- 型号:BOS 6K-PU-1HA-S75-C,BOS009Y
- 数量:100
- 制造商:深圳市天为机电设备有限公司
巴鲁夫BALLUFF传感器BOS 6K-PU-1HA-S75-C,BOS009Y
激光可显著增大检测距离,提高检测小物体的精度
对于防护等级为2级的激光,无需额外的预防保护措施
使用这类传感器解决复杂困难的问题将是一个理想的选择
加工定制:否
品牌:BALLUFF/巴鲁夫
种类:位移
材料:混合物
材料物理性质:磁性材料
材料晶体结构:非晶
制作工艺:集成
输出信号:数字型
防护等级:1
线性度:1(%F.S.)
迟滞:1(%F.S.)
重复性:1(%F.S.)
灵敏度:1 漂移 1
分辨率:1
外型尺寸:20×32×12 mm
BOS6K-PU-1YC-S75-C
BOS6K-PU-1YC-C-02
BOS6K-PU-1UC-S75-C
BOS6K-PU-1UC-C-02
BOS6K-PU-1TA-S75-C
BOS6K-PU-1TA-C-02
BOS6K-PU-1QC-S75-C
BOS6K-PU-1QC-S49-C
BOS6K-PU-1QC-C-02
BOS6K-PU-1QA-S75-C
BOS6K-PU-1QA-S49-C
BOS6K-PU-1QA-C-02
BOS6K-PU-1OC-S75-C
BOS6K-PU-1OC-S49-C
BOS6K-PU-1OC-C-02
BOS6K-PU-1N1O-S75-C
BOS6K-PU-1N1O-C-02
BOS6K-PU-1LQA-S75-C
BOS6K-PU-1LQA-C-02
BOS6K-PU-1LHA-SA1-S75-C
BOS6K-PU-1LHA-SA1-C-02
BOS6K-PU-1LHA-S75-C
BOS6K-PU-1LHA-C-02
BOS6K-PU-1HA-S75-C
BOS6K-PU-1HA-S75-00,5
BOS6K-PU-1HA-S49-C
BOS6K-PU-1HA-C-02
BOS6K-PU-1FR-S75-C
BOS6K-PU-1FR-C-02
BOS6K-NU-1YC-S75-C
BOS6K-NU-1YC-C-02
BOS6K-NU-1UC-S75-C
BOS6K-NU-1UC-C-02
BOS6K-NU-1TA-S75-C
BOS6K-NU-1TA-C-02
BOS6K-NU-1QC-S75-C
BOS6K-NU-1QC-C-02
BOS6K-NU-1QA-S75-C
BOS6K-NU-1QA-C-02
BOS6K-NU-1OC-S75-C
BOS6K-NU-1OC-C-02
BOS6K-NU-1N1O-S75-C
BOS6K-NU-1N1O-C-02
BOS6K-NU-1LQA-S75-C
BOS6K-NU-1LQA-C-02
BOS6K-NU-1LHA-SA1-S75-C
BOS6K-NU-1LHA-SA1-C-02
BOS6K-NU-1LHA-S75-C
BOS6K-NU-1LHA-C-02
BOS6K-NU-1HA-S75-C
BOS6K-NU-1HA-C-02
BOS6K-NU-1FR-S75-C
BOS6K-NU-1FR-C-02
BOS26K-PS-1LHC-S4-C
BOS26K-PS-1HC-S4-C
BOS26K-PO-1QE-SA1-C
BOS26K-PA-1QE-S4-C
BOS26K-PA-1LQP-S4-C
BOS26K-PA-1LQK-S4-C
BOS26K-PA-1LQE-SA2-S4-C
BOS26K-PA-1LQE-SA1-S4-C
BOS26K-PA-1LQB-S4-C
BOS26K-PA-1LHC-S4-C
BOS26K-PA-1LHB-S4-C
BOS26K-PA-1LHA-SA1-S4-C
BOS26K-PA-1IE-S4-C
BOS26K-PA-1HC-S4-C
BOS26K-NA-1QE-S4-C
BOS26K-NA-1LQP-S4-C
BOS26K-NA-1LHC-S4-C
BOS26K-NA-1LHB-S4-C
BOS26K-NA-1LHA-SA1-S4-C
BOS26K-NA-1IE-S4-C
BOS26K-NA-1HC-S4-C
BOSQ08M-NO-LE20-00,2-S49
BOSQ08M-NO-KE20-S49
BOSQ08M-NO-KE20-02
BOSQ08M-NO-KE20-00,2-S49
