- 型号:1756-L55M12
- 数量:44
- 有效期:2023/11/23 0:00:00
某人:“月初你还顶个啤酒肚,怎么到月底你肚子就瘦下去了?”
胖子:“我控制我的饮食,多吃蔬菜水果;每天锻炼做仰卧起坐、俯卧撑等…… ”
某人:“哦,我懂了!”
胖子:“你懂个屁!后来我不小心吃坏肚子,拉了一个多星期,就瘦下来了。”
润星贸易有限公司,专业从事自动化产品及自动化设备研发及销售的企业,
对各大自动化产品品牌有着强大的优势,并且对优势产品有着大量的备货。与欧洲
及世界从事电气的各大品牌公司有着良好的协作关系。欢迎来电咨询!—厦门润星!
————————小林欢迎您的咨询
公司名称:厦门润星贸易有限公司
联系人:小林
电话:18030263568
QQ:1950342667
电话:0592-6895313
传真:0592-6034581
E-mail:1950342667@qq.com
NH Research L4000-03
NH Research L4015M-01
NH Research Powertest 505
NH Research Powertest 525
NH Research S310
NH310 High Quality Portable Colorimeter Φ8mm/Φ4mm Measuring Aperture Color Meter
NHI NHI-2040MW-10L Solid State Amplifier (Reduced 8/12)
NHL261200 Square D SQD Circuit Breaker 2 Pole 1200 Amp 600V
NHR 4600 AC Load U
NI 747514-01 PXI-2172 Media SPX-i
NI National Instruments PXI-5124 12-Bit, 200MS/s High Resolution Digitizer
NI National Instruments SCXI-1000, SCXI-1303, SCXI-1102, Omega Strips & Thermo.
NI PXI-1031 Chassis, PXI-8175 Controller, PXI-6713 PXI-6527 PXI-6031
NI PXI-1042 8-S PXI Mainframe with PXI-8176, PXI-6030E, PXI-6120, PXI-7831R
NI PXI-2533 256-Crosspoint 4x64 SSR Matrix Solid State Relay 197805A-01 PCI-2533
NI PXI-2556 2.5 GHz 75 Ω Dual 4x1 Mux card
NI PXI-4071 7.5-Digit 26-Bit 1000V Digital Multimeter FlexDMM Isolated Digitizer
NI PXI-5142 100 MS/s, 14-Bit Digitizer for Communications
NI PXI-5152 2 GS/s Digitizer/Oscilloscope, Optimized for Automated Test , DSA
NI PXI-6542 Digital Waveform Generator / Analyzer for Interfacing Applications
NI PXI-6551 , 50 MHz Digital Stimulus/Response
NI PXI-7852R , R Series Multifunction RIO with Virtex-5 LX50 FPGA , DAQ ADC DAC
NI PXI-8106 Dual-Core 2.16GHz/4GB/60GB Embedded Controller National Instruments
NI PXI-8110 , 2.26 GHz Quad-Core PXI Embedded Controller
NI PXIe-1062Q 8-S 3U PXI Express Chassis With AC - Up to 3 GB/s
NI PXIe-4140 ,National Instruments 4 Channel Source Measure Unit ( Flex SMU )
NI PXIe-8115 2.5 GHz Dual-Core PXI Express Controller
NI, NATIONAL INSTRUMENTS PCI-5124,Digitizer/Oscilloscop
Niagara GoStream SURF 96-01256-05 Portable Streaming Media Encoder ViewCast
NIAS DS4E-SL2-DC5V 100 piece minimum20.00 each or 300 for sale as one lot.
