- 型号:C32
- 数量:1000000
- 制造商:广东华裕电子有限公司
- 有效期:2024/6/1 0:00:00
C32 IGBT缓冲吸收电容器
| 规格 |
价格(元) |
尺寸(mm) |
引出 |
C32 |
1.0vF/1200V |
9 |
Φ27.5*L44 |
d=1.2 |
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于UPS、逆变器、感应加热、电焊机等设备的IGBT模块吸收保护。
Widely used in UPS,inverter,inductionheaters,welding machine forIGBT snubber protection.
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:双面金属化与金属化膜内串结构
封装:阻燃迈拉胶带,阻燃(94V-0级)环氧封装
引出:镀锡铜线
能承受高脉冲电流,高dv/dt,ESL,ESR小,具有自愈性
Dielectric:Polypropylene film
Construction:Extended double side metalized carrier film withinternal series connection and metalized film
Coating:Polyester tape wrapping with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:Tinned copper lugs
High pulse current,high dv/dt, Low ESL and ESR, Self healing
技术性能/Specifications
| GB/T 17702 IEC 61071 |
工作温度范围/Operating temperature range |
-40℃~85℃ |
容量范围/Capacitance |
0.022μF~5.6μF |
额定电压/Rated Voltage |
700Vdc~3000Vdc |
容量偏差/Tolerance |
±5% ±10% |
极间耐电压/Test voltage between terminals |
1.5Ur(Vdc)10s 25℃±5℃ |
极壳耐电压/Test voltage between terminals and case |
3000V 50Hz 60s,25℃±5℃ |
损耗角正切/Dissipation factor |
tgδ≤6×10-4 at 25℃±5℃,1kHz |
绝缘电阻/Insulation resistance |
C×R≥30000s,at 100Vdc,25℃±5℃,60s |
预期寿命/Life expectancy |
200000h at Ur and 70℃ |
此产品关键字:
IGBT吸收电容、IGBTSNUBBER、IGBT吸收电容厂家、IGBT吸收电容价格
华裕电容-高品质金属化薄膜电容专业制造商
全国免费咨询热线:400-850-5811
电力电子电容专线:020-66311928 66311927 66311929 87022531 87022473
市场部专线:020--66311911 66311912 66311913
电力工业事业部韩经理:020-66311928
电力工业事业部陈经理:020-66311929
传真:020-66311920 87023473
手机:18665682511
- 电话:020-66311928
- 传真:020-66311920
- email:hydl@hy-el.com
