供应山东ABB变频器现货ACS550-031A
2016/4/7 15:42:30
0 人气:0
- 型号:ACS550-01-031A-4
- 数量:10
- 制造商:天津炎菱科技有限公司
- 有效期:2017/4/7 0:00:00
ACS510-01-03A3-4 ACS510-01-04A1-4,ACS510-01-05A6-4,ACS510-01-07A2-4,ACS510-01-09A4-4,ACS510-01-012A-4 ,ACS510-01-017A-4,ACS510-01-025A-4 ,ACS510-01-031A-4 ,ACS510-01-038A-4,ACS510-01-046A-4,ACS510-01-060A-4,ACS510-01-072A-4,ACS510-01-125A-4,ACS510-01-157A-4,ACS510-01-180A-4,ACS510-01-195A-4 ,ACS510-01-03A3-4+B055,ACS510-01-04A1-4+B055 ,ACS510-01-05A6-4+B055,CS510-01-07A2-4+B055,ACS510-01-09A4-4+B055,ACS510-01-012A-4+B055,ACS510-01-017A-4+B055,ACS510-01-025A-4+B055,ACS510-01-031A-4+B055,ACS510-01-038A-4+B055,CS510-01-045A-4+B055,ACS510-01-060A-4+B055,ACS510-01-072A-4+B055,ACS510-01-096A-4+B055,ACS510-01-124A-4+B055,ACS510-01-157A-4+B055,ACS510-01-180A-4+B055,ACS510-01-195A-4+B055,ACS-CP-C,ACS-CP-D,ACS/H-CP-EXT,OREL-0, ACS550-01-03A3-4,ACS550-01-04A1-4,ACS550-01-05A4-4,ACS550-01-06A9-4,ACS550-01-08A8-4,ACS550-01-012A-4,ACS550-01-015A-4,
ACS550-01-023A-4,ACS550-01-031A-4,ACS550-01-038A-4,ACS550-01-044A-4,ACS550-01-059A-4,ACS550-01-072A-4,ACS550-01-096A-4,ACS550-01-124A-4,ACS550-01-157A-4,ACS550-01-180A-4,ACS550-01-195A-4,ACS550-01-03A3-4+B055,ACS550-01-04A1-4+B055,ACS550-01-05A4-4+B055 ,ACS550-01-06A9-4+B055 ,ACS550-01-08A8-4+B055, ACS550-01-012A-4+B055,ACS550-01-015A-4+B055 ,ACS550-01-023A-4+B055 ,ACS550-01-031A-4+B055 ,ACS550-01-038A-4+B055,ACS550-01-044A-4+B055 ,ACS550-01-059A-4+B055,ACS550-01-072A-4+B055,ACS550-01-096A-4+B055 ,ACS550-01-124A-4+B055 , ACS550-01-157A-4+B055,ACS550-01-180A-4+B055,ACS550-01-195A-4+B055,ACS-CP-A, ACH-CP-B,ACS-CP-C,ACS-CP-D,ACH-CP-E,ACS-CP-F ,ACS/H-CP-EXT,ACS 800-11-0016-3,ACS 800-11-0020-3,ACS 800-11-0025-3,ACS 800-11-0030-3,ACS 800-11-0040-3,ACS 800-11-0050-3,ACS 800-11-0060-3,ACS 800-11-0070-3,ACS 800-11-0100-3,ACS 800-11-0020-5,ACS 800-11-0025-5,ACS 800-11-0030-5,ACS 800-11-0040-5,ACS 800-11-0050-5,ACS 800-11-0060-5,ACS 800-11-0070-5,ACS 800-11-0100-5,ACS 800-11-0120-5,
ACS 510
ACS510 是ABB又一款杰出的低压交流传动产品。
ACS510可以简单的购买,安装,配置和使用,可节省相当多的时间。[2]应用领域:
ABB传动应用于工业领域,ACS510特别适合风机水泵传动,典型的应用包括恒压供水,冷却风机,地铁和隧道通风机等等。
亮点:
1、完美匹配风机水泵应用;
2、高级控制盘;
3、用于降低谐波的专利技术;变感式电抗器;
4、循环软起;
5、多点U/F曲线;
6、超越模式;
7、内置RFI滤波器作为标准配置,适用于第一和第二环境;
8、CE认证[2]主要性能:
完美匹配风机水泵:
增强的PFC应用:最多可控制7(1+6)个泵;能切换更多的泵。
SPFC:循环软起功能;可依次调节每个泵。
多点U/F曲线:可自由定义5点U/F曲线;可灵活广泛的应用。
超越模式:应用于隧道风机的火灾模式; 应用于紧急情况下。
PID调节器:两个独立的内置PID控制器:PID1和PID2,PID1可设置两套参数;通过PID2可控制一个独立的外部阀门。[2]更经济:
直觉特性:噪音最优化,当传动温度降低时增加开关频率,可控的冷却风机,仅在需要时启动;可随机分布开关频率,从而降低噪音,极大改善了电机噪音,降低传动噪音并提高功效。
磁通优化:负载降低时自动降低电机磁通;极大地降低能耗和噪音。
连接性:简单安装,可并排安装,容易连接电缆,通过多种I/O连接和即插式可选件方便地连接到现场总线系统上;减少安装时间,节约安装空间,可靠的电缆连接。
更环保:
EMC:适用于第一及第二环境的RFI滤波器为标配;不需要额外的外部滤波器。
电抗器:变感电抗器:根据不同的负载匹配电感量,因此抑制和减少谐波;降低总谐波
其它:
高级控制盘:2个功能键,功能随状态不同而改变,内置帮助键,已修改的参数列表;容易配置和调试,快速启动,快速进入参数。
现场总线:内置RS485接口,使用Modbus协议,即插式现场总线模块作为可选件;降低了成本。
ACS550
特点:
助手型控制盘11KW以下标配制动斩波器
无传感器矢量控制
启动向导-指导用户设置参数而无需进入参数列表
诊断向导-故障时激活,利于快速查找故障
维护向导-监视运行小时或电机旋转[3][
ACS800
ACS800系列传动产品最大的优点就是在全功率范围内统一使用了相同的控制技术,例如起动向导、自定义编程、DTC控制、通用备件、通用的接口技术,以及用于选型、调试和维护的通用软件工具。先进的技术-DTCACS800的核心技术就是直接转矩控制(DTC)。它是目前最先进的交流异步电机的控制方式。DTC稳定杰出的性能,使ACS800适用于各种工业领域。启动向导
ABB交流传动持续不断的在完善用户界面。启动向导的应用,使ACS800的调试变得非常简便。
自定义编程
与传统的参数编程相比,ACS800的自定义编程具有更好的适应性。作为全系列的标准配置,就想传动产品内置了小型的PLC,且不需要添加任何附加的软硬件。高度集成和紧凑的结构设计
作为标准配置,ACS800全系列已经内置了电抗器。此外,在ACS800内部还可以同时再安装三个可选模块:I/O扩展模块,现场总线适配器模块,脉冲编码器接口模块或PC机的接口模块。对于这些模块,无任何附加空间和电缆的要求。
环保产品
ABB是ICC(国际商会)可持续发展商务的成员,并一致致力与环境的保护。ABB交流传动产品遵循16项ICC的规定,在生产过程中遵循ISO14001标准。
- 电话:13662157141
- 传真:022-27696117
- email:272506787@qq.com
工控宝APP下载安装
