HS-C12-P01,HS-C12-P02,HS-C12-A01,HS-C12-A02,HS-C12-N11电感式接近开关
供稿:li582586887 2014/3/8 20:37:08
人气:40
- 型号:HS-C08-P02,HS-C08-A01,HS-C08-A02,HS-C08-N11,HS-C08-N12,HS-C08-P11
- 数量:10000
- 有效期:2024/3/23 0:00:00
防水接近开关,模拟量线性开关,耐高温开关,耐高压开关 ,防腐 特点 1、放大电路一体式设计,2、内部元件全部采用进口件,3、最高可在150℃的恶劣环境中应用 4、使用寿命长、高可靠性,5、浪涌,过载,逆极性保护功能,6、防水等级:IP67,可在水中应用
HS-C08-P02,HS-C08-A01,HS-C08-A02,HS-C08-N11,HS-C08-N12,HS-C08-P11,
HS-C08-P12,HS-C08-A11,HS-C08-A12,HS-CS08-N01,HS-CS08-N02,HS-CS08-P01,
HS-CS08-P02,HS-CS08-N11,HS-CS08-N12,HS-CS08-P11,HS-CS08-P12,HS-C08-N01-P3,
HS-C08-N02-P3,HS-C08-P01-P3,HS-C08-P02-P3,HS-C08-A01-P3,HS-C08-A02-P3,
HS-C08-N11-P3,HS-C08-N12-P3,HS-C08-P11-P3,HS-C08-P12-P3,HS-C08-A11-P3,
HS-C08-A12-P3,HS-C08-N01-E4,HS-C08-N02-E4,HS-C08-P01-E4,HS-C08-P02-E4,
HS-C08-A01-E4,HS-C08-A02-E4,HS-C08-N11-E4,HS-C08-N12-E4,HS-C08-P11-E4,
HS-C08-P12-E4,HS-C08-A11-E4,HS-C08-A12-E4,HS-CS08-N01-P3,HS-CS08-N02-P3,
HS-CS08-P01-P3,HS-CS08-P02-P3,HS-CS08-N11-P3,HS-CS08-N12-P3,HS-CS08-P11-P3,
HS-CS08-P12-P3,HS-CS08-N01-E4,HS-CS08-N02-E4,HS-CS08-P01-E4,HS-CS08-P02-E4,
HS-CS08-N11-E4,HS-CS08-N12-E4,HS-CS08-P11-E4,HS-CS08-P12-E4,HS2-C08-N01,
HS2-C08-N02,HS2-C08-P01,HS2-C08-P02,HS2-C08-N11,HS2-C08-N12,HS2-C08-P11,
HS2-C08-P12,HS2-C08-N01-P3,HS2-C08-N02-P3,HS2-C08-P01-P3,HS2-C08-P02-P3,
HS2-C08-N11-P3,HS2-C08-N12-P3,HS2-C08-P11-P3,HS2-C08-P12-P3,HS2-C08-N01-E4,
HS2-C08-N02-E4,HS2-C08-P01-E4,HS2-C08-P02-E4,HS2-C08-N11-E4,HS2-C08-N12-E4,
HS2-C08-P11-E4,HS2-C08-P12-E4,HS3-C08-N01,HS3-C08-N02,HS3-C08-P01,HS3-C08-P02,
HS3-C08-N11,HS3-C08-N12,HS3-C08-P11,HS3-C08-P12,HS3-C08-N01-P3,HS3-C08-N02-P3,
HS3-C08-P01-P3,HS3-C08-P02-P3,HS3-C08-N11-P3,HS3-C08-N12-P3,HS3-C08-P11-P3,
HS3-C08-P12-P3,HS3-C08-N01-E4,HS3-C08-N02-E4,HS3-C08-P01-E4,HS3-C08-P02-E4,
HS3-C08-N11-E4,HS3-C08-N12-E4,HS3-C08-P11-E4,HS3-C08-P12-E4,HS-Q08-N01,
HS-Q08-N02,HS-Q08-P01,HS-Q08-P02,HS-Q08-N01-P3,HS-Q08-N02-P3,HS-Q08-P01-P3,
HS-Q08-P02-P3,HS-QS08-N01,HS-QS08-N02,HS-QS08-P01,HS-QS08-P02,HS2-Q08-N01-P3,
HS2-Q08-N02-P3,HS2-Q08-P01-P3,HS2-Q08-P02-P3,HS2-Q08-N01,HS2-Q08-N02,
HS2-Q08-P01,HS2-Q08-P02,HS2-QS08-P01-P3,HS2-QS08-P02-P3,HS2-QS08-N01,
HS2-QS08-N02,HS2-QS08-P01,HS2-QS08-P02,HS3-Q08-N01-P3,HS3-Q08-N02-P3,
HS3-Q08-P01-P3,HS3-Q08-P02-P3,HS3-Q08-N01,HS3-Q08-N02,HS3-Q08-P01,HS3-Q08-P02,
HS3-QS08-N01,HS3-QS08-N02,HS3-QS08-P01,HS3-QS08-P02,HS-C12-N01,HS-C12-N02,
HS-C12-P01,HS-C12-P02,HS-C12-A01,HS-C12-A02,HS-C12-N11,HS-C12-N12,HS-C12-P11,
HS-C12-P12,HS-C12-A11,HS-C12-A12,HS-CS12-N01,HS-CS12-N02,HS-CS12-P01,
HS-CS12-P02,HS-CS12-A01,HS-CS12-A02,HS-CS12-N11,HS-CS12-N12,HS-CS12-P11,
HS-CS12-P12,HS-CS12-A11,HS-CS12-A12,HS-C12-N01-E4,HS-C12-N02-E4,HS-C12-P01-E4,
HS-C12-P02-E4,HS-C12-A01-E4,HS-C12-A02-E4,HS-C12-N11-E4,HS-C12-N12-E4,
HS-C12-P11-E4,HS-C12-P12-E4,HS-C12-A11-E4,HS-C12-A12-E4,HS-CS12-N01-E4,
HS-CS12-N02-E4,HS-CS12-P01-E4,HS-CS12-P02-E4,HS-CS12-A01-E4,HS-CS12-A02-E4,
HS-CS12-N11-E4,HS-CS12-N12-E4,HS-CS12-P11-E4,HS-CS12-P12-E4,HS-CS12-A11-E4,
HS-CS12-A12-E4,HS2-CS12-N01,HS2-CS12-N02,HS2-CS12-P01,HS2-CS12-P02,
HS2-CS12-N11,HS2-CS12-N12,HS2-CS12-P11,HS2-CS12-P12,HS2-C12-N01,HS2-C12-N02,
HS2-C12-P01,HS2-C12-P02,HS2-C12-A01,HS2-C12-A02,HS2-C12-N11,HS2-C12-N12,
HS2-C12-P11,HS2-C12-P12,HS2-C12-A11,HS2-C12-A12,HS2-C12-N01-E4,HS2-C12-N02-E4,
HS2-C12-P01-E4,HS2-C12-P02-E4,HS2-C12-A01-E4,HS2-C12-A02-E4,HS2-C12-N11-E4,
HS2-C12-N12-E4,HS2-C12-P11-E4,HS2-C12-P12-E4,HS2-C12-A11-E4,HS2-C12-A12-E4,
HS2-CS12-N01-E4,HS2-CS12-N02-E4,HS2-CS12-P01-E4,HS2-CS12-P02-E4,
- 电话:18317108518
- 传真:021-57687139
- email:li582586887@163.com
