- 型号:REL-IR/LDP-24DC/2X21
- 数量:500
- 制造商:菲尼克斯
- 有效期:2070/4/19 0:00:00
可插拔工业继电器,带功率型触点,2PDT,测试按钮,状态LED,续流二极管,机械开关位置显示,极性A1+,A2-,输入电压24V DC,菲尼克斯所有继电器特价。
上海博谊自控电气设备有限公司
联系电话:021-66100983 021-66100663
传真:021-66100663
联系人:陈一非 手机:13817898648
REL-IR2/LDP-12DC/2X21
REL-IR2/LDP-48DC/2X21
REL-IR2/LDP-60DC/2X21
REL-IR2/LDP-110DC/2X21
REL-IR4/L-120AC/4X21AU
REL-IR4/L-230AC/4X21AU
REL-IR4/LDP-125DC/4X21
REL-IR4/L-24AC/4X21AU
REL-IR4/LDP-60DC/4X21
REL-IR4/LDP-220DC/4X21
REL-IR4/LDP-125DC/4X21AU
REL-IR4/LDP-24DC/4X21AU
REL-IR4/LDP-60DC/4X21AU
REL-IR4/LDP-48DC/4X21AU
REL-IR4/LDP-12DC/4X21AU
REL-IR4/LDP-220DC/4X21AU
REL-IR4/LDP-110DC/4X21AU
REL-IR/L-120AC/2X21
REL-IR/L-24AC/2X21
REL-IR/LDP-110DC/2X21
REL-IR/LDP-12DC/2X21
REL-IR/LDP-60DC/4X21AU
REL-IR/LDP-60DC/2X21
REL-IR2/LDP-220DC/2X21
REL-IR2/LDP-125DC/2X21
REL-IR/LDM-24DC/2X21
REL-IR/L-230AC/4X21AU
REL-IR/L-120AC/4X21AU
REL-IR/L-24AC/4X21AU
REL-IR/LDP-110DC/4X21AU
REL-IR/LDP-48DC/4X21AU
REL-IR/LDP-24DC/4X21AU
REL-IR/LDP-12DC/4X21AU
REL-IR/L-230AC/2X21
REL-IR/LDP-220DC/4X21AU
REL-IR/LDP-125DC/2X21
REL-IR/LDP-220DC/2X21
REL-IR/LDP-125DC/4X21AU
REL-IR/LDM-110DC/4X21AU
REL-IR/LDM-48DC/4X21AU
REL-IR/LDM-24DC/4X21AU
REL-IR/LDM-12DC/4X21AU
REL-IR/LDM-110DC/2X21
REL-IR/LDM-48DC/2X
REL-IRG 48
REL-IRG 24
REL-IR4/L-24AC/4X21
REL-IR2/L-230AC/2X21
REL-IR2/L-120AC/2X21
REL-IR2/L-24AC/2X21
REL-IR2/LDP-24DC/2X21
REL-IRG110
EMG 45-REL/IR-G24/HWR
PR2-BSP3/4X21
PR2-BSC3/4X21
PR2-BSC2/4X21
EMG 45-REL/IR-W230/HWR
EMG 45-REL/IR-W24/HWR
SZF 3-1,0X5,5
操作工具,用于ST端子,同样可用作一字刀口螺丝刀,尺寸: 1.0 x 5.5 x 150 mm,2件式夹具, 带防滑手柄,菲尼克斯工具价廉物美的产品,让您赶活得心应手。
SZF 0-0,4X2,5
SZK PH2 (杆长100毫米)
SZK PH1 (杆长80毫米)
SZF 2-0,8X4,0
SZF-1-0.6X3.5
SZS0.6X3.5
SZF 0-0,4X2,5
SZK PZ3 VDE
SZS 1,2X8,0 VDE
SZG 0,9X6,5 VDE
SZS 0,6X3,5 VDE
SZK PH3 VDE
SZS 0,6X2,5 VDE
SZS 0.4X2,0
SZS 0.8*4.0
SZS 0,5X3,0
SZS 1,0X6,5
SZK PZ2
SZG 0,6X3,5
SZS 1-1.0*6.5
SZK PZ0
SZK PZ1
SZF 1-0,6X3,5
SZK PH0
SZS 0.4*2.5
SZS 1.0*4.0
SZS 0.6*3.5
QUINT-PS-100-240AC/24DC/5A
QUINT-PS-3X400-500AC/24DC/10A
QUINI-PS-100-240AC/24DC/20A
QUINT-PS-100-240AC/12DC/10A
QUINT-PS-100-240AC/24DC/2.5A
QUINT-PS-3*400-500AC/24DC/30A
QUINT-PS-3*400-500AC/24DC/5A
QUINT-PS-100-240AC/24DC/10
QUINT-PS-100-240AC/24DC/40A
MINI-PS-100-240AC/24DC/1
