- 型号:750-316
- 数量:1000
- 有效期:2029/9/3 0:00:00
750-303
750-303
750-304
750-306
750-306
750-310
750-310
750-312
750-315
750-315
750-316
750-316
750-319
750-319
750-323
750-333
750-333
750-337
750-337
750-341
750-342
750-342
750-343
750-344
750-346
750-346
750-347
750-348
750-350
750-400
750-400
750-401
750-401
750-402
750-402
750-403
750-404
750-404/000-002
750-404/000-003
750-404/000-005
750-405
750-405
750-406
750-408
750-409
750-410
750-411
750-415
750-415
750-421
750-422
750-422
750-423
750-427
750-427
750-430
750-430
750-430/025-000
750-431
750-432
750-433
750-435
750-436
750-437
750-438
750-452
750-453
750-454
750-454
750-454/025-000
750-455
750-455/025-000
750-456
750-457
750-457
750-459
750-459
750-460
750-461
750-461
750-461/000-002
750-461/000-007
750-461/000-200
750-461/000-200
750-461/003-000
750-461/003-000
750-465
750-466
750-466/000-200
750-467
750-468
750-468
750-469
750-469/000-001
750-469/000-002
750-469/000-006
750-469/003-000
750-472
750-474
750-474/000-200
750-476
750-476
750-477
750-478
750-479
750-479
750-480
750-482
750-483
750-485
750-491
750-491/000-001
750-492
750-501
750-501
750-502
750-502
750-504
750-506
750-506
750-508
750-509
750-512
750-512
750-513
750-514
750-516
750-516
750-517
750-519
750-522
750-523
750-523
750-530
750-530/025-000
750-531
750-531
750-536
750-550
750-552
750-554
750-555
750-555
750-556
750-556
750-557
750-557
750-559
750-560
750-600
750-600/025-000
750-601
750-602
750-602
750-603
750-604
750-609
750-610
750-611
750-612
750-613
750-614
750-614
750-615
750-615
750-616
750-616/030-000
750-623
750-625
750-626
750-627
750-628
750-630
750-630/000-008
750-631/000-004
750-635
750-636
750-637
750-637/000-002
750-638
750-638
750-641
750-642
750-643
750-645
750-650
750-650/000-001
750-650/000-006
750-650/000-015
750-653
750-653
750-653/003-000
750-653/003-000
750-653/025-000
750-655
750-660/000-001
750-670
750-670
750-804
750-804
750-806
750-806
750-815
750-815
750-816
750-819
750-819
750-833
750-833
750-837
750-838
750-841
750-841
750-842
750-842
750-920
750-923
750-925
750-960
750-963
750-965
750-970
750-975
现场总线耦合器 的,数字和模拟信号
这buscoupler允许系统连接的WAGO的a的I / O a作为奴隶到PROFIBUS现场总线。该buscoupler是模块能够支持所有I / O。 该自动配置,创造了当地亲 塞斯的形象,包括模拟,数字或特殊模块。 Analog and 模拟和专业课程模块的数据通过发送文字 和/或字节,数字数据传送一点一滴。的允许可编程控制器),PC或NC的图像存储过程中相应的主控制(。 本地进程图像分为两个数据区包含数据的接收和发送数据。 这个过程可以发送数据通过PROFIBUS现场总线与PLC,PC或数控作进一步处理,并获得 the field via PROFIBUS. PROFIBUS现场通过。模拟模块的数据的存储过程中的图像进行自动创建按顺序 该模块连接到数字模块的位的发送字节一个字节,并添加到 模拟数据。 如果数字信息量超过8位,buscoupler自动启动一个新的字节。在实施新安装的PROFIBUS DP的,请考虑与现场总线耦合器
- 电话:021-66100983
- 传真:021-66100663
- email:boyi1010@126.com
