![](http://nfs.gongkong.com/Upload/trade/201506/20150618112734288_w.jpg)
- 型号:MODULE A9-1206-2
- 数量:1
- 制造商: 厦门兴锐达自动化设备有限公司
[5] 谷定燮,修木洪,戴敏,等.1000kV GIS变电所VFTO特性研究[J].高电压技术2007,33(11):27-32.
GUDingxie,XIU Muhong,DAI Mine al.Study on VFTO of 1000kV GIS Substation[J]. HighVoltage Engineering, 2007, 33(11):27-32.
[6] 郭天兴,徐杰,王璇,等.电容式电压互感器传递过电压的试验研究[J].电力电容器与无功补偿,2008,29(1):23-30.
GUOTianxing,XU Jie,WANG Xuan,et al.Testing investigation on transfer over voltage ofcapacitor voltage transformer[J].Power capacitor and reactive powerCopmensation,2008,29(1):23-30.
[7] 高景明,刘永贵,刘金亮,等.陡化前沿Marx发生器的设计与初步实验[J].强激光与离子束,2008,20(1):167-170.
GAOJangling, LIU Tongue, LIU Jingling, et al.Design and preliminary experimentalresults of wave erection Marx generator [J].High Power Laser and ParticleBeams, 2008, 20(1):167-170(in Chinese).
[8] 陈建.GIS中陡波前过电压特性及影响因素研究[D].华北电力大学硕士学位论文,2006.
CHENJian.Characteristic of very fast transient over voltages in GIS and analysis ofinfluencing factors [D].Master thesis of North China Electric Power University, 2006.
[9] 刘轩东,李登云,孙凤举,等.用于纳秒脉冲高压测量的同轴电容分压器[J].高压电器,2008,44(1):32-36.
LIUXuedong, LI Dengue, SUN Fungus, et alga coaxial capacitive voltage divider fornanosecond pulse measurement [J].High Voltage Apparatus 2008, 44(1):32-36(inChinese).
[10] 凌子恕.高压互感器技术手册[M].北京:中国电力出版社,2005.
[11] GB 20840.1-2010互感器第1部分:互感器通用技术要求.
GB20840.1-2010 Instrument transformers. Part 1: General requirements.
[12] 廖传书,黄道斌等.Lab VIEW与USB的直接数据通信[J].现代电子技术,2007,259(20):4-6.
LIAOChianti, HUANG Daubing, et al.Direct Data Communication between Lab VIEW and USB[J].Modern Electronic Technique,2007,259(20):4-6.
[13] 阚宝风,施乐平,马宪民.基于LABVIEW的冲击测量系统[J]仪器仪表学报,2010,31(8):352-353.
KanBaofeng,Shi Leping,Ma Xianmin.The shock measurement of data acquisition systembased on LABVIEW.[J].Chinese Journal of Scientific Instrument,2010,31(8):352-353.
[14] 张佩,赵书涛等.基于Lab VIEW的变压器直流电阻快速测量系统的设计[J].电工电气2013,7:42-45.
ZHANGPie, ZHAO Shoat, et al.Design of rapid Measurement System for Transformer DCResistance Based on Lab VIEW [J]. Janise Electrical Apparatus, 2013, 7:42-45.
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
OLSUN TRANSFORMER 21849 126177-2
FOXBORO 300 PSI PRESSURE TRANSMITTER IGP10-D21D2F
DYNAMATIC POWER SUPPLY ASSY 15-00P871-0005 REV A
BARKSDALE CONTROLS PRESSURE ACTUATED SWITCH B2T-M32
BAILEY MULTIFUNCTION CONTROLLER NMFC01 NETWORK 90
RELIANCE ELECTRIC 1200V 16.5uF CAPACITOR 69932-21B NEW, LOT OF 6
CONTROL BOARD 400-314 REV 2
VALMET AUTOMATION NOVE M2 SAMPLER G500VA
WESTINGHOUSE 50A 600VAC CURRENT LIMITER EL3050R / 2607D43G11 104636
NAMCO SNAP LOCK LIMIT SWITCH EA700-40100
PNOENIX CONTACT POWER SUPPLY MIN-PS-100-240AC/24DC/2
UNITED ELECTRIC TEMAPTURE SWITCH B54-1039040
PUMP IMELLERS CF8M 53984
FALK 1040G SLEEVE COUPLING 0744986
PUMP IMPELLERS CF8M 53984
SQUARE D 230V REPLACEMENT COIL, L-2010-AE
WESTINGHOUSE MOR RELAY CURRENT MODULE HTM-10
500FT TUBING 105-0312662-NT-500
WESTINGHUSE SILLCON RECTIFER 2018A40-G01
SMC CYLINDER CKG1A63-100Y
FANUC ROBOTICS CABLE ASSEMBLY A05B-1313-D003
PARKER 04.00" BORE 20.000" STROKE PNEUMATIC CYLINDER 04.00 CH2ANU19C 20.000
MACHINE TOOL WIRE 600FT 6699849
ASCO RED-HAT 110/120V 15.4W 1" NPT SOLENOID VALVE, 8215B51, NNB
CIRCUIT BOARD IC670ADC810-D REV 1
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
上一篇:HRP-D53.光电开关霍尼韦尔
