- 型号:SEV116AC
- 数量:100
- 制造商:宁波北仑日兴动力科技有限公司
- 有效期:2020/7/1 0:00:00
宁波日兴动力科技有限公司提供珀金斯Perkins 4012柴油发动机发电机SEV116AC油泵
Perkins柴油发动机油泵,珀金斯柴油发电机油泵,Perkins 4012柴油发动机发电机SEV116AC油泵,
更多资料请登录日兴动力官网www.rxdlkj.com 湖南英珀威官网www.perkins-rx.com
项次零配件编号 最近的零配件编号 描述
1SEV116S1SEV116AC油泵
45SEV116C/261SEV116C/26垫片 - 油泵
463164962316496图钉
473170124317012螺帽
483182104318210弹簧垫片
492121/822121/8图钉
502086/01022086/010弹簧垫片
51SEV121E/5011SEV121E/50喷射
52576/17412576/174密封O型圈
53576/17312576/173密封O型圈
5431206312312063固定螺钉
5531821012318210弹簧垫片
56SEV121H/501SEV121H/50喷射
57SEV121/501SEV121/50喷射
58282/3001282/300垫片
593120632312063固定螺钉
ItemParts No.Qty.Latest Part No.DescriptionCut OutCut InComment
2SEV116D/11SEV116D/1OIL PUMP HOUSING
3374/12262374/1226BUSH
4SEV116E/131SEV116E/13SHAFT
5506/4851506/485KEY
63533241353324KEY
7SE116B/321SE116B/32ROTOR
8SE116T/11SE116T/1COVER
9641/271641/27PLUG
113544702354470DOWEL
12SE116C/51SE116C/5GASKET
132121/722121/7STUD
143170124317012NUT
15SEV116/151SEV116/15OIL PUMP GEAR
1688/590188/590WASHER
172530/20012530/200NUT
18418/1821418/182BLANKING PLATE
19278/3791278/379GASKET
2031205022314C044SETSCREW
213182092318209SPRING WASHER
22SE125B/91SE125B/9PLUNGER
23365/5341365/534SPRING
24SE125/101SE125/10CAP
25418/1541418/154FLANGE
26278/3911278/391GASKET
27576/1721576/172SEAL - O RING
283120531312053BOLT
293170111317011METRIC NUT
3031205022314C044SETSCREW
313182092318209SPRING WASHER
32554/1011554/101SEAL - OIL
33SE597J1SE597NLIFT PUMP
34SE597C/71SE597C/7GASKET - LIFT PUMP
353164592316459STUD
363170112317011METRIC NUT
373182092318209SPRING WASHER
383144462314446GRUB SCREW
39SE266C1SE266CCOUPLING
40SE116/311SE116/31CARRIER
413100682310068BOLT
423182104318210SPRING WASHER
433180124318012WASHER
44506/5081506/508KEY
- 电话:15088860848 0574-26886646
- 传真:0574-26892499
- email:ygx556@163.com