NIB - Siemans Software Step 7 (6AV6584-1AD06-0CX0)
NIB 1-3/16" Twin Disc Clutch Model V-1045 V1045
NIB 2 P0972PP NCNI REV 0B FOXBORO PLC MODULES (S39i)
NIB ABB Robotics Wrist Unit 3HAB 5575-1, Gasket Optigear Oil BM 100, 3HAB55751
NIB ABB T5N400BW 3 POLE ELECTRONIC TRIP CIRCUIT BREAKER
NIB ADEPT TECH 30340-40100 CONTROLLER CHASSIS MV-10
NIB ALLEN BRADLEY 1404-M605A-ENT-02 POWERMONITOR 3000 MASTER MODULE
NIB ALLEN BRADLEY 810A-25A MAGNETIC OVERLOAD RELAY
NIB ALLEN BRADLEY AC DRIVE POWERFLEX 700SE 300HP 480V CLASS 20DD530N3NNNN1NN3
NIB Allen Bradley Logix 5345 Processor 1768-L45 Ser B 01/2012
NIB Allen Bradley Panelview Plus 1500 2711P-B15C4D1 Date 2012
NIB ALLEN-BRADLEY 1336-QOUT-SP19A TRANSISTOR ASSY OUTPUT Factory Sealed FS
NIB AMETEK 1995-A-6M-X-X PROGRAMMABLE LIMIT SWITCH 6OUTPUT RELAY 10AMP 1995A6MXX
NIB BERGER LAHR RDM 51122/50 LTB 5 PHASE STEPPING MOTOR
NIB Bosch Pump Motor Combination 0513400212/0513400248_0513400212_0513400248
NIB COOPER BUSSMANN JCY-125E FUSE JCY125E 125E AMP
NIB Cutler Hammer Soft Start Reduced Voltage Motor Starter S801N37P3S S801
nib cuttler hammer jgs325033wz2 circuit breaker 3 pole 250 a
NIB Eaton Cutler Hammer HFDE316032 Series C CIRCUIT BREAKER 60-160 AMPS 600VAC
NIB EATON CUTLER HAMMER SVX040A1-4A1B1 SVX9000 40HP 380-500V DRIVE SVX040A14A1B1
nib eaton cuttler hammer ecn1821bkd electric motor controls starter size 2
NIB Emerson Motor R112 55BC02JPP3_R11255BC02JPP3_55BCO2JPP3
NIB FACTORY SEALED ALLEN BRADLEY O-55307 POWER SUPPLY CARD 460V O55307
NIB FANUC A06B-0147-B075#0076 AC Servo Motor
NIB FANUC A06B-0827-B190#3000 SPINDLE MOTOR
NIB FANUC A06B-6078-H111#H500 SPINDLE AMP
NIB Fanuc A06B-6088-H122#H500 SPM-22 Spindle Amp Module
NIB FANUC A06B-6088-H130#H500 Spindle Amp
NIB FANUC A16B-2200-0431/01A WITH AB 1771-RIO INTERFACE
NIB Fluke LOOP TESTER ( 990DSL )
NIB Fluke-190-204 AM, Series II Color Display Oscilloscope MSRP 4432.
NIB GE 300HP Contactor 460V CK10CE311 CK10CE311Y
NIB GE 5KS182E205C 200-230/460V INDUCTION MOTOR 3HP
NIB GE FANUC 44A719307104 CPU14 PROCESSOR BOARD
NIB GE Fanuc A06B-0128-B675#7075 AC Servo Motor
NIB GE FANUC A06B-0145-B177#7008 AC SERVO MOTOR
NIB GE GENERAL ELECTRIC DS3800 DS3800DMEA1D1C 6BA04
NIB GE MULTILIN 269 PLUS MOTOR MANAGEMENT RELAY 269PLUS-100P-HI W/SOFTWARE
NIB GE Multilin Motor Management Relay Model 369-HI-R-0-0-0-0-0
NIB GE Multilin Motor Management Relay Model 369-HI-R-0-0-E-0-0
NIB GE SPEEDTRONIC FANUC DS200LDCCH1AKA PC BOARD DRIVE LAN FACTORY SEALED