BOS74K-UU-1FS-BO-Z-02
BOS74K-UU-1FR-BO-Z-S49-00,2
BOS74K-UU-1FR-BO-Z-02
BOS74K-UU-1FR-BO-Z
BOS74-HW-1
BOS73K-PU-1FR-C-S75-00,1
BOS73K-PU-1FR-C-S49-00,3
BOS73K-PU-1FR-C-02
BOS6-HW-1
BOS65K-5-M110T-2P-S4
BOS65K-5-M110T-1
BOS65K-5-C200T-2P-S4
BOS65K-5-C200T-1
BOS65K-5-B8T-2P-S4
BOS65K-5-B8T-1
BOS65K-1-M110T-1
BOS65K-1-C200T-1
BOS65K-1-B8T-1
BOS63M-PSV-LH10-S4
BOS63M-PS-LH13-S4
BOS63M-NSV-LH10-S4
BOS63M-NS-LH13-S4
BOS5K-PS-RR10-S75
BOS5K-PS-RR10-S49
BOS5K-PS-RR10-02
BOS5K-PS-RR10-01
BOS5K-PS-RH12-S75
BOS5K-PS-RH12-S49
BOS5K-PS-RH12-02
BOS5K-PS-RH12-00,1-S75
BOS5K-PS-RD11-S75
BOS5K-PS-RD11-S49
BOS5K-PS-RD11-02
BOS5K-PS-IX10-S75
BOS5K-PS-IX10-S49
BOS5K-PS-IX10-02
BOS5K-PS-ID10-S75
BOS5K-PS-ID10-S49
BOS5K-PS-ID10-02
BOS5K-PS-ID10-00,2-S75
BOS5K-PO-RR10-S75-S
BOS5K-PO-RR10-S75
BOS5K-PO-RR10-S49
BOS5K-PO-RR10-02
BOS5K-PO-RR10-01
BOS5K-PO-RH12-S75
BOS5K-PO-RH12-S49
BOS5K-PO-RH12-02
BOS5K-PO-RD11-S75
BOS5K-PO-RD11-S49
BOS5K-PO-RD11-02
BOS5K-PO-RD11-01
BOS5K-PO-IX10-SA1-03
BOS5K-PO-IX10-S75-S
BOS5K-PO-IX10-S75
BOS5K-PO-IX10-S49
BOS5K-PO-IX10-03
BOS5K-PO-IX10-02
BOS5K-PO-ID10-S75-S
BOS5K-PO-ID10-S75
BOS5K-PO-ID10-S49
BOS5K-PO-ID10-02
BOS5K-PO-ID10-01
BOS5K-NS-RR10-S75
BOS5K-NS-RR10-S49
BOS5K-NS-RR10-02
BOS5K-NS-RH12-S75
BOS5K-NS-RH12-S49
BOS5K-NS-RH12-02
BOS5K-NS-RD11-S75
BOS5K-NS-RD11-S49
BOS5K-NS-RD11-02
BOS5K-NS-RD11-01
BOS5K-NS-IX10-S75
BOS5K-NS-IX10-S49
BOS5K-NS-IX10-02
BOS5K-NS-ID10-S75
BOS5K-NS-ID10-S49
BOS5K-NS-ID10-02
BOS5K-NS-ID10-01
BOS5K-NO-RR10-S75-S
BOS5K-NO-RR10-S75
BOS5K-NO-RR10-S49
BOS5K-NO-RR10-02
BOS5K-NO-RR10-01
BOS5K-NO-RH12-S75
BOS5K-NO-RH12-S49
BOS5K-NO-RH12-02
BOS5K-NO-RD11-S75
BOS5K-NO-RD11-S49
BOS5K-NO-RD11-02
BOS5K-NO-IX10-S75-S
BOS5K-NO-IX10-S75
BOS5K-NO-IX10-S49
BOS5K-NO-IX10-02
BOS5K-NO-ID10-S75-S
BOS5K-NO-ID10-S75
BOS5K-NO-ID10-S49
BOS5K-NO-ID10-02
BOS50K-PSV-RH12-SA1-S4
BOS50K-PSV-RH12-S4
BOS50K-PS-RH12-S4
BOS50K-POV-RH12-S4
