![](http://nfs.gongkong.com/Upload/trade/201512/20151218110132526_w.jpg)
- 型号:Applied 91-00125A
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
Asyst 9700-6584-01 Advan Tag RFID Reader PB 90M
Tylan General Lam 4420 Manometer CMLA-21 853-017643-003-G-1135
Tylan General Lam 4420 Manometer CMLA-21 853-017643-003-D-C222
Estek Motor Controller Board 297-14264-1 Rev. B
Emoteq HS01001-A02-HGE BLDC Motor Amplifier Semitool T61105-47
Pall 5" Filter AB05P30018H15 Lot of 7 New
Semitool Solenoid Valve Manifold 20 Stage 3-Way 61593-09
Semitool 61593-12
Daifuku CLS-326IAA Interface Board
CGI Inc. Gearhead 023RNX0100-XX-01910 New
FutureStar Flow Meter 148-0300 New
Futurestar 148-01000-38 Pathfinder Series Flowmeter Semitool 72056-91 New
FutureStar Flow Meter 225-0035 New
Emoteq Motor Gearbox HS01001-A01-HGE
Balluff MicroPulse Transducer BTL-5-PI-M1143-R-KA05
Clean Room Products Filter U3030A00-ADACABA New
Screen PC-97010 Interface PCB PMCDIV
Screen HLS-MC3 PC-97014 Bridge PCB
Nemic-Lambda LWQ-200-5225 DC Power Supply
TDK RM 12-12RGB DC Power Supply Nikon NSR
Tokyo Electronic Industry 3kV High Voltage Module Lot of 3
MKS Instruments 128AA-00010B Baratron Pressure Transducer Type 128
MKS Instruments 128AA-00001B Baratron Pressure Transducer Type 128
SMC US11475 6-Port Pneumatic Manifold 02-141277-00
Control Concepts UC208D-T3 Teradyne Tester
Opto 22 PB32HQ PCB Lot of 2
Thermalogic Corp. Power Board K121-180 REV.C 718-562
Prometrix Corp. 36-0288 Z Limit Sensor Card Rev.A
MRC 884-13-000 MRC Eclipse Star Control PCB Rev.B
Applied 91-00125A
Toshiba VFS7S-2007UP Transistor Inverter
Eurotherm Controls AS-170A240V14-20MA AmpStack Controller new
Setra Pressure Transducer 2251250PCC411B1 New
Setra Pressure Transducer 225110CPCC411B1 New
Setra 225130CPCC411B1 Pressure Transducer New
Semitool Watlow 094XH001CX-891 120V 225W Immersion Heater 73080-39
Merlin Gerin Circuit Breaker C60N 60152 Lot of 7 New
Applied 91-00125A
Broadcom)公司推出全新的10G/25G/40G/50G可扩展以太网控制器产品系列。BCM57300 NetXtreme C系列可为云数据中心市场提供业界最低功耗和最小封装的25/50G解决方案。随着该系列产品的推出,博通公司进一步壮大了其端到端产品的阵营,并再度加强了其满足云级数据中心当前及未来需求的一贯承诺。
由于近半数云服务供应商的服务器均采用了虚拟化技术,且到2017年,每台服务器的虚拟机数量预计翻番达到96个,新一代以太网控制器必须加速才能满足虚拟化带来的更高流处理速度的要求。博通公司的NetXtreme C系列控制器可提供双向50G吞吐量,拥有30Mpps的性能以及数据中心所需的、用以支持更高虚拟机密度的更强大的流处理能力。集成TruFlow的流处理技术令网络吞吐量翻番,与纯软件解决方案相比,还将应用性能提升了高达50%。