NIB GENERAL ELECTRIC IS200ICBDH1BAA PC BOARD
NIB GENERAL ELECTRIC S3800HSQD1J1G PC BOARD LOW HP SEQUENCE W/ DS3800DSQD1A1A
NIB Heidenhain LS186 Scale_LS1861234_ML 1240_336 960 23
NIB HIRSCHMANN IP67 SWITCH OCTOPUS 24M 943-923-011
NIB HONEYWELL 627-1002R COMMUNICATION MODULE MINICOP
NIB LINEAR SET FOR SPINDLE HEAD STOCK, EMAG MANUFACTURING SYSTEMS 3071966-0000
NIB Lovato 11BF16 40 230 60 Contactor
NIB MATSUSHITA ELECTRIC GD-C2 DOUBLE FEED DETECTOR CONTROLLER
NIB MITSUBISHI HC-KFS73G2 HCKFS73G2 750W AC SERVO WITH 1/29 REDUCER NIB
NIB Mitsubishi Inverter 460V 25HP FR-A540-18.5K-NA
NIB Mitsubishi S-N800UR Contactor AC200V
NIB MODICON 140 CPU 434 12A QUANTUM UNITY CPU 140CPU43412A
NIB MODICON AS-B875-002 800 I/O ANALOG INPUT PLC MODULE 4-20MA 8 CH (E5)
NIB Modicon Factory Mate Plus FM+ Electrical Module 557VIC12650 Schneider
NIB NEXEN Air Champ Clutch Part No 964006 Model DFE - 2200 Dual Faced Element
NIB NOS RELIANCE ELECTRIC GV3000 AC DRIVE 30R4140/ 896'-12-80 8961280
NIB NUM AC Brushless Servo Motor BPH1904K5AF2L01 _ BPH19O4K5AF2LO1
NIB PARKER EUROTHERM DRIVE 955D-8R32, MANUAL NO. HA351742; 955D8R32
NIB PYLE-National Heavy Duty Safety Switch WFRS-6036_WFRS6036_60 Amp_600 VAC
NIB Quadtech Guardian 6000 Electrical Safety Analyzer AC/DC Hipot Tester Cal'd
NIB RELIANCE ELECTRIC 57552-4A 575524A DRIVE CONTROLLER
NIB Reliance Electric Output Transistor 300A 1200VAC 402410-221AW
NIB Rexroth Bosch _ PXMC-04-000 _ Pneumatic Mist Collect Muffler Exhaust
NIB REXROTH VT-HNC100-1-23/W-08-P-0 DIGITAL AXIS CONTR.
NIB Rockwell Automation Reliance Electric AC Drive GV3000 SE 7.5 HP M/N 7V4260
NIB S. Himmelstein Non-Contact Torquemeter MCRT 49004V(5-3)CNNZ10000_10,000 RPM
NIB Schneider Electric Modicon Premium Processor TSXP573623AM_PV:04_RL:06_SV:6.2
NIB SCHNEIDER ELECTRIC MODICON TSXCAY42 4 AXIS N2 ANA MOTION CONTROL TSX CAY42
nib sick 7026352 C40P-0903CA010 S/R PAIR / C4000 SENDER/RECEIVER PAIR KIT
NIB Siemens 1FT6064-6AC71-4EH0 AC Servo Motor 1FT60646AC71
NIB Siemens 30HP Drive 380-480V SED2 SED2-22/31X
NIB SIEMENS 6AV3-617-1JC20-0AX2 OPERATOR PANEL OP 17-DP 617-1JC20-0AX2
NIB SIEMENS 6ES5470-4UC12 OUTPUT MODULE 8 POINT ANALOG
NIB SIEMENS 6ES5470-4UC13 OUTPUT MODULE ANALOG 470
NIB Siemens Panel P2E30ML250FTS _ P2E3OML25OFTS _ P2 _ 480Y/277 3PH 4W
NIB Siemens Permanent Magnet Motor 1FT5076-0AC71-1-Z 0 Cincinnati Milacron
NIB SIEMENS SIMATIC PANEL IN WELLON CP-365 P/N: 6AV6 545-0CC10-0AX0 (WASH)
NIB SQUARE D 12240051410010001 PANEL BOARD UNIT W/ 10 EDB34030AABA BREAKERS