QUINT-DC-UPS/24DC/20
QUINT-BUFFER/24DC/20
TRIO-PS/1AC/24DC/5
QUINT-PS-100-240AC/48DC/5
TRIO-PS/1AC/24DC/10
QUINT-PS-1AC/24DC/10
QUINT-DC-UPS/24DC/10
QUINT-BAT/24DC/12AH
QUINT-PS-100-240AC/48DC/20
QUINT-PS/1AC/24DC/5
STEP-PS-100-240AC/12DC/3
QUINT-PS/3AC/24DC/20
TRIO-PS/1AC/24DC/20
TRIO-PS/3AC/24DC/40
TRIO-PS/1AC/24DC/2,5
QUINT-PS/3AC/24DC/10
TRIO-PS/3AC/24DC/10
QUINT-PS/ 1AC/24DC/40
QUINT-PS-1AC/24DC/20
QUINT-PS/ 3AC/24DC/ 5
QUINT-BAT/24DC/7.2AH
QUINT-PS-100-240AC/24DC/10/EX
QUINT-PS/3AC/24DC/40
QUINT-PS/FAN/4
QUINT-PS/24DC/24DC/5
QUINT-PS-100-240AC/24DC/5/EX
QUINT-PS/1AC/48DC/10
PLC-RSC-48DC/21-21
QUINT-PS/1AC/24DC/3.5
STEP-PS/1AC/24DC/4.2
QUINT-PS/1AC/12DC/15
TCP 5/DC32V
TCP 7,5/DC32V
TCP 10/DC32V
TCP 20/DC32V
REL-IR/L-230AC/2X21
MACX MCR-SL-RPSSI-2I
PSR-SCP-230UC/ESAM4/3X1/1X2/B
MCR-SL-D-FIT
PSI-MOS-PROFIB/FO1300 T
FLM DI 16 M12
PLC-BSC-24DC/1-1/ACT
PSR-SPP-24DC/ESP4/2X1/1X2
EEM-MA600
PLC-RSC-230UC/21HC
REL-MR-24DC/1IC
EEM-MA400
EEM-RS485-MA400
PLC-BSC-230UC/1/SEN
CM-KBL-RS232/USB
PLC-BSC-24DC/1/SEN
PLC-RSC-230UC/1AU/SEN
PLC-BSC- 24DC/21/SO46
PLC-RSC-24UC/21-21
MINI MCR-SL-RPS-I-I-SP
PSR-SPP-24UC/ESA4/2X1/1X2
ELR W3- 24DC/500AC- 9I
PLC-OSC-24DC/24DC/2ACT
PLC-RSC-120UC/21-21
MINI MCR-SL-U-U
MACX MCR-SL-RPSSI-I
MACX MCR-UI-UI-UP-NC
MINI MCR-BL-RPS-I-I
MCR-FL-UI-UI-B-DCI-24/230
PR2-RSC3-LV-230AC/4X21AU
NEF 1-10
MCR-C-U-I-4-DC
FLM AI 4 SF M12
MCR-SL-1CLP-I-I-00-4KV
PSR-SCP-24UC/ESAM4/8X1/1X2
MCR-S-10-50-UI-DCI
PLC-RSC-24DC/21-21AU
MINI MCR-SL-UI-UI-NC
PLC-BSP-24DC/21
FLM DI 8 M12
MINI MCR-SL-UI-2I-NC
PLC-RSC-24DC/21HC
REL-MR- 24DC/21HC
PSI-MOS-PROFIB/FO 850 T
FLKMS-D50 SUB/S
MCR-PT100-I-DC
OPT-24DC/230AC/1
MACX MCR-EX-SL-RPSSI-I
SUBCON-PLUS-PROFIB/PG/SC2
PSR-SCP-24UC/ESA2/4X1/1X2/B
PLC-RSC-230UC/21/S046
MCR-CLP-UI-I-4
PLC-BSC-230UC/21-21
PSM-ME-RS485/RS485-P
REL-MR-60DC/21
PLC-RSC-230UC/21-21/S046
PLC-RSC-24DC/1-1/ACT
MCR-C-I-U-4-DC
PLC-BSC-24DC/1/ACT
PLC-RSC-230UC/21-21
MACX MCR-SL-CAC-5-I-UP
PLC-RSC-24DC/1IC/ACT
PSM-EG-RS-232/TTY-P/2K
MINI MCR-SL-RPS-I-I
PLC-BSC-24UC/21-21
REL-MR- 24DC/21-21AU
MCR-FL-C-UI-2UI-DCI-NC
MINI MCR-SL-2CP-I-I-SP
DEK-REL-24/O/1
PSR-SCP-24UC/ESA4/2X1/1X2
PLC-RSC-120UC/21
MCR-C-UI-UI-DCI-NC
MCR-FL-C-UI-2UI-DCI
MINI MCR-SL-UI-2I
