- 型号:6ES7317-2FK13-0AB0
- 数量:10
- 有效期:2053/7/28 0:00:00
SIEMENS 6ES7 317-2FK13-0AB0 NEW-NO BOX SIMATIC S7 CPU MODULE 6ES73172FK130AB0
本公司专业销售大型进口各种品牌DCS系统模块备件:ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,GE FANUC,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSOM MVME,Other VME,TOSHIBA等大型模组,有着充足的库存,交货期快,库存价值大约3亿人民币,欢迎来电查询
厦门兴锐达自动化设备有限公司
联系人:苏清正 销售经理
热 线:0592-5580702(4008-555-103转021)
手 机:15359273797
传真:0592-5361156/5361297
QQ: 2227405598
EMAIL:2227405598@qq.com
地址:厦门市湖里区泗水道601号2层EF单元
邮编:361009
网址: www.dcsbeijian.com
Mitubishi PC board FX42A - BN624A219H04
Siemens Simatic S7 CPU 414-3 6ES7414-3EM05-0AB0 6ES7-414-3EM05-0AB0 V.06
Uticor 76731-16 Programmable Message Display Rev. A, 76
Uticor Tech 76561-64/D Programmable Message Display, 76
Fanuc A16B-1211-0520/05A Control Board
Fanuc A16B-1210-0970/04B Control Board
Banner QT50ULBQ6 U-GAGE Proximty Sensor Range: 200mm to
Total Control Products QPJ-DVN-202 Communication Module
Eberle TR6200N Temperature Controller
ABB 3HAC3378-1 Cable Assembly
Phoenix Contact FLS-IB-M12-DIO-4/4-M12-2-2A Digital In/
Banner MUSAS-1-02906 Microprocessor Control -
Namco EB700-69873 Solonid Assembley 115v 60hz Pull/Push
Siemens 3RB1045-1EB0 Overload Relay for Mounting on Con
Mitubishi PC board FX32B - BN624A232H04
Gould Modicon B373 0-10vdc Analog Input Module
Namco EE260-31920 Rotatable Cylindicator, 20-230VAC/DC
Controlled Power Company 5DZZX-2K-8-PI, Power Purificat
Siemens 6ES7 340-1AH01-0AE0, Communication Processor Mo
Baldor VSWDM3538 - 3PH 1/2HP 208-230/460VAC 1725RPM Ind
Flex
Modicon Compact CPU Module - PC-A984-141
Fanuc A16B-1210-0950/02A Control Board
Siemens 6EP1436-3BA00, SITOP Power 20, 24Vdc/20a/480w -
Alcorn McBride Interactivator
Siemens 3RV1131-4EA10 Circuit-Breaker, Size S2, Class 1
Sensotec 440/7229-04 Amplified Transducer 0-500 PSIG
EMS CIMR-XCBU41P5 Variable Speed Mini Drive 460v, CIMRX
Allen Bradley 1746-DCM Direct Communication Module, Ser
Parker 04.00 CCP2ANUS142AC 10.250 Series 2AN - Air Cycl
Temposonics Div. MTS Systems Corp. DCTM-18A-2 Electroni
Sick WT12L-2B550A01 1018473 Proximity Sensor -
Banner DX83 (77569) Sure Cross Ethernet Bridge Kit - NE
Belden 1505A Video Brilliance Cable HDTV 4.5GHZ - Appro
Rexroth R985000989 Fiber Optic Cable 6MM 06-0986/003.50...
Atlas Copco Fastening Tool Nutrunner - Assembly No. 442
Rexroth Connecting Cable - 0 608 830 177
Uticor 150-115N2L08EX Operator Interface Display Unit
Modicon TSX Quantum DC in 24V 4X8 Sink - 140 DDI 353 00
Eska CK-60 1.5 mm High-Performance Plastic Optical Fibe
Allen Bradley 505V-AOA, Series B, Bulletin 505 Full Vol
Schneider TSX Quantum RIO DROP - 140 CRA 931 00
Reliance 0-49042-1 CARDPAK Power Amplifier
Texas Instruments 405-14ABM Basic CoProcessor 16MHz Tri
Allen Bradley 702LP-DOD93 100 AMP. Continuous Rating Se
Meterologic Instruments MS-131 Scanner and I/O Module
SMC Air Valve Serial Interface Unit - IN313-AB2
Wago 750-301 Profibus-DP Includes (1) 750-650 Serial In
Allen Bradley 1764-LSP MicroLogix 1500, Series C Proces
Atlas Copco K258936 Processor Module Back Panel
Mitsubishi Mem Card MEM-A0, MC435 Memory Card W/PLC Typ
Autotech Controls ASY-M1250-08N Cam Output Module, ASYM
National Instruments SCXI-1000 REV:4.0, P/N 181445L-01
National Instruments SCXI-1000 REV: 4, P/N 181445K-01
Fanuc A80L-0001-0520-02 1.1kva Transformer Input 220-57
Modicon W801-012 Cable
FISHER CONTROLS POSITIONER 30 VDC MODEL 3622
