- 型号:HDA4445-A-400-000
- 数量:15
- 制造商:德国贺德克/HYDAC
- 有效期:2020/8/8 0:00:00
现货 供应 德国贺德克【HYDAC】品牌:
压力传感器:HDA4445-A-400-000
HDA4444-A-016-000
HDA4444-A-060-000
HDA4444-A-100-000
HDA4444-A-250-000
HDA4444-A-400-000
HDA4444-A-600-000
HDA4444-B-016-000
HDA4444-B-060-000
HDA4444-B-100-000
HDA4444-B-250-000
HDA4444-B-400-000
HDA4444-B-600-000
HDA4445-A-016-000
HDA4445-A-060-000
HDA4445-A-100-000
HDA4445-A-250-000
HDA4445-A-400-000
HDA4445-A-600-000
HDA4445-B-016-000
HDA4445-B-060-000
HDA4445-B-100-000
HDA4445-B-250-000
HDA4445-B-400-000
HDA4445-B-600-000
德国HYDAC贺德克 HDA4444 HDA4445系列压力传感器:
技术参数如下:
Technical data:
Input data
Measuring ranges1) 16; 60; 100; 250; 400; 600; 1000 bar
Overload pressures 32; 120; 200; 500; 800; 1000; 1600 bar
Burst pressures 200; 300; 500; 1000; 2000; 2000; 3000 bar
Mechanical connection1) G1/4 A DIN 3852; G1/2 A DIN 3852
Torque value 20 Nm (G1/4); 45 Nm (G1/2)
Parts in contact with medium Mech. conn.: Stainless steel
Seal: FPM
Output data
Output signal, permitted load resistance 4 .. 20 mA, 2 conductor
RLmax. = (UB - 8 V) / 20 mA [kW]
0 ..10 V, 3 conductor
RLmin. = 2 kW
Accuracy to DIN 16086 ≤ ± 0.5 % FS typ.
Max. setting ≤ ± 1 % FS max.
Accuracy at min. setting ≤ ± 0.25 % FS typ.
(B.F.S.L.) ≤ ± 0.5 % FS max.
Temperature compensation ≤ ± 0.015 % FS / °C typ.
Zero point ≤ ± 0.025 % FS / °C max.
Over range ≤ ± 0.025 % FS / °C max.
Non-linearity at max. setting ≤ ± 0.3 % FS max.
to DIN 16086
Hysteresis ≤ ± 0.4 % FS max.
Repeatability ≤ ± 0.1 % FS
Rise time ≤ 1 ms
Long-term drift ≤ ± 0.3 % FS typ. / year
Environmental conditions
Compensated temperature range -25 .. +85 °C
Operating temperature range -25 .. +85 °C
Storage temperature range -40 .. +100 °C
Fluid temperature range2) -40 .. +100 °C / -25 .. +100 °C
mark EN 61000-6-1 / 2 / 3 / 4
mark3) Certificate No. E318391
Vibration resistance to ≤ 20 g
DIN EN 60068-2-6 at 10 .. 500 Hz
Protection class to IEC 60529 IP 65 (for male EN175301-803
(DIN 43650) and Binder 714 M18)
IP 67 (for M12x1, when an
IP 67 connector is used)
Other data
Supply voltage 8 .. 30 V DC, 2 conductor
12 .. 30 V DC, 3 conductor
for use acc. to UL spec. - limited energy - according to
9.3 UL 61010; Class 2;
UL 1310/1585; LPS UL 60950
Residual ripple of supply voltage ≤ 5 %
Current consumption ≤ 25 mA
Life expectancy > 10 million cycles
0 .. 100 % FS
Weight ~ 145 g
Note: Reverse polarity protection of the supply voltage, excess voltage, override and
short circuit protection are provided.
FS (Full Scale) = relative to complete measuring range
B.F.S.L.= Best Fit Straight Line
1) 1000 bar only with mechanical connection G 1/2 A DIN 3852 and vice versa
2) -25 °C with FPM seal, -40 °C on request
3) Environmental conditions in accordance with 1.4.2 UL 61010-1; C22.2 No 61010-1
- 电话:021-56672707
- 传真:021-56673217
- email:paiyuyy@126.com
