厂家直供 16G福迪科SATA2固态硬盘 工业级SSD
2014/8/15 10:40:39
0 人气:1
- 数量:1000
Fordisk S2 16G | |||||
型号(Model) | Fordisk S2 16GB | ||||
概述(General) | 传输模式(Interface) | SATAII/3.0 Gbps | |||
尺寸(Dimensions) | 2.5" 100 x 70 x 9mm | ||||
容量(capacity) | 16GB | ||||
存取介质(Storage Media) | MLC NAND Flash | ||||
性能(Performance) | 连续读(Sustained Read) | up to 160MB/s | |||
连续写(Sustained Write) | up to 19MB/S | ||||
功耗(Power Consumption) | 输入电压(input Voltage) | 5V | |||
空闲(Idle) | 0.2W | ||||
工作(Active) | 1W | ||||
可靠性(Reliability& Endurance) | 均衡算法(Wear-Leveling) | 动态与静态全局平均算法(Dynamic and static wear-leveling) | |||
数据保存(Data Retention) | 10年(10years at 26oC) | ||||
平均故障间隔时间(MTBF) | >200 W小时(>2,000,000hours) | ||||
坏块管理(Bad Block Management) | 自动坏块管理(Auto Bad Block Management in system) | ||||
纠错能力(ECC) | Supports BCH ECC 72bits in 1K bytes | ||||
质保时间(Warranty) | 周期(Time limit) | 2年(3years) | |||
工作环境(Environment) | 工作温度(Operating Temperature) | 0 - +70℃ | |||
存放温度(Storage Temperature) | -40 - +100℃ | ||||
耐冲击度(Shock) | 1000G | ||||
耐振强度(Vibration) | 15G | ||||
环境湿度(Ambient Humidity) | 5%-95% | ||||
生产情况(Available unit) | 量产中,无停产计划(NO EOL) | ||||
测试系统(Testing OS) | WindowsXP SP2 | ||||
测试平台(Testing Platform) | Mainboard:ASUS B75M-A;CPU:G1620 2.7Ghz;DRAM:DDR3 2GB | ||||
测试软件(Testing Software) | CrystalDiskMark 3.01 x64 | ||||
注意:所有电气参数会因产品个性或测试平台不同而有所差异,仅供参考,请以实样为准! (Note:Electrical specifications and weight will vary with different capacity of products.) |
- 电话:15602217770
- email:1626979143@qq.com
相关推荐
工控宝APP下载安装