BOS50K-PA-RH12-S4
BOS50K-NSV-RH12-S4
BOS50K-NOV-RH12-S4
BOS50K-NA-RH12-S4
BOS45K-5-C90
BOS45K-5-C200T
BOS45K-5-B3T
BOS45K-5-B3
BOS45K-1-C90
BOS45K-1-C200T
BOS45K-1-B3T
BOS45K-1-B3
BOS36K-PA-1QH-S4-C
BOS36K-PA-1QH-C-02
BOS36K-PA-1PH-S4-C
BOS36K-PA-1HD-S4-C
BOS36K-NA-1PH-C-02
BOS35K-WS-7XB-BO-L-03
BOS35K-PS-SA1-S4
BOS35K-PS-1XB-S4-C
BOS35K-PS-1UD-S4R-C
BOS35K-PS-1UD-S4-C
BOS35K-PS-1RH-S4R-C
BOS35K-PS-1RH-S4-C
BOS35K-PS-1RH-BO-C-03
BOS35K-PS-1PD-S4-C
BOS35K-PO-1XB-S4-C
BOS35K-PO-1UD-S4-C
BOS35K-PO-1RE-S49R-C
BOS35K-PO-1PD-S4-C
BOS35-HW-1
BOS35-AD-2
BOS35-AD-1
BOS30-TF-1
BOS30M-PU-1PH-SA3-C
BOS30M-GA-1PH-S4-C
BOS30-DM-1
BOS30,0-KB-1
BOS2K-X-RS10-02
BOS2K-X-RS10-00,2-S75
BOS2K-X-RS10-00,2-S49
BOS2K-PS-RH11-02
BOS2K-PS-RH11-00,2-S75
BOS2K-PS-RH11-00,2-S49
BOS2K-PS-RH10-02
BOS2K-PS-RH10-00,2-S75
BOS2K-PS-RH10-00,2-S49
BOS2K-PS-RE10-02
BOS2K-PS-RE10-00,2-S75
BOS2K-PS-RE10-00,2-S49
BOS2K-PS-RD10-02
BOS2K-PS-RD10-00,2-S75
BOS2K-PS-RD10-00,2-S49
BOS2K-PS-PR10-02
BOS2K-PS-PR10-00,2-S75
BOS2K-PS-PR10-00,2-S49
BOS2K-PO-RH11-02
BOS2K-PO-RH10-00,2-S49
BOS2K-PO-RE10-02
BOS2K-PO-PR10-02
BOS2K-PO-PR10-00,2-S49
BOS2K-NS-RH11-02
BOS2K-NS-RH10-02
BOS2K-NS-RE10-02
BOS2K-NS-RD10-02
BOS2K-NS-PR10-02
BOS2K-NO-RH10-02
BOS2K-NO-PR10-02
BOS2-HW-3
BOS2-HW-2
BOS2-HW-1
BOS26-HW-1
BOS25K-5-T1-02
BOS25K-5-M25-P-S4
BOS25K-5-M25-02
BOS25K-5-C90-P-S4
BOS25K-5-C90-02
BOS25K-5-C200-02
BOS25K-5-B5-02
BOS25K-1-T1-02
BOS25K-1-C90-02
BOS25K-1-C200-02
BOS25K-1-B5-02
BOS25K-1-A6-02
BOS25-HW-1
BOS23K-XT-RS11-S4
BOS23K-XT-LS11-S4
BOS23K-PU-RR10-S4
BOS23K-PU-RH10-S4
BOS23K-PU-RE10-S4
BOS23K-PU-RD10-S4
BOS23K-PU-LR10-S4
BOS23K-PU-LH20-S4
BOS23K-PU-LH10-S4
BOS23K-PU-LE10-S4
BOS23K-PU-LD20-S4
BOS23K-PU-LD10-S4
BOS23K-NU-RR10-S4
BOS23K-NU-RH10-S4
BOS23K-NU-RE10-S4
BOS23K-NU-RD10-S4
BOS23K-NU-LR10-S4
BOS23K-NU-LH20-S4
BOS23K-NU-LH10-S4
BOS23K-NU-LE10-S4
BOS23K-NU-LD20-S4
BOS23K-NU-LD10-S4