NIB Square D 8536SFW21V02S Motor Starter
NIB Square D Class 9070 Transformer Disconnect SK1500A2 Ser. A_9070SK1500A2D1E23
NIB SQUARE D LAL362251021 MOLDED CASE CIRCUIT BREAKER
NIB SQUARE D SK3000G2 TRANSFORMER DISCONNECT 19026320
NIB SUPERMICRO 4U C2SBC-Q COMPUTER TPMS SYSTEM PC 4UC2SBCQ COMES W/SOFTWARE/INS
NIB TB WOODS P/N WF2C4001-0N WF2C40010N AC VECTOR DRIVE 1HP 3PH 380-460V
NIB TELEMECANIQUE ATV58HD16M2XZU DRIVE 15HP 208-240VAC
NIB TELEMECANIQUE XGSK6204321H4 COMPACT STATION
NIB TELEMECHANIQUE A203G12 3 PHASE SIZE 5 120V 60 HZ OPEN ENCLOSURE (232)
NIB THK GL15S16+1250L Linear Actuator Ball Screw 1250mm Travel 16mm Thread
NIB THK GL15S16+600L Linear Actuator Ball Screw 600mm Travel 16mm Thread
NIB THK GL15S16+800L Linear Actuator Ball Screw 800mm Travel 16mm Thread
NIB Toshiba VF-S11 Industrial Inverter Model VFS11-2075PMY-B1 3PH 200/240V
NIB TOYO MACHINERY PCP-45 CONTROL PANEL PCP45
NIB Vogel Centralized Lubrication Pump MFE5-BW30-V71 MFE5BW30V71_230/460 Volts
NIB Westinghouse 800 AMP Trip Unit HNB3800T 3 P Magnetic Trip Range 3000-6000 A
NIB XCEEDIUM GATEKEEPER XG9106-060V NETWORK
NIB? Allen-Bradley Scanner Head 2755-L9RD Ser D Rev C _ 2755L9RD
NIB? Rexroth Indramat Permanent Magnet Motor MDD112C-N-020-N2M-130GA2
NIBGould Modicon AS-516P-006 Prom PC Board Assembly CPU
NIBMetrologic HoloTrak IS8400 L Scanner
NIBSAFTRONICS GP10E1ST34030B1 AC INVERTER 460V 44/39A 30/25 HP NEMA 1 (R7)
NIBSchneider Magelis Display Control Unit TXBTF024510E _ TXBTFO2451OE
NIBSiemens Simo Drive Servo Motion Control 6SC6101-2B-Z _6SC61012BZ
NIBSiemens Simodrive 6SC6120-0FE01_6SC61200FE01_6SC-6120-0FE01_6SC612O-OFEO1
Nice Clean Unit...
NICE FANUC A16B-1310-0300 CNC BOARD A16B-1210-0410/03A AND ACP F10M/T10 PC BAORD
NICE Fischer Porter Differential Pressure Gauge + Manifold DA03 99LR03LW000C
NICE FLUKE DSP-4000 CABLE ANALYZER WITH DSP-4000SR SMART REMOTE DSP-LIA011 LINK
NICE HOUSTON ATLAS TRACKER XP THERMO ONIX
Nice Indramat Digital AC Servo Drive Compact Controller DDC01.2-N050C-DA02-01-FW
NICE MICRO-MOTION ELITE REMOTE FLOW TRANSMITTER W/MASS FLOW SENSOR CHF100M339NU
NICE OPHTHALMIC SET: STAND:71-49-01, PHOROPTOR: 11320,
NICE PORT 8800 PHOTONICS TEST SYSTEM W/ 8 MODULES
Nice Unit,Lk.
Nice UnitOptions 004 & 116 Recent Agilent Calibration
Nice UnitOptions 1,4 & 116 Recent Agilent Calibration
NICE5 HP BALDOR INVERTER DRIVE MOTOR + NORD 102 RPM SPEED REDUCER
NICEADEPT CARTESIAN ROBOT W/ Z-THETA MODULE, PENDANT, LITERATURE, WIRING, ETC.
