- 型号:GUW
- 数量:15
- 有效期:2020/12/9 0:00:00
广州欧冠机电设备有限公司销售奥地利EISENBEISS减速机,EISENBEISS钢包回转驱动器,EISENBEISS齿轮箱、双驱动主轧减速机等
奥地利EISENBEISS,. 为一家自主经营的独资公司,致力于高性能齿轮的生产与研发,九十年来,EISENBEISS始终秉承其技术创新精神和优良传统,这是我们得以成功跨入企业发展新纪元的坚实基础,同时,我们在全球范围内的合作伙伴也因此而不断体验着成功的喜悦。
今天,在我们的业务领域一挤出机齿轮、重工业用齿轮,齿轮加工及齿轮产品专业技术服务方面,面对当前与未来的市场挑战,埃森柏斯已成为不断创新,意识超前的代名词。EISENBEISS减速机及其驱动装置广泛地使用于钢铁行业
Mechanical Transmission
Spur gear reducer for bulb Kaplan hydraulic turbine
500 - 7500 kW | TGU series
Spur gear reducer
500 - 10000 kW | 2X, Y2 series
100 - 7.500 kW, 750 rpm | TGVF, TDVF series
Spur gear reducer
100 - 10000 kW | GW, GUW series
Spur gear reducer
20 - 5000 kW | KG, KD series
Planetary winch gear reducer
100 - 500 kW | GPGD series
Bevel gear reducer for bulb Kaplan hydraulic turbine
100 - 2500 kW, 750 rpm | TKF series
Gear reducer for single screw extruder
100 - 1000 kW, 60 - 130 rpm, max. 500 bar | EEX series
Double helical gear
Gear reducer for lifting system
Multi-stage bevel spur gear reducer for grinding machine
100 - 600 kW | KGX series
Spur gear reducer for circular saw
100 - 500 kW | DX, GDX series
Spur gear reducer for levelling machine
20 - 500 kW | GW, GDW series
Transmission system for tension levelling line
200 - 1000 kW | KP series
Double stage hollow shaft bevel spur gear reducer for continuous casting machine
10 - 100 kW | KGDAM, KDDAM series
Worm planetary gear reducer for ladle turret
30 - 100 kW | SPKP, PKP series
Gear reducer for hydraulic turbine
50 - 2000 kW, 750 rpm | TKGV series
Gear reducer for counter rotating twin screw extruder
11 - 220 kW, 30 - 60 rpm, max. 500 bar | KGG series
Gear reducer for co-rotating twin screw extruder
11 - 5200 kW, 600 - 1800 rpm, max. 250 bar | PGL series
50 - 280 kW, 20 - 50 rpm, max. 500 bar | PGG series
Power generation gear reducer
Metrology and Test Equipment
Oil condition sensor
GearControl-OiL? Related Searches
- 电话:020 89667334
- email:eucrown@yahoo.cn