BOS21M-XT-LS11-S4
BOS21M-XT-IS11-S4
BOS21M-PUS-RV13-S4
BOS21M-PUS-RH12-S4
BOS21M-PUS-LH12-S4
BOS21M-PA-RD10-S4
BOS21M-PA-PT14-S4
BOS21M-PA-PT10-S4S
BOS21M-PA-PT10-S4
BOS21M-PA-PR10-S4S
BOS21M-PA-PR10-S4
BOS21M-PA-PK10-S4S
BOS21M-PA-PK10-S4
BOS21M-PA-LR10-S4S
BOS21M-PA-LR10-S4
BOS21M-PA-LE10-S4S
BOS21M-PA-LE10-S4
BOS21M-PA-LD10-S4
BOS21M-PA-IE10-S4S
BOS21M-PA-IE10-S4
BOS21M-PA-ID10-S4
BOS21M-NUS-RV13-S4
BOS21M-NUS-RH12-S4
BOS21M-NUS-LH12-S4
BOS21M-NA-RD10-S4
BOS21M-NA-PT14-S4
BOS21M-NA-PT10-S4
BOS21M-NA-PR10-S4
BOS21M-NA-PK10-S4
BOS21M-NA-LR10-S4
BOS21M-NA-LE10-S4
BOS21M-NA-LD10-S4
BOS21M-NA-IE10-S4
BOS21M-NA-ID10-S4
BOS21-KH-2
BOS21-KH-1
BOS21-HW-4
BOS21-HW-3
BOS21-HW-2
BOS21-HW-1
BOS21-HS-1
BOS21-AD-1
BOS20K-ZU-1FR-S75-C
BOS20K-ZU-1FR-C-PU-02
BOS18-WS-1
BOS18-UK-2
BOS18-UK-10
BOS18-UK-1
BOS18-TF-1
BOS18-SM-1
BOS18-PK-1
BOS18-PF-1
BOS18-NF-2
BOS18-NF-1
BOS18M-XT-LS10-S4
BOS18M-XT-LS10-02
BOS18M-WS-7XB-BO-L-03
BOS18M-WS-7XA-BO-L-03
BOS18M-WS-7RB-BO-L-03
BOS18M-WS-7PB-B1-L-05
BOS18M-WS-7PB-B1-L-03
BOS18M-WO-7XA-BO-L-03
BOS18MR-XT-LS10-S4
BOS18MR-XT-LS10-02
BOS18MR-PS-1QB-E5-C-S4
BOS18MR-PS-1OD-E5-C-S4
BOS18MR-PS-1HA-E5-C-S4
BOS18MR-PA-LR10-S4
BOS18MR-PA-LR10-02
BOS18MR-PA-LE10-S4
BOS18MR-PA-LE10-02
BOS18MR-PA-LD10-S4
BOS18MR-PA-LD10-02
BOS18MR-PA-1HA-S4-C
BOS18MR-NA-LR10-S4
BOS18MR-NA-LR10-02
BOS18MR-NA-LE10-S4
BOS18MR-NA-LE10-02
BOS18MR-NA-LD10-S4
BOS18MR-NA-LD10-02
BOS18M-PU-1QB-S4-C
BOS18M-PU-1PD-SA5-C
BOS18M-PU-1PD-SA4-C
BOS18M-PU-1PD-SA1-C
BOS18M-PU-1PD-S4-C
BOS18M-PSV-RH22-S4
BOS18M-PSV-LH23-S4
BOS18M-PSV-LH22-S4
BOS18M-PS-SA1
BOS18M-PS-LH22-S4
BOS18M-PS-1XB-S4-C
BOS18M-PS-1XB-E5-C-S4
BOS18M-PS-1XB-E4-C-05
BOS18M-PS-1XB-E4-C-03
BOS18M-PS-1XB-E4-C-00,85
BOS18M-PS-1XA-E5-C-S4
BOS18M-PS-1XA-E4-C-05
BOS18M-PS-1XA-E4-C-03
BOS18M-PS-1XA-E4-C-00,85
BOS18M-PS-1RD-E5-C-S4
- 电话:0755-29412192
- 传真:0755-61104027
- email:sales@sztianwei.net
工控宝APP下载安装
