- 型号:150VCP-W500
- 数量:44
- 有效期:2023/11/12 0:00:00
润星贸易有限公司,专业从事自动化产品及自动化设备研发及销售的企业,
对各大自动化产品品牌有着强大的优势,并且对优势产品有着大量的备货。与欧洲
及世界从事电气的各大品牌公司有着良好的协作关系。欢迎来电咨询!—厦门润星!
————————小林欢迎您的咨询
公司名称:厦门润星贸易有限公司
联系人:小林
电话:18030263568
QQ:1950342667
电话:0592-6895313
传真:0592-6034581
E-mail:1950342667@qq.com
WEINIG 00308362X NSFP 00308362X
Weinschel 8852 Frequency Converter (Fall Clearance )
Weinschel Aeroflex 8310-138-4-T Quad Channel Programmable Attenuator 0.8 to 3GHz
Weinschel PA-4 Precision Attenuator
Weintek Weinview MT8150X
WEISS SIEMENS SPINDLE # 175301 C MOTOR mW17/15-4-139a/140arf DBL.010501 - -
Weiss Technik WK-2500/60-S Temperature & Climate Solar Panels Application System
Welch Allyn Proxenon 350 Surgical Illuminator
WELDER, L60, UK AND EURO PLUG, XF 313 FAR 4100669
Welding AIR CYLINDER ASS'Y ARO #11B #50084598 for resistance welding
Welding Graph+Crack height+Curved Surface Correction
WELDING TECHNOLOGY CORP 986-0054 NSPP 9860054
WELDING TECHNOLOGY CORP 986-0055 USPP 9860055
Welding Technology Corp 986-0055 Webview Ethernet
WELDING TECHNOLOGY CORP TIMER WT01-T11A
WELDING TECHNOLOGY CORP WI03-T13A USPP WI03T13A
WELDING TECHNOLOGY CORP WI03-T13B USPP WI03T13B
Welding Technology Medweld 3000S AC Welding Control 3015 _ 3O15 _ 952-0402
WELDOTRON 8221A-2 NSFP 8221A2
Wells Brookfield HADVII Viscometer 22W 115V RFB
WELLS BROOKFIELD LVDV-ICP115 USPP LVDVICP115
WELNAVIGATE GS 1010, DYNAMIC TEST SIMULATOR, GS-1010, GS1010, GPS
Welnavigate GS-500
WelNavigate GS700
Weltronics Welding Control WT-2000 811046 #34368
WENTWORTH AWP 1080 DSP TWO AXIS PROBE
WENZEL ULTRA STABLE LOW PHASE NOISE QUARTZ OSCILLATOR 5 MHz FREQUENCY STANDARD
WER AC MOTOR P25G7079B
Wer Louis Allis ED320QFM-4000-- Eddy Drive Electric Motor 40HP 3 phase
Werie Pump w Motor VFT 80 (01) 102080-0116 _ VFT80011020800116_Came Off a Router
WERTH ENGINEERING 0220403 USPP 0220403
werth messtechnik Probe control 04.8200.9081 & Delta Tau Micro A/D PMAC ACC28R
werth messtechnik Sweep Counter II BGR 04.8200.9066 6/409/01 64
Wesinghouse - Re manufactured HLC3600F Circuit Breaker
Wessel pro systems 1 pcb drill and rout cnc auto load
WEST ELECTRONICS M-3800 NSPP M3800
WEST Industrial Motor 250 HP 410 RPM
WEST. P&H CRANE DUTY ELECTRIC MOTOR 40 HP 365X DOUBLE SHAFT
WESTAMP 3 AXIS DC SERVO DRIVE 30101-3
WESTCODE 24870-708-01 NSPP 2487070801
Western Electric 463A Travelling Wave Tube TWT Collectors
WESTERN GEAR SPEED INCREASER #4113B 2500 H.P. RATED 3.066 -1 SURPLUS UNIT
WESTERN RIGHT ANGLE BEVEL GEAR REDUCER 350HP -1.6-1 RATIO BS117
WESTERN SERVO DESIGN CHASSIS W/1X PSU, 2X BPU-S3, 4X LDU-S1, 1X PCU-S1PL1
WESTIGNHOUSE MPR3B1A4DA MOTOR PROTECTIVE RELAY
Westinghouse (2608D26G01) 2000 Amp External Current Sensor,
Westinghouse (3351D67G01) Type LF-25 Control Power Transformer,
