account the skills of personnel to ensure the welding quality.
1, the use of advanced temperature control system control segment, given the flexibility to set the temperature state of the paragraphs. Temperature and time parameters can be controlled accurately.
2, the stability of the rapid warming, local transient heating can be a good way to curb the surrounding heat-affected components.
4, the closed-loop thermocouple feedback online to improve temperature control accuracy.
5, welding pressure, welding time, welding temperature regulation may be accurate.
6, can store 20 groups of welding parameters very convenient replacement products.
7, more than one-spot, high efficiency, consistency, and high strength welding, solder joint appearance, simple operation.
8, less consumables, the use of low cost.
  • 电话:0769-33353025
  • email:jingyiweld8@163.com