PSR-SCP-24UC/ESA4/3X1/1X2/B
REL-MR-24DC/21
PLC-RSC-220UC/21-21-SO46
PSM-ME-RS232/RS485-P
PLC-RSC-230UC/21
PLC-BSC-24DC/21-21
PSR-SCP-24DC/ESD/5X1/1X2/300
EMG 17-OV- 24DC/ 24DC/2
OPT-24DC/24DC/2
VAL-MS BE/FM
PLC-BSC-24DC/21
PLC-BSC-230UC/21
PLC-RSC-24DC/1/ACT
PLC-RSC-24DC/21
MINI MCR-SL-1CP-I-I
MCR-C-UI-UI-DCI
MCR-T/UI-E
MINI MCR-SL-I-I
MINI MCR-SL-PT100-UI
ETD-SL-1T-DTF
PLC-RSC-24DC/21-21
MCR-C-I-I-OO-DC
PLC-RSC-24DC/21AU
FL SWITCH SF 15TX/FX
FL SWITCH SFNB 4TX/FX
IB IL 24 FLM-PAC
IB IL 24 DO 8-PAC
FL SWITCH LM 8TX-E
IB IL IMPULSE-IN-PAC
FL SWITCH SFN 7TX/FX
IB IL 24/230 DOR1/W-PAC
IB IL 24 DO 8-2A-PAC
ILC 370 ETH 2TX-IB
IB IL AO 2/U/BP-ME
IB IL 400 CN-PWR-IN
FL SWITCH SFNT 7TX/FX ST
IB IL 24 DO 2-2A-PAC
FL SWITCH LM 5TX
FLM DIO 4/4 M12-2A
IB IL TEMP 2 RTD-PAC
FL SWITCH SFNB 8TX
IB IL 24 DI 4-PAC
IB ST 24 AO 4/SF
FL SWITCH LM 4TX/2FX SM
IB IL AO 1/SF-PAC
IB ST 24 DI 32/2
FL SWITCH SFN 6TX/2FX
FL SWITCH Sf 14TX/2FX
FL SWITCH SFN 4TX/FX
IB ST 24 AI 4/SF
FLM DO 8 M12
IB ST 24 AI 4/SF4
FL SWITCH SFN 5TX
FL SWITCH SFN 8TX
FL SWITCH SFN 6TX/2FX ST
IB IL 24 DO 4-PAC
FL SWITCH SF 16TX
IB IL AI 2/SF-PAC
IB IL 24 PWR IN/2-F-PAC
IB IL 24 DO 4-ME
IB IL 24 DI 4-ME
IB IL AI 8/SF-PAC
IB IL 24 DO 16-PAC
IB IL 24 DI 16-PAC
IB IL AO 2/SF-PAC
FL SWITCH SF 8TX
FL SWITCH SF 6TX/2FX
FLT-CP-3C-350
1+2类 /I+II级 / B+C插拔式组合防雷及电涌保护器采用AEC主动能量控制技术,用于三相四线(L1、L2、L3、PEN)电网的保护
FLT-CP-3S-350
FLT-CP-3C-350
FLT-CP-1S-350
FLT-CP-1C-350
FLT-CP-N/PE-350
FLT-CP-2S-350
FLT-CP-2C-350
FLT-CP-PLUS-350-ST
SFP 1-20/230AC
FLT-CP-3S-BE
FLT-CP-3C-BE
FLT-CP-350-ST
F-MS 40-ST
FLT-CP-PLUS-3S-350
FLT-CP-PLUS-3C-350
FLT-CP-PLUS-2S-350
FLT-CP-PLUS-2C-350
FLT-CP-PLUS-1S-350
FLT-CP-PLUS-1C-350
FLT 35/3+1 CTRL-0.9/I
FLT 100 N/PE CTRL-1.5
FLT-PLUS CTRL-1.5
LT-63
FLT-PLUS CTRL-0.9
FLT-PLUS CTRL-1.5/I
FLT-PLUS CTRL-2.5
FLT-PLUS CTRL-2.5/I
FLT-PLUS CTRL-0.9/I
F-MS 12/FM
F-MS 12
F-MS 12 ST
FLT 25-400
FLT-PLUS CTRL-3.0
FLT-PLUS CTRL-3.0/I
FLT 35 CTRL-0.9/I/50
FLT 60-400
FLT 50 N/PE
FLT 35-260
FLT-PLUS
FLT-PLUS CTRL-1.5
FLT-PLUS CTRL-1.5/I
FLT-PLUS CTRL-2.5
FLT-PLUS CTRL-2.5/I
FLT 35/3+1 CTRL-2.0/I
FLT 100 N/PE CTRL-1.5/25
FLT 35 CTRL-0.9/50
- 电话:021-66100983
- 传真:021-66100663
- email:boyi1010@126.com
下一篇:Dart甲醛传感器