Westinghouse (A201K5CX) Size 5 Contactor, Refurbished, excellent condition
Westinghouse (FDP365TR) Disconnect Switch 400 Amp, Refurbished
Westinghouse (LA3450) 450 Amp Circuit Breaker,/Cleaned/Tested
Westinghouse (MORA1MAE) Modular Overload Relay, Surplus
Westinghouse (NB31000) NB31200F 1000 Amp Circuit Breaker, Surplus
Westinghouse (PA31000) PA31600F 1000 Amp Circuit Breaker,/ Cleaned/ Tested
Westinghouse (PB31600T) 1600 Amp Type PB Trip Unit, Surplus (Take-out)
Westinghouse (PB31800T) 1800 Amp Type PB Trip Unit, Surplus in Original
Westinghouse (PB32500F) Circuit breaker frame w/ 1600 Amp trip unit, Surplus
Westinghouse (PB32500F) Circuit Breaker with 2500 amp trip unit,,
Westinghouse (SPB100) 800A, w/ 400A Rating Plug (8SPB400)
Westinghouse (SPB100) With LI POWER-R-TRIP7,
WESTINGHOUSE / CUTLER HAMMER MOTOR PROTECTOR & ENCLOSURE IQ1000-II IQ1000II
Westinghouse 10 HP Life-Line H DC Motor 70E61476 Explosion Proof
Westinghouse 100 HP 3560 RPM 230/460V 405TS MOTOR
WESTINGHOUSE 100HP MOTOR, TADP, 72C43784, ABEX T5DC0280141R00A1, 4525V60A17
Westinghouse 112.5 kVA 480 Delta / 208Y-120 Transformer
Westinghouse 1120250L2 Ampgard General Control Contactor 4160V 400 HP
WESTINGHOUSE 11-210K5RCNA USPP 11210K5RCNA
Westinghouse 1200 Amp Breaker NDC312T36W w/ Aux Switch
WESTINGHOUSE 1200 AMP CIRCUIT BREAKER 150-DHP-500
Westinghouse 1200A 15kV FSP Interrupter Switch 1200 Amp 15 kV
Westinghouse 1200A Circuit Breaker HNC31200F
WESTINGHOUSE 1200AMP 600V 3POLE ND312TW CIRCUIT BREAKER1,800.00
WESTINGHOUSE 125 HP MOTOR 3555 RPM 440V 444-US FRAME MODEL ABDP
WESTINGHOUSE 1301885 USPP 1301885
WESTINGHOUSE 143Y7878 DB-75 600V 3000A AIR CIRCUIT BREAKER
WESTINGHOUSE 149D930G01 USPP 149D930G01
WESTINGHOUSE 149D944G01 USPP 149D944G01
Westinghouse 150 DHP-500 Air Circuit Breaker
WESTINGHOUSE 150 KVA TRANSFORMER PRI 4160V SEC 208Y/120 3PH DRY TYPE V46D28T49J
Westinghouse 1500 HP 480 Volt Reduced Voltage Starter
Westinghouse 1500 KVA Transformer - 4160-480Y/277 Volt, 3 Phase, Dry Type
Westinghouse 1500kVA 4160-480/277 dry transformer
WESTINGHOUSE 150DHP-1000VR 15KV 2000A DO EO MEDIUM VOLTAGE CIRCUIT BREAKER
WESTINGHOUSE 150DH-P500 15KV 1200A DO EO MEDIUM VOLTAGE CIRCUIT BREAKER
WESTINGHOUSE 150VCP-W500 15KV 1200A DO EO MEDIUM VOLTAGE CIRCUIT BREAKER
WESTINGHOUSE 150VCP-WR18-500 15KV 2000A DO EO MEDIUM VOLTAGE CIRCUIT BREAKER
WESTINGHOUSE 1589A53G01 NSPP 1589A53G01
Westinghouse 15KV 600 Amp Load Interupter Switchgear
Westinghouse 1600 Amp 16SPBDOS SPB-100/SPB-65 Drawout Frame 1200 Amp Cradle
Westinghouse 1600 amp 600 volt circuit breaker RD65K cat# RD316TW
WESTINGHOUSE 1661D89G01-8 USPP 1661D89G018
WESTINGHOUSE 1-88Y220 DA-100 600V 4000A AIR CIRCUIT BREAKER
WESTINGHOUSE 1A48747C01 360A 360 A AMP VACUUM CONTACTOR MODEL S 120V CONTROL