GE FAULT DETECTOR RELAY 12NHC11A1A
COPELAND AIR COND. COMPRESSOR RES3-0175-PFJ-900
SQUARE D GROUND FAULT RELAY 600 VAC 50 AMP MODEL GC-100
TRANSFLUID HYDRAULIC COUPLING SIZE 7 4321X
ELLISON EDUCATION VAGABOND 8" SURECUT DIES FULL ALPHABE
GENERAL RADIO 1433-Z DECADE RESISTOR 1433Z
OMEGASCOPE OS-2106S
APW MCLEAN ELECTRONIC ENCLOSURE AIR CONDITIONER 600/230
TEXTRON CONE DRIVE HOLLOW SHAFT GEAR REDUCER 5:1 RATIO
MILTON ROY VS1625 1 INCH PRESSURE RELIEF VALVE 49 P
RIETSCHOTEN THRUSTER BRAKE CALIPER ASSEMBLY 105.7 F
REBUILT ZIEHL-ABEGG ASYNCHRONOUS EXTERNAL ROTOR MOTOR 3
RELIANCE 5 HP AC VARIABLE TORQUE DRIVE 5VU41005
LINCOLN ELECTRIC ULTIMATE-E2 SEVERE DUTY CS4B2T61 2
WALLACE & TIERNAN 2 INCH STAINLESS FLOW METER 5224M2203
FISCHER PORTER HEATER 5OUS314ABB
RELIANCE ELECTRIC LIMIT MODULE CARDPAK 0-49008-3
FLOWDATA JPA-2A-D FREQUENCY TRANSMITTER 3/8" FLOW M
ITT HOFFMAN F & T STEAM TRAP 2" FT125X
REMANUFACTURED KUNKLE SAFETY VALVE 1.5" 6252FJG01-AS
LEESON 174440.00 VFD Variable Frequency Drive 400-480V
WATLOW IMMERSION HEATER 7 Kw 7-18-219-308
ESAM 1-1/2" THREE PHASE BLOWER 3360 G/M 240▲/600 VAC MO
ROSEMOUNT PRESSURE TRANSMITTER 300S1AAK5M5
GRACO SERVICE KIT PART NO. D0F366
RESEARCH CONTROL VALVES 1/4" AIR-TO-CLOSE POSITIONE
STENTOFON CLM PC BOARD MODEL 1000631500
ASCO RED HAT 8210G89 SOLENOID VALVE
YAMADA 3/8" ALUMINUM DIAPHRAGM PUMP 100 PSI MODEL DP-10
MOELLER DIL10H CONTACTOR COIL 120VAC
GM 3315A SHIELD BEARING NUMBER 615
BTR CONTROLS POWER DOOR CONTROL OPENER TELEMECANIQUE 2
DANAHER MOTION CPU MAIN CIRCUIT BOARD M-1016-9023
WEG ELECTRIC MOTOR 00336ES3EJP56J W/STAINLESS STEEL PUM
STENTOFON PMI CIRCUIT BOARD MODEL 1000631000
STENTOFON PMD CIRCUIT BOARD MODEL 1000630910
ALLEN BRADLEY 300 HP ADJUSTABLE FREQUENCY AC DRIVE 460
ALLEN BRADLEY 400 HP ADJUSTABLE SPEED DRIVE 460 VAC 133
BALDOR ELECTRIC MOTOR 350 HP 449T
SQUARE D CIRCUIT BREAKER 4000 AMP NW40H WITH LITTLE USE
KELTECH ACUTEMP TANKLESS WATER HEATER 40 GPM CN1443
DURCO FLOWSERVE 125 HP PUMP D4/CF8M 2K3x1.5-13RV/11
RELIANCE 25 Hp DC MOTOR 1750 / 1950 RPM 500 / 300 V
HACH MARSH-MCBIRNEY FLO-DAR WITH FLO-STATION RADAR VELO
RELIANCE 15 Hp DC MOTOR 1750 / 2300 RPM 500 / 300 V
IN FACTORY PACKAGING HUGHES PROBEYE INFARED VIEWER
SQUARE D 2500 AMP CIRCUIT BREAKER SHUNT TRIP & AUX 2500
HAMMOND 660 KVA DRIVE ISOLATION TRANSFORMER 480 HV 480/
SIEMENS SBS4040 CIRCUIT BREAKER 4000 AMP SBS 4000 SBS40
SQUARE D 2000 AMP CIRCUIT BREAKER PEF362000LS
GENERAL ELECTRIC GE OIL FILLED 500 KVA PAD MOUNT TRANSF
KT DESIGN & PROTOTYPE 14" CHAMFER WHEEL RADIUS GRINDER
WATRING INGOT TILT MACHINE SILICON WAFER SOLAR INDUSTRY
VIRGINIA CONTROLS ELEVATOR CONTROL PANEL 50 Hp MAGN
HI-SPEED CHECKWEIGHER MODEL MM 120 VAC W/ CONVEYOR & RE
ROSEMOUNT 14" MAGNETIC FLOWTUBE WITH PLATINUM ELECT
10" TURBINE BEARING KI-035409 165A870CA-1
LENNOX 8 TON CENTRAL COOLING AIR CONDITIONER 208/23
MOOG RADIAL PISTON PUMP B514361037
CUTLER HAMMER CMD 3000 AMP NETWORK PROTECTOR BREAKER
REIMELT ROTARY DISCHARGE VALVE TYPE 31L
CREST ULTRASONIC HEATED CLEANER
SQUARE D F QMB BRANCH SWITCH 1200 AMP 600 VAC SERIE
FISHER ACTUATED 6" STAINLESS STEEL BALL VALVE WITH
SCHWEITZER SEL-311L LINE CURRENT DIFFERENTIAL RELAY
ALLEN BRADLEY 100 HP VARIABLE TORQUE AC DRIVE 380/480 V
SULLAIR 02250113-648 COMPRESSOR HEAD WORKING !!!!
YASKAWA ELECTRIC ROBOTIC CONTROLLER CACR-SK16AAC
GOULDS PUMPS MODEL 3175S PUMP POWER END 6" x 8" x 1
- 电话:0592-5580702
- 传真:0592-5580710
- email:jy04866398@126.com
