- 型号:WZP2-3.2
- 数量:1
- 制造商:苏州迅鹏仪器仪表有限公司
汽轮机铂电阻(电厂专用)迅鹏WZP2-3.2
WZP2-3.2系列汽轮机电阻
采用进口PT100测温元件,广泛应用在汽轮机上。WZP2-3.2/150系列铂电阻同等规格:WZP2-3.2/150/5、WZP2-3.2/150/7、WZP2-3.2/150/10。WZP2-3.2/150/5安装于汽轮机内部狭小或封闭空间,只有引线与温控仪表相连接。汽轮机运行时汽轮机铂电阻不能维修和更换,若产品损坏需要吊装汽轮机上盖才能更换。
技术指标
1、精度等级:△t=±(0.3℃+0.005|t|),满足JB/T8622-1997 A级和IEC751-1983 A级要求。
2、保护管材质为1Cr18Ni9Ti,外形尺寸为Φ3.2mm,电缆外径Φ5.4mm,引线长为5000mm,保护管与电缆过渡长150mm(可以按用户要求生产)。
1#测温电阻引线颜色为红色、白色和紫色;2#测温电阻引线颜色为蓝色、绿色和黄色。
WZP2-6.4系列汽轮机电阻
采用进口微型铂丝电阻元件,外加与汽轮机内部尺寸配套的安装结构及带有聚四氟乙烯护套的耐高温屏蔽电缆构成,汽轮机轴承测温专用铂电阻必须具备测温精度高、抗震耐油、高可靠性、结构合理和长寿命的特点。产品结构
精度等级
WZP2-6.4汽轮机铂电阻精度等级:△t=±(0.3℃+0.0 05|t|),满足国家标准JB/T8622-1997 A级和IEC751-1983 A级要求。
防爆热电偶/热电偶
WRN-240 WRN2-240 WRE-441 WRE2-441 WRE-241 WRE2-241
WRN-241 WRN2-241 WRE-440 WRE2-440 WRE-240 WRE2-240
WRN-440 WRN2-440 WRN-441 WRN2-441
防爆热电阻/热电阻
WZP-140 WZP2-140 WZP-441 WZP2-441 WZP-341
WZP-240 WZP2-240 WZP-241 WZP2-241 WZP-141 WZP2-141
WZP-340 WZP2-340 WZP-440 WZP2-440 WZP2-341
一体化防爆温度变送器/带温度变送器防爆热电偶
WRN-240M WRN-240S WRE-240M WRE-240S WRE-441M WRE-441S WRN-441S
WRN-340M WRN-340S WRE-340M WRE-340S WRN-441M
WRN-440M WRN-440S WRE-440M WRE-440S WRN-241M WRN-241S WRE-241M
WRN-341M WRN-341S WRE-341M WRE-341S WRE-241S
一体化防爆温度变送器/带温度变送器防爆热电阻
WZP-240M WZP-240S WZP-340M WZP-340S WZP-441M WZP-441S
WZP-440M WZP-440S WZP-341M WZP-341S WZP-241M WZP-241S
温度变送器模块/温度变送器
SBWR-1000 SBWZ-1000 SBWR-1001 SBWZ-1001 SBWR-1002 SBWZ-1002
SBWR-1006 SBWZ-1006 SBWR-1031 SBWZ-1031 SBWR-1034 SBWZ-1034
SBWR-1036 SBWZ-1036
端面热电阻
WZCM-201 WZPM-201
耐磨热电偶/热电偶
WRN-230NM WRE-230NM WRN2-230NM WRE2-230NM
WRN-630NM WRE-630NM WRN2-630NM WRE2-630NM
耐磨热电阻
WZP-230NM WZP2-230NM WZP-630NM WZP2-630NM
多点热电偶
WRN-230D WRE-230D WRN-430D WRE-430D
多点隔爆热电偶
WRN-240D WRE-240D WRN-440D WRE-440D
防腐热电阻
WZPF-130 WZP2F-130 WZPF-430 WZP2F-430
微细铠装热电偶 WRNK-191S WREK-191S
压簧固定热电偶WRET-01
直角弯头热电偶
WRN-530 WRN2-530 WRE-530 WRE2-530
WZP-120,WZP-121,WZP-130,WZP-131,WZP2-120,WZP2-121,WZP2-130,WZP2-131,
WZC-120,WZC-130
WZP-220,WZP-221,WZP-230,WZP-231,WZP2-220,WZP2-221,WZP2-230,WZP2-231,
WZP-221A,WZP-221A,WZC-220,WZC-230,WZC-220A
WZP-320,WZP-321,WZP-330,WZP-331,WZP2-320,WZP2-321,WZP2-330,WZP2-331,
WZC-320,WZC-330
WZP-420,WZP-421,WZP-430,WZP-431,WZP2-420,WZP2-421,WZP2-430,WZP2-431,
WZP-420A,WZP2-420A,WZC-420,WZC-430
WZP-621,WZP-621A,WZP-631,WZP2-621,WZP2-621A,WZP2-631
WZP-002,WZP-003,WZP-003A
WZP-010,WZP2-010,WZP-011,WZP2-011,WZC-010A,WZC-035S,WZC-001
WZC-200,WZP-260,WZP2-260,WZPM-267
WZP-269,WZP2-269,WZC-269,WZP-270,WZC-270,WZP-280
WZC-190,WZC-890J
WZP-892,WZP2-892
苏州迅鹏仪器仪表有限公司,电话:0512-68381802
- email:2850806280@qq.com
下一篇:耐磨热电阻 迅鹏WRPNM
工控宝APP下载安装