Westinghouse 2000 Amp Circuit Breaker 600 VAC SPCB2000
Westinghouse 2000 HP Electric Induction Motor
Westinghouse 2000A 600V 3P Circuit Breaker
WESTINGHOUSE 2000A BREAKER, #PCF32000F, 30 ,, SEE BELOW
WESTINGHOUSE 2045A45G USPP 2045A45G
WESTINGHOUSE 2066A10G11 NSPP 2066A10G11
WESTINGHOUSE 2067A02G06 USPP 2067A02G06
WESTINGHOUSE 2081400
Westinghouse 2100 1200 Amp Main Breaker Feeder MCC Bucket 1200A MCCB 600 VAC 42"
Westinghouse 2100 24" HKD3400F 400 Amp Feeder Bucket
Westinghouse 2100 250 Amp Size 5 Reversing MCC Bucket MCCB 54" Cutler Hammer
Westinghouse 2100 400 Amp Breaker MCC Feeder Bucket 400A MCCB CH 3 Pole 24"
WESTINGHOUSE 2100 600 AMP 480V 3P 3W MOTOR CONTROL CENTER MCC
Westinghouse 2100 MCC 5 vertical sections 3R rainproof enclosure 21 buckets
Westinghouse 2100 Series , 42" Size 5 Bucket,Breaker Type
Westinghouse 2100 Series , 66" Size 6 Bucket,Breaker Type
WESTINGHOUSE 210P085H01-1 USPP 210P085H011
Westinghouse 225 KVA 13,800D Volt Auxiliary Transformer L3953A51LD1
WESTINGHOUSE 225 KVA 480 208Y/120 VAC TRANSFORMER
Westinghouse 225 KVA Transformer V48M28T220 3 Phase Prim 480 Delta Sec 208Y/120
WESTINGHOUSE 23Y2307B DBN-1032 600V 3200A AIR CIRCUIT BREAKER
WESTINGHOUSE 24Y6089B DB-100 600V 4000A AIR CIRCUIT BREAKER
WESTINGHOUSE 24Y6314B DB-50 600V 1600A OCTD L/S/I AIR CIRCUIT BREAKER
WESTINGHOUSE 24Y9919B DS-632 600V 3200A Amptector I L/S/I/G AIR CIRCUIT BREAKER
Westinghouse 25 HP Life-Line T 1745 RPM Motor TUAM
Westinghouse 250 Amp Breaker hla3250 circuit hla
Westinghouse 2500 Amp Breaker Cat # PB32500F
WESTINGHOUSE 2500/3333 KVA 12000V TRANSFORMER WES8504-2
Westinghouse 251AA Turbine Load Gear
WESTINGHOUSE 27Y5990 DB-75 600V 3000A Amptector L/S/G AIR CIRCUIT BREAKER
WESTINGHOUSE 27Y6573 DB-25 600V 600A Amptector II L/I AIR CIRCUIT BREAKER
WESTINGHOUSE 2838A31G01 NSPP 2838A31G01
WESTINGHOUSE 2838A31G01 USPP 2838A31G01
WESTINGHOUSE 2840A21G01 ANALOG OUTPUT BOARD 3A99161G01
WESTINGHOUSE 2840A21G01 PC BOARD M369660
WESTINGHOUSE 2840A21G01 USPP 2840A21G01
WESTINGHOUSE 289B141A10 USPP 289B141A10
WESTINGHOUSE 289B141A13 USPP 289B141A13
WESTINGHOUSE 289B142A11 USPP 289B142A11
WESTINGHOUSE 289B142A15 USPP 289B142A15
WESTINGHOUSE 289B142A21 USPP 289B142A21
WESTINGHOUSE 289B142A25 USPP 289B142A25
WESTINGHOUSE 289B143A10 USPP 289B143A10
WESTINGHOUSE 289B145A31 USPP 289B145A31
WESTINGHOUSE 289B145A34 USPP 289B145A34
WESTINGHOUSE 289B932A18 USPP 289B932A18
WESTINGHOUSE 292B315A12 USPP 292B315A12
WESTINGHOUSE 292B333A10 USPP 292B333A10
WESTINGHOUSE 292B335A10 USPP 292B335A10
WESTINGHOUSE 292B335A14 USPP 292B335A14
WESTINGHOUSE 292B335A15 USPP 292B335A15
WESTINGHOUSE 292B335A18 USPP 292B335A18
- 电话:0592-6895313
- 传真:0592-6034581
- email:1950342667@qq.com
更多内容请访问 xmrxmy0012(http://home.gongkong.com/profile/?uid=2013072409553800001)