与StrataXGS Tomahawk以太网交换机结合,NetXtreme C系列控制器可形成适用于数据中心的业界领先的25/50G端到端解决方案。该解决方案提供的连接功能符合博通公司参与创建的25/50G以太网产业联盟标准和IEEE标准草案。BCM57300能作出快速且基于硬件的堵塞通知响应,比基于软件的传统方案快5000倍。在结合StrataXGS交换机的情况下,数据中心能提前避免网络堵塞的发生,从而在整个网络上实现确定的工作负载控制。
将网络边缘扩展至服务器
博通的NetXtreme C系控制器采用TruFlow引擎,将网络边缘进一步扩展至服务器网络接口卡(NIC),不仅能处理流同时还能处理数据包。将流处理从架顶式(ToR)交换机和服务器主处理器分布至服务器网络接口卡能实现众多优势,其中包括:
? 虚拟交换机加速:当下,服务器主处理器能像网络中的物理交换机一样处理来自每台虚拟机(VM)的网络数据包,我们称之为虚拟交换机或vSwitch。它全部通过软件方式执行编辑、分类、策略监管以及转发等功能,会消耗宝贵的主机CPU周期。随着每台服务器上虚拟机数量的增加,超过33%的服务器处理能力用于虚拟交换的情况并不罕见。TruFlow帮助数据中心运营商把虚拟交换机从主处理器迁移至博通C系列控制器,不仅能够为应用处理增加可用的CPU周期,同时还可将应用性能提升高达50%。
? 数据流可扩展性:超大规模云端数据中心的快速增长加大了网络扩展和管理的复杂性。TruFlow能将流处理分布到服务器端点,从而确保数据中心的增长不会影响网络和应用程序性能。
? 软件定义网络(SDN):TruFlow能以硬件方式实施分类/匹配/操作这样基本的SDN协议结构处理,包括最新的OpenFlow标准等。搭载SDN协议的BCM57300可使云运营商拥有可扩展的高灵活性动态网络,从而在数据中心获得SDN带来的众多益处。
NetXtreme C系列的更多特性
? 低功耗:<5W
? 芯片低时延:1.5μs环回跳变
? 双端口10/25G与单端口40/50G
? 业界最小封装的25/50G控制器:14x14毫米
? 集成的基板管理控制器(BMC)
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
AMAT 0100-90860 Beam Stabilizing Monitor Board XR80
AMAT 0100-90860 Rev. H Beam Stabilizing Monitor Board XR80
AMAT 0100-90468 Rev. F Charge Voltage Board XR80
EMC MSE402 Power Board AMAT XR80
Metron MRC 8" Cathode Dark Space Shield D112649 Rev.G new
Metron Spacer Gate Valve Shield D116375 Rev. E new TEL Tokyo Electron
Saes Getters SHC504M904-7 In-Line Manual Valve lot of 3
ABB SACE Isomax S3 Industrial Circuit Breaker S3B new 3104260
Leybold 844230/004 CoolVac System Controller New
USF Filterite PVDF Housing T910665-300 pair ID04-PVDF-3/4 300 new
Tescom 44-2268-R62-282 Pressure Regulator new
Applied 91-00125A
Unit Instruments UFC-8165 Mass Flow Controller AMAT 3030-00514 30L Ar New
Unit Instruments UFC-8165 Mass Flow Controller AMAT 3030-00055 2L NF3 New
Unit Instruments UFC-8165 Mass Flow Controller AMAT 3030-10998
UNIT 8165 MFC Mass Flow Controller UFC-8165 30L O2 new 3030-00524
Unit Celerity UFC-8165 300CC Mass Flow Controller New 3030-11007
Unit Celerity UFC-8165 50CC Mass Flow Controller New 3030-09427
Unit Instruments UFC-8165 Mass Flow Controller AMAT 3030-11008 30cc SiF4 New
Unit Celerity UFC-8165 500CC Mass Flow Controller New 3030-03719
Unit Celerity UFC-8165 20CC Mass Flow Controller New 3030-03262
Applied 91-00125A
Unit Celerity UFC-8165 1L Mass Flow Controller New 3030-03174
联系人:刘锦燕
手机:13295922579
电话:0592-5580706
传真:0592-5361191
邮箱:LJY_05228@163.COM
QQ:2711934024
QQ:2574619415
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