NICEAllen Bradley 2711E-K10C15/2711EK10C15 Panel view terminal
Nicolet ECO-8S FTIR Spectrometer
Nicolet GRX Operator Touch Panel
Nicolet Instrument Isobe 3000 Fiber Optic Tester
Nicolet NXR Cohu X-ray Camera
Nicolet NXR-1400 Multi-Power Gun Board
Nihon Koshusha HFS-450-020-5 Generator
NIHON MARUKO KEYTRAN-II-UL CONTROLLER
NIKKI DENSO / SERVO AMPLIFIER / NPSA-G MDA-301YY-A2 / -
Nikki Denso Auctus Power NPSA-20NN-50-F8 26A-60.6A AC 200/220 NPSA20NN50F8 3Kva
Nikki Denso Digital S-Pack Servo Control NDS-501B _ NDS501B _ NDS-501BS8
Nikki Denso NPSA-102MU-E3C | 12 mo. | Free EUping | Inc UK VAT
NIKKI DENSO NPSA-ZMTA-101AE USPP NPSAZMTA101AE
NIKKI DENSO NPSA-ZMTA-101AE-CE USPP NPSAZMTA101AECE
NIKKI DENSO NPSA-ZMTA-201AE USPP NPSAZMTA201AE
Nikki Denso NPSA-ZMTA-751AE-CE
NIKKI DENSO NPST-E USPP NPSTE
NIKON 4S007-692-1 200mm Wafer Handler Prealigner
Nikon 4S065-960 ADE Amplifier KT001637
Nikon 4S066-014-3 CMTY-L Amplifier SPA476E
Nikon 4S066-015-3 CMTY-R Amplifier SPA476F
Nikon 4S066-590-2 RY-LU AMplifier SPA474I
Nikon 4S066-593-4 RY RD Amplifier SPA474L
Nikon 4T070-145 RX AMplifier SPA371C
Nikon 6D Darkfield Autocollimator in Wooden Case With Extra Lamps
Nikon ECLIPSE ME600P
Nikon Eclipse TS100 40x 20x 10x ELWD 0.3/OD75 C-W10x/22 Inverted Microscope
Nikon Linear Measurescope 20 LS-403 Stage (Reduced 8/12)
Nikon Measurescope 20 LS-402 Stage
Nikon Measurescope Model II w/CCTV Camera- Rack 12
Nikon MSYF MSLCT SPA376FC Amplifier
Nikon NSR-S306C 4S064-548 Tazmo NSR18 Robot Controller
Nikon objective lens CF Plan 5X/0.13 TI
Nikon OPTIPHOT 150 Microscope
Nikon Rotary Encoder RFH 1024-22-1 _ RFH1024221 _ A86L-0026-0001#001
Nikon SMZ 800 STEREO ZOOM MICROSCOPE
Nikon SMZ800
Nikon SPA276EC GCTX Amplifier
Nikon SPA373C EXZ Amplifier
Nikon SPA373DC MSZ Amplifier
Nikon SPA376C RZTRM Amplifier
Nikon SPA376EC EXYF EXLCT Amplifier
Nikon SPA376EP Power Supply Unit 4S066-022
Nikon SPA471G MSX-F Amplifier
Nikon SPA471H MSX-B Amplifier
Nikon SPA471I EXX-F Amplifier
Nikon SPA471J EXX-B Amplifier
Nikon SPA472E EXYC-L Amplifier
Nikon SPA472G MSYC-L Amplifier
Nikon SPA472H MSYC-R Amplifier
Nikon SPA474J RY-LD Amplifier
Nikon SPA474K RY-RU Amplifier
Nikon SPA476D TCM Amplifier
Nikon TDK Power Supply Assembly MSE182G 4S064-072 RGW48-32R MSE182H 4S013-302
NIKON VM-1000N CONTROLLER, 100-240V POWER CORD NOT INCLUDED BA
Nikon XY Stage - SC-102 and 2 digital drums
Nikon Yaskawa 4S064-330 Linear Motor Controller CLSR-42-N2CA
Nikon Yaskawa 4S586-560-5 Motion Controller XU-DV0705X
Nikon Yaskawa 4S587-180 Linear Motor Controller SPA325B
NIOBRARA R&D CORP EPE5-D USPP EPE5D
NIOBRARA R&D CORP EPE5-T USPP EPE5T
NIOBRARA R&D CORP EPE5-TCP-D USPP EPE5TCPD
- 电话:0592-6895313
- 传真:0592-6034581
- email:1950342667@qq.com
更多内容请访问 xmrxmy0012(http://home.gongkong.com/profile/?uid=2013072409553800001)
